VWVortex.com - DIY: Cracked oil dip stick! Why you are having problems! Pics inside!
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 90
    Thread: DIY: Cracked oil dip stick! Why you are having problems! Pics inside!
    1. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      2008 BMW 335i, 2010 Rav4 V6 Ltd.
      01-03-2005 05:21 PM #1
      Hi all,
      Me and my buddy took a small (1 hour one way) trip to the nearest dealership to pick up some parts for his B4 Passat and for my Jetta. I also took a test drive in the 2005 GLI 1.8T.
      Anyway, I own a 1999.5 2.0 and ever since I got the car the orange dipstick tube was broken at the top next to the engine cover. It did not bother me for the last year or so since I really did not see any problems with it. Not to mention that it is a common thing at least the 2.0 engines and noone seems to have problems with it...
      Yesterday. I was checking the oil (you can never be too carefull) and noticed that there was some oil sludge on the dipstick. I have never seen oil sludge on my dipstick before and this worried me. I took a closer look and I found out that there was a hairline crack in the orange dipstick tube barely visible but big enough for moisture to get through!
      So I got an new dipstick tube.
      For the 2.0 engine the part number is 06A 103 663 C. It cost about $7.00 from the dealership.
      Replacement is pretty straight forward:
      1. Remove engine cover.
      2. Pull dipstick out.
      3. Pull the dipstick tube and reinstall the new one.
      The reason why I am writing this is becase I think I have found the reason why the dipstick tubes break so easily. This is because there is a coolant hose that passes right next to the dipstick and heats it up quite a bit:
      As a result from that, the normally strong plastic becomes very soft, inflexible and prone to brittling and cracking. I washed my old dispstick tube and here is how it looks like after 64K miles:
      Notice the color difference! The region with the color change is right next to the coolant hose! When you press on the discolored portion, the plastic bends very easily and you can literally hear it crack under the slightest pressure. If you press down on the normal part of the dipstick tube it is hard, strong, does not bend and does not crack!
      So go pick up a new dipstick tube from your dealer and replace it. You will minimise the amount of moisture entering your oil pan and also prevent any plastic pieces from falling into the oil pan!
      Good luck! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Quote Originally Posted by MAG58 View Post
      Please consider your audience before saying something sensible. 80% of TCL drivers were actually banned from Formula 1 for being too fast.
      A turbocharger is a device in where exhaust gases go in, witchcraft happens, and then you go faster.
    2. Member Khyron's Avatar
      Dec 5th, 2001
      Calgary, AB
      2013 FR-S, 2011 Outlander XLS, Gone: 10 Santa Fe, 08 Legacy, 02 Jetta
      01-03-2005 06:12 PM #2
      Nice - I'll have to remember to check that once in awhile.
      Khyron
    3. 01-03-2005 06:50 PM #3
      mine came broke believe it or not on my vr6
    4. 01-03-2005 07:22 PM #4
      The one on my 1.8t broke down where it connects to the metal tube. Guy at the parts dept. said its a common purchase.
    5. 01-03-2005 08:12 PM #5
      Nice find Vasil! That coolant hose is definitely causing it to break.
      Can the hose be moved over slightly so that it doesn't contact the guide tube? Or maybe put a small piece of foam in between the two so that they stay separated enough to keep the guide tube from heating up so much in that area?
      Gary
    6. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      01-03-2005 08:16 PM #6
      Gary,
      I think that it will be relatively easy to move the coolant hose little fither to the left. The problem however is that the little plastic clamp that keeps the hose in place is simply not strong to prevent it from returning to its original position. Not to mention that the hose is pre-shaped so it will be even harder to keep it in place.
      I am thinking that a good round of insulation tape wrapped around the dipstick tube will help.
      The heated part realy looked and felt as if you burnt it with a pocket lighter.
      Modified by vasillalov at 7:21 PM 1-3-2005
    7. 01-03-2005 08:16 PM #7
      also a crack in the dipstick tube will cause a vaccum leak and most likely cause a horrible idle.
