Page 1 of 2 1 2 LastLast
Results 1 to 35 of 47
Thread: GUIDE: How to install white faces and Blue LEDs in VDO gauges
  1. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    Q7 4.2 V8 , Smart 451 Turbo
    03-04-2005 05:35 PM #1
    The mother of all guides!
    So, here we go.
    You need 3 of these...
    The goal is this.
    Take your Dremel with the cutting disc.
    You can also use this but it removes more plastic so you might have a problem later when you put them back together. I didn't
    Here you see aproximetely where you need to cut.
    Mask the area arround the gauge to give you a guide line.
    I hope your hands don't shake.....
    Gauge opened!
    The Cover
    Cleaned
    Undo the small nut on the back to be able to remove the guage from the case.
    Now, this is I think the most difficult part of the whole project.
    THE NEEDLES!
    I used to small screwdrivers as you can see and very gently pulled the needle off. I doublechecked that I didn't cause any damage to the gauge before continuing by putting the needle back and checking if its moving smooth.
    Time to design the white faces. I used Coreldraw 12 to do mine since I found it very easy to use.
    After a few hours....
    This is the exact size of the gauges. Print it and they fit straight away.
    Trial test of the oil pressure gauge
    Now, on to put the LEDs in.
    I used a hot glue gun to glue the 2 LEDs inside the plastic housing of the gauge
    The LEDs. 5mm Ultra Bright Blue.
    There is a reason they are bent. You will understand in the next picture.
    After you glue both of them, route all 4 wires from the hole in the back of the case.
    I used a 470ohm resistor to wire all of the leds in parallel. Since I was doing it in my house using a power supply rated at 2 amps, I noticed that everytime I connected one more LED, the rest lost some of their brightness. That is probably because of the power supply but it can also be because I am using one single resistor for 6 leds. Since I am out of resistances I can not test how it will look with one resistance to each led. Maybe somebody else has something to say on that.
    Final result...
    Day.
    And night
    I hope this guide will give you some ideas and probably do some of the things I did different and better. If you have any hints please post them and I will edit my guide to make everybody's life easier!
    PS. some VDO gauges ready to go under the knife
    Modified by Black_cabbie at 11:29 AM 7-25-2005
    Chip Tuning for a living @ www.microchips-tuning.com
  2. Member Mixagolf1's Avatar
    Jan 21st, 2005
    Ukraine
    '07 Golf V TDI, '73 VW 1303
    03-04-2005 05:48 PM #2
    I wonder how you will assemble all this back?!
  3. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-04-2005 05:52 PM #3
    EDITED after completion of the guide
    Thats the least of my problems Mike.
    Modified by Black_cabbie at 8:58 AM 3-14-2005
  4. Member blast47's Avatar
    Sep 9th, 2002
    Arizona
    2004 A4 Audi Cabriolet
    03-04-2005 06:40 PM #4
    Quote, originally posted by Black_cabbie »
    http://img.photobucket.com/alb...0.jpg
    Why is there a pic of your crotch where "you need to cut" . . .that's uh.. dangerous
  5. Member VeeDubDriver1990's Avatar
    Jul 19th, 2004
    1981 Rabbit Pickup, 1990 Cabriolet, 1993 Corrado VR6 (up for sale)
    03-04-2005 06:44 PM #5
    YAY!!! George does it again!!!!
    Another one I saved in my favorites- well done George!
    Oh, I have a question- were you always a genius or was that an
    aquired skill?
  6. Member Moljinar's Avatar
    Sep 20th, 2001
    Indianapolis, IN
    87 Cabriolet, 85 Cabriolet, 90 JettaGL
    03-04-2005 07:12 PM #6
    Like this?
    I don't have a matching font installed at the moment so I just cleaned up the ones in the image but I could've replaced them. To do this properly I'd replace all the hash marks to.
  7. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    2001 Dodge Ram 2500 CTD 6speed, 82 ABA-swapped Caddy
    03-04-2005 07:23 PM #7
    Ok. Use a different cutting tip. Use the Dremel's cut-off wheel. It is 1" in diameter, and about .075" thick. Makes for a clean cut, as well, versus "chewing" the plastic away.
  8. 03-04-2005 10:04 PM #8
    This is sweet, I can't wait to do this!
  9. Member kuklaki's Avatar
    Sep 10th, 2002
    03 NB TurboS, 87 & 88 16V Scirocco-TWINS, 89 Cabriolet, 71 Ghia, 04 FJR 1300
    03-04-2005 10:45 PM #9
    Quote, originally posted by blast47 »
    Dang, you study the pics a lot...I'm a girl and I still didnt notice the shot
  10. Member VeeDubDriver1990's Avatar
    Jul 19th, 2004
    03-04-2005 10:52 PM #10
    Quote, originally posted by kuklaki »
    Let's all share a collective "oooooooooooooooooooo" like when
    someone got in trouble in elementary school
  11. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-05-2005 07:00 AM #11
    Ok, Oran was kind enough to help with the cleaned face. I am going to print it and continue with the assembly and the blue leds.
    Stay tuned for more updates!
  12. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-05-2005 05:10 PM #12
    After spending an entire afternoon with Coreldraw, I redesigned the faces from scratch using the original dimensions.
    I am missing the oil temp in Fahrenheit. Can somebody post a good picture of a gauge to use it for reference?
