Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 103
Thread: VAG-COM Controller Lists from Phaetons
  1. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    03-25-2005 11:25 PM #1
    The folks in the Touareg forum have created a very useful post that contains controller scan reports of different Touareg trucks with different equipment configurations. This compilation of controller lists is very useful to those of us who are trying to figure out how to add features or modify certain behaviors of our vehicles. So, I thought it would be useful to have a similar list of controller scans in one post for the Phaeton.
    If you have access to a VAG-COM diagnostic scan tool - or, if you can print the results of a VAS 5051 or 5052 scan to an Adobe Acrobat PDF, rather than a paper printer - please post the scan here, and describe briefly what kind of vehicle the scan came from.
    If you are doing this with a VAG-COM, please use the "Control Module Finder" button in the upper left of the VAG-COM start screen, rather than doing an "Auto-Scan". The difference is significant, the Control Module Finder will return a far more complete list of controllers than the Auto-Scan will. Just be aware that it takes about half an hour to do a Control Module Finder scan, for this reason, it is best to leave your engine running when you do this, to avoid communications errors caused by a drop in voltage from the vehicle power supply battery during the scan. After you have done the scan, copy the results to a blank text file (or Microsoft Word file), and either post the results here, or email them to me and I will post them here for you.
    A very important advantage of using the 'Control Module Finder' to do the scan that you will post here is that you don't have to worry about editing out all the horizontal dashed lines, fault codes, and other stuff like that. The 'Control Module Finder' scans only report on the controllers, their software version, and their coding. Fault codes are not polled, and the results of the scan are not formatted or paginated.
    Press THIS button when you do a scan for posting here
    - This will take about 30 minutes to complete. It's best to have the engine running during this process.
    Modified by PanEuropean at 3:14 AM 1-22-2008
  2. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    03-25-2005 11:26 PM #2
    Here are the results from my Phaeton. It is a 2004 W12 Premiere Edition, sold in Canada.
    Address 01: Engine
    Controller: 07C 906 018 C
    Component: D1-6.0L-AG-LEV G ª5211
    Coding: 0000173
    Shop #: WSC 01065 The shop code 01065 seems to be the identification used by the Transparent Factory in Dresden.
    Address 02: Auto Trans
    Controller: 3D0 927 156 N
    Component: AG5 01L 6.0 W12 USA 1114
    Coding: 0001102
    Address 03: ABS Brakes
    Controller: 3D0 614 517 R
    Component: ESP 5.7 allrad H33 0043
    Coding: 0008397
    Address 05: Acc/Start Auth.
    Controller: 3D0 909 135 M
    Component: Kessy 6400
    Coding: 0133356
    Address 06: Seat Mem. Pass
    Controller: 3D0 959 759 B
    Component: Sitzmemory D1 BF 1520
    Coding: 0000003
    Address 07: Control Head
    Controller: 3D0 035 008 M
    Component: ZAB COCKPIT 0188
    Coding: 0500305
    Address 08: Auto HVAC
    Controller: 3D0 907 040 G
    Component: Climatronic D1 1132
    Coding: 0000001
    Address 09: Cent. Elect.
    Controller: 3D0 937 049 G
    Component: STG.Bordnetz 5001
    Coding: 0000003 The coding of 3 here indicates that I have the daylight running lights turned off. The normal value for North America is 2.
    Address 11: Engine II If an engine has more than 8 cylinders, it needs a second, slave engine controller to look after cylinders 9 and up.
    Coding: 0000173
    Address 15: Airbags
    Controller: 3D0 909 601 D
    Component: 0A Airbag 8.4E+ H07 0934
    Coding: 0012353
    Address 16: Steering wheel
    Controller: 3D0 953 549 E
    Component: Lenksäulenmodul 3401
    Coding: 0000232 The coding 232 indicates that I have a heated steering wheel, 4 buttons on the cruise control side, and electric tilt and telescope.
    Address 17: Instruments
    Controller: 3D0 920 881 K
    Component: KOMBIINSTRUMENT RB4 0312
    Coding: 0005121 The 5 in the coding indicates that I have the brake wear indicator and low windshield washer fluid alert active, but not the seat belt warning chime. The 1 to the right of the 5 indicates I have set the country code to Europe, which disables the key in ignition with door open warning chime. The final 21 at the extreme right is the standard coding for North American Phaetons.
    Address 19: CAN Gateway
    Controller: 6N0 909 901
    Component: Gateway K<>CAN 0101
    Coding: 0000006
    Address 25: Immobilizer
    Coding: 0133356
    Address 28: HVAC, Rear
    Controller: 3D0 919 158 F
    Component: Klima-Bedienteil D1 0117
    Coding: 0000000
    Address 29: Left Light
    Controller: 3D0 909 157
    Component: EVG GDL+AutoLWR(l) X012
    Coding: 0000001
    Address 31: Engine other
    Controller:
    Address 33: OBD-II
    Controller: OBD-II/EOBD
    Address 34: Level Control
    Controller: 3D0 907 553 B
    Component: LUFTFDR.-CDC- 3C1V0 1101
    Coding: 0015500 The two fives in the middle indicate that no correction factor is applied to the standard European ride height settings. North American Phaetons ship with two sevens, indicating that the body of the car should correct upwards by 10 mm from the design ride height of the Phaeton.
    Address 36: Seat Mem. Drvr
    Controller: 3D0 959 760 B
    Component: Sitzmemory D1 F 1520
    Coding: 0000004
    Address 37: Navigation
    Controller: 3D0 919 887 A
    Component: NAVIGATION 0147
    Coding: 0400000
    Address 38: Roof Electronics
    Controller: 3D0 907 135 B
    Component: Dachmodul 0605
    Coding: 0000015
    Address 39: Right Light
    Controller: 3D0 909 158
    Component: EVG GDL+AutoLWR(r) X012
    Coding: 0000001
    Address 46: Central Conv.
    Controller: 7L0 907 719
    Component: Neigungssensor 0020 The 'tow-away protection' (tilt-sensor) device is built into this control module, hence the German name Neigungssensor, or inclination-sensor. This is not to be confused with level sensing for the air-ride suspension, which is handled by the controller at address 34.
    Coding: 0000000
    Address 47: Sound System
    Controller: 3D0 035 466
    Component: 12K-AUDIOVERST 0115
    Coding: 0000000
    Address 65: Tire Pressure
    Controller: 3D0 907 273 C
    Component: Reifendruckueberw. 0021
    Coding: 0010284
    Address 66: Seat, Rear PS
    Controller: 3D0 959 860 B
    Component: Sitzmemory D1 H 1513
    Coding: 0000001
    Address 68: Wiper Electr.
    Controller: 3D1 955 119
    Component: Front Wiper 2005
    Coding: 0000000
    Address 71: Battery Charger
    Controller: 3D0 915 181 B
    Component: Batteriemanagement 2600
    Coding: 0000000
    Address 75: Telematics
    Controller: 3D0 035 617
    Component: Telematik NAR1 0101
    Coding: 0061860
    Address 76: Park Assist
    Controller: 3D0 919 283 C
    Component: 03 Einparkhilfe 0807
    Coding: 0000000
    Modified by PanEuropean at 2:20 AM 4-26-2005
  3. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    03-25-2005 11:32 PM #3
    Here are the results from a very early production 2004 V8 Phaeton, sold in the United States of America. Controller 71 is missing from this scan.
    Address 01: Engine
    Controller: 4D0 907 560 CS
    Component: 4.2L V8/5V G 0030
    Coding: 0007873
    Controller: 09L 927 760 G
    Component: AG6 09L 4,2L V8 1903
    Coding: 0001102
    Coding: 0008376
    Controller: 3D0 909 135 K
    Coding: 0002280
    Component: Sitzmemory D1 BF 1401
    Coding: 0000003
    Controller: 3D0 035 008 Q
    Component: ZAB COCKPIT 0223 Normally, an early production car such as this one would not have such a high software revision number (0223) for the J523 Front Information Display Control Head. In the case of this vehicle, the Control Head was replaced in early 2005, and the replacement Control Head was a much newer part - with a higher software revision level - than the one that was originally installed in the car.
    Coding: 0400305
    Controller: 3D0 907 040 F
    Component: Climatronic D1 1127
    Coding: 0000002
    Coding: 0000002
    Address 15: Airbags
    Component: X6 Airbag 8.4E+ H07 0924
    Coding: 0022582
    Controller: 3D0 953 549 B
    Component: Lenksäulenmodul 3301
    Coding: 0000032 Note the lack of a 2 in the third position from the right. This indicates that this vehicle does not have a heated steering wheel.
    Controller: 3D0 920 981 A
    Coding: 0007221 This is the standard coding for an American car - seat belt warning is active (a 7), and the country code is 2, for USA, rather than 1 for Europe.
    Coding: 0000006
    Coding: 0000001
    Coding: 0017700 Compare the standard coding here of 17700 (a 10 mm correction factor upwards) with the coding for my car, shown above.