    8. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      01-03-2005 08:22 PM #8
      Quote, originally posted by DubAdicted »
      Interesting. Why whould that be? Is there any vacuum on the oilpan? I mean, I know the oil pump is getting the oil from the oil pan but vacuum?
    9. 01-03-2005 08:39 PM #9
      Quote, originally posted by vasillalov »
      PCV system
    10. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      01-03-2005 11:15 PM #10
      ttt
    11. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      01-04-2005 02:07 AM #11
      Late night bump
    12. Member vwtuner4ever's Avatar
      Feb 17th, 2004
      Gatineau Québec
      Golf 02
      01-04-2005 08:47 AM #12
      Nice find man. I will look at it asap.
    13. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      1971 Super Beetle, 2014 Golf TDI Manual, 2015 Silverado 1500 LT 4x4 Crew Cab
      01-04-2005 09:58 AM #13
      06A 103 663 C is for engine code AZG and AVH (2.0)
      for the 1.8T AWP it is 06A 103 663 B [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      if you need the number for your specific engine IM me with year model engine and engine code [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    14. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      01-04-2005 01:01 PM #14
      Quote, originally posted by 71sbeetle »
      I also worked for my 2.0 AEG engine code. I am assuming they are the same at least for the 2.0 engines....
    15. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      01-04-2005 08:49 PM #15
      yes you're right sorry I forgot to add AEG
    16. 01-04-2005 08:51 PM #16
      Thanks! Nice little tip/info. there!!!
      -Wes
    17. 01-04-2005 10:31 PM #17
      I actually think the sleeve is universal.....1.8T and 2.0 Jetta, golf cabrio, passat even ABA engines
    18. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      01-04-2005 10:33 PM #18
      Quote, originally posted by CorradoG60 »
      nope they're not
    19. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      01-04-2005 10:40 PM #19
      the 06A 103 663 B will also fit AWW and AWD
      the 06A 103 663 is for ALH
      Diesel (1.9L TDI 90hp) is 038 103 663
      24V is a long tube (IM me for part number but I think its metal so it shouldnt be a problem)
    20. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      01-04-2005 10:45 PM #20
      See that's the thing. Although they have different part numbers, it is the actual sleeves look the same. They are just stamped differently and are interchangeable.
      I am running a TDI thermostat in my 2.0 and it works like a charm. The part numbers were different only in the first 3 letters.
      Also, most of my engine part numbers for the 2.0 AEG start with 06A which makes me think this is engine code information.
    21. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      01-04-2005 10:52 PM #21
      trust me ... they are different
      06A is for external 4 cylinder parts
      does this look like your 2.0 dipstick ? I didnt think so
    22. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      01-04-2005 10:59 PM #22
      Actually it does! It is absolutely the same!
      I don't mean to start a war here. But this is my 2.0 dipstick sleeve! The little part that sticks out of it plugs to the bracket mounted at the intake mani...
      Modified by vasillalov at 10:01 PM 1-4-2005
    23. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      01-04-2005 11:01 PM #23
      1.8T :
      2.0 :
      and the one above is from a TDI [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    24. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      01-04-2005 11:03 PM #24
      Now that clears it..
      On the little pic from impexfap it looked the same.
      So I guess the difference is how the dipstick sleeve attaches to the intake mani bracket..
      Good job! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    25. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      01-04-2005 11:04 PM #25
      lol actually that piece extends parallel to the tube, the 2.0 version extends perpendicular to the tube [IMG]http://*****************.com/smile/emthup.gif[/IMG] I've had all 3 in my hand and trust me they are different (yes when I started to work in the parts dept I was the one stocking all the stuff ... and a VW part number is a VERY VERY smart thing ! the center 3 numbers are the category numbers, the first 3 change depending on model/year etc and 3 last digit + letters/numbers are the actual part # and if applicable color code
