Results 1 to 11 of 11
Thread: 6-speed conversion install -- parts list
  1. 11-08-2004 10:29 AM #1
    TDIclub link
    Note: the gear ratios listed is for the DRW model of the 6-speed. The DRW is for the PD130 & PD150. This differs from the gas engine, since it's basically like the 02J from 1st gear to 5th gear, with an even taller 6th
    edit: Updated link
    Modified by GT17V at 10:08 PM 7-6-2006
  2. 01-25-2008 10:29 AM #2
    where and how can this be done?
  3. 01-25-2008 11:25 AM #3
    are you trying to do a swap to an o2m?
    axles, starter, clutch, flywheel i think, and alot of other stuff
    its not a cheap swap
    Joosey - DubAudi - Banchwerks - ForceFed Engineering
    PVW 9/11
    Quote Originally Posted by uzi did it View Post
    you can compare me to kobe bryant of the vw world. i'm just that good.
  4. Member Bazmcc's Avatar
    Jan 10th, 2005
    Northern Ireland
    2002 Bora TDI, 1994 2.0 16v Corrado, 1991 MK2 Golf, 1983 MK1 Golf Driver, MK4 Golf, 1971 Fastback
    01-25-2008 11:34 AM #4
    Pros and cons?
  5. Member 18turbodub's Avatar
    Aug 28th, 2004
    Sacramento California
    2001 W220 S500
    01-27-2008 01:01 AM #5
    axles, hubs/knuckles, power steering line, flywheel clutch, clutch lines, starter may work from a 5 speed, and some time to do the swap
    Россия
  6. Member blueb316v's Avatar
    Nov 16th, 2002
    401 son
    08 Jett Set
    01-27-2008 10:35 AM #6
    if you are swapping to an 02m i've got everything except the starter, and tranny... I have axle's shift box w/ linkage, clutch line power steering line, and mounts, also hubs!!
    http://facebook.com/kddesignsri Airlift Dealer Contact Me For Pricing
    Bagging The Best Fixing The Rest
    youtube.com/kdjetta03
  7. Member Zwei Bora Tdi's Avatar
    Apr 23rd, 2004
    Colorado Springs Colorado
    2012 Audi A4 Avant Prestige with Titanium Package
    01-27-2008 11:55 AM #7
    Might lose cruise control function with a 6 speed conversion. I don't have it but that is because I put an R-32 steering wheel in and never changed out the comfort module from the 3 spoke. I hated that 4 spoke wheel. I would assume as well that the ecu will have to be fooled somewhat at higher rpm's that the 6th will allow to function v.s the relative road speed. The guys at tdiclub.com have toyed with this a lot. Since the 5th gear OD mod is fairly common there. Good luck with the project!
  8. 02-05-2009 08:28 AM #8
    ooo i have a question..
    i just had a six speed swap from a 5 speed auto in my 24v vr6. the mechanic was taking too long and my school started. so i took the car back. ok the only problem is the he didnt finsh programing the ecu. well atlest thats what he told me. sooo my car drives but my check engine light is on with the ase light and my speedometer doesnt work.. or my reverse light when i reverse and my middle digital cluster doesnt work. basically anything that has to do with tranny doesnt work. do u think its the speed sensor or the ecu or the wiring harness. the guy told me he changed everything and he only has to program the ecu for the new tranny. he did tell me he had hard time to get into the ecu. i think he doesnt kno how to program.. what do u guys think.. any help
  9. Member Mike GoFast's Avatar
    Mar 6th, 2006
    MA
    08 Jetta
    02-05-2009 09:41 AM #9
    I believe http://www.performancecafe.com carries the swap.
  10. Member velocity196's Avatar
    Feb 19th, 2006
    Washington
    2006 MK4 GTI, 2012 Golf R
    03-16-2009 05:03 PM #10
    i just did this swap a couple months ago. its pretty easy and straight forward. the only thing that got me off was the disc (thnks adam@unitronic). i installed it backwards and didnt notice until i was finished and the clutch wouldnt work. took it all apart and sure enough the spring hub was facing the flywheel and it needs to face the presure plate. parts list for a 2002 to 2006 mk4 should be as follows:
    -02M tranny
    -02M drive shafts with the nut end not the bolt end. if you get the bolt end you'll have to change the hubs. the bolt end is a direct fit.
    -02M starter (4cyl)
    -02M 240mm clutch (4cyl)
    -02M shifter cable end links (just the lil black adjuster part on the end of the cable. stock cables and shifter box are used.
    -02M bottom part tranny mount. the top is the same as 02J
    -all new bolts for the tranny and drive shafts.
    -stock 02J slave line can be bent to re use, i reused mine.
    -stock 02J power steering line can be re used, i reused mine.
    to sum it up, everything works fine. no reprogramming the ecu , no speed o problems, cruise works great, no cels, no esp problems, no anti lock brake problems, car is 100% just like before. and the gearing is bad a$$. with the power of the 35r im in and out of gears very fast, shifting over 8k is smooth and fast. best mod ever
    Modified by velocity196 at 2:15 PM 3-16-2009
  11. Member navynukenate's Avatar
    Apr 6th, 2006
    Columbia, SC
    2001 Wolfsburg with a motor/tranny/interior swap from 20ae gti
    04-30-2011 03:17 AM #11
    I've done this swap, and know the ins and outs. PM if you have any questions. http://forums.vwvortex.com/showthread.php?4029146
