Page 15 of 46 FirstFirst ... 5 11 12 13 14 15 16 17 18 19 25 ... LastLast
Results 491 to 525 of 1606
Thread: 16V G60 - How to
  1. 10-02-2006 12:32 PM #491
    Quote, originally posted by ozzman_g7 »
    If I did all this work, then wanted to put a 20v head later on, will it be easier to do this or would I need to change the pistons again, and relocate the alt again? etc.
    thanks
    Anyone??
  2. 10-05-2006 11:35 PM #492
    Thought you guys would like a peak at the latest incarnation of one of the local 16Vg60s here in the ATL.
    2L head with supertech valves and portwork with some cat cams.
    8.5:1 wiseco pistons
    big fmic
    78mm pulley and aobut 4psi boost... awaiting 68mm pulley.
    notice that there's no welding on the intake
  3. 10-06-2006 06:45 AM #493
    Man this thread has been useful. Am in the mock up stage atm. Mk1 16v g60 here we come.
  4. Member L8 APEKS's Avatar
    Feb 1st, 2006
    SoCal
    10-06-2006 12:37 PM #494
    re: Eaton M90...
    If you do use it, post pics/measurements of the brackets. That's the only thing holding many people back from using it...people do one-offs and keep everything a secret.
    Make a few extra sets and sell them here, or post the measurements so we can fab them up locally!
    Sean Williams :: SoCal
  5. 10-08-2006 06:57 PM #495
    Quote, originally posted by jwatts »
    big fmic
    What fuel rail is that?
  6. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    10-08-2006 07:33 PM #496
    Quote, originally posted by OttawaG60 »
    AWP 1.8T
  7. 10-13-2006 11:20 PM #497
    One of my customers had the mount bracket that is in BBM's picture on his 2.0L, so I asked if he had another from his engine swap and he did. That fixed that problem so I knocked some $ off his repair bill for the part. He told me his friend did the same BBM kit on a Jetts III and told me he would stop by so I could take a peek. 9 days latter, I still aint seen it.
  8. 10-13-2006 11:32 PM #498
    I have an old Bosch air flow meter(vane type) that was originally in the car. What do I use for air metering now?
    I dont know if I skipped over that part in all the reading I have done. Also quick question,what alternator with serp. belt pulley will drop on to BBM's relocate bracket?
  9. 10-14-2006 10:57 AM #499
    Hello and this is my engine!
  10. 10-14-2006 11:04 AM #500
    Modified by BI-G60 at 8:08 AM 10-14-2006
  11. 10-15-2006 09:52 AM #501
    lol , like that catch can mounting
    Quote Originally Posted by Pineapplegti ! View Post
    Brand enthusiasts are idiots.
    Klutch Republik - Live Fast , Drive Hard
    SCCH Cylinder Heads & Suspension Components
    OSD #16
  12. 10-15-2006 09:54 AM #502
    big fmic
    ATL is now the new home of 16vg60's ... bryson , mike... now this guy
    OSD #16
  13. 10-15-2006 01:14 PM #503
    ok looks bad,but i must never empty the oil catcher!
  14. 10-15-2006 05:31 PM #504
    BI-G60 - what radiator did you use with that intercooler?
  15. 10-15-2006 05:52 PM #505
    Quote, originally posted by BI-G60 »
    its just weird mounting thats all.
    OSD #16
  16. 10-15-2006 07:47 PM #506
    Hello!
    this is a Golf MK2 GTD radiator plus vr6 radiator fan!The original g60 radiator is smaller.
  17. 10-15-2006 08:19 PM #507
    Quote »
    What is a GTD? do you have a part number?
  18. 10-15-2006 09:03 PM #508
    @OttawaG60
    i have forget to say, it´s a turbo diesel 1,6l 80HP,engine code:SB.And i have installed the plastic side box from G60 radiator in these!!!
  19. Forum Sponsor JBETZ's Avatar
    Feb 17th, 2000
    Bend, Oregon
    02 GTI 337, 2010 H3T
    10-17-2006 01:10 PM #509
    Boost... the displacement replacement!
    BBM, LLC 541.388.1202
    www.BahnBrenner.com
    we share the passion!
  20. Member Scuba2001's Avatar
    Jul 15th, 2002
    Greenville, SC
    2000 BMW 528it
    10-17-2006 06:14 PM #510
    This sucks so much, becaue I need a kit so bad to get my engine build underway, but dont even have any cash..
    Im going to be left without a kit
    Scuba Steve
    2000 BMW E39 528it
  21. 10-17-2006 06:33 PM #511
    Quote, originally posted by Scuba2001 »
    you dont need a damn kit..
    OSD #16
  22. Member
    Oct 27th, 2002
    Fresno Ca
    60 15window, 63 ragtop, 76 Rocco, 82 coupe, 91 Jetta, 96 harlequin, 03 W8,
    10-20-2006 02:47 AM #512
    thinking of putting a 16v head on my pg, but i dont want to pull pistons, or my motor... any other options?? great thread btw
  23. Forum Sponsor JBETZ's Avatar
    Feb 17th, 2000
    Bend, Oregon
    10-20-2006 10:28 AM #513
    Quote, originally posted by 2deepn2dubs »
    The G60 pistons have a big fat scavenger boss sticking up.
