Page 1 of 2 1 2 LastLast
Results 1 to 35 of 64
Thread: Losing coolant from your 2.0? Maybe its from here...
  1. Member tjm0852's Avatar
    Jun 10th, 2004
    Cortlandt Manor, NY
    '04 .:R32
    02-16-2005 09:45 AM #1
    I was having to put coolant in the overflow at least once every two weeks this winter, because of the flashing coolant light. I never found any coolant on the ground under my car and wasn't sure where it was coming from, until I looked and the coolant flange on the tranny side.
    The red arrows point to where you can see some of the coolant leaking. It was worse on the backside of the flange, but difficult to photograph. Before you remove any coolant hoses get something to catch the fluid. I used a 1 gallon water bottle and chopped the top off, you can crush it to sit nicely on the tranny.
    I remove the larger Coolant hose first and drained it into the plastic bottle. Do the same for the other coolant hose on the back of the flange. Remove the metal clips and pull out the old sensors one at a time and reinstall them into the new flange. Replace the old washers and clips. This is the sensor that faces the front of the car. The old clips are on the right, new ones of the left.
    Here is the sensor on the top of the flange. Again old clips and washer is on the right and new ones are on the left.
    You need to remove 3 nuts to free the flange once you have removed all the sensors and hoses. Then you need to wiggle off the metal bracket that attaches to the flange. Then you can remove the two bolts that hold the flange onto the motor. Here is what it looks like once you get he old one out.
    You can't really see the coolant leakage on the bottom part of this pic.
    Here is the new coolant flange with the sensors installed and clipped in.
    Here is the new flange installed.
    I changed the hose clamps from the pinch OEM VW type to regular screw type hose clamps. Then I recycled the coolant fluid back into the overflow. Here is the old coolant flange washer, you can see how flattened & crushed it is.
    Should fix my leaky coolant problem. Hope this helps others out.
    Rehosted pics....
    Modified by tjm0852 at 1:04 PM 4-9-2008
    Modified by tjm0852 at 1:08 PM 4-9-2008
  2. Banned
    Jun 18th, 2004
    02-16-2005 09:53 AM #2
    you did good up till the part when you recycled the coolant. Just replace it, its cheap enough.
    good right up tho
  3. 02-16-2005 10:07 AM #3
    nice DIY very detailed. nice work!
  4. Member
    Sep 12th, 2003
    Baltimore
    97 GTI / 95 Jetta
    02-16-2005 11:08 AM #4
    Good DIY dude, every 2.0 owner needs to know about this; those damn plastic flanges break faster than a first-time S&Mer.
    -Dave
  5. Senior Member ClockworkChad's Avatar
    Mar 21st, 2003
    CT
    Is300
    02-16-2005 11:12 AM #5
    another place to look for leaking coolant is on the side of the radiator, there are metal brackets on the side that become slightly loose over time, and in the colder weather the plastic shrinks, so there are leaks.
    I had this problem, my mechanic said its common with the a3's and its not really worth replacing because its a large expense for such a small leak.
    Ferrari Scuderia 2012 - "The people who speak badly about me then tremble and cry when they want to have their picture taken with me” - F. Alonso
    Now recruiting for IT/financial/accounting/creative services in fairfield county and metro nyc, pm if interested
  6. 05-22-2007 09:27 AM #6
    Thanks for the DIY, buddy.
  7. Member cartercdad's Avatar
    May 13th, 2006
    pot hole central or PA
    94. VW Golf- sold 01 durango R/T - totaled, 00 GTI VR6 picking up soon
    05-22-2007 09:41 AM #7
    i will tell you before anyone else. GET RID OF THAT GREEN STUFF!!! it will f up your motor. if you dont believe me. check out dan's DIY page. and then do a really good flush.
  8. 05-22-2007 10:34 AM #8
    Great DIY...if you add "To avoid warping or cracking your coolant flange during the install, tighten flange bolts a little at a time, DO NOT over torque (80 inch pounds)....it will be complete!
    96 Golf...Gone...But not forgotten..Great ride!
    2000 Passat GLX...Gone...But not forgotten either..have scars on my knuckles from all the "wrenching" to keep it on the road!
    2008 Rabbit S, VWsport springs/OEM shocks, GTI brakes all around, GTI rear swaybar...best balanced car I've had in a while!
  9. 04-09-2008 12:36 PM #9
    Does anybody have pictures of this DIY....I am having this problem and would really like to see what I'm looking for.
