Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 72
Thread: Comfort Control Module Location
  1. 03-30-2005 08:04 PM #1
    My 2001 Jetta GL is experiencing the symptoms of having a bad comfort control module (non-working interior lights, door locks, trunk release, etc.). My question is, where is the CCM located in 2001 Jettas? And how do I get to it. I am hoping I can locate it on my own to retrieve the part number, then I figure I can order one online, because going through the dealership, I'll be set back about 400 bucks just to get the damn part, not even counting installation. ANY help is greatly appreciated.
  2. Member veedubgolf00's Avatar
    Dec 5th, 2004
    upper perk
    99.5 tdi jetta, 00 bt tdi jetta, 98 tdi jetta
    03-30-2005 09:45 PM #2
    hey i just did this when i bought my car. i have a 00 golf but its prolly the same location. if you take out the plastic pieces right below the steering wheel then take off the big metal plate behind the plastic its located near the top of the dash. its bolted on w/2 screws and has like 2 wiring harnesses attaced to it. Before you go 2 the dealer check out ebay i got one for 20 bucks. Also did you check fuse #13 or 14?? If you installed any electronics it could mess that up 2.
  3. 03-30-2005 10:49 PM #3
    Thank you very much. I plan on tackling this project within the next few days, so I'll check back once I'm done and let you know how it went. Also, I had fuse 14 checked out when I got the car, and its not that, so unfortunately, I think its the CCM for sure. Thanks again for your input
  4. 04-05-2005 07:35 PM #4
    I've got the same issue and need to order the CCM part and install it. I've procrastinated it enough and need to go ahead an do it. I's be interested to know how it goes. please let me know if you have any thing to watch out for.
    thanks,
    Ash.
  5. 04-06-2005 11:20 AM #5
    If you don't already know your part number, or don't have access to a scan tool to obtain it that way, you'll need to get to the part yourself so you can get the part number, because when replacing them, they have to match. The CCM is located behind lower dash area. To get to it, you'll need to remove the 2 black panels underneath the steering wheel, and also the black side panel that covers the fuses (they are knotched together, and I almost broke one of the pieces by not realizing that). After you remove those, there is a metal plate with about 5 screws in it, so remove that, then you should see the box screwed to a metal harness. Just remove 1 or 2 screws and you can pull the unit out. When installing the unit, however, it is not as simple as just putting it in and being done. If you have remote keys, you will need to have them programmed, which pretty much needs to be done by a VW dealership, unless you know of some place that has the special system they use. (Having them program it may even be necessary if you don't have remote keys, but I'm not absolutely positive). Hopefully this helps you, and good luck.
  6. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    04-06-2005 11:23 AM #6
    threw this in the faq
    Dave
  7. 05-05-2005 05:15 AM #7
    Bringing this one back...
    Is it true that Keys need to be reprogramed? I thought the ECU and cluster took care of all that?
  8. 07-25-2005 10:29 AM #8
    You can reprogram your keys yourself. The dealership will charge you $50 to do it, but the instructions are in the owner manual.
    Good luck!
  9. Member smooth_motion's Avatar
    Dec 15th, 2002
    NorCal
    07-25-2005 10:54 AM #9
    Quote, originally posted by AustinJettaVR6 »
    Good luck!
    You sure about this??
  10. 08-22-2005 03:20 PM #10
    Absolutely. When you buy a new key it comes with the directions on how to program it straight from the owners manual. Good luck!
  11. 08-24-2005 10:12 AM #11
    I need to do the same thing - so please post follow up info (I will do the same!).
    My 2001 Jetta GLS rolls down all the windows whenever you unlock the car, and when you unlock the car to get out.
    I found a new OEM comfort control module for $100.
    Jeremy
  12. 03-28-2006 08:43 PM #12
    Hi, where did you find the CCM? I might need one for my Passat.
    thanks.
  13. 05-03-2006 02:20 PM #13
    I need to know where to find a cheaper comfort control module. The dealer wants like $260. And thats whith a 20% discount.
  14. 10-10-2006 01:22 PM #14
    could a bad CCM effect only one door?
    I have no functions on my passenger door (no lights, no window, no lock etc)
  15. Member Notabora2's Avatar
    Dec 24th, 2002
    Darmstadt, Germany
    Jetta MK4 VR6 Audi A4 2.0TDi BMW 128
    10-27-2006 07:04 AM #15
    Yes, I have that same question. How do you know when the CCM is defective? What are the symptoms?
  16. 10-27-2006 07:47 AM #16
    Defective CCM can be any number of symptoms, too many too list, however, if it's only one door that seems affected (does not lock or unlock) but everything else works as it should, I can tell you it's NOT the CCM.
    Before ripping anything appart, try removing your battery cables, touching the positive and negative cables together for a few seconds (this should discharge any remaining current in the system) and reconnecting the battery, this sometimes clears "hickups" encountered in the CCM.
    A couple of tests you can perform beyond that are - try the lock/unlock button on the driver's door and passenger door as well as the remote control, if the door is not responding, yet the other door(s) are working fine, it is one of 2 possibilities, a dead door lock mechanism or a disconnected wiring harness at the door lock mech., either way, you will have to remove the door panel (see FAQ's for instructions) to get to the mechanism for trouble shooting.
    Once you have the door panel off, you can run some tests on the harness using a voltmeter to verify that hte problem is with the locking mechanism.
    1999 to 2001 model years have issues with the 6 solder points where the harness connector mounts to the circuit board at the mechanism, sometimes, all you have to do is re-solder those joints - also see faq's for the proceedure on repairing the mechanism.
    Scarpyards and ebay will have modules at relatively good prices.
