VWVortex.com - Mod Friendly Service @ Boardwalk VW in Redwood City!
    Page 14 of 14 FirstFirst ... 41011121314
    Results 326 to 339 of 339
    Thread: Mod Friendly Service @ Boardwalk VW in Redwood City!
    1. 06-22-2013 04:44 AM #326
      Isn't that kind of stutter when idling usually caused by the AC system? Would not surprise me if your problems are connected.
    2. Member driftme's Avatar
      Apr 12th, 2008
      Sacramento
      2010 BGP Jetta S
      06-24-2013 05:05 PM #327
      Quote Originally Posted by srkerd View Post
      I was without my car for 2 days and at the end nothing was resolved. I would like to get other VW drivers and Representatives from VW Boardwalk's opinion.
      I had a less than favorable experience as well. Since I'm slightly lazy, I'll just copy/paste the email I sent to the service manager when I was sent a survey request. (I felt a survey wasn't enough info to help)
      Basically, I brought my car in with communication issues, and after a weekend with no car (and missing work to bring my car there), they told me I had communication issues, and gave me an illegible printout of error codes, which wasn't even complete. I did not receive the level of service implied in this post, or promised to me on the phone before I made the trip out to SF to drop off my car.
      Here's my email detailing my experience:
      Hi Rick,
      I didn't want to just give you a 'yes/no' automated response, as i feel this is a more detailed question deserving of a proper response.
      I understand your service department is probably limited by protocol, but from the start I was under the impression that you guys worked around the edges more with modified vehicles.. this impression was founded on your VWVortex post about "mod-friendly service". Before traveling from Sacramento to have my car serviced at your dealership, I spoke at length on the phone with my service liason, Bob R. I went over exactly what aftermarket parts and modifications had been done to my car. I wanted to be certain there were no surprises.
      After dropping off my car, and again discussing what had been done, I returned home with a rental vehicle. The next day, Bob called me and informed me that after three hours of work, they had been able to pull a list of error codes, but could proceed no further without a stock ECU. The tuner that worked on my car said that there is nothing that would prevent any diagnostics from being run, nor did they physically modify the ECU. I understand if protocol dictates that you can no longer proceed if the ECU is modified, but that's not exactly "mod-friendly" service, and if I had been told at any point that a list of error codes is the most work that would be done on my vehicle, I would have certainly declined service. I basically was told what I already knew - that there are major communication issues on my CAN bus. I found that out in my driveway.
      What I was hoping for when I dropped off my car at your service department was that I could get a bit more detailed of an answer from a VW tech. You know, things like testing individual modules (all of which are still stock), or testing for faulty connections/bad wiring etc. What I got was a printout of error codes showing exactly what I told the techs initially. A summary of our interaction to this point would be something like: "My car is having major communication issues, could you look into it and hopefully give me more info about why?" "Sure".... "Oh here, its because your car is having communication issues". Do you see why this is frustrating to me?
      On top of this, when I picked up my vehicle, only 3 of 17 pages of the Diagnostic Log were available for me. I paid for the service because it was a Sunday and the only person there was the cashier, and I needed my car. I did eventually get Bob to mail me the full report, but it's basically illegible. Your printer must be out of toner or something because the only parts I can read are the bold parts.. the rest is too faint. Like I said before, this is basically information I already knew, but it's definitely not an acceptable printout regardless.
      I'm not at all satisfied with your service department's conclusion that the ECU has to be "brought back to stock". That's not mod friendly service, that's apathy and/or being restricted by protocol. A truly "mod-friendly" service department would have done everything they could AROUND the parts they couldn't work on to try and filter out other likely causes (instrument cluster, can gateway, bad wiring, etc.... so many other possibilities). When I was contacted, I even brought up this idea, and your tech said there was nothing more they could do because the ECU was "chipped".
      I'm not sure what else I can say about this. It's just not a great situation to have to pay $200+ to confirm the reason you brought a car in for service. I literally told your service department the same thing that they told me after the diagnostic. I brought the car in for communication issues, and had to pay for you to tell me I had communication issues. Seems to me like the communication issues are also between you and your techs/liasons. They don't seem to know about your "mod-friendly" post. They seemed surprised when I mentioned it.
      Overall, I'm really not at all pleased. I don't mind paying for diagnostic time, but I do mind paying for it when the answer I'm paying for is simply the reason I brought the car in.
      I waited a while before posting this to give the service manager a chance to reply to my concerns. It has now been about a month since I sent the email, so I'm reasonably sure I won't be getting even a simple response.
      I'm not sure how pulling a list of error codes equates to three hours of work either.
      Just want people to be aware of the limitations of this "mod friendly" service, which from my point of view and my experience, just seems to be a standard VW service dept.
      EDIT:
      Also, just to be clear, I did not ask for my service to be covered by warranty, as I was pretty sure it wasn't going to be covered. I knew the expense was going to be out of pocket, I just didn't expect to encounter a $300 bill and a missed day of work and end up with absolutely no answers or even leads, especially after the numerous and detailed conversations I had regarding my vehicle before my appointment.
      EDIT2:
      I should add that even though I was on-time (read:'early') for my appointment, I was told that my car wouldn't even be looked at that day because of some Lotuses. This was after my service liason recommended that I set up an appt for that day (a work day for me) because that was when his foreman was there. Not sure exactly how things work there but it definitely felt like I got bumped for some customers with fatter wallets.