    Thanks
  10. Member hockeystar17mnj's Avatar
    May 30th, 2007
    Northern NJ
    2010 GTI
    04-09-2008 12:46 PM #10
    Quote, originally posted by cartercdad »
    Thats only if you MIX coolants, you can successfully use the evil green if you COMPLETELY flush the system.
    Garden State Euros Northern New Jersey Tri-State European Car Club
    Current: 2010 vw GTI
    mods: APR carbonio stage 1&2 intake, APR K04 flash, AWE turbo outlet pipe, B&B DP, Magnaflow catback, Diesel Geek shifter, APR 27mm Rear Sway bar, autotech dogbone insert,BSH recirc. catch can, Southbend Stage 3 clutch disk, K04!!
  11. Member tjm0852's Avatar
    Jun 10th, 2004
    Cortlandt Manor, NY
    '04 .:R32
    04-09-2008 12:46 PM #11
    I will upload and relink them now
    Friggin Hostdubs still causing me pain
  12. Member tjm0852's Avatar
    Jun 10th, 2004
    Cortlandt Manor, NY
    '04 .:R32
    04-09-2008 01:04 PM #12
    pics are back up
  13. Member tjm0852's Avatar
    Jun 10th, 2004
    Cortlandt Manor, NY
    '04 .:R32
    04-09-2008 01:06 PM #13
    Quote, originally posted by hockeystar17mnj »
    Correct, mine came with the evil green and I am too lazy to flush the whole system, so I am going to stick with it. It has not caused me any problems.
  14. 05-31-2008 11:55 PM #14
    I just did this flange on my 2.oL while I was "vs my ignition system".
    My original was cracked on the inside, facing the block. The gasket has blistered and about useless. New one at dealership was ~$20, with o-rings.
    Replacing it is only tricky due the accessory elements around it, and draining the coolant is a PITA.
    Coolant levels have stabilized for me since swapping it out.
    My block was not discolored it was dripping.
  15. Member ekulnoyl's Avatar
    Jan 27th, 2006
    Lewiston, ID
    2001 Audi A4 2.8 Quattro, 1978 Rabbit, 2007 Land Rover LR3
    06-01-2008 12:09 AM #15
    what is the actual name of this piece? my g/f car needs a new one because the plastic that holds the o-ring in broke and so the whole piece needs to be replaced...
    Quote, originally posted by tjm0852 »
  16. Member vwishndaetr's Avatar
    Aug 8th, 2006
    CNY
    96 Jetta
    06-01-2008 12:18 AM #16
    That should go under the category of coolant flange. Got mine from germanautoparts.com --> Great people.
    I also replaced this a little while ago. I was always losing coolant, never knew where, it was also a slow week, about a reservoir every 2 weeks. I almost thought that it was a bad head gasket, but there were no other signs to simulate such a phenomena. One day I was at a stop light and ridiculous amounts of smoke were coming from under the hood, I popped the hood and little do you know that flange took a crap. I chuckled, kept a close eye on the temp gauge and drove home. One hour later I was good as gold and the ever so slow coolant leak was gone.
  17. Member toasters's Avatar
    Sep 17th, 2001
    Livermore, CA
    2011 VW Golf TDI
    06-01-2008 03:30 AM #17
    i made this exact same discovery about a month or so ago. Was leaking coolant but couldn't figure out from where.....finally noticed some dried blue coolant underneath this flange. Got a new flange and new gasket....my old gasket was shot! Replaced and coolant is stable ever since!
    I fixed my small oil leak today! Replaced my valve cover gasket that was weeping oil. Now i'm leak free!
    Great DIY!
  18. 08-05-2008 08:49 PM #18
    What would the direct part number be if I went to the dealer? I cannot seem to find this at napa or autozone
  19. Member cartercdad's Avatar
    May 13th, 2006
    08-05-2008 08:53 PM #19
    http://faculty.ccp.edu/faculty...x.htm
    Please read the green coolant is very evil do not use it please
  20. Member DukeDKT442's Avatar
    Jun 9th, 2008
    Eastern LI
    1997 Jetta 2.0, 2009 Tiguan 2.0T, 2003 BMW 325i, 1986 Olds 442, 1984 GMC S-15
    08-05-2008 10:22 PM #20
    Just get it from the dealer. $8.25, with new O-rings and gasket. The entire inside of mine was chipped away where the gasket sets on the block side, previous owner used Permatex copper seal.
  21. Member radzero9's Avatar
    Aug 29th, 2005
    Long Island, NY
    06 Rabbit 5spd
    07-15-2009 08:26 PM #21
    Nice DIY, the metal "hook" bracket around the coolant flange makes it a pain in the arse to replace. I had to play around with it for awhile.
