Closed Thread
Results 1 to 16 of 16
Thread: *** The MKIV How-To, FAQ, and Do-It-Yourself Guide - Please consult before posting***
  1. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:37 PM #1
    Welcome to the MKIV Do-It-Yourself, How-To and Frequently Asked Question Thread.This thread has step-by-step instructionals, links to helpful sites, and useful threads pertaining to many of the most commonly asked questions here in the MKIV section of VWVortex. This thread should be used in conjunction with the New User Guide to the MKIV Forum which deals with common questions about the forums and the forum software, such as
    -Picture posting and hosting
    -Forum Rules
    -User Ratings
    -Forum Help
    -Search tips
    -Forum Navigation
    -Moderation and Moderators
    Don't forget our Technical Forums that are broken down into more specific sections like interior, car audio and electronics, specific engines, transmissions etc.
    If you have anything that you would like to contribute to this list, or to report broken links, please use the report post to moderator function. Feedback is appreciated.
    To search within this thread, please press Control F or Open Apple F on your keyboard. (Note: Just because nothing is returned does not mean that it is not here, your search term may not be used in the description). Many items and issues may fit into all categories, so it is best to spend a couple minutes looking through the whole thread.
    The most repeated topic ever:
    1.8T vs. VR6
    Sections
    Exterior - Bodykits, Bumpers, Side skirts, Valances, Badges, Front End Conversions, Wipers, Mirrors, Windows, Sunroof
    Exterior Lighting - Headlights, Tailights, turn signals, side markers
    Interior - Rattles, squeaks, shift knobs, steering wheels, trim kits, gauge clusters, gauges, seats, alarm, heating and A/C, interior disassembly, interior lighting
    Interior Electronics - Audio/Video, Subwoofers, Radar Detectors, MP3 Players, GPS, Keyfobs, Alarm modifications, window controllers, cruise control
    Suspension - Shocks, Springs, Coilovers, Swaybars, Strutbars, Stressbars
    Wheel and Tire
    Brakes - Calipers, carriers, rotors, pads, brake light switch
    Transmission - Automatic and Manual, Starter
    Drivetrain - Items/Issues that are common across drivetrains (Engine/Transmission). Fault codes, coilpacks, 02 sensors, EDL and ASR, Oil, battery, engine mounts, bushings, bearings and hubs, axles, fuel filter.
    Intake and Exhaust - Cold Air Intakes, airboxes, CAI's, filters, exhaust systems and components
    VR6 - 12v (174hp) and 24v (200hp) VR6's
    1.8T - 150hp and 180hp versions of the 1.8t.
    2.0 - 2.0L Engine
    TDI - 90 HP and 110 HP Diesels
    General - Frequently Asked Questions and things that do not fit into a specific category - Fuses, Recalls, Color Registries, Abbreviations, How to jack up a mkiv.
    Troubleshooting MKIV Issues. - Problems with your car? This is a good place to start.
    The old FAQ can be found here.
    Archive of DIY threads as PDF.
  2. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:39 PM #2
    Exterior
    The Bodywork/Styling/Kits Forum General discussion of bodykits, exterior styling, bodywork techniques, products, and methods.
    Paint / Prep / Filling / Molding specifically for the MK4 commonly touched up areas.
    Jetta/Golf Front End Conversions Exploit VW's platform sharing by swapping front ends to get a Getta, a Jolf, or a JTI. Questions via archived threads #1 #2 #3
    Front End Swap Database Use this database if you are looking to swap front ends. *ALL front end swap wanted threads should be posted in the correct REGIONAL forum, if not they will be moved.
    Front end swap podcast Video of how to swap front ends.
    OEM Front Bumper post All you ever wanted to know about OEM front bumpers, including European and R32 fronts, valances, rubstrips, and how to remove front bumpers, valances and rubstrips. Putting Jetta parts on Golfs and vice versa. Jetta and Golf/GTI.
    Front Bumper Options for GTI's and Golfs Plus where to get them.
    Removing a front Bumper/Grille How to remove your front bumper, Golf/GTI and Jetta. (Includes Grille)
    Front Bumper Removal Another front bumper/grille removal. Applicable to Jetta/Golf/GTI
    Front Bumper Removal Video
    Removing a rear Bumper How to remove your rear bumper, Golf/ GTI and Jetta.
    Fitting a GLI lip to a GTi/Golf European Front bumper Much easier than fitting it to a North American Bumper (requires cutting/molding)
    OEM Body Kit Part Numbers Part numbers for 337/20ae/25ae/gli/r32/rline body kit pieces (you can not order euopean parts through North American dealers).
    Aftermarket Jetta Grilles Aftermarket Grille options for the Jetta.
    DIY - non-sag Badgeless Grill - Solve the "sagging badgeless grill" problem
    DIY - Non-Sag Bonrath Grille
    The Jetta BodyKit thread Lots of different Jetta bodykit options in one place.
    The Side skirt thread Side skirt options for the MKIV. (Pretty much all skirts will fit Golfs/GTI's and Jettas).
    Sideskirt Install Done with OEM sideskirts, but process can be used for ANY sideskirt.
    Jetta Rear Window Spoiler Options All of the options for a Jetta rear window spoiler in one place.
    Part Numbers for Drivers Side door lock delete parts Make your car more theft resistant (use the door lock module write up for removal/installation).
    Custom Boser Thread Pictures of custom boser hoods.
    Mesh Lower Front Grilles #1 DIY mesh front grilles.
    Mesh Lower Front Grilles #2 Another DIY Mesh front grille how to.
    Audi Style lower Center Grille Get the chrome look for your lower center grille.
    Painting factory valances How to color match your factory lower valances.
    Golf/GTI 4-motion rear valance install Install a 4-motion rear valance with exhaust tip cutouts.
    Stock Rear valance mod Modify your stock rear valance for exhaust tips.
    Debadging How to remove the badges from the rear of your car for a smoother look.
    Jetta Rear Emblem disassembly/painting/brushing Applicable to Golfs
    Removing the leftover adhesive after debaging Getting rid of the adhesive residue left over after you debadge.
    Painting your Emblems How to paint rear or front emblems the color of your choice.
    Blacking out B-Pillars How to black out the b pillar section between the front and rear side windows.
    Black Emblems How to black out your emblems.
    Shaved Engine Bays Pictures and Discussion
    Shaved Jetta trunk DIY - courtesy of tscbmxer92
    Front Single Wiper Conversion Attain the DTM look with a single front wiper.
    Audi Avant Rear wiper with rotating sprayer Reftrofit an Audi Wagon rear wiper to your Golf/GTI and make the rotating sprayer function work.
    Replacing aero wiper blades How to replace the blades on your aero wipers less expensively.
    5.5l Windshield washer resevoir upgrade Install the higher capacity european w/w fluid resevoir.
