VWVortex.com - A list of Motor Oils for the R32: Updated 1/22/07
    Page 1 of 18 1234511 ... LastLast
    Results 1 to 25 of 431
    Thread: A list of Motor Oils for the R32: Updated 1/22/07
    1. Administrator Emeritus adg44's Avatar
      Aug 2nd, 2000
      VA
      12-07-2004 01:05 AM #1
      There are so many topics on who makes motor oils for the R32, so I figured I would create a list with all of the ones I have found. If you have one that I missed, please let me know. These are all synthetic oils that I have listed and, as far as I know, have met the VW specification (VW 502) for motor oil. I'm sure if I'm wrong someone will tell me.
      All Oils Listed are Synthetics
      Motul:
      8100 Ester E-Tech 0w40
      8100 Ester E-Tech 0w40 Technical Data Sheet (PDF)
      8100 X-cess 5w40
      8100 X-cess 5w40 Techincal Data Sheet (PDF)
      Redline:
      Redline 5W-40 Synthetic
      Synthetic Oil Product Data (PDF)
      Amsoil:
      Synthetic 5w40 European Engine Oil
      Mobil1:
      Mobil1 0w40 with SuperSyn
      Valvoline
      Valvoline SynPower 5W-40
      SynPower Technical Data Sheet (PDF)
      Castrol:
      Castrol Syntec 5w40 (PDF)
      Shell:
      Shell Helix® Ultra 5W-40
      Pentosin:
      Pentosynth 5W-40 (Sold by ECS Tuning)
      Liqui-Moly:
      Lubro-Moly Vollsynthese 5W40
      Agip:
      Synthetic PC 5W-40
      Kendall:
      Kendall GT-1 5w40 (PDF)
      Elf:
      Elf Excellium LDX 5w40 - (Sold by German Auto Parts and by PAP-Parts)
      Technical Data:
      :::::::::::::::::::::: Pour pt/Flash Pt/TBN/Visc@40C&100C/VI/NOACK
      Motul 0W-40:::::: -60C / 438F / 10.8 / 73.2 & 13.3 / 186 / 9.8
      Motul 5W-40:::::: -39C / 442F / 10.3 / 83.1 & 14.0 / 173 / ?
      Pentosyn 5W-40: -48C / 464F / --?-- / 90.0 & 14.0 / 160 / ?
      Amsoil 5W-40:::: -59C / 449F / 12.2 / 83.6 & 14.5 / 182 / 5.5
      Liqui-Moly 5w40: -41C / 446F / 9.5 / 92.0 & 14.8 / 168 / 7.0
      Mobil1 0w40::::: -54C / 456F / --?-- / 80.0 & 14.3 / 187 / ?
      Shell 5w40::::::: -42C / 402F / --?-- / 76.3 & 13.8 / 187 / ?
      Valvoline 5w40:: -39C / 446F / 7.0 / 89.0 & 14.5 / 170 / 10.0
      Redline 5w40:::: -45C / 480F / 7.0 / 94.0 & 15.1 / 170 / 6.0
      Kendall 5w40:::: -46C / 450F / 10.1 / 84.5 & 14.3 / 175 / ?
      Elf LDX 5w40::::: -41C/ 438F / 10.4 / 86.5 & 14.2 / 170 / ?
      Thanks to Eddie from the Audi Club of NA, I have attached an Audi TSB that lists all VW 502.00 spec'd motor oils in the world. Note that a lot of these oils listed in the attached document are not available in the US.
      - Anthony
      Updated - 1/22/07
    2. 12-07-2004 01:22 AM #2
      Of course I'll bite
      1. There is a 0W-40 Motul (exact name I'll repost later unless someone else does first).
      2. Pentosyn 5W-40 (very good stuff; ECS tuning sells it)
      3. Lubro-Moly 5W-40 and I believe a 0W-40 too (I'll check that later too)
      4. Castrol 0W-30 ("Red Top"; German made; hard to find)
      5. Pennzoil Synthetic 5W-40 (I don't recommend since others are better)
      5. Quaker State Synthetic 5W-40 (I don't recommend since others are better)
      There are maybe a few more. Good idea as a thread!