  22. Member yorkcountydub's Avatar
    Oct 13th, 2007
    YC and Sterling, VA Bend, OR
    96GtiVR6/03A4Avant
    07-15-2009 08:30 PM #22
    NIce DIY, only thing i would add would be to use some fine sandpaper and clean off the block where the new flange will be up against it.
  23. Member
    Dec 23rd, 2008
    CT
    07-15-2009 09:03 PM #23
    the coolant flange is a pretty common point for vrs to leak from as well
    just as easy to fix though
  24. Member Pineapplegti !'s Avatar
    Dec 17th, 2008
    Las Vegas NV
    McLaren SLR 722 GT.2012 Gti 2012 Tiguan ,93 miata/01 CHEVY SCSB/Turbo rail
    07-15-2009 09:12 PM #24
    Typical place.. it usually blows out the oring housing lol then it start leaking
    autocrats...
  25. Junior Member
    Nov 7th, 2008
    Providence, RI
    98 GTI VR6 97 GTI 2.0 02 Golf 2.0
    07-15-2009 10:01 PM #25
    Need to do this myself, you just made it about 100x easier for me now that i know what to do.
  26. Member brobs is back's Avatar
    Jan 22nd, 2008
    gravel pit, IA
    golfs on junior cupkits with a side of chalet sauce... jetta ecodiesel w/snailtrail
    07-15-2009 10:03 PM #26
    put your cup under it. free drink!
    Quote Originally Posted by Paul Harley
    yo, is that a wolf?
    MODS IN THE SIG: MY MODS IS IN THE SIG!
  27. 09-01-2010 01:17 PM #27
    What is the best way to get the circlips that hold the sensors in back onto the coolant flange? The replacement coolant flange I got from GAP had crappy plastic ones that broke immediately, so I was stuck using the old rusted clips. I had to bend them to get them to fit back onto the coolant flange. Is there some special VW tool I need for this job?
    Awesome DIY writeup BTW!
  28. 09-01-2010 01:30 PM #28
    Uh, my coolant is neither purple green or blue..its orange. should i flush the thing out and buy some decent coolant?
  29. Member dumpedmk3's Avatar
    Nov 3rd, 2008
    Florida
    Muddy Ranger, LC3T mk3, Donk b5.5
    09-01-2010 01:40 PM #29
    hah, well it's a: rust or b: you have dex cool in there.
    If you flush it, make sure to flush it very well, as g12/g11/g12+ all like to turn into goo when they meet the green ****.
    Any one else notice this thread is from 2005?
    Quote Originally Posted by pillows View Post
    yarr matey me pirate flag license plate be troublin to the sailors on the road, i be havin the same problems as ye
    .:LOWECLASS:. BUY MY STUFF!
  30. Junior Member tsais's Avatar
    Aug 8th, 2010
    Blue Springs, MO
    '98 MK3 "K2"
    09-01-2010 02:07 PM #30
    Excellent information. I feel safe driving my '98 K2 with all the help I can get here on this forum.
  31. Member J3TTA 2.0's Avatar
    Aug 10th, 2009
    East Brunswick, NJ
    1997 Jetta 2.sl0w
    03-04-2011 02:11 AM #31
    I thought all vw's took the pink coolant
  32. Member LG6R's Avatar
    Oct 20th, 2003
    roadtrip mk3
    03-04-2011 02:18 AM #32
    Quote Originally Posted by J3TTA 2.0 View Post
    Well let's see-
    They used blue coolant (G11) on earlier mk3's up until 95 or maybe 96.
    They used pink coolant (G12) on later mk3's
    They used purple coolant (G12+) on mk4's
    Or you can use orange coolant (Dexcool) which is safe for aluminum parts and easier (and cheaper) to get. That's what I use. You really shouldn't be using the green stuff though.
  33. Banned
    May 15th, 2006
    PNW
    Jettas.. Dodge Cummins, 1985 Trans Am,
    03-04-2011 02:19 AM #33
    You really, really, really, need to flush that system and refill with G12
  34. Member LG6R's Avatar
    Oct 20th, 2003
    roadtrip mk3
    03-04-2011 02:30 AM #34
    Quote Originally Posted by dimbulb View Post
    That was 6 years ago dude. He doesn't even have a mk3 anymore.
  35. Banned
    May 15th, 2006
    PNW
    03-04-2011 02:40 AM #35
    Quote Originally Posted by LG6R View Post
    Tell Me "Dude" does the fact that the OP no longer owns the vehicle make my statement less
    valid?
    You, my friend, are a victim of disorganized thinking
