VWVortex.com - DIY: Replacing Spark PLug Wires on a 2.0 AEG engine. Pics inside!
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 35
    Thread: DIY: Replacing Spark PLug Wires on a 2.0 AEG engine. Pics inside!
    1. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      2008 BMW 335i, 2010 Rav4 V6 Ltd.
      04-11-2005 08:47 PM #1
      Hi all,
      Like most of you I have been enjoying the nice weather outside. On Thursday I picked up a brand new set of spark plug wires from my dealer. Yesterday was a good time for me to replace them and while I was at it I took some pictures.
      This is a complete DIY manual on replacing the Spark Plug Wires on a VW 2.0 engine with AEG engine code.
      DISCLAIMER:
      This DIY is given without any warranty. I am not responsible for any damages to your vehicle or to you that might have resulted while working on your car. Use this DIY merely as a guide!
      TOOLS AND PARTS:
      1. Spark Plug Boot Removal Tool
      2. 10 mm bit
      3. 10" socket extension
      4. Various screwdriver bits and pieces
      5. A set of Plug Wires. Part number: 06a905409L (Thanks Gary )
      Many have requested to see an image of the plastic boot puller tool. This tool was normally included with the MK3 and down and could be found strapped to the prop-rod. Since the MK4's don't have an actual prop-rod they did not include the tool to the car...
      Note:
      The latest part number for the plug wires is 06A905409L which supersedes the original set from the factory which is 06A905409F. The latest "version" is a bit different from the original. The OEM manufacturer is Beru in both cases but the actual wires in the revised set are thicker than the original and include extra silcone wrapping around the wires where te wires are close to the intake manifold. Also, the boots on the "new" wires are longer and contain a silicone flex joint which will prevent you from breaking the silicone insulation when twisting the wires. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      STEP 1: Preparation:
      1. Let the engine cool down. You will be working close to the intake manifold and the engine block so heat is something you want to avoid.
      2. Remove the engine cover.
      3. Take your time too look around things.
      STEP 2: Removing the Secondary Air Injection Pump:
      Note: This IS necessary in order to gain access to the coil pack which is right below the air pump.
      1. Unplug the Air Intake (coming from Air Box) hose and the other hose going to the combination valve:
      2. Unplug the power plug from the back of the Air Pump:
      3. Using the 10mm bit, remove the 3 nuts at the back of the Air Pump brcket. Note there are 3 nuts located at 120 degrees apart. The third nut is somewhat hard to reach. Use the 10" socket extention. BE CAREFULL NOT TO DROP THE NUT:
      4. Remove the air pump and set it aside. Make sure that you cover the two hose plugs so that no dirt can get to the motor of the pump. Those air pumps are expensive!
      Here is how the wires are aranged on the coilpack and how things look with the air pump out of the way:
      STEP 3: Removing the old plug wires:
      1. In order to use the boot tool to reach down and get to the plug boots, you will need to unplug the injector plugs on injectors #4 (driver-side most) and #1 (passenger-side most). The injector plugs are black and have 2 metal pins. Press down on the pins and you should hear 2 clicks, one per pin. This indicates that the injector plug has been freed. Simply pull it out of the injector seat:
      2. With the boot puller tool, reach down to the wire boots and unplug them.
      3. Look under the intake manifold. You should see a series of plastic clips that hold the plug wires in place and at the same time prevent them from rubbing on the intake manifold and the valve cover. Unclip the wires from the clips:
      4. One by one remove the wires starting with cilynder #4 (driver-side most). Be care full not to break any of the retaining clips show above. Also, be carefull not to put any strain on the fuel rail.
      STEP 4: Installing the new plug wires:
      1. The new plug wire set comes with some plastic retaining/separating clips. Also, the wires are labeled. You will see letters and corresponding numbers. The numbers are located close to the wire boots and the letters are located close to the coil pack plugs. So on the same cable you will see 1 and a corresponding A, 2 and a corresponding B and so forth.
      Also note that the retaining clips that come with the plug wires will show you which plug goes where on the coil pack:
      2. Plug the wires to the coilpack before starting to guide the wires under the intake manifold. That way you will not mess things up.