    Wiper Linkage Repair Fix your slow/dead front wipers.
    Hummer H2 antenna Use a shorter H2 antenna on your car.
    Removing/Deleting Rear Wiper How to remove your rear wiper for that clean look
    Installing Stubby Mirrors
    Power Folding Mirrors Retrofit power folding mirrors like available overseas
    Mirror Cap Removal DIY to remove mirror caps
    Roof Rack installation Working with a VW/Thule roof rack.
    Roof Rack Thread All you ever wanted to know about roof racks for MKIVs.
    3M Clear Bra Protective Strips for Roof Rack feet Protect the area where your roof rack feet sit on the roof
    How to remove window tint Got a fix-it ticket? Need to get rid of window tint? This is what you need.
    Window Regulators Did your window drop into the door, will it not roll up? Is it making funny noises? Did you hear something snap? This thread has everything you need to know about this rampant problem. You should always contact your dealer first regarding this issue, as there is an extended warranty.
    Replacing Front Window Clips/Door lock module Did you window fall into the door? Need to replace your regulator clips?
    Window Regulator Fix How to fix them yourself.
    Replacing Sunshade slides/clips Is it hard to push back your shunshade (sunroof cover)? Problems sunroof closing?
    1999.5 to 2004 Paint Codes OEM Paint Codes for most MKIV's.
    How to Polish Aluminium/Stainless
    DIY: Brushed Aluminum-Look Mirrors
    DIY: Removing the front end and bringing the "lock carrier" to the service position - Shows how to remove the front end so that you can move the "lock carrier" (which has the radiator and A/C condensor attached to it) forward for better access to the front of the engine and attached accessories.
    Installing TT Jack Pads Add the OEM jack pads from an Audi TT to your car to make it easier to jack up and down.
    DIY: Installing the Hidden Hitch Model #60963 - These instructions are for installing this model trailer hitch in your Volkswagen Jetta. The car pictured is a 2003 Jetta GL 1.8T.
    Modified by dashrendar at 2:45 PM 10-31-2008
    Modified by Mr. Rictus at 11:13 AM 4-2-2010
    Modified by Mr. Rictus at 11:14 AM 4-2-2010
  3. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:40 PM #3
    Exterior Lighting
    The Lighting Forum Discussion of general lighting issues, trends, products, and reviews (not MKIV Specific)
    MKIV Front bulb List Covers Golfs, GTIs and Jettas, High Beams, Low Beams, Turn Signals, City Lighs, Side Markers and Fender Markers.
    Exterior Bulb Listing w/ Pictures by GT17V
    OEM VW Sidemarker part numbers - compilied by diive4sho.
    MKIVHeadlight Bulb Change Discusses replacing all the bulbs in your headlight. Shown on a Jetta, Golf/GTI is the exact same but different bulbs.
    Golf/GTI Headlight removal (Jetta too) How to remove the front bumper in order to remove the headlights (easiest, but not shortest way to change bulbs). Process is the same for a Jetta, the parts just have a different shape (lights, bumper, grille, etc.).
    Detailed Jetta E-code Headlight Install Howto
    Golf/GTI Tailight removal How to remove your rear taillights.
    Golf/GTI Tailight Options Collection of OEM and Aftermarket Golf/GTI Tails.
    Jetta Tailight OptionsCollection of OEM and Aftermarket Jetta tails.
    Side Marker (Bumper) Light Removal How to remove your sidemarkers. Applies to all MKIV's.
    Side Repeater (Fender) Light Removal How to remove your turn signal repeaters. Applies to all MKIV's.
    Side Marker and Fender Repeater Removal
    Aiming Headlights How to aim your headlights.
    DIY LED Fender Repeaters Convert your fender repeaters to LEDs. Also good for removal and installation of stock side repeaters.
    DIY LED Tailights Convert your existing tails to led elements.
    Front turn signal/parking light replacement Can be used for Jettas, Golfs, and GTIs, helpful when replacing any bulb in the main cluster (low beam, high beam, city light...)
    Swapping front amber signal lenses for clean lenses Switch from the late style early amber turn signal lenses in the headlights, to the early style clear lenses. (Golf/GTI and Jetta)
    Part Number for VW Repair Wire Needed for rear and front fog installs, 5 brake light mod, etc.
    Cleaning/Polishing "Foggy" Headlights
    Reverse light switch install Replace a malfunctioning reverse light switch
    Replacing the Brake Light Switch If your Brake Lights stay on, do not come on, your cruise control has stopped working or any combination of the above, your brake light switch is faulty. They are currently on recall, check with your dealer first.
    Adjusting headlight aim/height Adjusting the height of your headlight sot compensate for a drop, etc. Process is the same for Jettas and Golfs/GTIs, the parts just have different shapes (lights, bumper, grille, etc.).
    Removing the haze from headlight covers Wetsand and polish your headlights to get clear them up.
    Hella DE Fog Light Install for Golfs (Jettas) Installation of Hella DE fog light kit into lower grilles of a Golf/GTI, can also be helpful for the Jetta kit, discusses basic relay function and wiring.
    Another Great Fog Wiring Thread
    Wiring of OEM Headlights w/Fogs How to wire OEM headlights with fogs into a car that did not originally come with them. Process is the same for a Jetta, the parts just have a different shape (lights, bumper, grille, etc.). For headlight removal and installation, use of of the above how-tos.
    DIY: Fog Lights on with your High Beams by tim00jti
    Adding OEM Fog lights to a car that did not originally have them Diagrams and pictures needed for wiring OEM fogs to a car not wired from the factory for them. Can be used for all body styles.
    Wiring aftermarket Foglights to a euroswtich How to wire foglights of your choice to a euroswitch, useful for any foglight install.
    Rear Fog Light wiring How to bring european style rear foglight functionality to your MKIV.
    ECS fog light wiring problem solved! FOG LIGHTS NOT WORKING? TRY THIS. by dahui9 and T-Rod2050
    Rear fog and 5-brake light wiring for Jetta Enables 5 brakes lights when brakes are applied or just the activation of the rear fog light.
    Wiring Up the instrument cluster rear fog icon Only applicable to the early MKIV's, bring the rear fog icon functionality to your MKIV.
    City Lights as DRLs (.doc) How to wire up your city lights to act as your Daytime Running Lights.
    Disabling DRLs How to disable you Daytime Running Lights
    Turn signals as DRLs How to wire your stock headlights to use the turn signals as DRLs instead of main lights.
    Jetta Low Beams with High beams How To jumper your lights so that your low beams stay on with your high beams.
    What does an Euroswitch do?