      Anthony, I initially did not see your last paragraph. The Valvoline 5W-40, Castrol 5W-40, and the Shell 5W-40 all use Group 3 basestocks. Yes, the latter is suprising, but true. The product safety data sheets show this but you just have to know what # sequences correspond to what the base oil's group # is. I have that info. at my house that I can dig up if you want. The Shell also has not shown good oil analysis results. That was surprising, but the proof is in the pudding. #'s 1,2,3 on my list have performed very well (in oil analysis). So has the Valvoline.
      Modified by groftja at 5:38 AM 12-7-2004
    3. Administrator Emeritus adg44's Avatar
      Aug 2nd, 2000
      VA
      12-07-2004 01:25 AM #3
      Quote, originally posted by groftja »
      Of course I'll bite
      I believe that is the 8100 I have listed above
      Quote »
      I'll get some links and add those too, as long as they meet the VW specs
      Quote »
      I want to keep this to a 40 weight oil.
      Quote »
      I checked Pennzoil, and they list a 5w40, but under the tech sheet they don't list one, so I omitted it,
      Quote »
      I checked quaker state, and I don't beleive it had the VW specs, thus why I didn't list it.
      - Anthony
    4. 12-07-2004 02:15 AM #4
      Sticky Thread homeslice?
    5. Member KevinC's Avatar
      Feb 16th, 1999
      Chandler, AZ
      '16 Golf R, '05 E46 330Ci ZHP
      12-07-2004 02:46 AM #5
      I'm surprised nobody has listed VW's "own" oil (actually Castrol but has VW part number, G052167A2, available from your local stealership, Impex, and others). It's Castrol 505.01 (VW spec and also the oil's name), 5W-40, imported (rear label is in German), and is the "proper" oil for our motors. There has been some discussion in the past about whether this is a full-synthetic oil or a semi-synth.. seems to me I read something that lead me to believe it's semi-. Anyone know definitively?
      I just had my 10k service done, and my oil appears a bit overfilled. I have a a feeling I know why - this oil is in one LITER bottles - our cars take 5.8 quarts of oil w/filter change. If you dump in 6 quarts, you're very close. 6 liters? Now that's enough overfill to really show up.. I have a feeling that's what they're doing.
      '05 E46 330Ci ZHP coupé ..PD99819
      '16 Golf R 6MT/DCC/DAP
    6. Member gabedibble's Avatar
      Feb 6th, 2003
      Los Angeles, California
      2004 VW .:R32 original owner since 18apr2004
      12-07-2004 03:16 AM #6
      gr8 thread, thanx Anthony!
    7. 12-07-2004 09:44 AM #7
      Hey Anthony, great list. I use AGIP Synthetic PC 5w40 and meets all of VW's R32 engine requirements. I think I paid about $60 for a case of 12 quarts. HAve used AGIP oils and lubes before and they are excellent. Once again, meets ALL of the VW requirements.
    8. 12-07-2004 09:46 AM #8
      Royal Purple also has a 5w-30, which is what I'm running now.. Although it doesnt 'meet the specs', it works wonders and I've had 2 tanks out of 3 where I got 380 miles on moderate to light driving.. That other tank was 320 on hard driving
    9. 12-07-2004 09:54 AM #9
      So I guess using Mobil 1 5w-30 is no good?
      Seems like 40 weight is a must?. I would like to know before I do my first 5k oil change (which I am already due for).
    10. 12-07-2004 11:01 AM #10
      Quote, originally posted by KevinC »
      You are right that the 505.01 Castrol is semi-synthetic. The 506.01 spec oils are full synthetic and I'd hate to see what they cost and I'm sure it would be tough to locate them. They fascinate me though. The oils that meet either of those specs have some mystery ingredient that resists very high-pressure contact wear that is seen in the valvetrain of the new PD diesel engines. By the way, what is your stealership charging for the 505.01 Castrol?
    11. 12-07-2004 11:03 AM #11
      Quote, originally posted by ShearSup »
      I did not list AGIP since I figured it could not be found easily enough in the U.S. but it is supposedly a great oil as you said. You are paying a good price too. Where do you get it?
