VWVortex.com - Jetta REVS by Itself. HELP!!!
    Results 1 to 17 of 17
    Thread: Jetta REVS by Itself. HELP!!!
    1. 01-09-2005 07:01 AM #1
      I have a Jetta 2.0 and just recently the engine has started to rev by itself. The car won't be in gear and I won't be pressing the gas but for some reason I see and hear the RPMs rise. It's only happended a few times...i just took the car out of gear and let it rev down on its own. Does anyone know why this is happening? Damn car burns oil too but that's old news
    2. Banned
      Oct 28th, 2004
      01-09-2005 07:10 AM #2
      i had this problem too. could be several things.
      ur maf is dieing out. new ones are liek 60 bux.
      ur throttle body needs a cleaning. its a easy clean. theres a DIT inteh FAQ post.
    3. Banned br0nfufu's Avatar
      Aug 27th, 2003
      01-09-2005 07:28 AM #3
      let me edit that for you
      " your MAF is dying out. the new ones are about 60$. your throttle body needs cleaning. It's an easy clean, theres a DIY in the faq post."
    4. Member murkywave's Avatar
      Nov 30th, 2004
      Philadelphia, U.S.
      2011 Jetta SEL
      01-09-2005 08:10 AM #4
      Quote, originally posted by ninja_BAN1sh »
      Reason #83 not to 'Tex while drunk.
    5. Banned
      Oct 28th, 2004
      01-09-2005 08:26 AM #5
      Quote, originally posted by murkywave »
      im sober..just lazy
    6. Member SixerFixer's Avatar
      May 3rd, 2004
      Winnipeg
      VW, Volvo, BMW
      01-09-2005 12:51 PM #6
      your car's possessed.
      03 Jetta 1.8T - 6-Speed Swapped, Recaro, BBS, and all the euro goodies
    7. 01-09-2005 12:52 PM #7
      how much are the revs rising?
    8. 01-09-2005 02:24 PM #8
      If it is the MAF sensor.. I called VWOA and they told me that the warrenty on it has been extended to 12 years unlimited miles... so a dealership should be able to take care of that for you..
    9. 01-09-2005 02:53 PM #9
      Yea the problem with that is that IF they determine it's the MAF you'll get a new one, if not you'll get a $125 diagnostics bill.
    10. 01-09-2005 03:00 PM #10
      Quote, originally posted by c_b23 »
      REALLY? I thought it was 70,000 miles. Will this apply to me if I bought it used from non-vw dealership? Can I just take it to any VW dealer? That would rock, cause at 75K, I'm sure mine will go at some point?
    11. 01-11-2005 04:33 AM #11
      Really I did not know that the MAF sensor got extended to 12 years with unlimited miles. Did they send out a mailing? How did you find out?
    12. 01-11-2005 04:34 AM #12
      It rises up to about 2500 rpm
    13. 01-11-2005 08:52 AM #13
      What would happen if your MAF sensor died out while you were driving?
    14. 01-11-2005 10:38 AM #14
      Quote, originally posted by banggooooo »
      Not sure. But your car would be acting up long before that and youd notice SOMETHING was wrong, then eventually (hopefully) figure ou it's the MAF sensor and get it fixed before that'd happen. I sure wouldn't want that happening to me.
    15. 01-11-2005 01:20 PM #15
      nothing would happen. Mine has gone bad before. I dorve around with it like that for over a year. Basically, it'll screw up your gas consumption ratio. The car will either use too much or too little fuel.
    16. 01-11-2005 01:25 PM #16
      I'm betting MAF as well, I dont have a 2.0 but mine was doing the same thing and my intake has already been cleaned out. Some other indications are a CEL or on my display thingy in the middle of the gauge cluster, it will tell me to take it to the "emissions workshop".
      Good Luck [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. Member
      May 14th, 2002
      NJ
      2001 Golf 24v VR6. 2002 Jetta Wagon 2.0
      01-11-2005 04:20 PM #17
      I think is your alternator going my was doing the same thing the RPM would rise by it self it was doing that for few days and then finally the battery ran out becouse nothing was charging it ...... and the car wont start so i checked the alternator and it was dead ..........changed that and everything is fine now .................alternators are expensive at the dealer you can rebuild yours for under $100 bucks or you can find a used one for cheap
      Modified by VR6 Dejan at 8:22 PM 1-11-2005
      Modified by VR6 Dejan at 8:23 PM 1-11-2005