  17. Member Notabora2's Avatar
    Dec 24th, 2002
    Darmstadt, Germany
    10-28-2006 07:04 AM #17
    Thanks. I went and got a new door lock Mechanism today. I will try and replace this this in the next week or so. Hope this works out.
  18. Member jaah's Avatar
    Dec 29th, 2006
    Finland
    2007 VW Golf 2.0TDI 4motion, 1992 Golf 1 Cabriolet, Polo classic -84, Jetta CL 1.5 AT -83
    12-29-2006 03:00 AM #18
    I have -99 Golf TDI without OEM keyless entry.
    Can I somehow recode the central convience system, until it will accepts OEM tansmitter/keyfob?
    I have transimitter:
    http://tos.pp.fi/koukku/DSC09118.JPG
    1J0 959 799 H
    soft coding 00257
    WSC 01317
    Extra: 1J1959801C 04 Tõrsteuerger . FS0001 | 1J1959802D 04 Tõrsteuerger. BF0001
    I have comfort windows..
    Thank you !
    and
    Happy new year 2007 and sorry about my english
  19. 01-02-2007 09:29 AM #19
    Does anyone know for sure whether this is the same location for a 2004 Jetta TDI? I don't want to do a bunch of tearing out and not find it. I see that most of the questions are about older ones.
    Thanks,
    Steve
  20. 01-02-2007 10:49 AM #20
    Yes it is the same.
  21. 01-02-2007 12:37 PM #21
    I found out it is under the dash on the 2004 and not under the seat, but I also found out that, contrary to outward appearances, the dome light fuse blew and all works when it was replaced. It was hard to believe that one fuse took out the door locks, windows, trunk, and dome light. Oh well,live and learn. Thanks for all the great posts all over this forum which helped me to solve this.
    Steve
    http://visionaircraft.com
    http://massagedaytona.com
  22. 01-02-2007 12:57 PM #22
    Quote, originally posted by vision001 »
    Who said it was under the seat?
  23. 01-02-2007 02:42 PM #23
    Quote, originally posted by NE_CT_1.8T »
    Just a brain fade. Old age does that. I was on another thread I searched regarding the module and it said it was just under the carpet under the front of the seat. When I read this thread again I realized I had responded to the wrong one.
    thanks again,
    Steve
    Modified by vision001 at 11:44 AM 1-2-2007
  24. 01-02-2007 03:20 PM #24
    No problem
  25. 01-22-2007 12:21 PM #25
    hi,i have the same symptoms on my 1999.5 jetta vr6 mk iv (trunk release,starter is not working,interior lights,sunroof,horn,etc)do you think all this stuff is related to the ccm
  26. 03-15-2007 12:34 PM #26
    The *******s at the VW dealership told me the comfort control module was behind the glove box? But it seems to me that EVERYONE with an MK4 is located under the stearing wheel.
  27. 04-11-2007 08:05 PM #27
    Hello,
    I have the same exact symptoms (no door windows, locks, and lights) on the passenger door of my 1999.5 Jetta. Can you or anyone else please let me know if you have pin pointed the problem to fix this?
    Thanks.
  28. Member TheReflex79's Avatar
    Feb 21st, 2005
    Alexandria, VA
    1998 Audi A4, Quattro, 2.8/30v, w/Tip; 2004 Nissan X-Terra SE
    04-16-2007 06:21 PM #28
    same problem here....bump it.
    Ocean State Dubs - A Rhode Island Based Volkswagen and Audi Club
    1998 Audi A4 2.8L Quattro, oh yes...it is Sable Mica Brown - 2001.5 VW Passat GLS, 30v (Unitronic)...and it's Reflex Silver
  29. 09-11-2007 12:23 AM #29
    I have a similar issue Ive posted almost everywhere to get some assistance I have no interior accent lights no sunroof power no power windows my trunk and gas release still work but no more door locks no ac and when I put the ebrake down I have to push the recirc button on the ac to get the brake light on the cluster to go off. also my remotes no longer work but they will start the car but I cannot lock my doors or my trunk with them so I dont know what to do. Im trying to avoid driving the 3 hours to the vw dealer in 100+ weather with no windows or ac so if anyone could help asses my problem it would be greatly apreciated.
  30. 02-06-2008 02:36 AM #30
    My CCM seems to be bad. I have no interior lights, no power windows, can't pop the trunk, no remote entry. I ordered a vag-com and I can't get a respone from 46-Central Conv. I was helped by someone on this forum to come to this conclusion. I'm looking around for a CCM now.
  31. 02-12-2008 12:02 PM #31
    would a malfunction in the CCM cause fuse 14 to blow? it's acting like a short, i cannot even get the fuse all the way in before it pops.
    sorry to bring this back, but some ideas would be great before i go drop cash on something i might not need.
    thanks.
  32. 07-03-2008 08:50 AM #32
    Ed
    Did you fix this and what was the cause? I have exactly the same problem with fuse 14, it just blows before i can get it seated into the holder.
    Any help would be appreciated before i start stripping out the doors!!
    Modified by Ralpharr2001 at 5:55 AM 7-3-2008
  33. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    07-03-2008 09:10 AM #33
    You're not putting the fuse in while the car is on are you?
  34. 07-04-2008 03:48 AM #34
    No, but good point.
    The ignition key is out and only the drivers door is open. As soon as the fuse makes contact with the fuse holder contacts it blows.
    I have checked the wiring in each door hinge point and none are broken. I am at a loss as to what the cause is.
  35. 03-22-2009 04:52 PM #35
    i am having the exact same problem. before i get the fuse in the holder it is blowing. i cant seem to find any short circuits in the system. its very frustrating. did anybody find any solutions to this problem. im stuck with no keyless entry, interior dome lights, power windows... 2001 vw golf.