    Component: Sitzmemory D1 F 1401
    Coding: 0000004
    Coding: 0400000
    Coding: 0000046
    Coding: 0000001
    Controller: 3D0 959 933 F
    Component: HSG 0101
    Coding: 0000040
    Coding: 0000000
    Coding: 0011304
    Coding: 0000000
    Coding: 0061860
    Coding: 0000000
    Modified by PanEuropean at 4:34 AM 4-26-2005
  4. Member
    Sep 13th, 2004
    Great Falls, Virginia, USA
    2004 Phaeton V8 Mirror Silver, 2006 Touareg V10 TDI Off-Road Grey, 2008 Diamond DA40 XLS (airplane)
    03-27-2005 09:10 AM #4
    I've updated this post to reflect the results of a full controller scan, following Michael's recommendation.
    Again, my car is a 2004 V8 with only 2 options: upgraded sound system and the comfort package. Note that I've modified the coding of a few modules, including instruments (17) and level control (34).
    - Dave
    Address 01: Engine
    Component: 4.2L V8/5V G 0040
    Coding: 0007873
    Controller: 09L 927 760 C
    Component: AG6 09L 4,2L V8 1003
    Coding: 0001102
    Controller: 3D0 614 517 AK
    Component: ESP 5.7 allrad H33 0047
    Coding: 0008376
    Coding: 0006376
    Coding: 0000003
    Component: ZAB COCKPIT 0220
    Coding: 0500305
    Component: Climatronic D1 1145
    Coding: 0000001
    Coding: 0000003
    Skipping Address 15-Airbags
    Coding: 0000232
    Controller: 3D0 920 981 H
    Component: KOMBIINSTRUMENT RB4 0411
    Coding: 0005021
    Coding: 0000006
    Coding: 0006376
    Coding: 0000000
    Coding: 0000001
    Address 33: OBD-II
    Coding: 0015500
    Coding: 0000004
    Controller: 3D0 919 887 F
    Component: NAVIGATION 0168
    Coding: 0400000
    Coding: 0000047
    Coding: 0000001
    Component: 12 HSG 0101
    Coding: 0000034
    Coding: 0000000
    Coding: 0011204
    Component: Sitzmemory D1 H 1524
    Coding: 0000001
    Coding: 0000000
    Controller: 3D0 915 181 C
    Component: Batteriemanagement 2700
    Coding: 0000000
    Coding: 0061860
    Formatting edit: removed comm. protocols and WSC’s for space reasons - Michael
    Modified by PanEuropean at 5:00 PM 4-11-2005
  5. 03-27-2005 10:54 PM #5
    This is the for the following car: 2004, 4 seater V8, Keyless start, No chime for key in ignition, No chime for seat belt, Front suspension: 390, Rear suspension: 400
    Address 01: Engine
    Coding: 0007873
    Coding: 0001102
    Coding: 0008376
    Coding: 0137452
    Coding: 0000003
    Coding: 0500305
    Coding: 0000001
    Coding: 0000002
    Address 16; Steering wheel
    Coding; 0000232
    Component: KOMBIINSTRUMENT RB8 0411
    Coding: 0005021
    Coding: 0000006
    Coding; 0137452
    Controller: 3D0 919 158 G
    Component: Klima-Bedienteil D1 0017
    Coding: 0000000
    Coding: 0000001
    Address 33: OBD-ll
    Controller: OBD-ll/EOBD
    Coding: 0017700
    Coding: 0000004
    Coding: 0400000
    Coding: 0000047
    Coding: 0000001
    Component: 1A HSG 0101
    Coding: 0000040
    Coding: 0000000
    Coding: 0011204
    Component: Sitzmemory D1 H 1526
    Coding: 0000001
    Coding: 0000000
    Coding: 0000000
    Coding: 0061860
    Coding: 0000000
    Formatting edit made to remove dashed lines and WSC's, for easier reading. Michael
    Modified by PanEuropean at 10:04 PM 3-28-2005
    Modified by fly4food at 10:59 AM 4-17-2005
  6. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    03-28-2005 12:12 AM #6
    David, Philippe:
    Thanks for posting those two scans, they are very useful to me.
    It is interesting to note - just a quick review here, not an in-depth study - the advances in software coding for some of the modules.
    The software code for each module is shown in red in the example below. It will always be the four digit number at the far right end of the "Component" line. Software can be flash-updated in the field. The fact that a component has a later release of software in it does not always mean that it is 'better' - in many cases the changes to the software are made to support options that are added later, for example, soft close doors.
    Looking at the software for the Control Head (the Front Information Display Control Head, or J523, that big screen between the two front seats), you can see that my car, built in September of 2003, has software version 0188 in it, the V8 that I posted, which was built in early 2003 but later had the control head replaced (it broke) has version 0223 in it, and Dave and Philippe's cars have 0220 in them. I know that version 0223 deletes the soft-key for RDS (the soft-key that does not work) and provides a 'present position' screen to replace the 'MANUAL' button that we have that presently does nothing.
    The two early-build cars (mine, and the early 2003 build V8) have 0147 for Navigation, the two later build cars have 0168.
    I also note that I have a totally different part number for my central convenience controller (address 46), and different coding for it also, than everyone else. That really perplexes me.
    Michael
    Which Number is the Software version number
    Coding: 0500305
  7. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    03-28-2005 01:52 AM #7
    I have attached a zipped archive at the bottom of this post that contains new and updated VAG-COM label files for the Phaeton. This collection of files represents about 100 hours of work writing and testing the files. These will be included with the next release of VAG-COM, however, I thought I would post them here now for those of you who have VAG-COM scan tools.
    To use these files, unzip the archive, and put all the files into the folder named 'USER' which will be found at the following path: C:/Program Files/VAG-COM/Labels/User. If you are running one of the 500.x beta versions of VAG-COM, then the VAG-COM folder will be at the root level of your drive, not in the Program Files folder.
    When the final version of VAG-COM 5 ships, you can delete all these files from your user folder, because they will be included with the new release in the 'LABELS' folder.
    The zipped archive contains 26 text files. Label files are nothing more than just text files with the suffix .LBL instead of .TXT So, you should not have any concerns about virus problems, executables, stuff like that, although it is always good practice to scan something like this first. If you want to view one of the files to see what is in it, just double-click on it, and choose WordPad (or your word processor) as the application to use to open it. Lastly, there is a read-me file - in .TXT format - in this bundle, if you open it and read it, it will give you an overview of what files exist for the Phaeton.
    Michael
  8. 03-28-2005 09:47 AM #8
    Can I disable rear head rests...since my little guy is not heavy enough to permanently activate the head rest and as a result is raises and lowerers frequesntly while he is in the seat...once catching and pinning his hand when it lowered itself on him.
    My dealer said nothing I could do. I also, however, don't want to disable other features.
    Thanks.
    I ask because I see a vag-com code for rear seat.
    Also, did you lower your car and how do you like it?
  9. 03-28-2005 03:49 PM #9
    There was a previous discussion regarding the headrest - follow this thread:
    http://forums.vwvortex.com/zerothread?id=1757298 (rear headrest)
  10. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    03-28-2005 05:13 PM #10
    Hi Gregory:
    First, thanks to Agnos for providing the link to the rear seat headrest discussion. That pretty much sums up all we know about the rear seat headrests at this moment. There might be a way to disable the rear seat headrests via adaptation or coding, but I don't know what it is. That particular controller (address 66) is not one of the ones I have documented.
    About lowering the car - all I did was just reset the coding for my Phaeton to the original design specifications (i.e. no upwards correction to ride height applied anymore), then I re-adapted (re-calibrated) the car. As a group, we have figured out about 95% of this process, but not quite 100%. David Cowan is the forum member with the greatest expertise on this subject. You can find some discussions about ride height at the following links - note carefully the posting dates, because our knowledge of the system grew over time. We started out by 'fooling the system', inputting overly high measurement values, and now we have learned to change the correction factor, then input true measurement values. The 5% we have not fully figured out is how to consistently get the car to re-adapt following changes made to the correction values. I had no problem, but David has had problems. On the other hand, a few months ago, David was able to drop his Phaeton half a foot by 'fooling the system', whereas I was unable to fool my car at all - it just rejected my falsified measurements.
    Here are the links:
    Let's talk about ride height (original exploration of this subject)
    Calling all Phaeton Owners who have a VAG-COM (Discovery of the coding correction values)
    Lowering my baby/VAG Tool (most recent discussion)
    As I said, watch the dates of the conversations carefully, some earlier hypothesis have been repudiated in later discussions.
    Michael
  11. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    03-28-2005 05:17 PM #11
    For the record, here is the status of our research and knowledge concerning measured value blocks, coding, and adaptation information for the Phaeton. This information is also contained in a 'read me' file within the archive I posted above.
