VWVortex.com - High Idle
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 32
    Thread: High Idle
    1. Member Mr. Bi-Polar's Avatar
      Jun 27th, 2003
      BFE, PNW
      A hunk o junk needing work
      12-21-2004 06:49 PM #1
      My car sits at 2k rpm when i have it just sitting. How do I fix this problem?
      Fear all that is... my belly
      astickymess.com
    2. 12-21-2004 06:50 PM #2
      adjust the idle screw.
    3. Member J.Knipl's Avatar
      Jun 5th, 2003
      The here and now
      1991 GTI a.k.a. Blackie, 1995 Golf a.ka. Little Red
      12-21-2004 07:17 PM #3
      Yeah like he said , idle screw . Located on the throttle body inside an indentation. Loosen to increase idle or tighten (clockwise) to decrease idle . Keep track of the umber of turns you give the screw so you can go back to the original setting if need be . On my car one full turn seemed to equal about 500 rpm of adjustment. You should also check the condition of the the tiny o ring that the idle screw sits in . if it's falling apart that will cause too much air to be bypassed and hence too high an idle. The ISV may also be faulty. You might want to remove and clean with thottle body cleaner.
      hope this helps
      I finally fixed my sig
    4. Member Mr. Bi-Polar's Avatar
      Jun 27th, 2003
      BFE, PNW
      12-21-2004 07:27 PM #4
      ISV?
      oh yeah its digi too. would make a difference?
      astickymess.com
    5. Member J.Knipl's Avatar
      Jun 5th, 2003
      The here and now
      12-21-2004 07:35 PM #5
      Quote, originally posted by MontanaGrnGTi »
      ISV?
      I think so , they are pretty expensive new though . Try to borrow one to test or get one used from the classified forum . Try the screw first , that's a free fix.
    6. 12-21-2004 08:18 PM #6
      and check for vaccuum leaks
    7. Member Mr. Bi-Polar's Avatar
      Jun 27th, 2003
      BFE, PNW
      12-21-2004 09:04 PM #7
      I was asking what a ISV was. rookie at this
      astickymess.com
    8. 12-21-2004 09:11 PM #8
      I dunno about digi, but I have a CIS. The ISV is on the driver's side of the engine, right next to the intake mani. It's a tubular like structure w/ some wires going into it. Just unplug 'em and pull it out.
      This is a pic o the ISV, see it on the right next to the intake mani?
      Modified by NeedyGTI at 9:16 PM 12-21-2004
    9. 12-21-2004 11:20 PM #9
      Idle Stabilization Valve, once you've located.. do ao quick experiment.. start the car, let it idle, record the idle speed.. kill the engine.. pull the plug on the ISV.. start the car again,, has the idle speed changed?
    10. Member
      Apr 9th, 2003
      Kirkland, WA
      20th AE
      12-21-2004 11:22 PM #10
      Modified by DmoneY at 8:24 PM 12-21-2004
    11. Member GodSquadMandrake's Avatar
      Feb 17th, 2004
      Minneapolis, MN
      04 CTS 91 Aristo
      12-21-2004 11:26 PM #11
      This may sound stupid but I recently discovered that my high idle was caused by a sticky gas pedal. That's right it will stick down a little bit and cause the idle to go up. You have to pull it back with your foot to idle normal sometimes... ghetto.....
      "It would take a cross-wired star trek replicator, if not an act of God, to make a left-hand-drive Skyline GT-R for the U.S." - Don Schroeder
    12. Member Mr. Bi-Polar's Avatar
      Jun 27th, 2003
      BFE, PNW
      12-21-2004 11:37 PM #12
      Quote, originally posted by GodSquadMandrake »
      Its been awhile but I think I even loosened the throttle cable and it was still up at that high.
      Also its an 8v so a pic of that would help more than a 16v I'll be trying these things tomorrow please help
      astickymess.com
    13. 12-21-2004 11:37 PM #13
      Speaking of ISV. Sometimes my idle jumps around. If it's a hot day (which isn't now) and I've been running it hard, it will bounce or rev continuously. The only thing I can really to do stop it is to stop the engine and start it again. Is this a faulty ISV?
