Page 1 of 2 1 2 LastLast
Results 1 to 35 of 51
Thread: For FAQ: How to calculate what size spacers YOU need - spacers adapters offset wheels et
  1. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    03-13-2005 04:50 PM #1
    Lately I've noticed that "what size spacers should I get" have been giving the wheel posts a run for their money. This is annoying for three reasons,
    1. like wheels, spacers should be a personal choice as they are mainly a way to alter the appearance of your car (if someone wants to argue about performance benefits, go ahead, but you'll probably get more repsponse from Pontiac owners).
    2. Inevitably people never supply, and usually don't know the required information so that someone else can tell you what to buy.
    3. Calculating the size spacers you need is easier than installing a euroswitch.
    That being said, if you are clueless as to offset, et, wheel sizes, tire sizes and coding and the like, you have some reading to do first. (all the below are in the MKIV FAQ/DIY)
    Offset tech
    Tire sizing
    MKIV Wheel Info
    Now, you should be able to fit yourself into one of two categories, you already have in you possession the wheels/tires setup you want to space out, or you don't.
    If you have the wheel/tire setup you want to space out
    This requires that the tires be mounted on the wheels and the wheels be mounted on the car. First level the car side to side. This can be easily accomplished by just measuring from the ground to the highest point of the fender. Theorectically the car should be even side to side, but they usually aren't. Just jack up the low side in small increments until the measurements on both sides are equal.
    Now get a plumb bob (you don't need anything fancier than a string with a nut or washer tied on the end.
    Tape the plumb bob to the centerline point of the fender (make good tape choices), wait until it stops swinging, then simply measure from the outer edge of the tire sidewall to the string. Convert this measurement to Millimeters and this is the size spacer you need for the tire to be flush with the fender. If you want to poke or tuck, add or subtract to get the desired width.
    dimension a is the required spacer size to get the tires flush
    (the above picture is not straight on since the original wheels on my gorgeous model are only 5 inches wide and tuck like no ones business. Therefore you can't see the sidewall from straight on behind as shown below)
    If you do not have the wheel tire setup in your possession
    You can still calculate what size spacers you need, but I recommend waiting until you get the new setup then following the above directions as that is simpler and more accurate, plus you can fool around with your "A" measurement to visualize what going with larger or smaller spacers will look like.
    If can't wait because you are impatient, get out your calculator.
    First remove the wheel from one side of the car on the desired end (do front and back separatley). You need to level the car. This can be as above, by measuring from the ground to the highest point of the fender lip and making sure both sides are the same. If they are not, just raise or lower your jack so they are equal. *One thing to note, on the front of the car, especially on lowered cars, because you have an independent suspension you may have to literally put the rotor on the ground to level the car, this is because the suspension is not compressed from the weight of the car. If you need to put the rotor on the ground, just put a block of wood under it, it is ok to let the ground compress the suspension. but make sure the majority of the weight is on the jack.
    Now make a plumb bob like above and tape it to the centerline of the fender. When the plumb bob has steadied, measure from the wheel mounting point on the hub (not the brake rotor, where the lug bolts thread in) to the string. Note this dimension.
    Because I'm not always a pain in the ass I've gone ahead and done this part for you.
    On GTI's/GOLFS the "A" mesurement from hub to fender is
    71.4375mm on the front (2 13/16")
    and
    87.3125mm on the rear (3 7/16")
    I am wiling to bet that the front measurement is very close for Jetta's if not identical and the rear is close enough for Jettas if not very close.
    *These measurements are only as accurate as the number of beers I drank before doing this, which I can't really remember. It's not my fault if you buy the wrong size spacers.
    Now, you want to replicate this distance with your wheel/tire setup in order to get the tire flush with the fender. Again, you can add or subtract to this to achieve a desired poke/tuck look.
    To do the calculation you need to know two things. 1, the offset of your wheel in MM (et 42 for example = 42mm) and 2, the width of your wheel OR the width of your tire OR the sidewall width of your tire.
    In regards to #2 the best measurement to have is the overall tire width, note this is NOT sidewall width (what is coded in tires sizes). Some people publish tire widths, but most don't. I have seen identically coded tires (205/55/15) vary as much as 3/4 inch in overall width depending on manufacturer and model.
    Since overall width is not usually published it is best to use tread width, if you don't even know what size tires you are running you can use wheel width, but usually wheel width will give you low values. *One thing to note, is if you are stretching your tires, you should use rim width NO MATTER WHAT, the whole point of tire stretch is that the wheels are too wide for the tire, so using tire measurements isn't going to give you accurate measurements.