    The following label files are provided for the Phaeton:
    ADDRESS ID Description Label File ID
    01 Master Engine Controller W12 BAP Engine 07C-906-018-BAP1.lbl
    11 Slave Engine Controller W12 Engine 07C-906-018-BAP2.lbl
    01 Engine Controller V8 BGH Engine 4D0-907-560-CS.lbl
    02 Five-Speed Automatic Transmission 3D0-927-156.lbl
    03 ABS Brake Electronics 3D0-614-517.lbl
    05 Access and Start Control Module (Kessy) 3D0-909-135.lbl
    07 Front Information Display Control Head 3D0-035-008.lbl
    09 Central Electronics 3D0-937-049.lbl
    13 Automatic Distance Regulation 3D0-907-563.lbl
    16 Steering Wheel Electronics 3D0-953-549.lbl
    17 Instrument Cluster 3D0-920-xxx-17.LBL
    19 CAN Gateway (part of J285) 6N0-909-901.LBL
    34 Level Control System 3D0-907-553.lbl
    37 Navigation with CD Mechanism 3D0-919-887.lbl
    38 Roof Electronics 3D0-907-135.lbl
    46 Central Control for Comfort System 7L0-907-719.lbl OR 3D0-959-933.lbl
    47 Digital Sound System Control Module 3D0-035-4xx-47.LBL
    57 Television Tuner 3D0-919-146.lbl
    65 Tire Pressure Monitoring 3D0-907-273.lbl
    71 Battery Monitoring 3D0-915-181.lbl
    75 Control Module for Telematics (NAR) 3D0-035-617.lbl
    76 Park Distance Control 3D0-919-283.lbl
    The following Phaeton controllers have not yet been documented for VAG-COM
    01 Engine Controller for V6 or V10
    11 Slave Engine Controller for V10
    06 Passenger Memory Seat
    08 Climatronic
    15 Airbag Control Module
    18 Auxiliary Heater (Park-heating)
    23 Brake Booster (installed with Adaptive Cruise Control only)
    27 Rear Information Display Control Head (large display, not just rear climate)
    36 Driver Memory Seat, Steering Column Adjustment
    66 Rear Memory Seat
    68 Wiper Control Module (includes slave J584)
    69 Control Module for Towing Sensor
    77 Telephone (not NAR Telematics, but cell phone)
    The following controllers are accessed via address 46 (Central Control for Comfort System)
    Trunk Lid Servo Assist Control Module (J605)
    All door control modules (J386, J387, J388, J389)
    All door soft-close control modules (J657's in each soft-close door)
    April 2005
    Modified by PanEuropean at 10:47 PM 4-12-2005
  12. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    03-28-2005 09:49 PM #12
    Here is a controller scan from a new series (D3) Audi A8 with a 4.2L engine. It appears that there are very few - if any - commonalities between this car and the Phaeton. This may be due to the fact that Audi has implemented CAN (Controller Area Network) communication for diagnostic purposes on the D3 series. The Phaeton, Bentley, and Touareg do not use this protocol.
    Control Module Listing from an Audi A8 (D3 series)
    Address 01: Engine
    Protocol: CAN
    Controller: 4E0 910 560 A
    Component: 4.2L V8/5V G 0070
    Coding: 0007773
    Protocol: CAN
    Controller: 4E0 910 156 E
    Component: AG6 09E 4,2L5V USA 0110
    Coding: 0000002
    Protocol: CAN
    Controller: 4E0 910 517 B
    Component: ESP 5.7 allrad H44 0500
    Coding: 0007597
    Protocol: CAN
    Controller: 4E0 910 131
    Component: FBS AUDID3 H03 0140
    Coding: 0263168
    Protocol: CAN
    Controller: 4E0 910 760 C
    Component: Sitzmemory BFS H07 0060
    Coding: 0794720
    Protocol: CAN
    Controller: 4E0 910 729 J
    Component: Interfacebox H43 0600
    Coding: 0000103
    Protocol: CAN
    Controller: 4E0 910 043
    Component: KLIMAAUTOMAT 016 0240
    Coding: 0037121
    Protocol: CAN
    Controller: 4E0 910 279 E
    Component: ILM Fahrer H11 0100
    Coding: 0111111
    Address 0E: Media Player 1
    Protocol: CAN
    Controller: 4E0 910 111 C
    Component: CD-Changer H43 0340
    Coding: 0000000
    Protocol: CAN
    Controller: 4E0 910 549
    Component: Lenksäulenmodul H13 0040
    Coding: 0012041
    Protocol: CAN
    Controller: 4E0 910 900
    Component: KOMBIINSTR. VDO H44 0090
    Coding: 0016403
    Protocol: CAN
    Controller: 4E0 910 468 A
    Component: Gateway H07 0030
    Coding: FCFE7BDD1B2304
    Protocol: CAN
    Coding: 0263168
    Protocol: CAN
    Controller: 4E0 910 553 E
    Component: LUFTFDR.-CDC H05 4290
    Coding: 0011110
    Protocol: CAN
    Component: Sitzmemory FS H07 0060
    Coding: 0925794
    Protocol: CAN
    Controller: 4E0 910 887 K
    Component: MNS US H42 0570
    Coding: 0000000
    Protocol: CAN
    Controller: 4E0 910 135 A
    Component: Dachknoten D3 H01 0090
    Coding: 0003973
    Address 42: Door Elect, Driver
    Protocol: CAN
    Controller: 4E1 910 802
    Component: Türsteuer.FS BRM005 0110
    Coding: 0028196
    Protocol: CAN
    Controller: 4E0 910 289 A
    Component: Komfortgeraet H03 0030
    Coding: 0064606
    Protocol: CAN
    Controller: 4E0 910 223 H
    Component: DSP-High D3/AUX H13 0370
    Address 4F: Centr. Electr. II
    Protocol: CAN
    Controller: 4E0 910 280 A
    Component: ILM Beifahrer H08 0020
    Coding: 0010111
    Address 52: Door Elect, Pass.
    Protocol: CAN
    Component: Türsteuer.BF BRM005 0110
    Coding: 0028196
    Address 53: Parking Brake
    Protocol: CAN
    Controller: 4E0 910 801
    Component: EPB A01H019 H01 0190
    Coding: 0000532
    Address 55: Xenon Range
    Protocol: CAN
    Controller: 4E0 910 357
    Component: Pre-AFS H01 0040
    Coding: 0000001
    Address 56: Radio
    Protocol: CAN
    Controller: 4E0 910 541 C
    Component: TUNER EU/US/RDW H41 0290
    Coding: 0000002
    Address 61: Battery Regul.
    Protocol: CAN
    Controller: 4E0 910 181 B
    Component: ENERGIEMANAGER H02 0240
    Coding: 0000000
    Address 62: Door,Rear Left
    Protocol: CAN
    Controller: 4E0 910 802
    Component: Türsteuer.HL BRM005 0110
    Coding: 0028196
    Protocol: CAN
    Controller: 4E0 910 273
    Component: Reifendruck 2 H01 0210
    Coding: 0212127
    Address 72: Door, Rear Right
    Protocol: CAN
    Component: Türsteuer.HR BRM005 0110
    Coding: 0028196
    Protocol: KWP2000
    Controller: 4E0 910 616
    Component: Telematik USA1 0070
    Coding: 0000005
    Protocol: CAN
    Controller: 4E0 910 283 A
    Component: Parkhilfe 8-Kan H11 0010
    Coding: 0001208
  13. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    03-28-2005 10:14 PM #13
    Hello All:
    Earlier releases of VAG-COM software did not full list all of the different controllers that are installed in the Phaeton. The result of this was that when a user selected the 'Auto-Scan' function, not all the controllers present in the car were polled. I have attached below a more up to date autoscan.txt file that identifies all of the controllers that could possibly be installed in a North American Phaeton. To use this newer file, simply replace the existing 'autoscan.txt' file in your VAG-COM folder with the one below. Like the label files, this is a text only file, pure and simple, so not worries about virus or executable problems. You can even examine the contents of the file by just double-clicking on it.
    Please, though, when making controller scans for posting here, use the Control Module Finder function, as described in the first post at the top of this thread, rather than the 'Auto-Scan' function. The Control Module Finder function will return a more complete listing, without fault codes and without the dashed lines between the controllers. Be sure to leave the engine running while doing this, to avoid communication errors caused by lower than normal voltages present on some of the more sensitive controllers.
    Thanks and regards,
    Michael
    Modified by PanEuropean at 10:19 PM 3-28-2005
  14. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    03-28-2005 11:11 PM #14
    Here is a scan from a Bentley Continental GT.
    Michael
    Address 01: Engine
    Controller: 07C 906 018 J
    Component: BY-6.0L-TT G ª6240
    Coding: 0000173
    Shop #: WSC 00083 The shop code 01065 seems to be the identification used by the Bentley Factory.
    Controller: 09E 927 760 A
    Component: AG6 09E 6.0L W12TT 1005
    Coding: 0000101
    Controller: 3W0 614 517 B
    Component: ESP 5.7 4WD H01 0011
    Coding: 0007878
    Controller: 3D0 909 135 M The same PN and coding as a W12 Phaeton.
