VWVortex.com - clipper kit side skirt removal
    Results 1 to 3 of 3
    Thread: clipper kit side skirt removal
    1. 02-19-2005 01:06 PM #1
      as the title states I am trying to undo my side skirt so that I can take out my passenger side front fender flare. I took out all th screws from under the side skirt but it is still somehow stuck to the door...are there clips in back of it or what? Need your help homies,
      thank u in advance
    2. Member Mixagolf1's Avatar
      Jan 21st, 2005
      Ukraine
      '07 Golf V TDI, '73 VW 1303
      02-19-2005 02:15 PM #2
      Just try again! As i remember there is nothing special in this case...
    3. 02-19-2005 02:29 PM #3
      If you already have all the screw out from underneath, just pull the sill out about an inch from the bottom ( no more or you risk cracking it ).
      the screws are screwed into little plastic clips so you may need to push down a little as you pull out the bottom, just so as to clear the clips the screw were in.
      then just tap it up, it is just lightly hooked on the clips at the top,
      Modified by eurocabi at 7:30 PM 2-19-2005
      Need your fenders rolled, pulled or shaved? Check me out here...
      http://forums.vwvortex.com/showthrea...fender-rolling
