VWVortex.com - Which spark plug is best for the 1.8t? - Poll
    Page 2 of 5 FirstFirst 12345 LastLast
    Results 26 to 50 of 115
    Thread: Which spark plug is best for the 1.8t? - Poll
    1. Member smd3's Avatar
      Aug 5th, 2001
      Golf R, Routan, GMC Astro
      07-05-2003 04:49 PM #26
      autolite copper's should be on the list. They run perfect in my car! $1.07 each.. gapped at .028.
      no misfires, no burnt out coil's.
    2. 07-05-2003 11:32 PM #27
      just picked up the ngk bkr7e's...theyre copper and one heat range colder than stock..cost me around 15 bucks at foreign autopart, i have 44k on the car, never changed plugs, decided it was time, cuz performance is lacking and gas mileage is aweful
    3. 07-06-2003 04:56 AM #28
      Quote, originally posted by UMDKappy »
      That's where my confusion lies. If someone can clear this up. From what I recall reading and hearing....
      BKR6E is ONE heat range colder than stock
      BKR7E is TWO heat range colder than stock.
      Can someone confirm this? I have the 6E's in my car at the moment and all is well.
    4. 07-06-2003 11:49 AM #29
      The 1.8T FAQ has a plug write up as well, which covers a lot of this material.
      For the record, the NGK BKR7E is one (1) heat range colder. The 6E is two ranges colder, the 5E is three ranges, and so on...
    5. 07-06-2003 04:17 PM #30
      Hi everybody,
      As you can tell, I don't post too often - but I thought I might be useful on this issue. I work in the engineering department for a sparkplug company (one of the BIGGIES) on the production side of the business.
      If there is one or two burning technical questions you guys wanted answered, I could take them to the guys in product engineering to get them answered. Everybody LOVES cars where I work - believe me. I'm always up for learning more myself - so fire away...
    6. 07-07-2003 07:05 PM #31
      Is copper better than platinum?
      A
      cheers Rex!!
    7. 07-07-2003 07:54 PM #32
      Quote, originally posted by TUR-80 »
      IF PLATINUM PLUGS ARE SO BAD, WHY DO VW AND AUDI FIT THEM AS STANDARD TO OUR CARS?
      As pointed out platinum works for long plug life, but not best performance. VW needs the long plug life to sell people cars now since you can buy a malibu that will go for 100K miles before a "tune up". Yes in general the factory does know more then the average vortex member, however there goal is not performance, while 99% of the people here alooking for plugs, it is.
    8. 07-08-2003 05:24 PM #33
      From NGK specs 2=Hot, 11= Cold
      From this 7E is one range colder, 6E is stock, 5E is 1 heat range hotter
      Specs are here>>>http://www.sparkplugs.com/images/ngksparkplug.jpg
      Quote, originally posted by GTI-Turbo »
    9. 07-08-2003 06:36 PM #34
      note also, ik20s are stock heat range, ik22s are a range colder
    10. Banned
      Sep 21st, 1999
      South Alabama
      99 Passat 1.8Tm, 04 Passat 1.8Tm
      07-08-2003 07:43 PM #35
      Quote »
      Copper is better for a high output engine because of the larger electrode (can remove comb. chamber heat at a faster rate than a "thin wire" platinum plug).
      Bosch F5DPOR Platins are better than copper plugs, but most people are a little alarmed at paying $100 for a set of plugs.
    11. 07-09-2003 11:10 PM #36
    12. Member boraIV's Avatar
      Jan 8th, 2001
      six.oh.two.
      '14 JKU Rubicon, '16 Audi SQ5, '03 SL55
      07-14-2003 05:54 PM #37
      so for those of you running ngk bkr7e-11, what do you have them gapped at? [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    13. Banned
      Feb 18th, 2003
      07-14-2003 07:11 PM #38
      Besides the personal prefernce, which spark-plugs should I use (GIAC X-chipped car) with my car? Since it's chipped, ya know...
      I'm also located in hot climate
    14. 07-14-2003 09:48 PM #39
      I guess chipping has to be included in this, and if more than chipping is used.
      If its stock just keep using stock plugs, but what happens when you add a little more boost than VW was contemplating? will a one range cooler plug be better always? on what ocassions will it be better or worst? at what boost levels should you go 2 range colder etc....
      This is a complicated topic as all of these have to be adressed, maybe not necessarilly going into brands, but saying what materials and what heat ranges and then each can go out and buy whatever brand fulfills this.