    You will need to swap out the pistons or go with a true 16V engine or an ABA 2.0L 8V engine.
    www.BahnBrenner.com
  24. Member
    Oct 27th, 2002
    Fresno Ca
    10-21-2006 05:25 AM #514
    thats what i was afraid of ill prolly leave my jetta alone and build an 16v g60 for my caddy...
  25. Member
    Oct 27th, 2002
    Fresno Ca
    10-25-2006 05:12 AM #515
    heres mine so far, i think im going to go with the aba alt tho... does anyone have any more pics of alts mounted under the charger to the charger brkt? ...also, is it ok to run the waterpump backwards?
  26. Member kindbudz91G60's Avatar
    Oct 7th, 2003
    Ft. Collins
    91 Corrado1.8T, 92 CorradoVR-S, 77 Rabbit1.8T, 89 JettaVR, 48 Willys, 79 Jeep-J20, 94JeepGrand, 73RV
    10-26-2006 01:39 PM #516
    And we all know how awesome the BBM kit is... It doesn't come with one scrap of paper that tells anything about the products or how to install them. Also, the aluminum bracket that the tensioner mounts too (and slips on the charger bracket) is siezed on my G-60 bracket.
    When the tensioner bracket siezed on the charger bracket it stopped the tensioner from doing anything and locked the serp belt under tension. This in turn was too tight on the supercharger and smoked the mainshaft bearings and seals. Now, the charger passes oil right down the mainshaft seals...sweet design BBM.
    Then when I asked John about this he said "no that's never happened before, but I might put a grease zerk in the tensioner bracket if I were you". Well John, that would have been a good idea for YOU to do, since you're selling the kits. Oh yeah, sorry I don't have the $3K to buy your Lysholm, but my G-60 WAS working just fine.
    Long story short the BBM "kit" gets you pointed in the right direction, but certainly is not a turnkey kit, nor is it engineered that well. For the cost I would try to source the components used on the net.
    $0.02 exactly.
  27. 10-26-2006 05:27 PM #517
    ahem
    http://forums.vwvortex.com/zerothread?id=2610427
    OSD #16
  28. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    10-26-2006 08:48 PM #518
    Considering the vanes on the waterpump are clockwise,I would not run them counterclockwise.In order to make the ABA alternator fit,you have to do some grinding of the AC supports on the charger bracket.The ABA alternator does work though and your going to want to run your belt system something similar to this:
  29. Member
    Oct 27th, 2002
    Fresno Ca
    10-27-2006 02:48 AM #519
    ok, sweet! that looks alot less confusing and looks like pretty good routing...
    does it matter if the donor pg parts are from a '92 obd1???
    what else will i need from the pg besides the following...
    G60 throttlebody
    G60 engine harness/ecu
    G60 Fuel Injectors
    G60 Idle stabilizer valve (ISV)
    G60 CO% potentiometer
    G60 Lower water pump pipe
    Upper and lower coolant hoses
    G60 Radiator
    can you think of anything else?
    Modified by 2deepn2dubs at 11:56 PM 10-26-2006
  30. 10-27-2006 10:17 AM #520
    Quote, originally posted by kindbudz91G60 »
    $0.02 exactly.
    that is for sure . thats why i made my build pages cause i couldnt fin everything in one place . I spent hours looking at the BBM picture to figure out how to get it on right . The Yahoo group is good , but the information is so scattered around and hard to fine . this post helped alot for me .....
    for this thread
    oh and for mine
    Up and Live >>> www.Herbys53.com <<< sick of the BS , check it out :thumb:
    860-798-5227 TEXT anytime
    Herbys53 VW/Audi Corral May 29th Lime Rock Park Ct.
    53Motorsports-Koni/APR/TT/Bilsteins/Oem+/Service:clap:
  31. 10-27-2006 01:11 PM #521
    Be careful with the size of the alt down below the charger, I know I had problems with it hitting (ever so slightly) the subframe.
    There are some tiny alt's out there, might be worth whole looking at.
  32. Member
    Oct 27th, 2002
    Fresno Ca
    10-27-2006 02:27 PM #522
    Quote, originally posted by Wizard-of-OD »
    this looks like the g60 alt... your right, looks like it will hit the subframe... ? ...i think the aba alt is smaller...
    Modified by 2deepn2dubs at 11:28 AM 10-27-2006
  33. Member
    Oct 27th, 2002
    Fresno Ca
    10-27-2006 04:50 PM #523
    so anyone know, does it matter if the donor pg parts are from a '92 obd1???
  34. 10-27-2006 05:02 PM #524
    what parts are you planning on using?
    OSD #16
  35. Member
    Oct 27th, 2002
    Fresno Ca
    10-27-2006 09:09 PM #525
    Is there a difference in these parts between obd1 and obd exempt?
    G60 Fuel Injectors and FPR
    G60 Digifant1 ECU and engine wire harness
    G60 Digifant control relay
    G60 Oxygen sensor
    G60 Water temperature sensor (blue)
    G60 Relays, fuel pump
    G60 Radiator and fan assembly
    Modified by 2deepn2dubs at 6:11 PM 10-27-2006
