VWVortex.com - How to manually open the gas cap door flap (if it is frozen closed)
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 28
    Thread: How to manually open the gas cap door flap (if it is frozen closed)
    1. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      02-01-2005 03:20 AM #1
      Hi All:
      While I was away in nice warm Africa, my wife was stuck in ice-cold Canada, where temperatures were averaging about -20° or so the week before I came home. When I called my wife and told her I would be home on the weekend, she thought it might be wise to get the Phaeton washed, since she had not bothered to wash it since I left for Europe in November.
      Very nice thought on the part of my wife, except, she didn't consider the effect of pouring lots of water all over a car that had chilled to 20° below the freezing point. After running the car through the touchless car wash, she drove it over to the gas pump to fill it up, and lo and behold, the gas flap was frozen shut. The kid that was pumping gas wisely declined to try forcing it open with a screwdriver.
      My wife then drove the car home, and called our VW dealer. Mark, the Phaeton technician at our dealership, showed up at our home about an hour later, and he showed my wife how to release the gas cap flap manually, in case my wife ever decided, in the future, to once again turn the Phaeton into a large rolling Popsicle.
      Well - my wife was pretty impressed with this level of service (and so was I), so one of the first things she mentioned when I arrived back home was "Guess what, I know how to do something with the car that YOU don't know how to do."
      So - with thanks to my wife, and special thanks to Mark at my VW dealer, here's how you open a gas cap flap that is frozen shut:
      1) Open the trunk, assuming of course that it is not also frozen shut.
      2) Grab hold of either side of the little storage compartment on the right hand side of the trunk (the thing with the little net on it), and pull it straight out. It is held in place by spring clips.
      3) If you are wearing any rings, watches, stuff like that, take them off now, because you are going to be sticking your hand into the area where the starter battery and a whole lot of electrical cables are found.
      4) Look above the starter battery, on the inner fender wall, and you will see a white plastic component. This is the electrical actuator that pulls the cable to open the gas cap door. Stick your hand in there, and push the plunger in. "Pushing the plunger in", in this context, means you push the plunger aft and downwards, because it is installed pointing up at about a 45° angle.
      Hopefully, the little door over the gas cap will now open. If it does not open, just push harder on the plunger.
      Below are some photos to help explain the process.
      Michael
      After you have removed the storage bin on the right side of the trunk, this is what you will see:
      Here's a close-up of the device that normally opens the gas cap door. The object in the foreground is the negative terminal of the starter battery.
      This is what the device looks like when it is not actuated (meaning, the gas cap flap is locked closed).
      This is how you want to squeeze it, to pull the cable and cause the flap to open.
      NOTE: You DON'T have to remove it from the car, I only removed it to permit a better picture of it. I couldn't take the picture of the thing with the plunger compressed when it was still mounted in the car - my hand was in the way.
    2. 02-01-2005 03:55 AM #2
      thanks michael. I have a photographic memory, but you post so much information, even my memory can't keep up.
      Nov 15th, 2004
      Indianapolis, IN
      02-01-2005 09:10 AM #3
      Quote, originally posted by PanEuropean »
      Michael,
      You are truly dedicated to the site's information exchange. Who else tears their car apart just to get a pic! Anyway, thanks to you and your wife for sharing.
    4. Member
      Mar 15th, 2000
      Dallas
      2004 W12- Premier Edition, 1990 Porsche S2, 2009 Genesis V8
      02-01-2005 11:45 AM #4
      Michael, if you ever have to run for 're-election', you have my vote. You really went to a lot of trouble to afford this info, which, truth said, isn't much use in Texas.
      But, I have a question. How in the world does a car wash operate in freezing weather?
      Jack
    5. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      02-01-2005 01:31 PM #5
      Quote, originally posted by Jack Orr »
      Hello Jack:
      Gee, if they couldn't do that, they would go bankrupt up here. The 'tunnel washes' are pretty much the same as I expect they are in warmer climates, the only difference being that they have a set of 'curtains' on each end of the tunnel - sort of like what you sometimes see on walk-in freezer doors. When the car approaches the entrance, the curtains open, as soon as the car is inside, they close again. This keeps the temperature inside the tunnel just fractionally above freezing.
      If it gets really cold, say, -30° or so, then they have to shut down, but we don't get those kind of temperatures in the lower great lakes area (Ontario), where I live - that's kind of a Western Canada thing. For example, the Prairie provinces are famous for brutally cold weather.
      Michael
    6. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      01-30-2006 10:06 PM #6
      I went to visit my brother in far Northern Canada last week, and the temperature was pretty cold - about -20°C. I made the mistake of washing the car at an indoor coin-op, figuring that if I did a decent job of drying it off, I would not have any problems due to the cold temperatures.