    Adding a turnsignal Comfort Module (3 flashes)
    DIY: Change the DRL's on a Jetta
    Joey Mod (Blacked out Headlights) How to black out your headlights (or paint them any other color you wish). Process is the same for Jettas and Golfs/GTIs, the parts just have different shapes (lights, bumper, grille, etc.). Another, More
    Tinting Your Tailights General procedures for tinting your own tailights
    "Golf Estate Variant" Tailights for your Jetta Wagon Installing the European Golf Wagon tails in your Jetta Wagon for a different look.
    Jetta/Bora Tailight Options Tailight (OEM and Aftermarket) for your Jetta Sedan.
    Auto Leveling for OEM HIDS Installion of Automatic headlight leveling motors and sensors.
    OEM HID Harness assembly Make your own harness adapter for the installation of OEM HIDs. Applicable to Jettas and Golfs/GTIs.
    HID Leveling Motor Wiring How to wire up the OEM HID leveling motors. Applicable to Jettas and Golfs/GTIs.
    HID Rheostat (Leveling switch) installation and Wiring Install the manual leveling switch (your headlights need to have the leveling motors for this to work). Applicable to Jettas and Golfs/GTIs.
    MKIV Jetta FK Projectors + HID DIY Install Instructions Modifying MKIV Jetta FK projector headlights to accept HID's
    How to Wire Depo Angel Eye Headlights / MkIV Jetta (others might find useful info)
    DIY / Review: Helix Replica Jetta OEM HID Projectors
    HID Projector Retrofit Overview, by BrunoVdub Jetta HID Retrofit Info
    Golf & Jetta HID Headlight Retrofit DIY(If I may) - DIY Retrofitting
    HID RetrofitAnother HID Retrofit part II
    DIY: Trunk harness fix - license plate lights no working
    S5 Style Headlight DIY
    DIY: HIDs Install Instructions (without the crap)
    DIY: Polishing Your Headlights
    Modified by rs4-380 at 9:48 AM 7-27-2009
    Modified by Mr. Rictus at 10:14 AM 8-26-2009
  4. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:42 PM #4
    Interior
    -For the most part all the interior installs are common across models and trim lines.
    Rattles, squeaks, shift knobs, steering wheels, trim kits, gauge clusters, gauges, seats, alarm, heating and A/C, interior disassembly, interior lighting, mirror switches
    Interior Forum Discussion of general interior issues, seating, lighting, materials, products, etc. Not MKIV specific.
    Door Rattle fix Fix that pesky door rattle.
    Squeaky door seal fix Fix your squeaky door seals.
    Squeaks and Rattles thread Discuss solutions to interior squeaks and rattles (it's a VW, get used to it!).
    Recovering Your Door Cards
    Rieger Illuminated Shift Knob Install
    Momo Shift knob and SCR adapter How to install a momo shift know and SCR adapter. Also details hoe to remove your stock shift knob (manual tranny).
    Putting a leather shift boot on an Automatic shifter Make your auto look like a manual.
    Putting an OEM shift knob on a B&M short shifter DIY: OEM shift knob on a B&M short shifter
    Glen Gauge Mod :: Painting your gauge cluster faces.
    Instrument Clusters Everything regarding instrument clusters, MFA's, European clusters etc.
    How to paint your interior pieces
    W8 Overhead console install and wiring Install the Passat W8 overhead console which includes red ambient lighting for the center console.
    W8 Overhead Console Accessory Lighting W8 lighting without spending the money on a new overhead console.
    W8 Console additional information Another useful thread on the W8 console install.
    W8 Console Install With part numbers.
    OEM Overhead Panel Upgrade Add LEDs to your existing overhead console for a W8 console look without the W8 console price.
    Aluminum Gauge Ring Install Add aluminum rings to your older MKIV instrument cluster
    Interior Makeover Installing OEM Interior Trim Kits, Door Pins, Door Lock LED's, Footwell Neons.
    Brushed Aluminum Dashkit Install How to install a PICI dashkit (can be applied to others).
    Part Numbers for OEM trim Add OEM wood, metal, Carbon fiber, etc. interior trim to your car.
    Home Depot Aluminum Door Sills Inexpensive Do-It-Yourself door sills.
    OEM Black Interior Trim/Headliner part numbers and pictures Part numbers for OEM black interior trim (ala 20AE GTI's).
    Black Headliner in a can-mod/Removing the headliner Get around the expensive and hard to find OEM black headliner by converting your existing one.
    Suede headliner
    Removing the sunvisor clips Useful for when you are removing the headliner.
    Sunvisor/Vanity Mirror LightRemoval and replacement of bulb
    Fix your peeling rubber trim Deal with peeling rubber coating on door handles and pulls.
    Recovering Door Cards Recover your door cars with whatever you want (removal instructions above)
    How to turn Chrome interior trim into Brushed Aluminum Look
    Complete Interior Swap / Color Change
    Exchanging Floor mat clips
    Audi mirror with hidden compass and on / off install
    Air/Fuel Gauge Install How to install an Air/Fuel ratio gauge.
    Boost Gauge Install How to install a Boost gauge.
    Oil Pressure and Temperature Gauge (sender) installs General idea/locations can be used no matter what the brand of gauge/sender
    Boost gauge Install How to Install a Boost gauge.
    42 Draft A-Pillar Pod Install Useful for any A-Pillar gauge pod install as well as removing the a-pillar trim
    Adding a gauge to the overhead console/sunroof motor cover
    A Pillar Pod Install
    European Sport FIS Cluster Install How to install the European sport FIS cluster in a car that previously had an MFA (useful to all instrument cluster installs and removals).
    Where to find the tach singal Finding the tach signal wire for turbo timer, tachometer, and other electronic devices that need it.
    Interior Hardwiring For ALL Gauges and more How to hardwire anything inside the car. Gauges, Radar Detectors, Neon Lights, Boost Pressure, Ipod 12V Dimmer. Also includes wire routing through the firewall.
    Removing interior parts (e-brake & center console, armrest, glovebox, ashtrays)
    Removing interior parts II (dash trim, brake light switch, radio, cupholder, radio/ HVAC cage)
    Removing rear door parts (door panel, door unlock handle and rusty triangle window insert)
    Removing front door parts (door panel, door unlock handle and sideview mirror)
    Replacing trunk microswitch on MKIV Jetta (may apply to Golf/GTI as well)
    Removing and Replacing Glove-Box Door If your glovebox door hinge is broken, this is for you.
    Removing Glove Box Latch/handle/Lock
    Glove box difference by model year They do exist
    Glove box difference by model year #2(part number and lighting issues addressed).
    Removing Jetta Rear Deck-Lid (Parcel Shelf).
    Removal of OEM steering wheels Process for removing ANY OEM steering wheel.
    Steering Wheel and wiper/turn signal stalk removal Remove your steering wheel and/or either of your control stalks.
    Turn Signal's Stuck On? Wiring fix to correct constant on turn signals after using the remote to lock/unlock doors.
    Door Pin Removal How to remove and install the interior door lock pins.