      3. Start guiding the wires under the intake manifold one by one, starting with cylinder number 1.
      4. After you plug each wire to its corresponding spark plug, clip the wires to the retaining clips. Do it one by one or you won't have enough space to mess with all of them at the same time.
      5. The last wire to install is on cylinder #4.
      STEP 5: Finishing touches:
      1. Make sure that all the wires are cliped to the retaining clips and that they are not rubbing against the intake manifold or the valve cover.
      2. Plug all your unplugged injectors!
      3. Reinstall the secondary air pump.
      4. MAKE SURE THAT YOU PLUG THE AIR PUMP POWER CABLE! I forgot to do that part and the engine came back with a CEL light. You will get trouble code P0411 if you don't plug your air pump!
      5. Plug the two air hoses to the secondary air pump.
      6. Check everything again and start the engine.
      If it runs fine and the CEL is not on then you nailed it!
      First Observations:
      I know it is too early to say anything but I can definitely feel that the engine is running little more smoothly than before. The rpms at idle are little more stable and the engine revs up little better.
      Hope you enjoyed it and good luck!
      Quote Originally Posted by MAG58 View Post
      Please consider your audience before saying something sensible. 80% of TCL drivers were actually banned from Formula 1 for being too fast.
      A turbocharger is a device in where exhaust gases go in, witchcraft happens, and then you go faster.
    2. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      04-12-2005 12:50 PM #2
      bump for the people who missed it yesterday.
    3. 04-21-2005 11:00 AM #3
      Quote, originally posted by vasillalov »
      Not necessarily! Air pump only runs on cold start... so if your engine was warm when you started the job, and warm when you finished... then leaving the air pump unplugged won't throw a code until the next COLD start.
      Modified by digitalhippie at 11:01 AM 4-21-2005
    4. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      04-23-2005 05:38 PM #4
      Quote, originally posted by digitalhippie »
      Well almost!
      According to the Bentley manual,
      the Secondary air pump will be initiated for exactly 100 seconds upon cold start. On each subsequent start, the air pump will be initiated for only 10 seconds as the ECU performs emission tests!
      So yeah, even with a warm engine, there is a chance that you get the P0411 code
      Modified by vasillalov at 5:39 PM 4-23-2005
    5. 04-23-2005 06:39 PM #5
      nice writeup! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Should be included in FAQ.
    6. 06-15-2005 12:46 AM #6
      Bump for a good writeup, not enough people check the DIYs
    7. 10-30-2006 02:32 PM #7
      hahah including me! [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. Member vwtuner4ever's Avatar
      Feb 17th, 2004
      Gatineau Québec
      Golf 02
      10-30-2006 06:19 PM #8
      As usual, great write up man
    9. 02-22-2007 01:24 PM #9
      Thank you so much. This is exactly what I was looking for!
    10. 02-22-2007 01:30 PM #10
      Nice write up, now where is the one to change the sparkplugs/waterpump/timing belt at?
    11. Member vasillalov's Avatar
      Nov 4th, 2003
      Chicago, IL
      02-22-2007 11:03 PM #11
      Quote, originally posted by Moko7 »
      1. In my signature
      2. In the 2.0 FAQ/DIY Thread
      3. In the MK4 FAQ/DIY Thread
      4. In the Search results!
      Jul 14th, 2003
      2000 Jetta GLS 2.0 Black
      07-05-2007 03:13 PM #12
      This is a great writeup! Thanks vasillalov !!
      Are there any tricks to replacing the coil pack on the same 2.0 MKiV AEG?
      Seems like once the air pump is out of the way, it's just a matter of removing the pack too.
      Anyone have experience with this?
    13. 07-17-2007 02:20 PM #13
      I followed the instructions completely. Once you remove the Air Pump then you can remove the pump bracket bolts. Once this is done you can access the coil. There are no "tricks" it's easy.
      It is straight forward from here provided you have the correct coil for the engine.
    14. 09-14-2007 01:35 PM #14
      anyone know the gap for NGK plugs for the AVH engine?
    15. Member SMG8vT's Avatar
      Oct 8th, 2004
      Nova Scotia
      '00 Beetle R32, '66 Beetle Project, 2011 Jetta TDI Highline
      04-03-2008 01:22 AM #15
      Ok so I figured this would be a good thread to bump rather than cluttering up the forum with a new one.
