VWVortex.com - Have a water leak? - MKIV sunroof drain locations
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 123
    Thread: Have a water leak? - MKIV sunroof drain locations
    1. 03-30-2005 08:14 AM #1
      This topic comes up all too often, so I figured it was about time that these locations got posted. FYI, these locations were photographed on a 99.5 Jetta - the locations may differ slightly on the Golf/GTI and on later model-year cars.
      If you have water leaking into your MKIV, make sure to check that the drain tubes for the sunroof tray (all sunroofs leak - the tray catches the water so that doesn't enter the car and tubes carry is safely away).
      The sunroof tray has 4 drain holes in it, one in each corner, i.e., front left, front right, rear left and rear right. The two pictures below show the location of the front right drain hole. The holes at the other locations are similar.
      NOTE: The rear holes are covered by the roof and are not normally visible.
      Each of the four drain holes is connected to a tube that runs through the A- and C-pillars and end at a nipple. It is common for the nipple to stick closed and not drain the water out of the tube. When this occurs, the water backs up into the sunroof tray and overflows into the car. If you notice a wet headliner in proximity to the sunroof opening, then this is most likely the cause. To drain the tubes, squeeze the nipples and some water and other crap may/should flow out. If you think there may be a tube clog, it's a good idea to carefully pour a cup or so of water into the sunroof tray to flush each of the tubes out. I would do this until the water flows out clearly and easily.
      NOTE: Some repositioning of the car may be necessary to individually place each of the drain holes at the lowest point of the tray ... that is unless you've figured out a way to beat gravity and make water flow uphill.
      The four drain tube nipples are shown in the pics below.
      Gary
      Modified by VgRt6 at 8:25 AM 3-30-2005
    2. Member melanotaenia's Avatar
      Sep 14th, 2004
      Manhattan
      2006 GTI
      03-30-2005 08:19 AM #2
      awesome thanks Gary!!
    3. 03-30-2005 08:23 AM #3
      Anytime Jonathan.
      BTW, when are you taking me for a ride in the .:R? We're replacing brakes and flushing brake fluid this Saturday up at my place if you want to stop by. You can take us for a ride in the .:R and you can take a ride in my friend's APR Stage III 1.8T Jetta. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Gary
    4. Member melanotaenia's Avatar
      Sep 14th, 2004
      Manhattan
      2006 GTI
      03-30-2005 11:39 AM #4
      ahh yes I will definately be there, send me a PM where you live and I will come over when you guys are doing the flush [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. 07-14-2005 02:28 PM #5
      problem solved!
      helpful post, thanks
    6. Member EvilWabbit's Avatar
      Jan 22nd, 2005
      2010 Golf 2.5
      07-14-2005 05:45 PM #6
      Are you supposed to cut those drain tube nipples or leave it as is?
      Thanks
    7. Member nutsofast1.8T's Avatar
      Feb 3rd, 2004
      Ontario CA
      B6 S4, '00 CBR 929, 64 Pontiac Lemans
      07-14-2005 05:47 PM #7
      Leave them as is, or you are gonna get little critters up in them drains or debris and clog them up.
      "If no one has been offended by what you have done, you need a larger audience."
    8. Member EvilWabbit's Avatar
      Jan 22nd, 2005
      2010 Golf 2.5
      07-14-2005 06:30 PM #8
      Oops,
      I cut them.
      I live in an apartment and park the car in an underground garage, so no critters here
      BTW, i thought those were supposed to be cut. How's the water going to drain if the tubes aren't cut?
      Just a curious question
    9. Member Fugee's Avatar
      Aug 22nd, 2003
      Las Vegas, NV
      06 VW 95 GMC
      07-14-2005 06:33 PM #9
      Thanks god I havent had problems with those...Knock on wood..the car is almost 7 years old now
    10. Member dremhmrk2's Avatar
      Sep 19th, 2003
      Fort Lauderdale FL
      2001 Mojave GTI GLX
      07-14-2005 06:38 PM #10
      You are my hero
      "Turning right in fifth gear from the left hand lane into the wrong end of a one-way street while indicating left, if at all."