    Front and Read seat removal and installation
    Upgrade to the Center Console w/ Cupholders Convert an earlier car to the later style in-console cupholders.
    Center Console Swap #2 Another version of above.
    Eliminating the front armrest Replace your front arm rest with the GL coin pocket.
    Floppy Arm Rest Fix
    Cleaning a Sticky Cup Holder
    MKV Jetta shopping bag hook How to add this to your MKIV Jetta trunk.
    Broken Glove Box hinge...?...DIY for repairing that ever-so-common broken glove box hinge.
    DIY MKIV Seat Swap & Restoration/Cleaning (Recaro Content)
    Neon Trunk Light Install Add neon lighting to your trunk (procedure can be applied to Golfs/GTIs).
    Neons in Footwell connected to headlight switch Add neon lighting of your color choice to your footwells and have it turn on with your exterior lights.
    Cold Cathode Trunk Lighting Want your trunk lights to be brighter? Check this out.
    42nd Draft Interior LED Install Install LED's in all the interior dome lights.
    Removing Rear Seats How to remove your rear seat bottoms and backs.
    Rear Seat Delete Options - For weight reduction
    More Rear Seat Delete Options - A collection of many rear seat delete setups
    Air Bag Related Part #'s and Connectors for swapping newer seats in older cars
    Removing Front Seats Removing front seats and side airbag issues.
    Airbag resistors when using aftermarket seats The proper resistors to wire into the front airbag harnesses when using aftermarket seats to take care of the airbag warning light.
    Airbag resistors for aftermarket seats Another thread with resisotr info for getting rid of the airbag light.
    Seat Heater Temp sensor repair How to fix a likely problem in the heated seat system.
    Adding heated seats to a non heated seat car Toasty on cold mornings.
    Changing the harness for the airbags in the seats (euro recaro, applies to stock seats too)
    Alarm not arming First thing to check if your alarm will not arm is that your doors are all shut, as well as your trunk/hatch and your hood. In addition any OEM radio needs to be fully seated in it's mounting cage (push it in).
    Door Lock Module Dissection and Replacement If you have problems with door locks, alarm arming, etc. your door lock module could be at fault.
    Door Lock Module Removal How to get to the DLM in order to dissect it.
    Rear Hatch Actuator Removal/Replacement For Golfs/GTI's
    Comfort Control Module Location How to get to the CCM which controls many of the interior functions of the car.
    Manual HVAC Bulb Replacement If your heating and A/C console no longer lights up at night or if it flickers your bulb is blown or dying, this thread discusses replacement.
    Climatronic swap discussion Discussion and feasibility of insalling Automatic Climate Control in a Manual Climate Control car. More.
    Swapping Jetta Vents into a GTI/Golf Swap the lighted "shutter" style Jetta vents into a hatchback.
    B5 Mirror switch Install a passat mirror switch in your MKIV.
    Replacing the Pollen (Cabin) filter How to replace the cabin filter, recommend change every 40k miles.
    Have a water leak? MKIV sunroof drain locations.
    Repairing Golf and GTI Rear Sunroof Drains How to repair rear sunroof drains that are leaking water into the interior of the vehicle.
    Repairing Sunroof Drains Another DIY on this common problem.
    DIY for Airbag decal removal from sunvisors
    Repairing Peeling Center Console Material
    Modified by rs4-380 at 5:07 PM 11-1-2009
  5. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:43 PM #5
    Car Audio and Electronics Forum General discussion of all car audio, video, and electronics products, issues, installs, and trends.
    How to route wires through the firewall/cowl Need to run power wires for an amp? Maybe trip wires for foglights? This shows you a good path for getting through the firewall.
    Interior Hardwiring How to hardwire anything inside the car. Gauges, Radar Detectors, Neon Lights, Boost Pressure, Ipod 12V Dimmer. Also includes wire routing through the firewall.
    Double Din Wiring Fix Does your Double-Din (~2002.5+) headunit sound bad? Many were incorrectly wired from the factory.
    Blaupunkt Single Din Radio Install Questions about installing a Blaupunkt headunit, can be useful for other aftermarket units and double-dins as well.
    How to install a new antenna base This requires dropping the headliner, which is covered in this write-up.
    How to Remove a Stuck CD From Your Monsoon/DoubleDin/Premium6 HeadunitProcedure for removing and disassembling the headunit in response to CDP Error 1&3/stuck cd.
    Aftermarket radio compatibility with VagCom, VAG 1551/1552 and OBD II Scanners (K-line) All about the k-line issue (aftermarket radios) and how to deal with it. K-wire, k wire, k line.
    Monsoon Subwoofer Add-On Add a subwoofer to your OEM Monsoon sound system.
    Double Din Monsoon Sub and Amplifier Guide Installing a sub and/or an amplifier onto a double-din system. Can also be useful for single din/non-monsoon systems.
    Valentine 1 Radar detector hard wire Hard wire a V1 to your car. Can be useful for other Radar Detector installs.
    Escort Passport Radar detector hard wire Hard wire an Escort to your car. Can be useful for other Radar Detector installs.
    IPod user guide for MKIV's Everything you wanted to know about IPods and MKIV's[/url]
    IPod in the armrest install Take your install a step beyond just tossing the Ipod in the armrest.
    MP3 Player Mount How to install and MP3 player mount, can also be used for cell phone, PDA, GPS holders etc.
    PhatBox Install How to install and wire a PhatBox (MP3 storage device) in a MKIV.
    IPod Integration Integrating an Ipod using a blitzsafe adapter and Blaupunkt HU. Can be used/useful for installs using other adpaters and headunits including stock.
    Aftermarket Speaker install Replacing your stock speakers with aftermarket units.
    Alarm Shock Sensor Add-in Add a shock sensor to the factory alarm system.
    Install Alarm LED's onto both doors / Change LED color Add an alarm LED to the passenger door as well as the driver door, also deals with changing LED colors.
    Car Alarm Horn DIY Hate the horn alarm chirp that sounds when you lock the car and the alarm activates? Change the horn and sound using this DIY.
    Guide to Keyfob replacement and programming What you need to know about replacing a keyfob (remote).
    How to program a new key Information on programming a new key.
    Increasing Keyfob range How to increase your Keyfob range (works better than holding it under your chin).
    "Turbo" Key Mod Add a turbo emblem to your keyfob.
    Replacing the battery in your key
    Alientech Install Guide How To install the Alientech window controller[/url] Add a circuit board that leverages the built in features of you car to roll up and down the windows with the remote.
    Hella Horn Install How to make the stock horn louder by installing Hella Air Horns.
    DIY: Disable Factory Alarm Horn
    Push Button Engine Start Add push button ignition to your MKIV.
    Camera Mounts Want to shoot cool videos? You'll need one of these.