    12. 12-07-2004 11:09 AM #12
      Quote, originally posted by Shamma1977 »
      The 5W-30 has shown good oil analysis results in the 1.8T despite not meeting the specs. The only way to know for the 3.2l engine would be try it and have the oil tested. But it seems simpler to me to just find one of the excellent oils listed above and not worry/wonder. Plus the dealership and VOA will like you better if you use an oil meeting the specs. If you race, I would not recommend the 5W-30 at all due to the already low viscocity getting even lower at elevated engine temps.
    13. 12-07-2004 11:18 AM #13
      I ordered it online through American AGIP's U.S. division. Just set up an account with them. Mine came out of their Cabot, Pa center. Salesman was good also. He sent me a card in the mail and if you like, I'll send you his name.
      One thing I liked about using this oil is that there are no questions as to whether it meets the requirements which some of the other oils people are using meet one or the other or none of them. I'm just trying to stay in the safe....
    14. 12-07-2004 11:55 AM #14
      Awesome thread... I have my first oil change coming soon. Need to decide on an oil.
    15. Member krzysztof's Avatar
      Jul 9th, 1999
      Lakewood, CO
      2004 R32, 2000 Boxster S
      12-07-2004 12:07 PM #15
      Just so all the good info is in one thread, here's what the owner's manual says about oil:
      Quote, originally posted by VW R32 Owner's Manual, section 3.2 p. 35 »
      Engine Oil
      Specifications and viscosity
      Your engine was factory filled with an all season high quality engine oil that has a viscosity grade of SAE 5W-40. You can use this oil over all temperature ranges for normal driving. If you need to add oil between oil changes use any high-quality petroleum- or synthetic-based oil with correct specifications. If engine oil viscosity grade SAE 5W-40 is not available, you can also use SAE 5W-30.
      To assure that the oil you use is of the highest quality required by your vehicle the following terms must appear on the oil container singly or in combination with other designations:
      - VW 502 00
      - ACEA A3
      General recommendations
      VOLKSWAGEN recommends that you use any synthetic-based oil as a replacement lubricant as long as it meets the vehicle manufacturer's specification listed in this booklet.
      Synthetic oils available today provide better engine lubrication which can outlast traditional petroleum-based oils - making a smart choice for use throughout the life of your new VOLKSWAGEN.
      If SAE 5W-40 or 5W-30 viscosity grade oil is not available in your area, be sure to always use a viscosity grade suitable for the climate and seasonal conditions that exist where the vehicle is being operated. Always make sure that the oil meets the quality standards listed above.
      Your authorized VOLKSWAGEN dealer has the most up-to-date technical information regarding the correct oi [sic] specification and viscosity for your engine. Always ask your Service Advisor about the correct oil to use when topping off your engine.
      Engine oil identification symbol
      Oils of proper quality or your vehicle will be identified with a new "starburst" symbol A. The starburst symbol indicates that the oil has been certified by the American Petrolium Institute (API).
      Another oil identiciation symbol B could be added to the oil container to help you select the correct oil.
      1 - The top portion indicates the oil quality by API designations.
      2 - The center portion shows the SAE oil viscosity grade.
      3 - The lower portion indicates that the oil has fuel saving capabilities.
      Note
      Look for one of these symbols on the front of the oil container, and use only oils that display these symbols.
      So to sum up, the advice seems to be:
      * Meeting those two specs (VW 502 00 & ACEA A3) is mandatory.
      * Viscosity: while 5W-40 is preferred, 5W-30 is also okay, as is any viscosity that's "suitable for the climate and seasonal conditions that exist where the vehicle is being operated."
      Modified by krzysztof at 9:44 AM 12-7-2004
    16. Administrator Emeritus adg44's Avatar
      Aug 2nd, 2000
      VA
      12-07-2004 12:13 PM #16
      Excellent info. [IMG]http://*****************.com/smile/emthup.gif[/IMG] I must not have read the data sheet correctly for the shell oil. I'll fix the original paragraph. If you could find that info and post it here, I am sure many of us would find it helpful.