      Wrong. When I next tried to open the gas tank filler flap to fill the tank, the flap refused to budge - it was frozen shut. It was cold as heck out, and I didn't relish the idea of digging through all my stuff in the trunk to get access to the latch release mechanism as illustrated above. So, I tried another strategy, and it worked. I used the credit card that I already had out to pay for the fuel as a trim tool, and pried the frozen flap open. That strategy worked.
      Below are some photos that show how to do this trick. They also illustrate where the water accumulates and freezes if you wash the car during very cold weather.
      Michael
      An emergency trim tool...
      The cause of the problem
      May 29th, 2004
      East Haddam, CT
      More than I need
      01-31-2006 01:25 PM #7
      Think I'll fill first and wash second. I try to dry the insides of all door openings to prevent freezer lock after a winter car wash but until now neglected the fuel door. I do clean and dry that area when I do a detailed cleaning on fair days at home. Nice heads up for winter driving. Would a little WD-40 on the inside panel of the door (not the door itself) help keep water away and from freezing the door shut?
      RB
    8. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      01-31-2006 06:02 PM #8
      Hi Again Ron:
      Personally, I would not use WD-40. WD-40 is a very clever invention, it contains two-thirds Stoddard Solvent (a solvent), and one-third oil (a lubricant). (reference: Canadian MSDS disclosure for WD-40 Aerosol) The two components are, obviously, working at cross purposes to each other, but that explains exactly why WD-40 'works every time' - you spay it on something, and if the solvent doesn't dissolve the crud and allow you to work it loose, the solvent then evaporates and the oil remains behind as a lubricant. Kind of like the 'good cop, bad cop' routine.
      Volkswagen makes a silicone lubricant that is specifically intended to be a lubricant - the assumption is made that you will be applying it to a reasonably clean surface, so, there is no solvent in it. The text on the side of the can states "It prevents seals from freezing", which I think suggests it would be ideal for this purpose. You can buy (or order) a can of this from the parts department of any VW dealer.
      Michael
      Volkswagen Silicon Lubricant Spray
    9. 01-31-2006 06:15 PM #9
      This just happened to me last week, who knew there was a thread on the forum just for this ... my technique involved discrete banging on it
    10. Member chrisj428's Avatar
      Feb 26th, 2005
      Vernon Hills, IL
      '15 Ford C-Max Energi
      01-31-2006 06:29 PM #10
      There is also a product that is a liquid teflon. I'll try & get a photo and more information. I have used this on Jettas to solve issues where the seal is making a creaking noise against the door.
      --Chris
    11. 01-09-2010 09:02 AM #11
      Hello Michael
      Just thought I'd thank you for your suggestion, having bought from Audi dealer a can of Silcon Lubricant Spray and tested in on my A5 it really helps prevent the window from being stuck at sub-zero temperatures.
      I have had this problem ever since I bought the car back in 2008, and also suffered the same issue with my previous car a 1994 Audi Coupe. Seem to be a design flaw by manufacturers making cars, especially coupes and convertables without frames around front windows.
      I carefully applied the spray yesterday and tested my window this morning at 8:30am when the temperature outside was -3.5 degrees. Window operated almost instantly, when the temperature last night reached around -6.0 degrees.
      Many thanks again, I'll post your tip and a link from this thread to other forums I am a member of.
      All the best.
      Dave
    12. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      10-07-2012 03:49 AM #12
      Photos re-hosted.
      Michael
    13. 05-01-2014 07:35 AM #13
      Hello.
      I have problem like this:
      I cannot open fuel filler gap by pressing button on drivers door. The same problem with trunk button. When I use VCDS is works properly. I checked fuse #14 but it was ok. I cannot remove 5B so I cannot check it.
      Can anyone help?
      Greetings
    14. Member
      Apr 4th, 2014
      Kuwait - NYC
      2004 Phaeton V8 + 2011 Range Rover Sport + Three lovely Porsches
      06-20-2014 07:22 PM #14
      Michael,
      My gas door is stuck with no gas in the tank! I tried to depress the electrical actuator to no avail. Must the engine be on to do this?
      Regards,
      Salah
      Salah
      Give a lot, expect nothing
    15. Moderator Paximus's Avatar
      Aug 26th, 2011
      Dorset, UK
      2005 Phaeton V10 swb 4-seat, Jeep XK Commander Hemi, SY Stavic 4x4, SY KJ Korando, Mercedes W168
      06-21-2014 01:20 PM #15
      Hi Salah,
      Michael is currently touring Europe on his motorbike, but perhaps he will have Internet access somewhere and post a comment.
      I just went out and tested the fuel filler operation. You don't need the ignition on for the button to open the flap, or to have engine running. However, I did have the car unlocked (and the fob away from the car, so as to test without the keyless entry interfering).
      I think you may have to open it manually using the instructions in this thread.