    Component: 11 Kessy 6400
    Coding: 0131309
    Controller: 3W0 959 759 A
    Component: CM Seat Pass. 0009
    Coding: 0000002
    Controller: 3W0 035 008 The same PN and coding scheme as a W12 Phaeton.
    Coding: 0400325
    Controller: 3W0 907 040 B
    Component: Climatronic BY614 0030
    Coding: 0000002
    Coding: 0000107
    Coding: 0000173
    Controller: 3D0 953 549 E The same PN and coding scheme as a W12 Phaeton.
    Coding: 0000212
    Controller: 3W0 920 840 Q
    Component: KOMBIINSTRUMENT RB8 0401
    Coding: 0023200 101101010100000
    Coding: 0000006
    Coding: 0131309
    Address 33: OBD-II - transmittion
    Controller: 3W0 907 553 The same PN and coding scheme as a W12 Phaeton.
    Component: LUFTFDR.-CDC- 3C1V0 7014
    Coding: 0015500
    Controller: 3W0 959 760 A The same PN and coding scheme as a W12 Phaeton.
    Component: CM Seat Driver 0008
    Coding: 0000002
    Controller: 3W0 919 887 A The same PN and coding scheme as a W12 Phaeton.
    Coding: 0400000
    Controller: 3W0 907 135 C The same PN and coding scheme as a W12 Phaeton - but a higher revision of software, and an unrecognized code.
    Component: Dachmodul 0702
    Coding: 0000157
    Controller: 3D0 959 933 F The exact same PN and coding scheme as a V8 Phaeton with infrared protecting glass.
    Component: 1F HSG 0101
    Coding: 0000032
    Controller: 3W0 035 456 C
    Component: 12K-AUDIOVERST 4121
    Coding: 0000000
    Controller: 3W0 907 801 A
    Component: EPB BC6HX21 HC6 X210
    Coding: 0022401
    Address 54: Rear Spoiler
    Controller: 1C0 959 733 G The exact same PN and coding scheme as a New Beetle Convetible.
    Component: Heckspoiler 0002
    Controller: 3W0 907 273 The exact same PN and coding scheme as a V8 Phaeton.
    Component: Reifendruckueberw. 0022
    Coding: 0011344
    Controller: 3W1 955 023 C
    Component: Wischermodul ª0323
    Coding: 0000000
    Controller: 3D0 915 181 C The same PN and coding scheme as a W12 Phaeton - but a higher revision of software.
    Coding: 0000000
    Controller: 3W0 919 283
    Component: 02 Einparkhilfe 0203
    Coding: 0000000
    Address 77: Telephone
    Controller: 3W0 035 729 C
    Component: Telefon 0241
    Coding: 0000000
    Modified by PanEuropean at 4:05 PM 4-11-2005
  15. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    04-11-2005 04:02 PM #15
    Here is a scan from a 2004 V8 Phaeton, Canadian spec.
    VAG-COM Version: Release 504.0-UD
    Chassis Type: 3D - VW Phaeton D1
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 34
    36 37 38 39 46 47 57 65 66 68 69 71 75 76 77
    Address 01: Engine
    Coding: 0007873
    Controller: 09L 927 760 A
    Component: AG6 09L 4,2L V8 0901
    Coding: 0001102
    Coding: 0008376
    Coding: 0002280
    Coding: 0000003
    Coding: 0400305
    Coding: 0000001
    Coding: 0000002
    Address 15: Airbags
    Controller: 3D0 953 549 D
    Coding: 0000032
    Controller: 3D0 920 881 L
    Coding: 0005121
    Coding: 0000006
    Coding: 0000001
    Coding: 0015500
    Coding: 0000004
    Coding: 0400000
    Coding: 0000047
    Coding: 0000001
    Controller: 3D0 959 933 E
    Component: 4D HSG 3212
    Coding: 0000034
    Controller: 3D0 035 456
    Component: 08K-AUDIOVERST 0109
    Coding: 0000000
    Coding: 0011204
    Coding: 0000000
    Coding: 0000000
    Coding: 0061850
    End -------------------
  16. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    04-26-2005 01:56 AM #17
    I am going to post a series of complete diagnostic scans that were done on the Phaetons at the 2004 Phaeton Owner Get-Together in Auburn Hills, MI. This group of scans will be of great value to us in the future, because it gives us a chance to compare controller and software versions between our vehicles, and it also lists common fault codes that were present.
    For example, just about everyone had a sunroof fault code present (00220 - Connection to Sunroof 004 - No Signal/Communication - Intermittent) in the Roof Electronics Control unit at address 38 - but not one of us had a sunroof problem. This suggests that this particular code is spurious - either there is a tiny flaw in the software of that controller that causes it to generate this fault code when no fault is present, or this particular controller is very, very sensitive to minor voltage drops.
    Also, by noting which scans show an "intervention load management" history in the Central Electrical controller (address 09) and seeing what other common fault codes seem to always appear following a low battery voltage condition that results in intervention load management becoming active, we can draw some useful conclusions about what intermittent fault codes can be safely ignored - meaning, they are not actually suggestive of faults, they probably arise just because of a temporary low voltage condition to a controller.
    Anyway - here they all are, showing the way the Phaetons were when they came into the shop, before any changes were made.
    Michael
  17. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    04-26-2005 01:59 AM #18
    Joe's Phaeton:
    Address 01: Engine
    Coding: 0007873
    Shop #: WSC 01065
    No fault code found.
    Readiness: 0000 0000
    Coding: 0001102
    Shop #: WSC 00000
    Coding: 0008376
    Shop #: WSC 01065
    Coding: 0006376
    Shop #: WSC 03207
    1 Fault Found:
    01176 - Key
    008 - Implausible Signal - Intermittent
    Coding: 0000003
    Shop #: WSC 01065
    Coding: 0500305
    Shop #: WSC 01065
    1 Fault Found:
    00384 - Optical Databus
    Component: Climatronic D1 1144
    Coding: 0000002
    Shop #: WSC 00000
    Coding: 0000002
    Shop #: WSC 01065
    1 Fault Found:
    00907 - Intervention load Management
    000 - -
    Address 15: Airbags
    Controller: 3D0 909 601 E
    Component: 0G Airbag 8.4E+ H10 0934
    Coding: 0012359
    Shop #: WSC 01065
    Coding: 0000232
    Shop #: WSC 01065
    Coding: 0007221
    Shop #: WSC 01065
    Coding: 0000006
    Shop #: WSC 01065
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0000001
    Shop #: WSC 01065
    Coding: 0017700
    Shop #: WSC 01065
    Coding: 0000004
    Shop #: WSC 01065
    Coding: 0400000
    Shop #: WSC 01065
    1 Fault Found:
    00625 - Vehicle Speed Signal
    004 - No Signal/Communication - Intermittent This fault has appeared on diagnostic scans of quite a few Phaetons, and we think it is not significant and can be safely disregarded. We are not sure what causes it, but it does not seem to have any symptoms associated with it.
    Coding: 0000047
    Shop #: WSC 01065
    2 Faults Found:
    004 - No Signal/Communication - Intermittent Everyone has this fault code, without exception. Because none of us has ever encountered a problem with our sunroof, we think this fault code can be disregarded any time it appears.
    00216 - Signal EC-mirror Fade Out
    009 - Open or Short to Ground
    Coding: 0000001
    Shop #: WSC 01065
    Component: 12 HSG 0100
    Coding: 0000034
    Shop #: WSC 01065
    3 Faults Found:
    00316 - Bulbs for Rear Illumination
    00933 - Electric Window Motor; Passenger Side (V148)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    00132 - Outside Door Handle Illumination/mirror Light Passenger Side
    012 - Electrical Fault in Circuit
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0011204
    Shop #: WSC 01065
    Coding: 0000001
    Shop #: WSC 00000
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0061860
    Shop #: WSC 03207
    Modified by PanEuropean at 4:15 AM 4-26-2005
  18. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    04-26-2005 02:01 AM #19
    George's Phaeton:
    Address 01: Engine
    Coding: 0000173
    Shop #: WSC 01065
    1 Fault Found:
    18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
    P1951 - 002 - Lower Limit Exceeded - Intermittent
    Coding: 0001102
    Shop #: WSC 98765
    Coding: 0008397
    Shop #: WSC 01065
    Coding: 0133356
    Shop #: WSC 01065
    Component: Sitzmemory D1 BF 1501
    Coding: 0000003
    Shop #: WSC 01065
    Coding: 0500305
    Shop #: WSC 01065
    1 Fault Found:
    Coding: 0000002
    Shop #: WSC 00000
    Coding: 0000003
    Shop #: WSC 02172
    1 Fault Found:
    000 - -
    Coding: 0000173
    Shop #: WSC 01065
    Address 15: Airbags
    Coding: 0012353
    Shop #: WSC 01065
    Coding: 0000232
    Shop #: WSC 01065
    Coding: 0007221
    Shop #: WSC 01065
    Coding: 0000006
    Shop #: WSC 01065
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0000001
    Shop #: WSC 01065
    Coding: 0017700
    Shop #: WSC 01065
    Component: Sitzmemory D1 F 1501
    Coding: 0000004
    Shop #: WSC 01065
    Coding: 0400000
    Shop #: WSC 01065
    Coding: 0000015
    Shop #: WSC 98765
    1 Fault Found:
    Coding: 0000001
    Shop #: WSC 01065
    Component: Neigungssensor 0020 Again, interesting to note here that George's Phaeton - also a W12 - has an inclination sensor in this module, same as my car does. The V8 Phaetons don't seem to have this tow-away protection component.