      2010 BGP Jetta | my soundcloud - trance/progressive/etc | LatemodelRestoration.com
      UM Tune | BSH intake | Votex exhaust | ECS light crank pulley | Koni orange and Neuspeed race | Misc visual
    3. Junior Member
      Jul 16th, 2013
      Bay Areeuh
      2013 JETTA SE CONV. & SUNROOF
      07-29-2013 02:36 PM #328
      Got a lot of love for VW Boardwalk, especially for the good man Tom Sutton. I just bought a B-E-A-UTIFUL brand new Jetta SE '13 from him. Can't be happier - especially considering the financing VW hooked me up with.
      Now I just need to know ... I want to get my calipers painted red, and swap out my rims (16" for 16"). Rates @ VW Boardwalk? A auto paint shop in San Bruno quoted me at $400 for all 4, multiple coats.
      Can you beat that?
    4. Member
      Jun 7th, 2007
      San Francisco, CA
      '95 GTI VR6, '05 GTI 1.8, '13 Golf R, '15 Golf GTI AutoBahn
      09-21-2013 12:13 AM #329
      Brought my 13' golf r to do a stainless steel brake line along with fluid flush and wasn't happy with the result. My brakes now feel soft and not stiff as it's suppose to be. Tech changes all 4 lines and then bleeds when it's suppose to be one at a time. Would like this taken care of ASAP.
      -Alan
      UPDATE AS OF TODAY: Brought the car back and they assessed the problem, had air in my brake lines and re-bled it. Happy camper now!
      Thanks again Poh and Zaymar (dunno how to spell) for taking care of this for me.
    5. 11-04-2013 01:57 PM #330
      Is bwvw still mid friendly? How about stage2 friendly? I'm having DSG PROBLEMS
      Sent from my fingerprint scanning iPhone
      Exterior: NEW WHEELS SOON; Megan Racing Coilovers; 6k HIDs; 3k HID fogs; Smoked turn signals; Smoked Tails
      Performance: APR Stage 2 CAI; APR Downpipe with resonator; APR stage 2+ tune; Snow Performance W/M stage 3
      INSTAGRAM: BUZZO2012
    6. 12-29-2013 12:06 PM #331
      Do you guys have a 28point inspection appt open for this week?
    7. A beautiful Summer's Eve Sold Over Sticker's Avatar
      Nov 28th, 2009
      Corner of salt water and vinegar
      8 Nozzles and 16 Valves
      12-29-2013 12:26 PM #332
      Quote Originally Posted by nasty50 View Post
      I'd check for you, but I'm off this weekend. Call 650-568-5270 and they'll be able to help you.
      Driving While Awesome Podcast. Give it a listen.
      Quote Originally Posted by bothhandsplease View Post
      Brendan told me to get the best discount, I had to send dick pics. I thought this was standard car buying practice.
      Quote Originally Posted by H.E. Pennypacker View Post
      Brendan and his all knowing heavy breathing baboon are correct.
    8. Member driftme's Avatar
      Apr 12th, 2008
      Sacramento
      2010 BGP Jetta S
      08-28-2014 02:11 PM #333
      so... finally resolution to my car trouble. NO THANKS to boardwalk vw.
      The problem was just some wires that had been rubbed bare on my main wiring harness. Local shop fixed the harness, adjusted things so they don't rub, did a computer adaptation, and changed my fluids for $500.
      Boardwalk cost me almost $500 and was only able to tell me that i had tons of errors. The solution was "bring it back to stock", which would NOT have fixed my problem at all!
      After over a year of my car being broken, banging my head against the wall, paying Boardwalk to do NOTHING to fix my problem... it's finally fixed in less than 24 hours after bringing it to a local shop.
      Boardwalk VW Service department is just like every other dealer service department unfortunately. Crooks.
    9. Member flygliii's Avatar
      Jun 29th, 2006
      SF Bay
      a Mk4 and a B7.
      05-12-2015 10:47 PM #334
      Any updates to their current state of mod-friendliness?
      Gone and missed: '01 B5 V6 GLX wagon, '96 FZJ80, '89 16v GLI, '84 Scirocco, '81 Scirocco S, '80 HiLux 4x4, '77 Kawi Enduro, '74 sparkling green Schwinn Stingray.
    10. A beautiful Summer's Eve Sold Over Sticker's Avatar
      Nov 28th, 2009
      05-13-2015 01:56 PM #335
      Quote Originally Posted by flygliii View Post
      I haven't checked in on this thread in a long time. I'll chat with the Service Director and see what the word is. Obviously we can't replace your failed turbo if your car is APR Stage 3 since VW won't warranty it, but we're not going to pull the typical dealer shenanigans like "Your CEL is on because you're on bags."
    11. Member flygliii's Avatar
      Jun 29th, 2006
      SF Bay
      a Mk4 and a B7.
      05-23-2015 02:31 PM #336
      Cool. Thanks!
    12. Member Bucktown80's Avatar
      Mar 8th, 2016
      San Francisco, CA
      2013 Tiguan SEL
      12-12-2016 11:48 PM #337
      Are you guys able to install and/or program a Helix Spare Tire Mount Subwoofer kit (part #000051419) in a 2013 Tiguan?
      A dongle (part #DKS051419A) is required to program the EQ specifically for a Tiguan.
      Barry
      2013 Tiguan SEL
      San Francisco, CA
    13. Junior Member
      May 9th, 2016
      San Francisco, CA
      2016 Passat S
      06-14-2017 02:50 PM #338
      seems like a lot of people have moved since this thread was started. Still mod friendly?
    14. 06-17-2017 11:02 PM #339
      Most dealers now seem to be mod tolerant as long as its reasonably clear the mods aren't causing any issues.