    If you plan on using wheel width convert it to millimeters. Now you have your tire/wheel width and the wheel offset. The rest is just math.
    Take the tire or wheel width measurement and divide it in half. Subtract the offset from this figure. Subtract the resulting value from the appropriate hub-fender measurement above, and that is the size spacer you need in order to be flush, again, you can vary this to achieve a desired look.
    Example. Montreal I rim et42, 205/55/16 tire
    (205 / 2) - 42 = 60.5
    71 - 60.5 = 10.5
    So 10mm Spacers would get me flush in front
    87 - 60.5 = 26.5
    and 25mm Spacers would get me flush in the back
    Things to remember in either case
    1. 1 inch = 25.4mm http://www.onlineconversion.com
    2. 5mm is only 1/5 of an inch, going down 5mm in spacer size may save you a bunch of money without seriously affecting whether you are "flush" or not
    3. If the number you get after calculating your offset - wheel/tire width is LARGER than the hub - fender measurement you are going to poke no matter what. Spacers only extend your wheel and tire out, they can't subtract width. You need to do that with offset.
    4. Along with #2, you do not need to hit the values EXACTLY, depending on drop, 15mm inside the finder can look "flush".
    If people want to post pictures from straight on (front or rear) with the appropriate values as a reference go ahead, but make sure you include OFFSET, TIRE WIDTH/TREAD WIDTH/WHEEL WIDTH, and any SPACER size if applicable. Alternatively, you could just figure out your hub to sidewall width and give that to us instead (WIDTH/2 - OFFSET + SPACER). The good thing about giving the hub - sidewall value is that is doesn't matter what size wheel tire or spacer you have. A hub -sidewall width of 85MM should look the same no matter what wheels tires or spacers you are using (factoring in of course the error caused by tire/tread width and that it is on the same end of the car).
    Dave
  2. Member Chacolla's Avatar
    Jun 19th, 2004
    RI
    2006 GTI
    03-13-2005 04:52 PM #2
    awesome...good post
  3. 03-13-2005 04:53 PM #3
    Wouldnt it be best to measure from the inner fender lip as to not rub?
  4. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    03-13-2005 04:56 PM #4
    Quote, originally posted by 2002GTI »
    Good point, however, A, it's hard to tape your plumb bob there, B, thats not really "flush", C, if you are worried about rubbing just measure the width of the lip and subtract that from your hub - fender measurement.
    Dave
  5. Member RavinJetta's Avatar
    Mar 31st, 2002
    San Diego
    2011 S4
    03-13-2005 04:58 PM #5
    Very nice post.
  6. Senior Member abydielsgli's Avatar
    May 7th, 2003
    the field of bakers
    a few vw's and toyotas
    03-13-2005 05:08 PM #6
    Quote, originally posted by RavinJetta »
    Very nice post.
    true
    but also remember people. the wider the spacer the easier it is for the lug bolts to brake
  7. 03-13-2005 07:31 PM #7
    Quote, originally posted by rs4-380 »
    Yea it is hard to tape, but I just held it there. The reason why I mentioned that is when I did the measurements for the Kinesis wheels they instructed me to take the measurement from the inside lip as to not rub, just food for thought. Nice write up.
  8. 03-14-2005 01:39 AM #8
    Ok lemme do a quick check on this for a 9in wide rear wheel I want
    9inx25.4mm= 228.6mm
    228.6mm/2= 114.5mm
    114.5mm-87mm=27.3mm
    so ideally a +27.3mm offset on a 9in wide wheel would flush out the rears?
    so lets see with a 10in wide shall we
    10inx25.4= 254mm
    254mm/2= 127mm
    127mm-87mm= +40mm offset for flush rear! should i worry about rear clearance if I'm running 12in rear rotors with stock calipers?
    Modified by manasteel at 10:52 PM 3-13-2005
  9. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    03-14-2005 02:40 PM #9
    Quote, originally posted by manasteel »
    You shouldn't have any problems with the stock caliper but it totally depends on the wheel.
    Dave
  10. 03-14-2005 03:33 PM #10
    yea so it would depend on the wheel face too, whether the concave is deep or shallow
  11. 03-14-2005 03:40 PM #11
    dont forget that tires are not square. they have enough of a curve that the measuring location would not make any difference really in the rubbing issue.