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0011224
    Shop #: WSC 02172
    Coding: 0000001
    Shop #: WSC 00000
    Coding: 0000000
    Shop #: WSC 00000
    Controller: 3D0 915 181 A
    Component: Batteriemanagement 2500 It seems that the A suffix controllers have software revision 2500, the B suffix have revision 2600, and the C suffix have revision 2700. The C suffix controller appears to do a better job of maintaining voltage on the Vehicle Power Supply battery, but we don't have a big enough sample to make a firm conclusion about this. Right now, this is just a hypothesis.
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0061860
    Shop #: WSC 02172
    Coding: 0000000
    Shop #: WSC 00000
    Modified by PanEuropean at 4:19 AM 4-26-2005
  19. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    04-26-2005 02:03 AM #20
    Bob's Phaeton:
    Address 01: Engine
    Coding: 0007873
    Shop #: WSC 01065
    1 Fault Found:
    16840 - EVAP System: Very Small Leak Detected
    P0456 - 002 - Lower Limit Exceeded - Intermittent
    Coding: 0001102
    Shop #: WSC 00000
    Coding: 0008376
    Shop #: WSC 01065
    Coding: 0006376
    Shop #: WSC 01065
    1 Fault Found:
    00165 - Switch for Transmission Position P/N
    007 - Short to Ground - Intermittent
    Coding: 0000003
    Shop #: WSC 01065
    Coding: 0400305
    Shop #: WSC 01065
    Coding: 0000002
    Shop #: WSC 00000
    Coding: 0000002
    Shop #: WSC 01065
    1 Fault Found:
    00907 - Intervention load Management This is a fairly common message. We don't think it is a "fault", in the sense that something is broken, we think it is just a message indicating that at some time in the past, the battery voltage got a little low. There seems to be a very high correlation between the presence of an 'Intevention Load Management' message, and the appearance of intermittent fault code messages in other controllers that appear to be working perfectly well. So, if you see this message, be quite skeptical about 'intermittent' messages on other controllers that are not actually demonstrating any functional problem.
    000 - -
    Address 15: Airbags
    Coding: 0012353
    Shop #: WSC 01065
    Coding: 0000032
    Shop #: WSC 01065
    Coding: 0007221
    Shop #: WSC 01065
    Coding: 0000006
    Shop #: WSC 01065
    Coding: 0000001
    Shop #: WSC 01065
    Coding: 0017700
    Shop #: WSC 01065
    Coding: 0000004
    Shop #: WSC 01065
    Coding: 0400000
    Shop #: WSC 01065
    1 Fault Found:
    Coding: 0000047
    Shop #: WSC 25807
    1 Fault Found:
    Coding: 0000001
    Shop #: WSC 01065
    Coding: 0000034
    Shop #: WSC 01065
    Controller: 3D0 035 465
    Component: 08K-AUDIOVERST 0111
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0011204
    Shop #: WSC 01065
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0061850
    Shop #: WSC 02132
    Modified by PanEuropean at 4:24 AM 4-26-2005
  20. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    04-26-2005 02:06 AM #21
    Chris's Phaeton
    (This is a very early production vehicle - almost what you could consider a prototype - so it should not be considered representative of the fleet)
    Address 01: Engine
    Coding: 0007873
    Shop #: WSC 98765
    Coding: 0001102
    Shop #: WSC 00000
    Coding: 0008376
    Shop #: WSC 01065
    Coding: 0002280
    Shop #: WSC 01065
    2 Faults Found:
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    01299 - Diagnostic Interface for Data Bus (J533)
    Coding: 0000003
    Shop #: WSC 01065
    1 Fault Found:
    Coding: 0400305
    Shop #: WSC 01065
    Coding: 0000002
    Shop #: WSC 00000
    1 Fault Found:
    Coding: 0000002
    Shop #: WSC 01065
    3 Faults Found:
    00978 - Lamp for Low Beam; Left (M29)
    000 - -
    Address 15: Airbags
    Coding: 0022582
    Shop #: WSC 01065
    Coding: 0000032
    Shop #: WSC 01065
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    Controller: 3D0 920 980 N
    Component: KOMBIINSTRUMENT RB4 0310
    Coding: 0007221
    Shop #: WSC 01065
    Coding: 0000006
    Shop #: WSC 01065
    Coding: 0000001
    Shop #: WSC 01065
    Coding: 0017700
    Shop #: WSC 98765
    Coding: 0000004
    Shop #: WSC 25807
    1 Fault Found:
    Coding: 0400000
    Shop #: WSC 01065
    Coding: 0000047
    Shop #: WSC 98765
    1 Fault Found:
    Coding: 0000001
    Shop #: WSC 01065
    Component: HSG 0101
    Coding: 0000040
    Shop #: WSC 98765
    6 Faults Found:
    01504 - Bulb for License-Plate Light (X)
    009 - Open or Short to Ground - Intermittent
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    00930 - Locking Module for Central Locking; Rear Left (F222)
    00931 - Locking Module for Central Locking; Rear Right (F223)
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0011204
    Shop #: WSC 98765
    1 Fault Found:
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0061860
    Shop #: WSC 09995
    2 Faults Found:
    013 - Check DTC Memory - Intermittent
    Coding: 0000000
    Shop #: WSC 00000
    1 Fault Found:
    00435 - Right Front Inner Parking Aid Sensor (G333)
    014 - Defective - Intermittent
  21. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    04-26-2005 02:12 AM #22
    Mark's Phaeton
    Address 01: Engine
    Coding: 0007873
    Shop #: WSC 01065
    Coding: 0001102
    Shop #: WSC 00000
    Coding: 0008376
    Shop #: WSC 01065
    Coding: 0002280
    Shop #: WSC 01065
    Coding: 0000003
    Shop #: WSC 01065
    Coding: 0400305
    Shop #: WSC 01065
    1 Fault Found:
    004 - No Signal/Communication The optical databus is the fiber optic cable that runs between the CD player for the navigation CD and the J523 Front Information Display Control Head (this controller, meaning, address 07). If the nav system works well and you see the map on the screen, we believe you can quite safely ignore (erase) this fault code without further investigation.
    Coding: 0000001
    Shop #: WSC 00000
    Coding: 0000002
    Shop #: WSC 93004
    1 Fault Found:
    000 - -
    Address 15: Airbags
    Coding: 0012353
    Shop #: WSC 01065
    Coding: 0000032
    Shop #: WSC 01065
    Coding: 0005121
    Shop #: WSC 01065
    Coding: 0000006
    Shop #: WSC 01065
    Coding: 0000001
    Shop #: WSC 01065
    Coding: 0015500
    Shop #: WSC 93004
    Coding: 0000004
    Shop #: WSC 93004
    Coding: 0400000
    Shop #: WSC 01065
    1 Fault Found:
    Coding: 0000047
    Shop #: WSC 00000
    1 Fault Found:
    Coding: 0000001
    Shop #: WSC 01065
    Coding: 0000034
    Shop #: WSC 01065
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0011204
    Shop #: WSC 01065
    No Faults Found
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0061850
    Shop #: WSC 01065
    Modified by PanEuropean at 4:30 AM 4-26-2005
  22. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    05-21-2005 05:26 PM #23
    Here (following) are some scans from European Phaetons - a V6 TDI, a V10 TDI, and a W12.
    It is most interesting - funny as heck, in fact - to note that the W12, which belongs to the Transparent Factory in Dresden and is maintained by them - has the same fault codes in the roof controller that we found in all of our W12's at the Auburn Hills GTG. I suppose that means that "for sure" it is safe to ignore those roof controller fault codes, as we surmised last month!
    Michael
    V6 TDI Phaeton - German Specification (Kai's car)
    This car was built in early 2005 - it was possible to recode the Central Comfort controller (address 46) to enable remote window operation with the key fob, just by changing adaptation channel 025 from 0 to 1. This scan was done at the Phaeton Treffen in Dresden, May 2005.
    It was NOT possible to change the coding settings of the suspension controller on this Phaeton to anything other than 5, which is the default European suspension height setting. This is the first time I have found a controller that cannot be changed. I don't know whether this is something peculiar to European Controllers, or perhaps it indicates a production change in the controller software.