    Key Fob Immobilizer Swap
    Another Key Fob Swap DIY
    Broken Key Fob Key Chain Fix
    DIY: Key Fob Immobilizer Swap (yes, it can be done)
    Cruise Control Install Install factory cruise on a car not otherwise equipped
    LED Project #2 DIY - MKIV Instrument Cluster Upgrade Incredible DIY for adding LEDs to the speedo and tach that sweep with the gauge needles
    D.I.Y. Fiberglass sub enclosure made easy DIY that explains how to build a fiberglass subwoofer enclosure for you trunk.
    DIY: Installing speakers in a mk4 golf/jetta - pwnt by pat
  6. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:45 PM #6
    Suspension
    Issues and Discussion
    General discussion on lowering Lowering for looks vs. lowering for handling,
    the incorrect assumptions often made, lower does not always equal better, vehicle dynamics, etc.
    The "LOW" thread Pictures and wheel well measurements of cars considered "low" along with what suspension and wheel/tire combo yielded it.
    How does a swaybar work? What does a sway bar do? How does it help or hinder a car, how does it affect understeer and oversteer?
    The Suspension Tuning Forum Discusssion of suspension tuning (lowering, swaybars, strutbars, springs, shocks, coilovers).
    Oversteer vs. Understeer Always wondered the difference? Why are FWD cars associated with understeer and RWD cars associated with oversteer?
    MKIV Suspension Geometry Thread Why a majority of the time lowering a MKIV gains you more in looks than it does in handling.
    MKIV Rear Swaybar List List of rear sways for the MKIV.
    Coilovers vs. Springs and Dampers Can a spring and damper setup compete with coilovers? Can coilovers compete with a spring and damper setup?
    The Damper Thread How they work, what they do. Excellent general thread, but has a MKIV-centric view. You should read this thread if you consider yourself a car person.
    MKIV Guide to Camber and Alignments What it is, what it does, and why we can't adjust it (Covers Front and Rear). Deals with why you can't perform a four wheel alignment on a MKIV.
    Alignment Specs General alignment specs for MKIV's (there are variations, but all MKIV chassis cars should be within these ranges).
    Coilover List
    Can I just put lowering springs on my stock dampers/shocks/strut? It's not as easy as yes or not, but in the end, it's better to do it right the first time, read about the pro's and con's here.
    Can I put a VR6 suspension on a 1.8t and vice versa? 2.0 and TDI? GTI and Jetta? Why there is nothing technically wrong with "mixing" suspensions.
    Spring height comparison between OEM, OEM "Sport" and Eibach Pro-Kit springs
    How To's
    **Notice - The process for changing the suspension for any MKIV platform car is fundamentally the same. Therefore it does not matter if you are installing just springs, a cup kit, coilovers, a stock suspension, and if you are installing it on a Jetta, a Golf, a Wagon, a GTI, a 2.0, a TDI, a 1.8t or a VR6. Any suspension how-to is applicable. The same is generally true for swaybars and strutbars as well.
    Diagram of Front Suspension
    Shock and Spring Install General Shock and Spring Install.
    H&R Coilover Install Coilover Install.
    Bistein PSS9 Coilover Install Coilover Install.
    Eibach Spring Install Spring install.
    Shine Real Street Suspension Install Spring and shock install.
    Replacing the front strut mounts/bushings without a spring compressor
    Autotech front swaybar installation Front Swaybar Install (PDF)
    Replacing/Lubricating front swaybar bushings Do you have a front end creak over bumps? Want to replace your front swaybar bushings?
    Autotech Rear Swaybar Install Rear Swaybar Install
    Neuspeed Rear Swaybar Install Rear Swaybar Install
    Do I need a new front sway when changing my suspension? Find out if you may have axle clearance problems with a lowered suspension.
    Which Way do I move my endlinks on my adjustable swaybar? Discusses which direction to move your endlinks in order to adjust the stiffness of an adjustable rear bar.
    How to replace the rear axle bushing on a MKIV Have an older MKIV and hearing noises come from the rear suspension? You might want to check this out.
    Autotech Front Upper Stressbar Install Front Upper Stress/Strut Install.
    Neuspeed Front Upper Strut Install Front Upper Stress/Strut Install.
    Autotech Front Lower Stressbar Install Front Lower Stress/Strut Install.
    How to lower koni coilovers more in the rear When all the way down just isn't low enough. The strategy of removing the perches is applicable to ALL brands of coilovers.
    Modified by rs4-380 at 6:49 PM 8-30-2008
  7. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:46 PM #7
    Wheel and Tire
    Correct procedure for jacking up a car (jackstands, etc).
    Wheel/Tire Database - Has pictures of dozens of MKIV wheel/tire and suspension combinations.
    Pitting on Wolfsburg Wheels - Discussion about pitting, discolored, and peeling BBS RXII's used on Wolfsburg Edition Jettas.
    Peeling wheel petition for MKIV's - Discussion about peeling, discolored and peeling wheels on all MKIV cars.
    Wheel Weights - Outside thread with listing of many Aftermarket wheel weights.
    FAQ: Wheel Tech - General information on wheel specs including Offset, Bolt Pattern, Center Bore, Backspacing, Diameter and Width.
    FAQ: Tire Tech - General information tire specs including plus sizing, speed ratings, deciphering the sidewall ratings (ex. 225/45-17H).
    Wheel Bolt Pattern and Offset, Spacers, Bolts, etc - Information on acceptable MKIV Bolt Patterns and Offset, Hub Bore, Wheel Bolt type (conical and ball seat), spacers, adapters etc.
    Stock tire sizes - Recommended tire sizes (15" - 19" wheels) to keep you speedmeter as accurate as possible. Including why moving from a 15" wheel to an 18" can not affect the speedometer.
    The spacer thread - How to choose the correct size of spacers for your desired look.
    Using Flat 8mm Spacers with aftermarket wheels - Discusses the issue and solution for using lipless 8mm spacers with wheels that use centering rings.
    Offset Calculator - See how a different wheel width/ offset will affect your tire position.
    Tire & Wheel size calculator - Use this to see how different wheel and tire sizes will affect your speedomter readings, or to just compare two different sized setups.
    The Stretched Tire Thread - The hows and whys of poking and stretching.
    DIY for wheel polishing
    Gallery of VW OEM Wheels - Many pictures and names of OEM wheels and rims.
    Rim refinishing through painting
    Wheel Repair/Refinishing
    Wheel Lock key search (DIY) How to identify what wheel lock to buy
    Modified by Peter at 5:16 PM 11-8-2008
  8. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:47 PM #8
    Brakes
    The Brake Forum General dicussion about brakes including Upgrades, Pads, Rotors, Calipers, Carriers, Fluid, ABS, Proportioning Valves, Stainless Lines, E-Brakes etc.