      - Anthony
    17. 12-07-2004 12:31 PM #17
      Quote, originally posted by Anthony@VWvortex »
      - Anthony
      Here are the CAS # descriptions:
      The following information is from a professor named “Molakule” who posts on http://www.bobsitheoilguy.com. You can use this info. to determine the type of base oils used by looking at an oil Material Safety Data Sheet (MSDS). Group 4 and 5 is what you’d like to see.
      As of July 15, 2004
      Mineral Paraffininc Base Oil - 64742-54-7; VI of +94 to 120, any group # from 1 to 3.
      Mineral Naphthenic Base Oil - 64741-96-4; VI of -15, any group # from 1 to 3.
      Mineral Aromatic Base Oil - 64742-03-7; VI of -185, any group # from 1 to 3.
      Hydrotreated paraffininc, heavy - 64742-52-5, Group 1, 2, or 3
      Hydrotreated paraffinic, light - 64742-53-6, Group 1, 2, or 3
      PAO's (Group 4 oils): 68649-12-7, 68037-01-4, 163149-29-9, 151006-63-2, 151006-62-1, 151006-60-9. VII's of +155 or greater.
      Diester (Group 5 oils): 28472-97-1; VII's average +170.
      Viscosity Index Copolymers - 127883-08-3
      Additives:
      ZDDP Type Adds: 68649-42-3, XXXXX-46-6.
      As of October 21, 2004
      New CAS Numbers for Group III oils
      Hydrocracked hydroisomerized Group III
      178603-64-0,
      178603-65-1,
      178603-66-2
      Edit, added bold letters
      Modified by groftja at 4:56 PM 12-7-2004
    18. Administrator Emeritus adg44's Avatar
      Aug 2nd, 2000
      VA
      12-07-2004 12:39 PM #18
      Great! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I added the Agip oil, and I also removed two of the Motul oils as they specifically say not to be used in VW 502 engines.
      This list is looking great!
      - Anthony
    19. Administrator Emeritus adg44's Avatar
      Aug 2nd, 2000
      VA
      12-07-2004 12:40 PM #19
      Quote, originally posted by Mr. Ginster »
      Nice post, we needed this. I'm running the Motul Specific, my dealer uses it. I'm due for my first change with it and I'm gonna stick with it, no complaints, seems to hold up nicely...I also like that it says VW Specific right on the bottle and the fact that my dealer uses it, in the highly unlikely case anything ever did happen.
      That's what I thought too, it says VW 500 and 505.01, but in the description it says "not to be used with VW 502 engines". I have removed it from the list...
      Whether or not this actually means anything.....
    20. 12-07-2004 01:32 PM #20
      What is our oil capacity? How much should we order?
    21. Administrator Emeritus adg44's Avatar
      Aug 2nd, 2000
      VA
      12-07-2004 01:36 PM #21
      Quote, originally posted by cfberlin »
      6 quarts.
    22. Member KevinC's Avatar
      Feb 16th, 1999
      Chandler, AZ
      12-07-2004 02:00 PM #22
      I think it's either $5.95 or $6.95. They charge $59.95 for an oil change - an absolute bargain, given the cost of the oil & filter. On my first oil change they itemized the oil & filter and backed in the labor cost, which came out to like $4 and change.
    23. 12-07-2004 02:09 PM #23
      Why such a limited range of viscosity's? If you live south FL, AZ or etc. you could run Mobil 1 15-50 (ACEA A3 rated) The manual does say use a viscosity grade suitable for the climate and seasonal conditions that exist where the vehicle is being operated.
    24. 12-07-2004 02:25 PM #24
      Quote, originally posted by drew2fast »
      XW-40 weight oils have proven to be thick enough to prevent additional bearing wear and other wear at high temps and high loads (verified via oil analysis by many people). So going to Mobil 1 15W-50 has no benefits, mostly just negatives. It also has lots of ZDDP which leaves behind more deposits that lead to detonation and the extra ZDDP innactivates catalytic converters sooner.
    25. Member Max Rebo's Avatar
      Apr 11th, 1999
      Pottstown, PA
      '07 BMW 335i
      12-07-2004 02:49 PM #25
      Damn... CAS Numbers. You da man! All the chemists (including me) appreciate that! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Oddfellows Local 726