    15. 07-15-2003 03:36 PM #40
      Bump as I've been wondering the exact same thing. Going to do plugs soon I'm thinking as I'm at 17,000 miles, and contemplating the Denso Iridiums. Did some homework on http://www.sparkplugs.com so I'm not totally dumb but I don't know if I should go w/20's or 22's a range colder. I am chipped and plan on TB exhaust in the future, maybe an intercooler, etc etc (where does it really end ). But alas I cant' do a phatty turbo setup.
      So with a KO3 sport/Revo 4bar chipped blah blah blah should I go a range colder??
      THANKS
      Quote, originally posted by Giancarlo »
    16. Member boraIV's Avatar
      Jan 8th, 2001
      six.oh.two.
      07-15-2003 03:53 PM #41
      ok, but what should they be gapped at? heheh please, i want to do this today [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. 07-15-2003 04:17 PM #42
      From the 1.8T Plug FAQ:
      *avoid BKR7E-11 as the factory gap is too large, .042*
      >> That is when they are gapped correctly (.028) the angle is to steep for a good burn. You want the BKR7E, not the BKR7E-11.
      Anyway, the gap for a one range colder plug is .028
      >FROM THE FAQ<
      Stock spark plugs NGK PFR6Q stock gap .032"
      --Common replacements
      Autolite 3923
      Autolite 3922 (one heat range colder)
      Denso Iridium IK20
      Denso Iridium IK22 (one heat range colder)
      Bosch F7LTCR
      NGK BKR7E (Race plug, one range colder)
      For every additional 50HP over stock, a general rule is:
      --1 heat range colder
      --gap shrinks by .004
      So, a chipped 1.8T would make good use ofa plug one range colder gapped to .028
      Reference: From NGK's FAQ: Spark Plug Gap
      "Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005"."
      >END FAQ<
    18. Member boraIV's Avatar
      Jan 8th, 2001
      six.oh.two.
      07-15-2003 04:24 PM #43
      Well damn, I couldn't find a place that sold BKR7E i could only find the -11 part. I guess i'll be getting some autolites. Thanks for the info, i guess i neglected the FAQ.
    19. Member
      Jun 28th, 2000
      Pasadena, CA
      07-15-2003 09:54 PM #44
      What about sparkplugs.com? http://www.sparkplugs.com/resu...BKR7E
      -Ian
    20. 07-16-2003 08:40 PM #45
      Quote, originally posted by swett &raquo;
      -Ian
      Yup, I ordered two sets from them last week. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    21. 07-17-2003 02:31 PM #46
      None of you guys change your plugs seasonally?
      I've probably tried all the plugs one can get at Autozone. Made a database so I can compare ignition advance (VAG-COM) to weather conditions.
      The plug that works best for me is one of the plain Bosch platinums.
    22. 07-29-2003 01:29 PM #47
      How often should a chipped 1.8T have it's plugs changed?
    23. 07-29-2003 04:36 PM #48
      Quote, originally posted by TUR-80 &raquo;
      If I had $1 for everytime I saw someone post "platinum spark plugs are bad for your car", I'd be rich by now.
      Give it a break...
      The main advantage invoked by the manufacturing and the use of Platinum Tipped Spark plugs over the "Conventional" Copper Plugs (and I don't mean that in a bad way) is that it cuts down on environmental waste, and to a certain point, New Car Warranties.
      Platinum tipped plugs typically have a much longer serviceable life span than conventional copper plugs
      Pro and Cons.... Manufacturers warranty and the "All Service" included for "X" Number of years is good for the Manufacturers, since it costs them less in that they are "longer lasting".
      Cons... They typically don't offer the same performance as a conventional copper plug (mind you, 99% of you won't be able to FEEL or Quantifiably Evaluate the difference between OEM platinum vs Copper Plug). As well, Backyard mechanics and enthusiasts get Raked for the cost of Platinum Tipped Plugs vs Conventional Copper Plugs, in that they typically don't cost 4-5x the price to make.
      Save you time and money, go OEM in 95% of the cases. If you at Stage 3, then perhaps it's worth going the route of Copper or "Alternate" type plugs.
    24. Member caj1's Avatar
      Feb 16th, 1999
      Washington, DC
      2016 Audi TTS; 2016 VW GTI w/PP
      07-29-2003 05:10 PM #49
      For me, not having to worry about changing plugs every 10K (and associated risks to damaging the head, interlocking threads, damaging the coil, etc.) outweigh the negligible performance difference between platinum and copper. I agree, stick with stock unless you've done some serious modifications.
    25. 07-29-2003 05:34 PM #50
      I have read this thread and I still don't know what is one temp range COLDER than the stock NGK PFR6Q?