    Address 01: Engine
    Controller: 3D0 907 401
    Component: 3.0L V6TDI G000AG 0030
    Coding: 0011773
    Controller: 09L 927 760 E
    Component: AG6 09L 3.0l V6TDI 2201
    Coding: 0000101
    Coding: 0008356
    Controller: 3D0 909 135 N
    Component: Kessy 6610
    Coding: 0004328
    Controller: 3D0 959 759 C
    Component: Sitzmemory D1 BF 1720
    Coding: 0000003
    Controller: 3D0 035 007 P
    Coding: 0400525
    Controller: 3D0 907 040 H
    Component: Climatronic D1 2021
    Coding: 0000001
    Controller: 3D0 937 049 H
    Component: STG.Bordnetz 5101
    Coding: 0000003
    Address 15: Airbags
    Component: 0J Airbag 8.4E+ H10 0935
    Coding: 0012362
    Coding: 0000032
    Controller: 3D0 920 882 F
    Component: KOMBIINSTRUMENT RB8 0517
    Coding: 0005111
    Address 18: Aux. Heat
    Controller: 3D0 815 005 AA
    Component: Standheizung 2426
    Coding: 0000000
    Coding: 0000006
    Component: EVG GDL+AutoLWR(l) 0001
    Coding: 0000001
    Controller: 3D0 907 553 C
    Component: LUFTFDR.-CDC- 3C3V0 1122
    Coding: 0005521
    Coding: 0000004
    Controller: 3D0 919 887 E
    Coding: 0000000
    Coding: 0000059
    Component: EVG GDL+AutoLWR(r) 0001
    Coding: 0000001
    Component: 29 HSG 0101
    Coding: 0000034
    Controller: 3D0 035 466 A
    Component: 12K-AUDIOVERST 0118
    Coding: 0000000
    Controller: 3D1 955 119 A
    Coding: 0000000
    Coding: 0000000
    Component: 01 Einparkhilfe 0807
    Coding: 0000000
    Coding: 0000000
    Modified by PanEuropean at 6:57 AM 5-26-2005
  23. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    05-21-2005 05:27 PM #24
    V10 TDI Phaeton - German Specification (Oaci's car)
    Address 01: Engine
    Controller: 070 906 016 B
    Component: V10 5,0L EDCG000AGMª5726
    Coding: 0000175
    Controller: 09F 927 760 B
    Component: AG6 09F 5,0L V10TDI 1202
    Coding: 0001101
    Controller: 3D0 614 517 J
    Component: ESP 5.7 allrad H24 0042
    Coding: 0008646
    Controller: 3D0 909 135 C
    Component: Kessy 6120
    Coding: 0213228
    Component: Sitzmemory D1 BF 1405
    Coding: 0000003
    Controller: 3D0 035 007 L
    Coding: 0500735
    Controller: 3D0 907 040 D
    Coding: 0000001
    Controller: 3D0 937 049 E
    Component: STG.Bordnetz 4501
    Coding: 0000003
    Component: V10 5,0L EDCG000AGSª5726
    Coding: 0000175
    Address 15: Airbags
    Controller: 3D0 909 601 A
    Component: Airbag 8.4E 0506
    Coding: 0241705
    Coding: 0000032
    Controller: 3D0 920 881 A
    Component: KOMBIINSTRUMENT RB4 0211
    Coding: 0029111
    Controller: 3D0 815 005 M
    Component: Standheizung 2415
    Coding: 0000000
    Coding: 0000006
    Controller: 3D0 919 158 B
    Coding: 0000000
    Coding: 0000001
    Controller: 3D0 907 553 A
    Component: LUFTFDR.-CDC- 3C1V0 1090
    Coding: 0015500
    Component: Sitzmemory D1 F 1405
    Coding: 0000004
    Controller: 3D0 919 887 B
    Coding: 0500735
    Coding: 0000016
    Coding: 0000001
    Component: Neigungssensor 0018
    Coding: 0000000
    Controller: 3D0 035 456 A
    Component: 12K-AUDIOVERST 0110
    Coding: 0000000
    Address 57: TV Tuner
    Controller: 3D0 919 146
    Component: TV Tuner H07 1205
    Coding: 0000010
    Component: Reifendruckueberw. 0018
    Coding: 0010244
    Coding: 0000000
    Coding: 0000000
    Coding: 0000000
    Controller: 3D0 035 704 D
    Component: Telefon 8110
    Coding: 0000000
    Modified by PanEuropean at 6:48 AM 5-26-2005
  24. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    05-21-2005 05:30 PM #25
    W12 Phaeton - German Specification (GMD car)
    For pictures of this car, see this post: Navy Blue Leather with Sterling Leather Inserts, Black Piano Lacquer wood. This car has a selling price of about USD $170,000 at today's exchange rates.
    Address 01: Engine
    Controller: 07C 906 018 G
    Component: D1-6.0L-AT A ª5571
    Coding: 0000173
    Controller: 3D0 927 156 T
    Component: AG5 01L 6.0 W12 RdW 0404
    Coding: 0000101
    Coding: 0008697
    Controller: 3D0 909 135 L
    Coding: 0213228
    Coding: 0000003
    Coding: 0500525
    Coding: 0000001
    Coding: 0000003
    Coding: 0000173
    Address 13: Auto Dist. Reg
    Controller: 3D0 907 567 G
    Component: AC101 W12 5HP244 09 0337
    Coding: 0001201
    Address 15: Airbags
    Coding: 0012362
    Coding: 0000022
    Controller: 3D0 920 881 P
    Component: KOMBIINSTRUMENT RB8 0414
    Coding: 0007111
    Controller: 3D0 815 005 AC
    Component: Standheizung 2422
    Coding: 0000000
    Coding: 0000006
    Address 23: Brake Booster
    Controller: 3D0 907 563 C
    Component: BREMSBOOSTER 4310
    Coding: 0000000
    Coding: 0000000
    Coding: 0000001
    Coding: 0015500
    Coding: 0000004
    Coding: 0000000
    Coding: 0000023
    Shop #: WSC 01065
    2 Faults Found:
    00222 - Connection to Rain Sensor
    Coding: 0000001
    Coding: 0000000
    Coding: 0000000
    Component: Sitzmemory D1 H 1521
    Coding: 0000001
    Coding: 0000000
    Coding: 0000000
    Coding: 0000000
    Coding: 0000000
  25. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    05-26-2005 06:52 AM #26
    V6 Gasoline Engine Phaeton - German specification (Peter's Car)
    Many thanks to Peter for allowing me to take this controller scan of his Phaeton at the Phaeton Owner GTG in Dresden. It is a very early production - ca. 2002 - V6 Phaeton. It is only two wheel drive (front wheels only), which is a very rare engine-drivetrain configuration.
    Address 01: Engine
    Controller: 022 906 032 BN
    Component: MOTRONIC ME7.1.1G 0009
    Coding: 0000033
    Controller: 3D0 927 156 M
    Component: AG5 01V 3.2l4V RdW 0609
    Coding: 0000103
    Controller: 3D0 614 517 AF
    Component: ESP 5.7 front H33 0043
    Coding: 0008597
    Controller: 3D0 909 131 J
    Component: Kessy 5550
    Coding: 0000232
    Coding: 0400225
    Component: Climatronic D1 1123
    Coding: 0000001
    Coding: 0000003
    Address 15: Airbags
    Coding: 0241705
    Component: Lenksäulenmodul 2901
    Coding: 0000011
    Component: KOMBIINSTRUMENT RB4 2411
    Coding: 0029111
    Coding: 0000006
    Coding: 0000001
    Coding: 0015500
    Coding: 0000000
    Coding: 0000013
    Coding: 0000001
    Component: 05 HSG 0101
    Coding: 0000032
    Controller: 3D0 035 465 A
    Component: 08K-AUDIOVERST 0112
    Coding: 0000000
    Coding: 0011204
    Component: Front Wiper 2004
    Coding: 0000000
    Coding: 0000000
    Controller: 3D0 919 283 B
    Component: ?? Einparkhilfe_ 0606
    Coding: 0000000
    Controller: 3D0 035 704 A
    Component: Telefon 8100
    Coding: 0000000
    Modified by PanEuropean at 6:59 AM 5-26-2005
  26. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    06-01-2005 01:44 PM #27
    Here's a very interesting scan from a 2005 Phaeton, North American spec, with the cell phone prep package. This car was built in August of 2004. There are some noteworthy coding changes
    VIN Number: WVWAF93D058001664
    Address 01: Engine
    Controller: 4D0 907 560 DD
    Coding: 0007873
    Coding: 0001102
    Coding: 0008376
    Controller: 3D0 909 135 R
    Coding: 0137452
    Coding: 0000003
    Coding: 0500325
    Coding: 0000002 - Interesting, I wonder what the the meaning of a 2 is in the coding, rather than a 1. This car does have a rear seat control panel, same as my car.
    Coding: 0000002
    Address 15: Airbags
    Coding: 0012359
    Coding: 0000232 - Same coding for the steering wheel as my car, even though this Phaeton has telephone button controls on the right side of the steering wheel.