    Common Brake Upgrades for the MKIV platform List of front and rear upgrades for all MKIV cars.
    Stock Brake Sizes Don't know how big yoour front and rear brakes are? Want to know the differences between certain MKIV's?
    Caliper Painting How to paint your calipers the color of your choice.
    Front Brake Install How to change rotors and pads on the front.
    Front/Rear pad and rotor install High level install of pads and rotors for VR6/1.8t cars. Process much the same for TDI and 2.0
    12.3" Front Brake upgrade Upgrade to the 12.3" rotors and came on the 337/20AE/TT and 1.8t GLI's from the factory.
    Front Brake Change for 2.0/TDI's Change your pad's and/or rotors on your 2.0/TDI.
    Rear Brake Install How to change rotors and pads on the rear.
    337/20th/1.8t GLI Rear Brake Upgrade Upgrade to the vented rotors that came on the 337/20AE/TT and 1.8t GLI's from the factory.
    Brake Fluid Change
    .:R32 Brake Conversion Checklist
    Brake Job Tools and Items Things you need for front and rear brake jobs, tools sizes etc.
    Stainless Brake Line Install Includes flush and fill
    Installing a new brake light switch Rear brake lights not come on? Rear brakes lights stay on? This switch is subject to recall but easy and inexpensive to replace yourself.
    How to bypass the brake pad wear warning light How to turn off the brake pad warning light in the cluster if you are running aftermarket pads or pads w/o sensors.
    How to replace and adjust e-brake cables and handle Have your rear calipers locked up in cold weather? Does your e-brake handle feel very loose? Check out this DIY to replace bad cables and adjust the feel of te e-brake handle.
    Brake fluid flush/replacement
    Tyrolsport Brake
    Caliper Stiffening Kit
    Adding a stiffening kit on the calipers.
    Modified by bhb399mm at 9:56 AM 5-3-2009
  9. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:48 PM #9
    Transmission
    Automatic and Manual Starter
    Discussions and Issues
    Manual Transmission Forum General dicussion of VW manual transmission including troubleshooting, gearing, differences, rebuilding, and operation (includes clutch).
    Automatic Transmission Forum General dicussion of VW automatic transmissions (tiptronic and 4-speed) including troubleshooting, gearing, differences, and operation. Ever wonder how a torque converter works?
    Double Clutching and Synchromesh discussion Want to know what they are talking about in those Hollywood movies? What are synchros and how do they take the place of "double clutching".
    How to feather or "slip" the clutch for the best launch Technique used for the best launch when drag racing.
    Downshifting debate Downshifting and staying in gear when coming to a stop versus coasting.
    How to drive a car with a manual transmission New to stick? Get advice and tips here.
    Information on synchros Do you have gear grind or trouble shifting into a certain gear in a manual transmission?
    Second Gear Grind Fix Does your manual transmission grind when going into second gear?
    How Tos
    Transmission Removal & Clutch Replacement
    - this one has everything you'll need, including lots of pics
    Manual Transmission Removal, Clutch and Flywheel replacement. with PICS, done on a 12v 5spd, but can be used for an engine/manual transmission combination.
    DIY: Transmission Fluid Change for 6 Speed O2M
    Transmission Removal, clutch replacement - 00' GTi VR
    VR6 12v Transmission Removal, Clutch and Flywheel replacement. with PICS
    Changing Manual Transmission Fluid
    6-speed Conversion
    Installing a Audi TT "Style" short shifter (2002.5-2005) Install guide that can be used for pretty much every short shifter out there. Done with a post-2002.5 car with the "pin type" cable ends, earlier cars slightly different. (Applies to 6 speeds as well).
    Audi TT "Style" short shifter install (1999.5-2002.5) Can be used for other short shifters. Done with a pre-2002.5 car with the "ball socket" cable ends, later cars slightly different.
    Part numbers for Audi TT short shifter Use the above install pictures to determine if you have a pin or ball socket style connection on 2002 cars[/url]
    Adjusting your shift linkage for smoother shifting How to align/adjust your shift linkage. Uses a short shifter install (see "Adjsutment" Section), but the process is the same for even stock transmissions and linkages.
    Adjusting your shift linkage DIY w/ Pics
    Installing a B&M style short shifter - Installing a B&M or other "in-car" short shifter.
    Replacing a starter Replacing a starter and/or fixing a grinding starter. 6-speed a little different, but much the same process, automatics can use the same basic outline.
    Modified by dashrendar at 4:59 PM 4-13-2009
  10. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:49 PM #10
    Drivetrain
    Items/Issues that are common across drivetrains (Engine/Transmission). Fault codes, coilpacks, 02 sensors, EDL and ASR, Oil, battery, engine mounts, bushings, bearings, axles and hubs, fuel filter.
    DTC Codes Did your engine throw a check engine light? Find out what the code means here.
    It's NOT a bad MAF, until you do this >>>DTC Flow Card Diagnoses for bad MAF
    The MKIV Coil Pack Guide Find out what is what, what the hoopla is all about, how to diagnose, and how to fix any coilpack problems.
    The MAF Thread Like Coilpacks, Mass Air-Flow Sensors are a common failure point, find out what is what here.
    Where to get security torx bits for maf removal The actual MAF element uses hard-to find bits, find out where to get them here.
    Testing MAF, O2 Sensors, and Catalytic Converters on a MKIV Using a VAG-COM.
    How to ADD Cruise Control Using a VAG-COM
    How to adjust the shifter and cables
    DIY: Cleaning up and hiding engine bay wiring
    Replacing the dog-bone (rear) engine/tranny mount and Bushings How to replace the rear engine mount (can be used for stock or aftermarket replacement).
    Replacing the Transmission (drive side) mount bushings Can be used for replacement of the entire transmission mount.
    Dog-Bone mount install Can be used for stock or aftermarket units.
    VF-Engineering DogBone Mount Install
    Stiffness of Various Dog Bone Mounts
    Automatic ASR defeat Do you turn off ASR each time you get in the car? Modify the switch so the default is off instead of on.
    Disabling ASR/EDL with VAG-COM Disabling the electronic traction aids via the ECU using a Vag-Com.
    ESP FAQ
    Ignition Switch Replacement
    Front wheel bearing and hub replacement Front wheel bearing making noise? Stipped lug bolt threads in a front hub? Discusses the proper procedure for replacing these units (bearing needs to be replaced whenever hub is removed).
    Rear wheel bearing and hub replacement Same as the above, but for the rear wheels.
    Rear wheel bearing and hub replacement v2
    Rear wheel bearing replacement VIDEO
    Axle Removal and Installation Also can be used for CV/CV Boot Replacement (axle needs to come out).