      However, you do need a good vehicle power supply. It could be worth charging the left battery overnight if the car is near a power point and not stranded by the road. This will help the controllers reset any issues they may have had from low battery voltage. You should use a a smart charger which is specifically-marked as AGM-capable, because the finish voltage is different from that of flooded car batteries. However, it is probably best not to turn on the ignition while the charger is connected, as the car's load could be 40 amps.
      If a good battery does not clear the issue it may take a DTC reset using a diagnostics cable. Or just wait a day or two for the car to reset its lock status itself once the battery is in good condition and charged. I'm not sure if this is a software feature or just a fact of life, but it often works.
      It would be unusual for the mechanism itself to break.
      Chris
      -- I just bought a Phaeton. How do I..............................-- Upgrades, modifications, pampering
      -- Colours, factory options, reviews...............................-- Technical Reference
      -- Troubleshooting.................................................. ....-- See the TOC/FAQ (Index) for more details
    16. Member
      Apr 4th, 2014
      Kuwait - NYC
      06-22-2014 12:41 PM #16
      Many thanks Chris for your valuable input. Will see what can I do and report.
      Regards,
      Salah
      Salah
    17. Member
      Apr 4th, 2014
      Kuwait - NYC
      06-23-2014 09:38 AM #17
      Chris,
      Here's the situation. No gas in the car, gas door doesn't open, and now trunk doesn't open by any mean! To add to the great news, the hood doesn't open as well!
      Salah
      Salah
    18. Moderator Paximus's Avatar
      Aug 26th, 2011
      Dorset, UK
      06-23-2014 10:41 AM #18
      Has the car been stored? It sounds like the trunk and hood latch lubrication has dried out in the heat, and the battery is flat.
      What are the good points? Can you open the driver's door? Is the car in a safe location with electricity available? Do you have the set of keys that came with the car?
      Operational recovery will be less difficult if you can open the trunk/boot. What happens when you insert the key into the black slot in the trunk lid logo, slide it to one side, insert the key and turn it? This normally actions the mechanical lock release so that the lid can be pulled open by hand.
      Chris
    19. Member
      Apr 4th, 2014
      Kuwait - NYC
      06-23-2014 06:35 PM #19
      The car was run daily while it sat in a parking lot (no electric outlet in sight) awaiting new dampers to be fitted (arriving in few days). Gas ran out. I opened the trunk two days ago by inserting the key in the emblem but now it doesn't work. Key can go to the right but that's it. Driver door opens a d locks with the key but not the other doors. I have one key only.
      Salah
    20. Moderator Paximus's Avatar
      Aug 26th, 2011
      Dorset, UK
      06-24-2014 06:18 AM #20
      Hi Salah,
      If the key is capable of rotating in the trunk lid lock, then try turning it while pressing down on the lid. Then it may unlatch. You may then be able to squeeze your fingers under the edge of the lid rim and pull hard to open it. Quite a lot of force is required to get it moving, especially if the rubber seals are stuck together.
      Once it is open, I suggest that both batteries are taken off the car and fully re-charged using an AGM-capable charger. For safety, the factory procedure should be followed for battery removal and replacement. See this thread of Jason's: Battery replacement procedure
      This should restore some normal functioning for a while. If the gas cap does not open at this point, then try resetting all DTCs using a diagnostics tool. After that, remove the trunk trim and manually release the gas cap.
      The garage should be able to do something with the hood release once they can get the car on a lift.
      If all that fails, I think you may be in for some destructive access...
      Chris
    21. Member
      Apr 4th, 2014
      Kuwait - NYC
      06-27-2014 11:41 AM #21
      Many thanks Chris for your support. I have a date tonight with that untamed beast and we'll see how it goes.
      Regards,
      Salah
      Salah
    22. Member
      Apr 4th, 2014
      Kuwait - NYC
      06-27-2014 03:58 PM #22
      Trunk and gas door opened, Thank God. Engine started.
      Salah
    23. Moderator Paximus's Avatar
      Aug 26th, 2011
      Dorset, UK
      06-27-2014 05:41 PM #23
      Congratulations! It's a shame that this is a diversion, and the struts are yet to be sorted out!
      Chris
    24. Member
      Apr 4th, 2014
      Kuwait - NYC
      06-27-2014 05:46 PM #24
      Struts are next, hopefuly tomorrow.
      Salah
    25. Member
      Mar 22nd, 2009
      No. Virginia
      2006 Phaeton (sold), 2014 Audi A8 TDI, 2013 Jaguar XKR, 2011 VW CC, 2006 Passat, 2003 Passat
      06-30-2014 10:35 AM #25
      Salah:
      Could you explain what you did to get everything open - the trunk, hood, and gas tank filler cap? Have you had to recharge your batteries? There were so many suggestions that I would like to know exactly what worked in your case.
      Thank you,
      cai
