VWVortex.com - how to get ignition lock cylinder out of steering lock assembly ?
    Results 1 to 23 of 23
    Thread: how to get ignition lock cylinder out of steering lock assembly ?
    1. 01-31-2005 08:04 PM #1
      so im trying to update my steering column to ce2, in order to do that i need to get a new steering lock assembly and i want to use my old key so i use one key for the whole car.
      so how do i get this....
      out of this...
      what do you guys think ? should i just say screw it and get a new key and lock ?
      help me out here
      TIA
      Aug 5th, 2003
      Centerport, NY 11721
      87 GTI, 03 GTI, 96 Ranger, 88 Shadow VT800C
      01-31-2005 08:09 PM #2
      bump cause i have to change out my whole lock set and the bentley manual dosent even mention how to change the ignition lock cylinder, i should never have lost my keys
      '87 GTI 1.8t, '03 20th GTI #2100, '96 Ranger 4x2, '88 Shadow VT800C
      '01 TT 180Q, '98 Ranger 4x4, '01 Catera, '90 GLI 16vT, '94 850 Turbo, '90 Golf, '89 Golf, '90 Mustang LX, '91 Jetta, '88 9000S, '86 Jetta, '91 Continental
    3. 01-31-2005 08:10 PM #3
      here's a picture of the one in question
      done be afraid to answer now
    4. Moderator The_Hamster's Avatar
      Jul 31st, 2000
      Alberta
      Barbie Jeep Power Wheel
      01-31-2005 08:22 PM #4
      there's a retaining screw on the back of it, see page 14-27 in the bentley, shows a picture on the top right of the page, and an arrow pointing to the screw.
      Aug 5th, 2003
      01-31-2005 08:28 PM #5
      got it
    6. 01-31-2005 08:29 PM #6
      could any one take a pic of this screw n post it up for me ? i dont have the MKII bentley yet
    7. Member Batan's Avatar
      Dec 15th, 2000
      Vancouver, BC
      01-31-2005 08:31 PM #7
      I thought you had to drille a 3mm hole in one spot and press a spring to get the lock out?
    8. Moderator The_Hamster's Avatar
      Jul 31st, 2000
      Alberta
      01-31-2005 08:33 PM #8
      Quote »
      that rang a bell with me as well, but that's all i could find after a quick search in the bentley, points to the screw and says "the ignition lock cylinder is held in with this screw" or something, and that's about all it says.
    9. Member 2035cc16v's Avatar
      May 18th, 2000
      New England
      2012 GLK350 1999 A4 Avant
      01-31-2005 08:35 PM #9
      Quote »
      It most certainly does!!!!!
      This is why we preach "buy a bentley".
      After 9k posts that still hasnt sunken in yet?
    10. 01-31-2005 08:36 PM #10
      are you gusy sure that it's the lock no tthe ignition switch ?
      cus there's no more screws left on it (at least ones i knwo of)
      Modified by Jetta2NR at 8:37 PM 1-31-2005
    11. Member Batan's Avatar
      Dec 15th, 2000
      Vancouver, BC
      01-31-2005 08:42 PM #11
      From Bentley
      To replace the ignition lock cylidner drill a 3mm hole in the lock cylinder housing at the point indicated in Fig(well, damn no scanner at home). Inset a pin though the hole and press down on the spring that holds the lock cylinder in the housing
      There...now we have to figure out how to get the picture.
      Ok, drill 12mm froom the edge of where the cylidner enters the cast housing and 3mm from the vw/audi symbol towards the big part of the husing(or to the right...
      Got it?
      Modified by Batan at 4:47 PM 1-31-2005
    12. 01-31-2005 08:45 PM #12
      so if i would order a new one would i still need to drill the hole ?
    13. Member 2035cc16v's Avatar
      May 18th, 2000
      New England
      01-31-2005 08:45 PM #13
      A hole has to be drilled into the outside of the housing allowing you to puch the retaining clip down and pull the lock cylinder out.
      Turn to Chapter/page 11/34 in your bentley manual and find the WHOLE procedure in detail.
      Edit: already posted.
      yes you STILL have to drill a hole...old one still has to come out right?
      Modified by 2035cc16v at 4:59 PM 1-31-2005
      Modified by 2035cc16v at 5:00 PM 1-31-2005
    14. Moderator The_Hamster's Avatar
      Jul 31st, 2000
      Alberta
      01-31-2005 09:00 PM #14
      much better advice to look on page 11-34.
      here:
      so drill a 3mm (or 15/127th's of an inch ) hole in that red area, and press down in the spring loaded peice underneath, that should eject the lock cylinder, that's the best i can reckon from the bentleys instructions, somebody correct if i'm wrong!
    15. Member 2035cc16v's Avatar
      May 18th, 2000
      New England
      01-31-2005 09:02 PM #15
      you are correct sir!
      well, except for the ejection part... you have to pull it out...
    16. Member Batan's Avatar
      Dec 15th, 2000
      Vancouver, BC
      01-31-2005 09:10 PM #16
      Quote, originally posted by The_Hamster »
      here:
      Damn , I just notice that picture looks very falic...in a limp kinda way.
    17. 01-31-2005 09:11 PM #17
      Any idea why VW didn't just put the hole there to begin with?
    18. Member
      Aug 5th, 2003
      01-31-2005 09:11 PM #18
      Quote, originally posted by Batan »
      From Bentley
      could you please tell me what page that is on, i have the bentley in my lap and for the life of me cannot find it, and im not a dumb ass
    19. Member Batan's Avatar
      Dec 15th, 2000
      Vancouver, BC
      01-31-2005 09:16 PM #19
      Quote, originally posted by L33t A2 Jetta »
      Chapter 11, page 34. there' a picture.
    20. Member 2035cc16v's Avatar
      May 18th, 2000
      New England
      01-31-2005 09:17 PM #20
      look up...
      yuo=dumbass
    21. Member
      Aug 5th, 2003
      01-31-2005 09:26 PM #21
      ahh of course its in the suspension and steering chapter
      damn thee bentley damn theee ahhhhh, lol
      i was thinking it belonged in the body and interior or maybe next to the ignition switch part in chapter 14
      thanks
    22. Member Batan's Avatar
      Dec 15th, 2000
      Vancouver, BC
      01-31-2005 09:29 PM #22
      thanks
      It took me a while too...I thought it was in the body.
    23. 01-31-2005 09:34 PM #23
      i dunno i think i did something wrong cus my lock is all mesed up
      i think i'll have to order a new one
      Modified by Jetta2NR at 9:36 PM 1-31-2005