    Passenger Axle Removal Remove the passenger axle without pulling the spindle
    Blown CV Boot Replacement and Joint Inspection Have a ripped CV boot? Here's how to replace it instead of buy an entire replacement drivehaft
    Tie Rod Tool - Make your own handy tool for easily removing and instaling tie rods on you car
    Tie Rod Replacement and discussion
    Optima Battery Replacement Replace your battery with an Optima.
    DIY Lightweight battery install
    Starter Motor Grind Fix and Starter Motor Replacement DIY
    Oil that meets VW's requirements Especially important for 1.8t's (sludging).
    Getting Better Fuel Mileage Out of Your MK4 "Beating the Pump" with tips / common practices
    Replacing the Fuel Filter All gas engines.
    DIY: Removal and Reinstallation of Fuel Sending Unit
    Fuel Pump Replacement All gas engines.
    Replacing the Fuel Pressure Regulator How to change the FPR, applicable to all engines, 3-bar, 4-bar etc.
    VW-approved 502.00 and 505.01 Oils.
    Catch Can DIY
    Official MkIV Service Interval Check List - For all engines: What gets done by the dealer when schedules maintenance is performed.
    Everything You'll need to Know about MkIV Engine Swaps
    Replacing the alternator wiring.
    Modified by the brit at 11:31 AM 3-2-2010
    Modified by Mr. Rictus at 6:13 PM 3-16-2010
    Modified by Mr. Rictus at 6:14 PM 3-16-2010
  11. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:51 PM #11
    Intake and Exhaust
    All you ever wanted to know about CAI's What to buy, where to buy, what they do, adventages, disadvantages, do they make more power? More courtesy of the search. Also via 1.8t forum
    GHL and Neuspeed CAI Installs Can be used for most CAI's (process is pretty much the same no matter what brand) on all MKIV's.
    Stock Airbox CAI Turn your stock airbox into a cold air intake and get the benefits of both.
    How to clean a foam filter (PDF) Clean your ITG filter
    Eurosport CAI Install
    Replacing exhaust hangers Exhaust rattling? Tips hanging crooked? The hangers may be at fault.
    Will a GTI/Golf exhaust fit on a Jetta or vice versa? Find out why that sway with a friend will not work.
    Stock Exhaust sizes All 1.8T's VR6's and TDI's have a 55mm exhaust, 2.0's have 50mm exhausts.
    A list of most of the 1.8T Transverse Exhaust Systems
    DTC Flow Chard Diagnoses for bad MAF
    Magnaflow catback exhaust DIY installation for MkIV Jetta(Golf/GTI can use this as well)
    Modified by rs4-380 at 9:14 PM 7-26-2007
  12. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:52 PM #12
    VR6
    Many components on these engines are the same, so many of the how-tos apply to both even though they are written from the perspective of one. If you are not sure, just ask.
    12v VR6 forum Forum for all issues pertaining to the 12v (174hp) VR6.
    24v VR6 forum Forum for all issues pertaining to the 24v (200hp) VR6.
    12v VR6 FAQ Frequently asked questions, modifications, how-tos, pertaining to the 12v VR6.
    24v VR6 FAQ Frequently asked questions, modifications, how-tos, pertaining to the 24v VR6.
    Which VR6 do I have/How to tell them apart Don't know which version of VR6 you have? Go here.
    What does VR6 stand for? The name, VR-6 come from a combination of Vee and the German word Reihenmotor. The combination of the two can be roughly translated as "in-line Vee."
    The MKIV Coilpack Guide Learn about the Coilpack problem. (12v's and 24v's use different systems)
    Testing a 12v VR6 Coilpack How to test a 12v coilpack.
    JB Weld Your coil pack 1 How to fix a coilpack for cheap. (JB Weld method will not work with 24v's).
    JB Weld your coil pack 2 Another how to fix your coilpack for cheap.
    JB Weld your coil pack 3 Another how to fix your coilpack for cheap.
    JB Weld your coil pack 4 Another how to fix your coilpack for cheap.
    MSD Coilpack Replacement Replace your coilpack with an MSD setup and a little ingenuity.
    Replacing a VR6 Serpentine belt tensioner and lubricating the bearing The tensioner is know to be the cause of engine compartment noise.
    Replacing the Main Water Pump Main water pump replacment.
    Replacing Timing Chains, Tensioners and Guides on a 12v Should be done around 100k miles.
    Sound clip of timing chain noise Learn to diagnose the chains.
    Pictures of worn timing chain parts See what happens when they start to fail.
    Testing 12v compression How to test for cylinder compression.
    Removing and Cleaning the throttle body
    Replacing Oxygen Sensors Driving for extended period with a bad MAF will often kill your O2 sensor(s).
    Generating readiness codes on a 12v (.doc)
    VgRt6's Master List Master list of above maintenance procedures and more.
    Oil Change Guide How to change your oil correctly.
    Oil Change Guide Another how to change your oil correctly.
    Replacing the oil pan
    Replacing the Coolant Temp Sensor Change to the new green top coolant sensor. The older versions often cause check engine lights.
    12v Plugs and wires Changing spark plugs and wires on a 12v (not applicable to 24v's).
    Replacing the intake shifter rod Engine sound like it is filled with marbles? How to replace the manifold shifter rod.
    Another Shifter Rod DIY (the better one! LOL.)
    Alternator Replacement DIY - Need to replace your alternator and for the life of you can't figure out how to get to it? Well, now you know.
    T-stat housing and "crack pipe" replacement DIY - If you've got a coolant leak on your VR6 near the front driver's side corner of the engine, then you'll probably find this DIY very handy.
    Engine bay fuel line replacement Good DIY to replace broken or cracked fuel lines located in the engine bay.
    Another MkIV alternator DIY with fuel line replacement
    2.0 MAF sensor in VR6 housing Use the cheaper 2.0 MAF sensor in your VR6.
    Proof that 2.0 and VR6 MAF sensor innards are the same
    MKIV 12v Turbo/Supercharger Kit list FI VR's are fun
    12v VR6 Exhaust Shoot Out Power figures and ratings of several popular VR6 exhaust done by a popular VW magazine. 24v's can use this as a reference.
    12v Cam Install Useful for head teardowns/chain work and 24v work as well.
    12v Grounding Locations Locations for connection points if installing a grounding kit.
    Modified by rs4-380 at 11:23 AM 9-3-2008
  13. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:53 PM #13
    1.8t
    The 1.8t Forum Discussion of all things 1.8t. Anything related specifically to 1.8t's (chips, turbos, intercoolers, downpipes, exhausts, etc) should be posted here.
    The 1.8t FAQ Thread dedicated to Frequently Asked Questions about the 1.8t. Includes How-tos, mods, information, Big turbos, exhausts, clutches, maintenance etc. (Old FAQ)
    Basic 1.8t Modding Guide Common areas to start with. Chips, DV's, Suspension, Intakes.
    Stock Turbo Modifications A detailed guide of one individual's process for getting the most out of the stock turbo. Discusses common 1.8t mods.