    14. Member Mr. Bi-Polar's Avatar
      Jun 27th, 2003
      BFE, PNW
      12-22-2004 03:42 PM #14
      bump
      astickymess.com
    15. Member J.Knipl's Avatar
      Jun 5th, 2003
      The here and now
      12-22-2004 03:57 PM #15
      Quote, originally posted by GretchenGLi »
      yes 100% ISV at fault
    16. Member Mr. Bi-Polar's Avatar
      Jun 27th, 2003
      BFE, PNW
      12-22-2004 04:25 PM #16
      Quote, originally posted by J.Knipl »
      That worked a little bit. couldn't turn it any more but it was cold so i'm sure it will lower as it warms up. I'm just trying to get it to run a little better. it is a huge pos
      astickymess.com
    17. 12-22-2004 04:45 PM #17
      Had exact same problem, don't forget about the two small wires going into the idle switch at the top and rear left area of the throttle body area. my wires were corroded and loose and pulled right free. once reinstalled,,,idled awesome. [IMG]http://*****************.com/smile/emthup.gif[/IMG] oh yeah, once that is corrected, you may want to readjust that idle screw...
      Modified by rmarnett at 1:46 PM 12-22-2004
    18. 12-23-2004 04:13 PM #18
      any luck?
    19. 02-06-2005 11:59 PM #19
      Quote, originally posted by DrMSH »
      What does it mean if the idle speed has changed? Faulty ISV?
    20. Member MK2SnowPilot's Avatar
      Sep 8th, 2005
      Keswick, Ontario
      99 Golf Wolfsberg Edition (to be parted out soon), 2 X MK6 Jetta 2.Slo
      01-07-2006 04:35 AM #20
      Hard to believe that that powerfull spring could be held up by a sticky gaspedal. Are you sure it's not the part where the cable attaches to the throttle body? Or maybe a rusty throttle cable?
    21. Member MK2SnowPilot's Avatar
      Sep 8th, 2005
      Keswick, Ontario
      01-07-2006 04:43 AM #21
      Quote, originally posted by Mr. Bi-Polar »
      Umm - The idle scew isn't supposed to go all the way in and considering there's rubber (or SHOULD be) under there then the cold has nothing to do with it.
      I think it one of the following
      1) I think you've got bad rubber on the idle screw
      2) Vacuum leak - This includes the rubber grommet your PCV valve sits in AND the oil dipstick holder - It's the bright orange piece that the dipstick sits in.
      Check out the 8v FAQ list in my signature and go down to DanielAdams post. It has all you need to fix a wonky idle [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. 09-26-2006 07:06 AM #22
      what do you guys think about bouncing rpm's and and stalling on cold start up's even when it's not cold outside? bouncing meaning 1500 to 800. also, bogs down over half throttle
    23. 11-12-2006 02:46 PM #23
      Hi there, I have a 1985 VW Golf and I'm hoping somebody can help me out...
      In the dry summer months, the car would start every time and run pretty well with the exception of the idle speed being a little too high. Lately we've had quite a lot of rain and I went out to start the car one day and it just wouldn't start. I drained the battery trying to get it going so we attempted to jump start it, but it just wouldn't go. Later, we dried up the electrical components and the battery with a hairdryer and a fan and tried jump starting it again. This time it started, but the idle speed was going crazy, bouncing from 3,000 to 8,000 RPM (past the tachometers limits) and of course we shut it off as quickly as possible to not cause further damage to the engine. We let it sit another week in the rain and then when the rain stopped for a day, we took another try at drying out the engine first and then starting it again. Unfourtunatly the same thing happened and we decided to give up and do some research before we damaged the engine.
      If anybody could help me here or offer me suggustions, I would be very appretiative to have my beloved golf running again.
    24. 11-12-2006 03:41 PM #24
      is it a bad idea to delete the ISV?
    25. 11-12-2006 03:43 PM #25
      If the idle screw doesn't solve the problem. Clean the ISV. Then try cleaning the throttle body. If your not sorted then, try the MAF sensor.
      If they don't solve the problem, I would focus more attention on the ignition system and timing.