  12. Senior Member CapeGLS's Avatar
    Aug 2nd, 2002
    Connecticut
    01 Golf GLS 1.8T, 02 Jetta WGN 2.0, 11 JSW 2.5SE (Wifes)
    03-14-2005 04:05 PM #12
    The rear axle on a MK4 has 2 different "sizes" I believe the passenger side sits further inside the fender than the drivers side...
    This is a good writeup though!
    Chamber: My Wheels Rub on the Inside|Forgeline Wheels|WRDusa.com|
    FlickR
  13. 03-24-2005 03:38 PM #13
    I'm confused .. can someone please help me out?
    So according to this calculation for my rear monte carlo wheels, I would need:
    7 x 25.4 mm = 177.8 mm
    177.8 mm / 2 = 88.9 mm
    88.9 - 38 offset = 50.9 mm
    87.3 - 50.9 mm = 36.4 mm spacer needed?
    If this is the case, then why are there so many ppl on here who say that 20 mm is the max you can go on rear stock monte rims before you experience rubbing?? What am I doing wrong in my calculation? HELP !!! thanks,
  14. 03-31-2005 11:44 PM #14
  15. 04-05-2005 07:22 PM #15
    Quote, originally posted by GTIk2to »
    You are using the wrong first number measure the width of the tire -- not the rim UNLESS you are using stretched tires.
    I'll pretend you have 225mm tires -- which isn't the true width -- but we'll give it a shot.
    225/2 = 112.5 - 38 = 74.5
    87.3125 - 74.5 = 12.812 so depending on how much you are lowered I think 15 mm would bring you quite flush.
    Substitute in the correct tire width -- measure not from the side of the tire and you should be okay.
    Modified by Kahnjr321 at 7:25 PM 4-5-2005
  16. 06-24-2005 11:24 AM #16
    yo can anyone tell me what size spacer i would need for 17x7 et +48mm this is for a 2001 golf gti
    -thanks
  17. 06-24-2005 11:58 AM #17
    ok i tried doing the formula tell if im on the right track
    17x7 et+48mm
    i got 6.5mm for the front so im guessing i would go with 8mm spacers???
    now for the rear i got 22mm so 25mm spacers would do it??? correct me if im wrong
    -thanks
  18. 07-19-2005 05:36 PM #18
    Quote, originally posted by IronFistMonk »
    That would equal your wheels sticking out the sides and rubbing over bumps, you would want the next size smaller not to rub.
  19. 03-18-2007 12:54 PM #19
    Great post
    However i have BBS RK's Silver painted the rims are 7 inches wide and the ET 48. I tried putting them on last night at work but when i did the wheel goes in too deep therefore it slightly touches the brake caliper. I was devastated because i was really looking forward in putting them on. So now I need spacers so how would i calculate the spacers that i need for these wheels considering that i want to lower my car in the future.
    I used the formula that you have I have 215/45/17 (7Jx17h2 ET 48) does that mean i need 11.5 mm spacers in the front and 27.5 mm in the back and if so how long the bolts are supposed to be and i can't determine what is the seat on my rims as well I thought it was conical but I also thought that the stock bolts were conical as well not the ball seat.
    Well i would love to hear back from you because I really want to put these rims on as soon as possible.
    Thanks
  20. Member burtondk12's Avatar
    Mar 19th, 2006
    93 hoopty slc. 97 drop top
    03-18-2007 12:58 PM #20
    CT / tristate suspension/ airride installs. pm me for details
  21. 03-20-2007 12:38 PM #21
    also looking for help my gti vr6 is lowered 1.5 inches and has 15" DE wheels with 205/50/15 rubber what is the largest i can go without rubbing
  22. 04-01-2007 10:33 AM #22
    I'm sorry I still don't understand this...when would you need spaces...are they required for example to lower your car...what exactly is the purpose of them...
  23. 04-01-2007 11:04 AM #23
    To space out your wheels from the hub, to give you that wide euro stance
  24. Member GTIaintNOgOlF's Avatar
    Apr 24th, 2006
    Amherst, NY
    2002 Beetle GL
    04-12-2007 02:29 PM #24
    i have the 20th stock rims and wheels.....so i shud just go with 15mm in back and 10mm in front?
    WTB:
    2 beetle fog lights in good condition, no cracks
    passenger side door latch actuator
    both door panels preferrably in black but ill consider another color
  25. 08-22-2007 03:57 AM #25
    I ordered a pair of 5mm spacers. im wondering if: i shoudl have gone bigger, i want it to look good,subtle and clean on a stock car. will i run into any problems when installing (rubbing etc).
    i have a completely stock 2003 GTI on stock 17's
    also ive been looking in the DIY for how to install these and i cant coe up with anything. Can anybody send me a link?