      All the custom, none of the cool.
      "Trying to be the cool kid is so cool." - MkIV Scene
    11. 07-18-2005 06:08 PM #11
      what about the rear drain holes of a gti, are they in the same place? I have water stains on my right rear c pillar from the head liner to the seat noticed it at waterfest, you know how bad it rained there on sunday.
    12. 07-18-2005 06:17 PM #12
      Mmmm... nipples.
      Nice work, Gary (as usual). I found out about these drain plugs the hard way this winter during the apocalyptic Southern California rainfall. Came back to my car one afternoon, and the rear passenger side footwell had an inch of standing water in it. Not fun. Particularly since it took a good three months to completely eliminate the odor.
    13. Member melanotaenia's Avatar
      Sep 14th, 2004
      Manhattan
      2006 GTI
      07-18-2005 06:51 PM #13
      Gary always has great threads about little neat things that VW incorporates into their cars.
      And oh yeah, Gary, I still owe you a ride in the .:R, 3000 miles on it and going strong!
    14. 07-19-2005 06:54 PM #14
      i checked for the rear drain nipples(ha ha) on my gti but cant find them anybody have any ideas
    15. 07-19-2005 07:24 PM #15
      Wondering the same here for the GTI.
    16. Member veedub11's Avatar
      Mar 9th, 2002
      Shaw District DC
      MK6 GTI Autobahn & 2013 Tiguan SEL 4-motion (Past: MK4 Golf TDI, MK3 Surf Green GTI 2.0T, Corrado VR
      08-29-2005 03:51 PM #16
      good thread, hopefully it will be a fix for my problem.
    17. Senior Member abydielsgli's Avatar
      May 7th, 2003
      the field of bakers
      a few vw's and toyotas
      08-29-2005 04:07 PM #17
      your the man with helping out [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    18. 08-29-2005 04:13 PM #18
      I was wondering what those were for. The body shop that unsmashed my car didn't mask one of them off. Wonder if that one still drains.
      Thanks, you always out do yourself. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. Member
      May 6th, 2004
      Ct -203-
      88 Turbo Coupe
      10-27-2005 07:37 PM #19
      so the gtis dont have rear drains??
      Quote Originally Posted by SLK350 View Post
      Penises have everything to do with science.
    20. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      10-27-2005 07:44 PM #20
      another good one gary [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Current: 2011 Jeep Grand Cherokee 5.7 Hemi 4x4, 2015 BMW R1200GS, 2016 Mazda CX-5 GT AWD (Wife)
      Gone: 2010 Audi S4; 2008 GTI; 2007 Audi A6; 2004 Audi allroad 2.7T; 2001 Audi A6 2.7T; 1999.5 Mk4 Jetta VR6; 1991 Jeep Cherokee 4.0 4x4
    21. Banned
      Nov 24th, 2001
      10-27-2005 07:48 PM #21
      Quote, originally posted by redgeeteeeye »
      yes they do..and in the same place...
      dang!! talk about "back from the dead"?!?!?!
    22. Member Gorgeous's Avatar
      Aug 15th, 2005
      Bellevue, WA
      2009 370Z sport/touring
      10-27-2005 07:57 PM #22
      Who [IMG]http://*****************.com/smile/emlove.gif[/IMG] 's Gary?
      I [IMG]http://*****************.com/smile/emlove.gif[/IMG] Gary.
      ...and Larry, for clarifying where the tubes are.
    23. 10-27-2005 08:13 PM #23
      Yes they do.
      I had a problem with water getting into my rocker panel.
      They said that the rear window drains were blocked
      which cause water to get in there.
      They had to remove the rear fender liner to get to the drains.
    24. 10-29-2005 10:12 PM #24
      How exactly do these drains get blocked? Couldnt one just blow some compressed air through the holes to blow out all the crap that may build up in the hose?
    25. Banned
      Nov 24th, 2001
      10-29-2005 11:26 PM #25
      Quote, originally posted by Gorgeous »
      I love Gary...he's my hero!!! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
