VWVortex.com - Software Upgrades
    Results 1 to 18 of 18
    Thread: Software Upgrades
    1. 01-03-2005 11:15 PM #1
      I am taking my W12 in for service this week (10,000mi). My deal has told me that there are no software upgrades since I bought the car in March of 04. Does anyone know the facts about current upgrade? Does anyone know how to determine the rev of my installed software?
      Thanks
    2. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      01-04-2005 04:50 PM #2
      Hi John:
      Your dealer is telling you the truth. Not only have there been no software updates issued (ever) for the North American Phaetons, as far as I know, there have been no Technical Service Bullitans issued either. The Phaeton seems to have become the most trouble-free new product that VW has ever launched in North America.
      Here's a related thread that provides more background on software updates: Various Upgrades.
      Please let the Phaeton tech at your dealership know about our forum - we are not having much luck attracting Phaeton techs to join the forum, and they would be a really, really valuable group to have on board.
      Michael
    3. Member brosen's Avatar
      Jun 21st, 2009
      Plymouth, MN US
      2004 Phaeton V8
      07-29-2009 08:01 PM #3
      Please could you help me to understand the following error codes with my 2004 Phaeton, some of the information is in German.
      They will always come up, even after having cleared all of them, thanks
      Address 16: Steering wheel Labels: 3D0-953-549.lbl
      Part No: 3D0 953 549 D
      Component: Lenksäulenmodul 3401
      Coding: 0000032
      Shop #: WSC 01065 000 00000
      1 Fault Found:
      01336 - Data Bus for Comfort System
      004 - No Signal/Communication - Intermittent
      Address 37: Navigation Labels: 3D0-919-887.lbl
      Part No: 3D0 919 887 A
      Component: NAVIGATION 0147
      Coding: 0400000
      1 Fault Found:
      00625 - Vehicle Speed Signal
      Address 38: Roof Electronics Labels: 3D0-907-135.lbl
      Part No: 3D0 907 135 B
      Component: Dachmodul 0605
      Coding: 0000047
      Shop #: WSC 98769 666 36180
      1 Fault Found:
      00220 - Connection to Sunroof
      Address 46: Central Conv. Labels: 3D0-959-933.lbl
      Part No: 3D0 959 933 E
      Component: 4D HSG 3211
      Coding: 0000034
      Shop #: WSC 08110 444 00517
      Part No: 3D1 959 701 D
      Component: Tuersteuergeraet FS 0104
      Part No: 3D1 959 702 D
      Component: Tuersteuergeraet BF 0104
      Part No: 3D0 959 703 D
      Component: Tuersteuergeraet HL 0104
      Part No: 3D0 959 704 D
      Component: Tuersteuergeraet HR 0104
      Part No: 7L0 907 719
      Component: Neigungssensor 0020
      4 Faults Found:
      00927 - Terminal 30 (Right)
      011 - Open Circuit - Intermittent
      01516 - Terminal 30; Left
      00926 - Terminal 30
      00668 - Supply Voltage Terminal 30
      002 - Lower Limit Exceeded - Intermittent
    4. 07-29-2009 10:09 PM #4
      Looks like you have a loose wiring connection.
    5. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      08-02-2009 02:09 PM #5
      Hi Bernard:
      Although you have not posted the report from controller 17 (the instrument cluster), I can tell from looking at your diagnostic scan that you need to have the software in your instrument cluster flash-updated. There is a description of how to go about getting this done (by your VW dealer) at this post: TB: Distortion in the Display Unit in the Instrument Cluster (MFI, or Y24).
      Take your car to the dealer and tell them you are seeing distortion in the instrument cluster, and ask them to flash-upgrade your instrument cluster software in accordance with the information posted on the above-referenced thread. That will get rid of the following fault codes:
      Coding: 0000032
      1 Fault Found:
      Coding: 0400000
      1 Fault Found:
      Disregard the fault code for the sunroof in controller 38, every Phaeton reports that, it is a small software bug in the controller. It does not cause any problems and cannot be cleared, so, simply ignore it.
      The fault codes for controller 46 indicate a low voltage condition at the controller. Next time you do a diagnostic scan, leave your engine running. That will supply sufficient voltage to the controller, and as a result, you will not see these codes.
      The German language words simply describe the components, nothing more. Lenksäulenmodul means steering wheel controller. Dachmodul means roof controller. Tuersteuergeraet means door controller. If there are any problems, the VAG-COM software will report the problems in plain English, you never have to worry about translation.
      Michael
    6. Member brosen's Avatar
      Jun 21st, 2009
      Plymouth, MN US
      2004 Phaeton V8
      08-02-2009 09:27 PM #6
      Thanks Michael, I did the same test today with the engine running, I got DTC errors only on addresses 16, 37, 38:
      Coding: 0000032
      1 Fault Found:
      Coding: 0400000
      1 Fault Found:
      Coding: 0000047
      1 Fault Found:
      I think address 17 has already the latest version of SW: RB4 0321, it's correct ?
      Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
      Part No: 3D0 920 981 A
      Component: KOMBIINSTRUMENT RB4 0321
      Coding: 0005121
      Shop #: WSC 24314 444 59148
      No fault code found.