      I installed new plug wires on mine, started it up and it ran like piss, so I shut it down. It turns out I accidentally switched 2 wires. I pulled the SC off tonight, fixed the order and it runs like a champ now, as strong as ever. Could I have hurt anything doing this, or is the ECU smart enough to not fire those cylinders?
    16. 04-05-2008 09:04 PM #16
      Quote, originally posted by pack-man »
      http://forums.vwvortex.com/zerothread?id=2157409
      Secondary Air Pump Issue...
      I'm having a problem putting back the connector on the Secondary Air Pump.
      It is the intake connect..The one which is connected to the Air Filter Housing. Does anyone have any tips on putting it back together or is there a tool which I should be using?
      Thanks
    17. Banned
      Feb 15th, 2008
      04-05-2008 09:13 PM #17
      those pics are like the size of my wiener
      waaaaaay too small
    18. Member FlyBy's Avatar
      May 27th, 2004
      OH
      2004 Jetta Sedan
      04-06-2008 01:16 PM #18
      So, since the plug wires are metal jacketed, unlike the mkIII's that were rubber, you can't just get a good grip on the metal jacket and pull them off by hand? As long as you don't pull on the wire?
      Insert catchy phrase here.
    19. 08-13-2008 05:47 PM #19
      Hi,
      I have a 2001 VW Jetta GLS 2.0L (engine code AVH) and I want to replace the plugs and the coil. Plugs b/c the car has more than 40k miles and the coil b/c it's misfiring, but only when it's raining or foggy/humid...I suspect there is a crack, but I'll know when I check it out. In any case, where do you get the tool to remove the spark plug wires from plugs themselves?
    20. 09-25-2008 02:35 AM #20
      Great tutorial, saved me a lot of grief. I managed to get the plugs off with a pair of pliers wrapped with some cloth tape. Man that stuff is all crammed in there tight, finally got it done though and she's running much better now, thanks!
    21. 08-21-2009 12:58 AM #21
      I know this post is old but its according to the Bentley its the wrong order.
      Quote
      "Marked for ignition cables:
      A= Cylinder 1
      B= Cylinder 3
      C= Cylinder 2
      D= Cylinder 4"
      I know the wasted spark thing, so I guess it doesnt matter...or does it?
      Modified by seattle111 at 10:08 PM 8-20-2009
    22. Member FolksVagen908's Avatar
      Nov 10th, 2008
      ATL
      mkv Jetta TDI
      10-02-2009 08:46 PM #22
      THANKS so much! this is what i needed. now ma car is up and runnin ;P
      BUMPPPPPPPPPPPPPPPPPPP [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. 12-26-2009 12:02 AM #23
      Thanks for the write-up. I changed my spark plugs today and was successful in removing the wire boots with a needle nose plier. I wanted to replace the set of wires as well, but couldn't figure how to remove/detach the wire from the coil pack. Do you just yank them out of the coil pack or is there a special tool for that? Can I just use some kind of plier to pull it out?
      Update: Nevermind. I used the needle nose plier to grab on to it and it pulled right out. Car's is running smooth with the new wires and NGK spark plugs.
      Modified by peterSR at 9:58 PM 12-27-2009
      2001 Jetta GLS 2.0 AZG engine
    24. Semi-n00b mkivbanger's Avatar
      Apr 22nd, 2008
      Mid-Atlantic East Coast
      99.5 jetta mkiv 92 jetta16 valve
      12-30-2010 11:49 AM #24
      Quote Originally Posted by seattle111 View Post
      Quote
      A= Cylinder 1
      B= Cylinder 3
      C= Cylinder 2
      D= Cylinder 4"
      So your sayn in the thread pic he has up the #'s on the coil pack layout are wrong or the wiring to the plugs is wrong? bc im having issues and need this cleared up for me thx
      The Only DUMB question is the one you Failed to ASK
    25. Member 04 2.slow's Avatar
      Feb 19th, 2011
      Pittsburgh
      Jetta
      03-14-2011 02:33 PM #25
      so is this also the same as replacing plugs and wire on different 2.0 models. I have a bev and i believe its the same but cannot find a write up on them im assuming its the same they look identical but are sold as different products?