    Controller: 3D0 920 882 H
    Coding: 0007321
    Coding: 0000006
    Coding: 0000000
    Coding: 0000001
    Coding: 0017700 - Normal North American default settings (indicating a 10 mm upwards correction)
    Coding: 0000004
    Coding: 0400000
    Coding: 0000047 - This perplexes me, I have never seen a roof controller coded this high before. I have seen a few with '46' as coding, but never a 47.
    Coding: 0000001
    Coding: 0000000 - This is the first time I have ever seen a V8 Phaeton with the 7L0 controller, rather than the 3D0 controller, in address 46.
    Coding: 0000000
    Controller: 3D0 907 273 D
    Component: Reifendruckueberw. 0025
    Coding: 0411204 - First time I have ever seen a '4' in the second position from the left.
    Controller: 3D0 959 860 C
    Component: Sitzmemory D1 H 1724
    Coding: 0000001
    Coding: 0000000
    Coding: 0000000
    Controller: 3D0 035 617 A
    Component: Telematik NAR1 0106
    Coding: 0061850 - This is the OnStar module - below is the telephone module. This car has NAR Cell Phone Prep. Normally the OnStar is 61860, but, this car has not been sold, and therefore the OnStar is not activated yet - maybe that explains it.
    Coding: 0000000
    Controller: 3D0 035 729 - Here's the PN for the North American cell telephone controller.
    Component: Telefon 0118
    Coding: 0000000
  27. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    06-03-2005 11:55 PM #28
    Here is a scan from David Cowan's NAR spec 2004 W12 Phaeton. I was very curious to compare the scan from David's car to my car. We both have 2004 W12 Phaetons, but David's was built quite a bit later than mine - my Phaeton was built in September of 2003 (VIN ending is 8349), and David's was built in March of 2004 (VIN ending is 11685). As can be expected, David has higher software revision numbers in a few of the controllers in his car.
    What does perplex me is the difference in the coding of the HVAC system (address 08). I know David has more advanced solar reflecting glass in his car than I do - perhaps this accounts for the coding difference?
    Michael
    2004 W12, very late production, not a Premiere Edition
    Address 01: Engine
    Coding: 0000173
    Coding: 0001102
    Component: ESP 5.7 allrad H33 0047 – newer version software, compared to Michael’s car (the first scan at very top of this thread)
    Coding: 0008397
    Coding: 0133356
    Coding: 0000003
    Component: ZAB COCKPIT 0220 – newer software, but not the newest. The newest is 0223. Might this perhaps account for the slow clock problem?
    Coding: 0500305
    Component: Climatronic D1 1145 – newer version software, compared to Michael’s car (1132)
    Coding: 0000002 – Michael’s W12 is coded 000001 – could this be due to differences in the window glass?
    Coding: 0000002
    Coding: 0000173
    Coding: 0000232
    Coding: 0005121
    Coding: 0000006
    Coding: 0000000
    Coding: 0000001
    Coding: 0015500
    Coding: 0000004
    Component: NAVIGATION 0168 – newer version software, compared to Michael’s car (0147)
    Coding: 0400000
    Coding: 0000015 – this is the same as Michael’s car, even though the glass is different.
    Coding: 0000001
    Coding: 0000000
    Coding: 0000000
    Coding: 0011224
    Component: Sitzmemory D1 H 1524 – newer version software, compared to Michael’s car (1513)
    Coding: 0000001
    Coding: 0000000
    Controller: 3D0 915 181 C – this is the latest version of this controller.
    Coding: 0000000
    Coding: 0061860
    Shop #: WSC 07134
    Coding: 0000000
  28. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    06-06-2005 01:21 AM #29
    This is from a 2004 Phaeton 4 seater, Canadian specification. I managed to get this scan just before the car went off to auction.
    VIN Number: WVWBF63D348011011
    Address 01: Engine
    Coding: 0007873
    Coding: 0001102
    Coding: 0008376
    Coding: 0137452
    Coding: 0000003
    Coding: 0500305
    Coding: 0000002
    Coding: 0000002
    Address 15: Airbags
    Coding: 0012359
    Coding: 0000232
    Controller: 3D0 920 882 A
    Coding: 0007321
    Coding: 0000006
    Coding: 0000000
    Coding: 0000001
    Coding: 0017700
    Coding: 0000004
    Coding: 0400000
    Coding: 0000047
    Coding: 0000001
    Coding: 0000000
    Coding: 0000000
    Coding: 0011204
    Coding: 0000001
    Coding: 0000000
    Coding: 0000000
    Coding: 0061850
    Coding: 0000000
  29. 07-09-2005 10:30 PM #30
    Here's a scan of my 2004 W12 4 seater. I believe that this car was very early production - the Carfax the dealer showed me said it was a VWOA car, put in service in the fall of 2003. It also apparently sat with minimal use for the better part of a year before I bought it, judging by the same Carfax.
    The car had two faults when I purchased it: a bad Nav unit, and a bad height adjustment motor in the rear seat, driver's side. At the time this scan was run, the Nav had been fixed, but not the seat motor - the dealer had examined the car, and had to order the part. The scan was also run before I made any coding adjustments.
    Address 01: Engine
    Controller: 07C 906 018 AB
    Component: D1-6.0L-AT-LEV G ª5700
    Coding: 0000173
    Shop #: WSC 98765
    Coding: 0001102
    Shop #: WSC 98765
    Coding: 0008376
    Shop #: WSC 25807
    Coding: 0000232
    Shop #: WSC 01995
    No fault code found. My car does not have keyless access
    Coding: 0000003
    Shop #: WSC 01065
    1 Fault Found:
    00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
    Component: ZAB COCKPIT 0179
    Coding: 0500305
    Shop #: WSC 98765
    7 Faults Found:
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    01312 - Powertrain Data Bus
    01320 - Control Module for Climatronic (J255)
    00457 - Control Module for Network (J519)
    00455 - Control Module for Access and Start Control; Comfort CAN (J518)
    Except for the Nav problem, I've had no problems with the control screen
    Coding: 0000002
    Shop #: WSC 25807
    Coding: 0000002
    Shop #: WSC 02132
    1 Fault Found:
    000 - -
    Coding: 0000173
    Shop #: WSC 98765
    Address 15: Airbags
    Controller: 3D0 909 601 B
    Component: XK Airbag 8.4E+ H07 0624
    Coding: 0022603
    Shop #: WSC 00000
    Controller: 3D0 953 549 C
    Coding: 0000232
    Shop #: WSC 01065
    Controller: 3D0 920 980 M
    Coding: 0007221
    Shop #: WSC 01065
    Coding: 0000006
    Shop #: WSC 01995
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0000001
    Shop #: WSC 01065
    Coding: 0017700
    Shop #: WSC 25807
    Coding: 0000004
    Shop #: WSC 01995
    1 Fault Found:
    Coding: 0400000
    Shop #: WSC 02132
    No fault code found. Dealer may have cleared when they replaced Nav unit
    Coding: 0000012
    Shop #: WSC 25807
    No fault code found. Michael, isn't this the code where everyone has a fault?
    Coding: 0000001
    Shop #: WSC 01065
    Component: HSG 0101
    Coding: 0000040
    Shop #: WSC 02132
    1 Fault Found:
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0010284
    Shop #: WSC 25807
    Component: Sitzmemory D1 H 1516
    Coding: 0000001
    Shop #: WSC 00000
    1 Fault Found:
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0000000
    Shop #: WSC 00000
    Coding: 0061860
    Shop #: WSC 25807
    Coding: 0000000
    Shop #: WSC 00000
    Modified by bobschneider at 9:33 PM 7-9-2005
  30. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    07-10-2005 01:16 AM #31
    Hi Bob:
    Thanks a lot for posting that scan. It is very interesting to note that your car has a brand new battery management controller (the controller at address 71) in it - the version with the PN suffix 'C' and the software at level 2700 did not exist when your car was built. That is a good sign, it suggests someone has done a bit of updating on your vehicle.
    You have a very old software version in your Central Display and Control Panel (Infotainment screen) - you are at software version 0179, the current shipping version is 0223. I have never seen a version as old as what you have - I have 0188, which I thought was the oldest in North America. I would not be too concerned about the fault codes shown on controller 07, though - they probably were caused by unplugging cables when the technician fixed the nav unit. If you have further nav unit problems, then the next step it just to have them replace the whole thing with a new (re-manufactured) display - that will have the newer software in it.
    Michael
  31. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    08-27-2005 04:44 PM #32
    Here is a controller scan from Daniel's W12, which is a German configuration car. This car has automatic distance regulation installed, and also the OEM DVD player system.
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 34 36 37 38 39 46 47 57 65 66 68 69 71 75 76 77
    Address 01: Engine
    Controller: 07C 906 018 B
    Component: D1-6.0L-AT A ª5112
    Coding: 0000173 Same coding as a North American W12.
