VWVortex.com - Autotech Feb. '05 Special of the Month: FREE SportTuned Brake Lines!!!
    Results 1 to 8 of 8
    Thread: Autotech Feb. '05 Special of the Month: FREE SportTuned Brake Lines!!!
    1. Former Advertiser
      Sep 26th, 2001
      02-04-2005 05:40 PM #1
      For the month of February, Autotech is offering a FREE set of SportTuned braided stainless steel brake lines for your VW when you purchase a set of Autotech front & rear drilled & slotted rotors with Mintex brake pads. Save up to $139.95!!! This offer is available to VWVortex enthusiasts only!
      Autotech manufactures the highest quality cross-drilled & slotted brake rotors for water-cooled Volkswagens. Cross-drilled & slotted rotors are an excellent way to increase the braking performance from your VW. We start with high quality German-made rotors manufactured by the identical suppliers that supply VW. Each rotor is then precision machined on a CNC machining center (NOT A DRILL PRESS). The hole patterns are designed to give optimum cooling, but do not sacrifice durability, nor do they significantly reduce swept area. Each hole is then radiused to prevent pad galling, and the radius depth is set to the rotor’s wear limit. Front rotors are slotted for improved gas venting and pad cleaning. Finally, a cadmium plating is applied to military standards.
      Autotech’s SportTuned Brake Lines feature billet stainless steel ends, instead of carbon steel ends used by most others. This exclusive design ensures corrosion-free performance. Everytime you brake, some of the mechanical energy put into the pedal is wasted expanding the stock rubber brake lines on your car. This causes a spongy brake pedal feel and loss of some initial braking power. Because Teflon hose wrapped in stainless steel braid does not expand like ordinary rubber hose, these lines provide quicker brake response and a firmer pedal. Autotech Sport Tuned Brake Lines are direct replacements for the original rubber hoses and do not require adaptors. ABSOLUTELY THE BEST AVAILABLE!
      To take advantage of this special offer, call us toll-free in the United States at 800.553.1055 or via fax at 949.240.0450. You can also contact us via email at ralph@autotech.com. Please mention that you saw this on VWVortex.
      EXAMPLES LISTED ARE REPRESENTATIVE ONLY & DOES NOT REPRESENT OUR COMPLETE APPLICATION LIST:
      A1/Mk1 16V
      AST Front 256mm (10.1”) Drilled & Slotted Rotor Kit w/ Mintex Pads $179.95
      AST Rear 226mm (8.9”) Drilled Rotor Kit w/ Mintex Pads $189.95
      AST SportTuned Brake Line Set (reg. $99.95) FREE!!!
      A2/Mk2 8V/16V
      AST Front 239mm (9.4”) Drilled & Slotted Rotor Kit w/ Mintex Pads $169.95
      A3/Mk3 VR6
      AST Front 288mm (11.3”) Drilled & Slotted Rotor Kit w/ Mintex Pads $229.95
      AST SportTuned Brake Line Set (reg. $139.95) FREE!!!
      A4/Mk4 1.8T/VR6
      AST Rear 232mm (9.1”) Drilled Rotor Kit w/ Mintex Pads $149.95
      AST SportTuned Brake Line Set (reg. $109.95) FREE!!!
      B5 Passat 1.8T/V6
      AST Rear 245mm (9.7”) Drilled Rotor Kit w/ Mintex Pads $149.95
      AST SportTuned Brake Line Set (reg. $69.95-$139.95) FREE!!!
      * - Offer ends 02/28/05 and is limited to stock on hand. Prices do not include shipping. Cannot be combined with any other offers, specials or discounts.
      Autotech Sport Tuning Corp.
      32240-E Paseo Adelanto
      San Juan Capistrano, CA 92675
      (800) 553-1055 toll free in USA
      (949) 240-4000 tel
      (949) 240-0450 fax
      http://www.autotech.com
    2. 02-24-2005 07:02 PM #2
      awesome deal [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 02-26-2005 12:36 AM #3
      it comes with break lines for the front and back???get back to me at Adaaam66@yahoo.com
    4. Member ubercruizinvr6's Avatar
      Jul 5th, 2002
      Orange County, SoCal
      98 GTI VR6s, 2011 GTI
      02-26-2005 02:24 AM #4
      from what the post says, yup, front and rear. some kits have 4 lines, some kits have 6 lines, but all the kits have enough lines for the front and rear. sounds like a good deal to me!
    5. 02-28-2005 11:48 AM #5
      what about the GLI and 337 brakes? any deals on them?
    6. 02-28-2005 02:15 PM #6
      You are more than welcome to get a free set of lines as well. We have both front and rear rotors and pads for your GLI/337.
      Thanks!
      -SC
    7. Former Advertiser
      Sep 26th, 2001
      02-28-2005 05:50 PM #7
      Quote, originally posted by 04 GLI »
      312mm (12.3") Drilled & Slotted Rotor Kit w/ Mintex Pads...$249.95
      Rear 256mm (10.1") Drilled Rotor Kit w/ Mintex Pads...$239.95
      4 pc. SportTuned Brake Line Set (reg. $109.95)...FREE
      You better hurry though, today is the last day to do the deal!
      Ralph
    8. Junior Member 88mm's Avatar
      Nov 3rd, 2003
      Omaha
      Old Cars: 88' GLI, 92' Corrado SLC, 95' GTI VR6, 02' GTI 1.8t
      03-06-2005 10:19 AM #8
      Man that is a sweeeeeeeeet DEAL. Sorry I missed it!