    Modified by Illuminati63 at 10:42 AM 8-22-2007
  26. Member the_journalist's Avatar
    Jul 21st, 2004
    Irmo, SC
    '03 GTI, '84 'Rocco, '02 NB Turbo
    08-22-2007 05:41 AM #26
    Quote, originally posted by Illuminati63 »
    With those wheels you can easily go with 10mm in front and 20mm in the rear. However, if you're running stock suspension still, it will just accentuate the wheel gap.
  27. 08-22-2007 10:48 AM #27
    well see i have a small problem with going 20mm, one i dont want to do alot to my car until its mine. second, because my dad still owns it he is against me modifying it heavily. so i dont want the excessive stance because i think it would look ugly on a stock car. which is why i went with the 5mm. ill take before and after pics to show today but can someone with a pretty much stock exterior show me the 10mm? thanks
    Modified by Illuminati63 at 10:58 AM 8-22-2007
  28. 08-22-2007 10:57 AM #28
    well see i have a small problem wiht going 20mm, one i dont want to do alot to my car till its mine. second, because my dad still owns he he is against me modifying it heavily. so i dont want the excessive stance because i think it would look ugly on a stock car. which is why i went with the 5mm. ill take before and after pics to show today but can someone with a pretty much stock exterior show me the 10mm? thanks
    Just search a little man, you will find tons of people running 10/20mm spacers w/ stock wheels and height. It does look better and remember, a 5mm spacer is just 3/16s of an inch so it's going to be very mild.
  29. Member
    Mar 24th, 2002
    Central, NJ
    01 VW Jetta 1.8T
    09-17-2007 02:18 PM #29
    First off, this is a very informative write up which increased my understanding of wheel offset and spacing.
    I'm trying to figure out what size spacers I would need for the "flush" look. Here are my wheel specs and calculations.
    H&R/Billstein sports 1.5" drop
    19 x 8 et35 w(235/35/19 pilot sports ps2)
    235/2 = 117.5 - 35 = 82.5
    87.3125 - 82.5 = 4.81 (so a 5mm spacer in the rear)
    71.4375 - 82.5 = -11(apprx front) Does this mean the front will poke?
  30. Member VR's Avatar
    Jul 2nd, 2001
    PA
    08 Suzuki SV650sf, 07 Passat Wagon 3.6L 4MO
    03-16-2008 10:41 PM #30
    was this measurement taken from the inside of the fenders or the outer edge? I plugged in 225 and ET of 35 and I came up with 6.5 F and 9.5 R. This seems very mild to what I have seen around. I was thinking if you measured to the inside of the fender this would make more sense, measuring front the outside could add a few MM.
  31. 03-16-2008 11:01 PM #31
    Edit for noobness: My ass is blind.
    Modified by Gakka at 11:07 PM 3-16-2008
  32. Member VR's Avatar
    Jul 2nd, 2001
    PA
    03-16-2008 11:03 PM #32
    Quote, originally posted by Gakka »
    busted pics?
    look at the original post date
  33. 05-15-2008 12:05 PM #33
    I know this is an old post but I'm buying some sawblades this weekend. I just want to make sure I have the calcs correct.
    wheel = 56mm offset
    f 215mm wide/2 = 107 - 56 = 51 , 71 - 51 = 20mm
    r 241mm wide/2 =120 - 56 = 64 , 87 - 56 = 23mm
    So what I gather is I need 20mm adaptors front and back and should be fine BUT I saw two seprate guys saying f1.3' and r1.5" for these wheels. Would that just be personal preferance? Thanks for you help.
  34. Member Kelevra85's Avatar
    Sep 1st, 2008
    Rota, Spain
    2003 VW VR6 Jetta
    09-23-2008 03:57 AM #34
    havin some trouble figuring out what size i need..
    Stock VR6 gli w/ monte carlos
    i'm about to Purchase a Koni Coilovers
    what size spacers would i need to flush up
  35. Member Navydub's Avatar
    Sep 29th, 2006
    Pleasant Prairie, WI
    Saab STi and a Land Rover
    09-23-2008 04:42 AM #35
    Best...Post....EVAR
    Turbo Unicorn | HS Tuning | 42DD | Cabin Krew