    Controller: 3D0 927 156 C
    Component: AG5 01L 6.0 W12 RdW 0911
    Coding: 0000101 North America is 0001102 - see the scan of my W12 at the top of the post for a comparison.
    Coding: 0008697
    Coding: 0213228
    Coding: 0000003
    Coding: 0500735
    Coding: 0000001
    Coding: 0000003
    Coding: 0000173
    Controller: 3D0 907 567 E
    Component: AC101 W12 5HP244 10 0334
    Coding: 0001201
    Address 15: Airbags
    Component: 0C Airbag 8.4E+ H07 0935
    Coding: 0012355
    Coding: 0000022 Wood steering wheel installed, therefore no heat. Also, ADR installed, therefore 6 buttons & thumbwheel on left side.
    Controller: 3D0 920 881 E This is the PN for the instrument cluster used with ADR on a W12.
    Coding: 0007111
    Controller: 3D0 815 005 Q
    Coding: 0000000
    Coding: 0000006
    Address 23: Brake Booster The brake booster is only installed when Automatic Distance Regulation (ADR) is installed.
    Controller: 3D0 907 563 B
    Component: BREMSBOOSTER 4010
    Coding: 0000000
    Coding: 0000000
    Coding: 0000001
    Coding: 0015500
    Coding: 0000004
    Coding: 0500735
    Coding: 0000023 Solar sunroof installed.
    Coding: 0000001
    Controller: 3D0 959 933E
    Component: 1B HSG 3211
    Coding: 0000000
    Coding: 0000000
    Controller: 3D0 919 146 Now we have the part number...
    Coding: 0000010
    Coding: 0010284 Note the European coding for the W12.
    Component: Sitzmemory D1 H 1501
    Coding: 0000001
    Coding: 0000000
    Coding: 0000000
    Coding: 0000000
    Address 77: Telephone This is the telephone system with the handset in the armrest, not the Bluetooth system.
    Coding: 0000000
    Modified by PanEuropean at 4:58 PM 8-27-2005
  32. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    08-29-2005 07:31 PM #33
    Not quite from a Phaeton, but darn close - this scan is from a Bentley Continental GT, Canadian spec.
    Two VW's, darn near identical controller lists.
    Plug & Play
    Bentley Scan Results
    Chassis Type: 3W - VW Bentley Continental GT
    Scan: 01,02,03,05,06,07,08,09,11,15,16,17,18,19,23,27,34 ,35,36,37,38,42,46,48,49,52,55,56,57,61,62,65,68,6 9,72,76,77
    Address 01: Engine
    Controller: 07C 906 018 AR
    Component: BY-6.0L-TT G ª6521
    Coding: 0000173
    Controller: 09E 927 760 C
    Component: AG6 09E 6.0L W12TT 1903
    Coding: 0000101
    Controller: 3W0 614 517 D
    Component: ESP 5.7 4WD H01 0021
    Coding: 0007878
    Component: 0R Kessy 6610
    Coding: 0139501
    Coding: 0000002
    Coding: 0400325
    Coding: 0000002
    Coding: 0000105
    Coding: 0000173
    Address 15: Airbags
    Component: 0P Airbag 8.4E+ H10 0936
    Coding: 0012368
    Coding: 0000012
    Controller: 3W0 920 840 N
    Component: KOMBIINSTRUMENT RB8 0402
    Coding: 0023300
    Coding: 0000006
    Coding: 0015500
    Coding: 0000002
    Coding: 0400000
    Component: Dachmodul 0703
    Coding: 0000157
    Component: 1X HSG 0101
    Coding: 0000032
    Coding: 0280340
    Coding: 0000000
    Coding: 0000000
    Controller: 3W0 035 729 K
    Component: Telefon 0252
    Coding: 0000000
    Modified by PanEuropean at 7:32 PM 8-29-2005
  33. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    10-03-2005 07:54 AM #34
    Here is a controller scan from Alex's 2005 V6 TDI Phaeton - Swiss specification. Note some of the updates in the controller software, compared to my 2004 Phaeton (listed at the top of this post)
    Michael
    2005 V6 TDI Phaeton
    Address 01: Engine
    Coding: 0011773
    Coding: 0000101
    Component: ESP 5.7 allrad H33 0047 updated from 0043
    Coding: 0008356
    Component: Kessy 6610 updated from 6400
    Coding: 0004328
    Coding: 0000003
    Coding: 0400525
    Component: Climatronic D1 2021 updated from 1132
    Coding: 0000001
    Component: STG.Bordnetz 5101 updated from 5001
    Coding: 0000003
    Address 15: Airbags
    Coding: 0012362
    Coding: 0000032
    Coding: 0005111
    Coding: 0000000
    Coding: 0000006
    Coding: 0000001
    Component: LUFTFDR.-CDC- 3C3V0 1121 updated from 1101
    Coding: 0005521
    Coding: 0000004
    Component: NAVIGATION 0168 updated from 0147
    Coding: 0400000
    Coding: 0000055
    Coding: 0000001
    Component: 12K-AUDIOVERST 0118 updated from 0114
    Coding: 0000000
    Coding: 0000000
    Coding: 0000000
    Coding: 0000000
    Coding: 0000000
    Modified by PanEuropean at 8:00 AM 10-3-2005
  34. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    10-16-2005 12:42 AM #35
    The most recent (beta) release of VAG-COM, which is version 5.10, better supports reporting of all the 'slave' controllers in the car. Slave controllers are controllers that don't have their own individual controller address (e.g. address 46 for the central comfort controller) but are instead controlled directly by another controller. A good example of this are the door controllers and the power trunk lid controller - they are all slaves to the central comfort controller.
    The 'bug' in VAG-COM that has caused misidentification of controller 46 since version 4.09 has been fixed. For this reason, I recommend that Phaeton owners who use a VAG-COM download the 5.10 beta, and begin to use it. Be aware that beta software from Ross-Tech will install to a different directory that 'final release' software. Betas install to the path c:/VAG-COM beta, and final release software installs to the path c:/Program Files/VAG-COM. This means that if you install the beta, you will have two different installations of VAG-COM on your computer - the beta, and your previous final release. This is not a problem, you just need to be aware of it so you don't get the two confused. Log files created with the beta stay in the beta folder, and log files created with the final release stay in the final release folder.
    The link to the beta download site is: Ross-Tech Betas. Please carefully read the release notes for the beta (on that same page) before downloading and installing it.
    Michael
    Michael's Phaeton, scanned with version 5.10 (beta)
    Compare this with the scan of my car at the very top of this thread.
    VAG-COM Version: Beta 510.0-UD
    Saturday,15,October,2005,21:23:50
    VIN Number: WVWAH63D648008349
    Address 01: Engine
    Part No: 07C 906 018 C
    Coding: 0000173
    Part No: 3D0 927 156 N
    Coding: 0001102
    Part No: 3D0 614 517 R
    Coding: 0008397
    Part No: 3D0 909 135 M
    Coding: 0133356
    Part No: XXX XXX XXX XX
    Component: ELV XXXX
    Part No: 3D0 959 759 B
    Coding: 0000003
    Part No: 3D0 035 008 Q
    Coding: 0500305
    Part No: 3D0 907 040 G
    Coding: 0000001
    Part No: 3D0 937 049 G
    Coding: 0000001
    Coding: 0000173
    Address 15: Airbags
    Part No: 3D0 909 601 D
    Coding: 0012353
    Part No: 3D0 953 549 E
    Coding: 0000212
    Part No: 3D0 920 881 K
    Coding: 0005121
    Part No: 6N0 909 901
    Coding: 0000006
    Part No: 3D0 919 158 F
    Part No: 3D0 909 157
    Coding: 0000001
    Part No: 3D0 907 553 B
    Coding: 0015500
    Part No: 3D0 959 760 B
    Coding: 0000004
    Part No: 3D0 919 887 A
    Coding: 0400000
    Part No: 3D0 907 135 B
    Coding: 0000015
    Part No: 3D0 909 158
    Coding: 0000001
    Part No: 3D0 959 933 F
    Component: 1A HSG 0100
    Coding: 0000040
    Part No: 3D1 959 701 E
    Component: Tuersteuergeraet FS 0104
    Part No: 3D1 959 702 E
    Component: Tuersteuergeraet BF 0104
    Part No: 3D0 959 703 E
    Component: Tuersteuergeraet HL 0104
    Part No: 3D0 959 704 E
    Component: Tuersteuergeraet HR 0104
    Part No: 3D0 909 610 C
    Component: 3L HDSG
    Part No: 7L0 907 719
    Part No: 3D0 035 466
    Component: 12K-AUDIOVERST 0114
    Part No: 3D0 907 273 C
    Coding: 0010284
    Shop #: WSC 64579
    Part No: 3D0 959 860 B
    Coding: 0000001
    Part No: 3D1 955 119
    Part No: 3D0 915 181 C
    Part No: 3D0 035 617
    Coding: 0061860
    Part No: 3D0 919 283 C
Page 1 of 3 1 2 3 LastLast