      It's weird that having the latest version 0321 and I still get the DTC codes for address 16 and 37 ????
      Modified by brosen at 7:35 PM 8-2-2009
    7. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      08-03-2009 02:43 AM #7
      Ah, OK. The cause of the fiber optic cable and speed sensor faults has to do with the version of the navigation software in the navigation CD reader.
      But - you might not be able to apply the software flash that takes it from 0147 up to 0168. Read the information on the following post, especially the information on the second page that describes the different hardware versions of the central display screen. If you have an older model display screen (has a MANUAL button on it, not an INFO button), then you cannot solve the problem without replacing the central display, which is a very expensive part.
      TB 90-07-01 "Clock Runs Too Slow" (Was: TB 90-05-05).
      Michael
    8. Member brosen's Avatar
      Jun 21st, 2009
      Plymouth, MN US
      2004 Phaeton V8
      08-03-2009 05:29 PM #8
      I am almost 100% sure I have the one with the Info Button, because I have the phone button as well, and I remember when the dealer gave me the service records of the car, the Display Screen has been recently changed, I'll check it tonight and I'll post back.
      Update: Here is the output from VAG-COM, it's version 0223, it's that good or bad news ?
      Address 07: Control Head Labels: 3D0-035-00x-07.lbl
      Part No: 3D0 035 008 Q
      Component: ZAB COCKPIT 0223
      Coding: 0400305
      Shop #: WSC 24315 444 52549
      Modified by brosen at 3:39 PM 8-3-2009
    9. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      08-04-2009 02:54 AM #9
      Yes, the software version in the front information display (big screen) is the correct version, but the software version in the navigation CD reader does not match it. You have 0148 in the navigation CD reader, and it should be 0168 if you have 0223 in the ZAB.
      There is a table on one of the above-referenced posts that shows what the relationship between controller 07 and controller 37 software should be.
      Michael
    10. Member brosen's Avatar
      Jun 21st, 2009
      Plymouth, MN US
      2004 Phaeton V8
      08-04-2009 09:46 AM #10
      Thanks Michael, what should be the right explanation to the dealer in order to have the Navigation CD SW updated ?, today I had a quick conversation with the service manager and his first question was: "what's the problem with the Navigation CD unit ?", and my answer was DTC errors, but they are "intermittent", so for the dealer that means no problem.
      I have to bring the car to the dealer tomorrow to check the issue with the TPMS System Fault (details on the 4 tires, or 5 thread) what I should tell them regarding the Navigation CD problem in order to get the SW updated ?, thanks
      Modified by brosen at 9:30 AM 8-4-2009
    11. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      08-04-2009 07:45 PM #11
      There is a relationship between the software in the front information display and control head (controller 07, the big screen) and the navigation CD reader (controller 37, the device you put the navigation CD into) that should be maintained. The table below shows the relationships.
      If your navigation system is working satisfactorily, then leave it alone. If you are experiencing problems, in particular if the system is not showing the correct location of the vehicle on the map, then get the nav reader software flashed up.
      Michael
      Relationship of J523 software to J401 software
    12. Member brosen's Avatar
      Jun 21st, 2009
      Plymouth, MN US
      2004 Phaeton V8
      08-04-2009 08:17 PM #12
      Thanks Michael, is there any TSB or VW document I can reference to the dealer ?, from where did you get this VERY useful table ?, thanks again
    13. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      08-04-2009 09:27 PM #13
      I've attached the Technical Solution. It is in German, but your dealer should be able to look up an English language version, using the same document number.
      Michael
    14. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      08-04-2009 09:34 PM #14
      For further information, see this thread: Change the Language used on the Infotainment Display.
      Read everything on that thread carefully before you do anything, ESPECIALLY my post of 8:18 AM 2-24-2006.
      Michael
    15. Member brosen's Avatar
      Jun 21st, 2009
      Plymouth, MN US
      2004 Phaeton V8
      08-04-2009 10:35 PM #15
      Great information Michael, there is TON of information here. I have only 1 question
      Today I have the Navigation Display Unit with version SW 223 (ready), language is English (ready) and Navigation CD Unit is SW 147, meaning I have to update it to version SW 168.
      To just upgrade the Navigation CD Unit, do I have to follow the same steps to change the language ?, meaning ignition off, keys off, insert CD into navigation unit..... etc.
    16. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      08-05-2009 11:48 AM #16
      Correct, the procedures are pretty much the same for a software update or a language chage. If all you want to do is update the software, simply disregard any options presented to change the language.
      Michael
    17. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      09-11-2012 11:58 PM #17
      Photo and TB re-hosted.
      Michael
    18. Moderator Paximus's Avatar
      Aug 26th, 2011
      Dorset, UK
      2005 Phaeton V10 swb 4-seat, Jeep XK Commander Hemi, SY Stavic 4x4, SY KJ Korando, Mercedes W168
      09-12-2012 06:44 AM #18
      Hi Michael,
      Many thanks for continuing to re-host the photos and attachments. It is breathing new life into the information archive.
      Regards,
      Chris