    This is the JPG ready to be printed. Print it in Photoshop/Coreldraw and they dimensions are ready. Plug and play !
  13. 03-05-2005 08:47 PM #13
    Thanks for this guide George. Its something I will do for sure.
  14. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    03-05-2005 09:52 PM #14
    VERY good job, george!! (again!)
  15. Member topduko19's Avatar
    Sep 29th, 2003
    Norfolk, VA
    Driving 98 Cabrio,Owned: 95 Golf Sport, 90 cabriolet, 90 jetta, 90 Jetta w/ ABA swap(trying to sell)
    03-06-2005 09:52 AM #15
    And george great thread on VDO guages but you know instead of using the two screwdrivers to remove the needle you can use a fork and it will be a lot easier to take out and it lessens the chance of breaking it... just another super ghetto ideas that helps out...
    My cabrio is costing me an arm and a leg....
    Fixing "my new" MK2 ABA Jetta
    Topduko's MK2 ABA Wiring Guide
    Topduko's MK3 Cabrio Top Replacement Guide
  16. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-06-2005 10:02 AM #16
    Quote, originally posted by topduko19 »
    We will gather all these small points and create A GREAT guide for the other groups to envy!
    Update on the VDO.JPG (added red bar in voltmeter and changed the oil temp gauge)
  17. Member topduko19's Avatar
    Sep 29th, 2003
    Norfolk, VA
    03-06-2005 10:07 AM #17
    I actually got this idea off a mk2 thread... they got a few tricks up there sleeve too
  18. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-07-2005 06:08 PM #18
    We are getting there.....
    I printed the JPG on standard self adhesive paper.
    I used two layers. One white and then the printed face. I did this because the paper is not that thick and it's semi transparent, thus allowing the black face and number to appear. With two layers of paper the result is very good. I used my thunb and pressed the paper carefully on the edges of the face. Perfect result!
  19. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    03-07-2005 06:57 PM #19
    Sweet result, G-money! warm and a to you!
  20. Member VeeDubDriver1990's Avatar
    Jul 19th, 2004
    03-07-2005 07:42 PM #20
    Quote, originally posted by qwikxr »
    Wouldn't you want George to have a cold ? LOL!
    But anyway, looks great George!!
  21. Member topduko19's Avatar
    Sep 29th, 2003
    Norfolk, VA
    03-07-2005 07:51 PM #21
    George that looks really good... does your RPM & Speedometer guage faces line up the same with Photoshop...
  22. 03-08-2005 02:17 AM #22
    where'd you put the LEDs and what do they look like lit up?!?
    did you superglue, or model glue the gauges back together?
  23. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-08-2005 03:23 AM #23
    The ones I created yes. They line up.
    As for the LEDs I have no idea yet. I will connect them tomorrow and see what happens.
  24. Member topduko19's Avatar
    Sep 29th, 2003
    Norfolk, VA
    03-08-2005 09:25 AM #24
    so where can I download Coreldraw??? is ther a sertain type of coreldraw that I gotta download???
    i wanna do this A.S.A.P. to have a hott speedometer & guages...
  25. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-08-2005 09:41 AM #25
    I got mine from emule..... version 12.
  26. Member 85 diesel's Avatar
    Feb 16th, 1999
    2000 Jetta GLS TDI
    03-08-2005 09:38 PM #26
    Quote, originally posted by VeeDubDriver1990 »
    aquired skill? [/Q[QUOTE=VeeDubDriver1990]YAY!!! George does it again!!!!
    aquired skill?
    I agree you did a SWEET JOB on the lights. Have you done the dash lights yet. If so what did you use to change the color to blue like the MK4's I love the way it looks on my 2000 Jetta. It would be cool to change the lights on the cabby to blue to match the 2000. If you have done this PLEASE IM me with how you did it THANKS
  27. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-09-2005 07:05 AM #27
    Quote, originally posted by 85 diesel »
    I will wire the leds tonight. As always I will post pics
  28. Member topduko19's Avatar
    Sep 29th, 2003
    Norfolk, VA
    03-09-2005 07:11 AM #28
    I will start this when I get a second set of VDO guages from ebay...
    but good job George... I luvin the guages
  29. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-09-2005 07:24 AM #29
    Make sure you don't get the voltmeter with the metal housing like mine is. There are two different voltmeters.
  30. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-09-2005 02:01 PM #30
    Almost there.....
    Modified by Black_cabbie at 9:52 PM 3-9-2005
  31. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    03-09-2005 02:19 PM #31
    schweeet
  32. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    03-09-2005 05:45 PM #32
    FINISHED!
    and the result is better than I expected.
    Will post all the details if the LEDs/wiring/puting back together tomorrow as I am done for today!
    Off to bed now!!!!!
  33. Member VeeDubDriver1990's Avatar
    Jul 19th, 2004
    03-09-2005 06:43 PM #33
    Bravisimo, George!!!
    Can't wait to see them all lit up at night
  34. Member topduko19's Avatar
    Sep 29th, 2003
    Norfolk, VA
    03-09-2005 08:31 PM #34
    so how did you put all the stuff together & where exactly did you place the LEDS...
  35. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    03-09-2005 09:10 PM #35
    FINISHED!
    Off to bed now!!!!!
