VWVortex.com - Dimentions needed!!!! vw motorsport shifter.
    Page 4 of 20 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 480
    Thread: Dimentions needed!!!! vw motorsport shifter.
    1. Member 16V_Scirocco_GTX's Avatar
      Jul 18th, 2001
      In the 94086 California
      98 Passat V6, 90 Corrado TDI, 84 Scirocco GTI
      04-20-2005 04:41 PM #76
      I suppose the rod and cable models aren't interchangable ... since I have the rod shifting but may want to swap to cable down the road.
      What's the ballpark price?
      Tobias
      98 Passat V6, 90 Corrado TDI, 84 Scirocco GTi
    2. 04-20-2005 07:45 PM #77
      Quote, originally posted by bahnblitz »
      I have a fully working rod selector model for 020 gearboxes if anyone is interested in buying one!!!
      Quote, originally posted by 1.8t rabbit »
      i'm going to make it only for cable shift trannys at first, and then i'll make the 020 shifter if i can sell these.
      Bahnblitz and 1.8t.......do you have any pics of your setups and info on how they work? Or at the very least a good description of how they differ from the standard linkage?
      I have never seen anything remotely heavy-duty designed to work with the 020 (rod shift boxes) so I'm extremely curious here.
    3. 04-21-2005 02:56 AM #78
      Here is a preliminary set up from last weekend of my stock VWMS shifter with some pieces i machined to keep the stock tower. They are now being redone/changed a bit and anodized to match the stock pieces. What a bitch!
    4. 04-21-2005 04:04 AM #79
      I like the way you did the side to side cable... goos chit...
      I was a man... I was a good man... Selling insurance...
    5. 04-21-2005 11:35 AM #80
      Ohh and i wanted to say that my rod shifter setup still uses the factory rod that runs through the tunnel.
      I'm glad you mentioned that as that was a concern of mine...My stock shifter has already been relocated further towards the rear of the car and I've had to lenghten the stock shift rod.
      On a side note, I voted in your other thread so I'm interested in seeing the final product.
    6. 04-21-2005 02:54 PM #81
      1.BillyT -do you know if VWMS ever offered taller towers? I like the factory look with the stamped holes. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. 04-21-2005 04:53 PM #82
      Quote, originally posted by rallyebmx »
      DOn't think so. The ones that wer ein the race cars here had taller towers but they were all custom. If you can find a decent race fab shop, they should be able to build a tower that looks just like the original one... but taller.
    8. Senior Member Muffler Bearing's Avatar
      Apr 4th, 2004
      54 green with a white roof, 84 also green with a white roof.
      04-21-2005 05:39 PM #83
      rallyebmx, what cables are those your using? would they work with an o2o box? im new to cable shifting...
      -j
      A Rabbit is not to be wasted on the tentative or weak. Only the worthy are invited, and then only at your own risk. If you have even a modicum of hesitation, DO NOT buy one of these cars. Instead, leave it for a worthy soul who has already matriculated to the sublime ecstasy of what those in the know refer to as a "MK1"
    9. 04-21-2005 06:27 PM #84
      To the best of my knowledge, they are stock VWMS cables. Or at least the ones they were using for their shifters. There are no markings on them at all. I've heard that Bildon is now selling B&M cables for this purpose. I dunno. Don't know about the o2o box either. If any one is looking for all styles of threaded rod ends for the shifter cables, I highly recommend spring fix linkages. These are not the easiest to find. They have a great website and a great assortment.
      Modified by rallyebmx at 10:32 PM 4-21-2005
    10. 05-19-2005 01:06 PM #85
      Anybody want to pony up and show their 020 rod-linkages? I still can't visualize how the heck this works.
    11. Member rventoo7's Avatar
      Nov 12th, 2002
      92 16v GTI, 91 VRT GTI Lugtronic
      06-17-2005 08:56 AM #86
      so is someone gonna build these for ale on the vortex or what?
    12. Member CorradoCody's Avatar
      Oct 13th, 2001
      90 VW Corrado G60
      06-18-2005 11:00 PM #87
      That's definately hot. If someone were to make this, there would definately be a few buyers.
      CC
    13. 06-19-2005 02:42 PM #88
      Quote, originally posted by Muffler Bearing »
      just thought of something while changing a shifter cable. why not just get a stock cable shift box and mount it ontop of the tunnel instead of below? BAM! raised shfiter.
      -j
      Exactly what I did in my rabbit.
    14. 06-20-2005 11:57 PM #89
      Quote, originally posted by CorradoCody »
      CC
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] 2nd that
    15. 07-01-2005 06:36 PM #90
      anyone still willing to post the dimensions? Rabbit 1.8t can you send me the CAD file? I'm building a 87 golf up for rally.
    16. 07-04-2005 12:51 PM #91
      A German Company called CAE makes a conversion kit for the rod change boxes, as well as a shifter for the cable boxes. Their site is here: http://www.cae-automobiltechnik.de
      Here's some pics:
    17. Member speed51133!'s Avatar
      Aug 5th, 2002
      alexandria va/milwaukee wi
      02 audi tt 225 / mk3 jetta /audi 5000s turbo
      07-04-2005 04:48 PM #92
      569 euros for it.
      thats like...800$ almost for US dollars.
      umm..ill stay stock
    18. 07-05-2005 10:02 AM #93
      Quote, originally posted by speed51133! »
      569 euros for it.
      umm..ill stay stock
      Yeah, it is steep, as is the VWM piece, if you can find it, which also runs about $800.00 (at least last time I looked), but for those folks that fabricate, at least they were kind enough to illustrate their solution to converting a rod shift tranny to cable shift.
      I came across another clone of the VWM shifter piece one time on a Swedish site, but I've never been able to find it again.
    19. 07-08-2005 05:22 PM #94
      How'd the first run come out? or did it?
    20. 07-09-2005 04:22 PM #95
      Quote, originally posted by wvonkessler »
      I think you are talking about a swedish company called Selholm Tuning !! They do alot of race / rallycars and stuff for these cars too ! they make VWM shifters !
      // Oscar Larsson
      TT-R Sweden
    21. 07-11-2005 05:15 AM #96
      Ok i'm ready to make the first run, but i need to know how many to make so please post in the poll in the link provided below:
      http://forums.vwvortex.com/zerothread?id=1948064
      Did they kill your thread?
    22. 07-12-2005 02:20 AM #97
      http://www.stroevemotorsport.nl/
    23. 07-14-2005 09:57 PM #98
      I am aware of the Sellholm shifter. A nice piece. Sellholm also sells awesome gearkits and rally suspension. Available here: http://www.mobeck.com/
      In addition, I found another German site that does a conversion for 020 boxes: http://www.t-k-sport.de
      The CAE folks said that their conversion does not work on A2-A3 020 boxes.
      I wish that the folks on this thread that have done conversions of the shifter to 020 boxes would share their info.
      On another note, one of these with a short shift kit might work for the 020:
      http://www.tmtuning.com/rsd/images/RSD-652.jpg
    24. 07-15-2005 01:20 PM #99
      so is there anyway to convert the rod type to cable type shifter? is there anyway to fab something up? maybe some cables going to the shift linkages and springs to return them?
    25. 07-15-2005 03:12 PM #100
      Quote, originally posted by Kiff »
      Did you miss this, just a few inches above?
      It does exactly what you mention, and it costs almost 600 Euro.
      Modified by Mr Black at 2:14 PM 7-15-2005