    Stock Turbo Removal And K04 install
    Cranked Wastegate Discussion How to tighten your wastegate for more boost at the risk of killing your turbo.
    1.8t terminology and stats (150 vs. 180, AWD vs. AWP, etc) What does AWW/AWD/AWP mean? What are the differences between them? Stock boost values, etc.
    BOV vs. DV Why replacing your Diverter Valve with a Blow Off Valve may not be the best idea.
    General Blow Off Valve Information All you ever wanted to know about Blow Off Valves on 1.8T's via the search.
    Diverter Valve Replacement
    Water/Methanol Injection
    The 1.8t Chip Tuning Guide Which chip to get? Where to buy? What does a chip do?
    Everything you wanted to know about 1.8t chips Via the search (there isn't much that hasn't been asked before).
    The "Official" 1.8T Chip Opinion Poll - Users Opinions on which chip they own and why.
    Changing 1.8t Coilpacks How to change the Coilpacks yourself.
    Cracked Coilpack Wiring There is a TSB on this, (not a recall).
    1.8T Overlay Harness First Aid - goodbye misfire codes
    DIY: OEM Audi Ignition Coil Wiring Wrap "Deflector"
    Changing Sparkplugs and Coilpacks Change your own plugs, change your own coilpacks
    1.8t Turbo Inlet How to install an upgraded Turbo Inlet Pipe.
    K04 Turbo Inlet Pipe Install and review
    Forge Turbo Inlet How to install an upgraded TIP (applicable to other brands).
    Audi TT Intercooler Vent Mod How to vent your fenderwell to increase intercooler flow.
    Modifying an Advan Racing Intercooler ("ebay") to fit underneath a stock bumper
    Install Europsort underdrive pulleys How to install Eurosport's underdrive pulley kit (applicable to other brands).
    Clamping the MAP Sensor (Diode Mod) How to clamp your MAP sensor for increased performance.
    Downpipe install How to remove and install a downpipe. (applicable to other brands as well).
    Removal/Installation of N75 valve How to change an N75 Valve.
    Diverter Valve Maintenance Done with a hyperboost, applicable to most others as well.
    1.8t Oil Change Via 1.8t Faq
    Changing the Valve Cover Gasket Also deals with removing the valve cover.
    Alternator DIY
    1.8T Timing Belt Replacement Can be used for water pump replacement as well.
    Turbo Timer Install How to install a turbo timer to facilitate turbo cool down. Applicable to other brands.
    Turbo Timer Install with COMPANION Lite
    (more turbo time/boost gauge threads in interior and interior electronic sections of this thread)
    Turbo Timer Install
    Aftermarket Fog Lights for the 1.8t Deals with issues specific to blocking the intercooler.
    WHy the 1.8T is loud at startup
    Powergasket + DIY
    DIY: Stock Side Mount Intercooler Clean and de-oil
    Modified by rs4-380 at 7:36 PM 9-7-2008
  14. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:53 PM #14
    2.0
    2.0L Engine
    The 2.0 Forum All 2.0 Specific issues, questions should be posted here.
    The 2.0 Forum FAQ Common questions, modifications and installs for the 2.0.
    One take on budget modding a 2.0 Good place to start if you are looking for something more wihtout spending a whole lot.
    2.0 Oil Consumption 1 Does your 2.0 burn oil? Does it constantly need to be topped up?
    2.0 Oil Consumption 2 More discussion on the oil consumption issue.
    Replacing Spark Plugs on a 2.0 (.pdf)
    Replacing Spark Plug Wires on a 2.0
    Installing a TDI thermostat in a 2.0 Use a less expensive TDI thermostat in your 2.0. Also covers how to drain all coolant.
    Eurosport Underdrive Pulley kit Installing underdrive pulleys to liberate a few more horses.
    Replacing a cracked dipstick tube Can be used as a guide for all engines.
    Replacing the timing belt and water pump Save some big money by doing this necessary evil yourself.
    Cam Replacement Can be used for stock and/or aftermarket cams.
    A guide to tuning the 2.0
    Modified by Peter at 8:52 PM 12-17-2007
  15. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:54 PM #15
    TDI
    TDI forum Discussion of all diesel related modifications, installs, maintenance and issues.
    TDICLUB A helpful TDI resource.
    TDI FAQ Frequently asked questions, concerns, and issues with the TDI.
    TDI Chips Thread on chipping a TDI.
    TDI Timing Belt Replacement
    ALH Injection Pump replacement
  16. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    02-16-2005 12:55 PM #16
    General
    For all your VW needs (Massive list of websites) ["The List"]
    ::fficial Vendor Feedback Thread:::FAQ
    VW Coil Pack/Ignition Coil Guide
    THE 1.8T/VR6 Poll and Thread See what engine is most popular with forum users, and what owners of the repective engines have to say about them.
    The Registry Registry Want to find pictures of a specific color of car? Want to find others who own your color or model? Links to all the "Registry" threads.
    Major Recall List Gathering of info on the major recalls, window regulators, coilpacks, mafs, o2 sensors, heated seats, brake light switch, abs controller, etc.
    Fuse Listings
    Differences between GLI's Differences between the 2003-2004 200hp 24v VR6 GLI and the 2004.4+ 180hp 1.8T GLI.
    4-Door 1.8T Golf Production Figures
    What Mods won't void my warranty Be careful on this one, nothing is a hard fast rule, it usually depends on the dealer.
    How do I jack up my car? Safe way to jack up and support your car.
    Correct jacking Procedure
    Jacking podcast
    VW Supplied Specs Compare engine specs, fuel ecomony and performance ratings
    The engine thread Stock dyno plots, engine specs etc. Use this if you can't decide between two different engines. (Best advice is to drive both and buy what YOU like.)
    Spark plug specifications for MKIV engines - Need to know the type of spark plug, gap spec and torque value for your car?
    What does GTI stand for? Gran Turismo Iniezione (Grand Touring Injected)
    What does GLI stand for? Gran Luxe Iniezione (Grand Luxury Injected)
    Winter Car Storage Information - Storing your car for the winter/long period of time? read this.
    Coolant low? Cold temperatures? Here is why! - Low coolant level warning in the winter? check here first.
    How to polish - How to polish your intake manifold as well as other engine parts]
    DIYower Steering System Oil Flush/ Service
    DTC code lookup with comments/solutions Website to look up DTC codes and P-codes.
    Spark Plug Colors - Pictures showing various types of damage to spark plugs.
    How-to open key fob/remote and replace battery - How-to open key fob/remote and replace battery
    Starting Your Car DIY- Just in case the "Putting gas in your car DIY" wasn't enough.
    Fuel Line Repair DIY
    Modified by the brit at 5:02 PM 12-10-2009
Closed Thread
