Page 2 of 2 FirstFirst 1 2
Results 36 to 55 of 55
Thread: mkII rear caliper parking brake seized, can I upgrade?
  1. Member J. Daniel's Avatar
    Dec 3rd, 1999
    Gaithersburg, MD
    07-31-2012 07:33 AM #36
    Quote Originally Posted by killervr6 View Post
    driving depends all on the driver. ive driven my brothers car with pads worn out so it was metal on metal durring the rain. i had to stomp on the breaks once and the wheels locked up. sure the car slid sideways a little but i was able to control it. i pulsed the break pedal to simulate abs in the rain.
    Congratulations on keeping the car straight. You're obviously a super driver.
    OTOH, no matter how good a driver you are a car with too much brake bias on the rear will never stop as fast a car with correct brake bias. It's not only keeping the car straight, it's getting the maximum braking force from each tire. Keeping the rears from locking when there is too much rear brake bias simply means the fronts aren't supplying as much braking force as they could.
    I do get a kick out of the fact that, considering the condition of the brakes on the car you describe above, you probably are correct in repeatedly calling them "breaks!"
  2. Junior Member killervr6's Avatar
    Feb 15th, 2009
    salinas,CA
    2001 vw jetta gls vr6 87 scirocco 16v :)
    07-31-2012 01:30 PM #37
    [QUOTE=J. Daniel;78418499]Congratulations on keeping the car straight. You're obviously a super driver.
    i understand this as well thats why i am converting my front calipers too. aside from better braking i just thought about it. This upgrade would actually make the car handle a little better too due to less unsprung weight on the suspension. hmm cant belive nobody has mentioned that yet now all we need is a good pair of light weight rotors to complete this set up
    rip jetta vr6
    87 scirocco 16v has arrived.
    let the monster begin.
  3. Junior Member killervr6's Avatar
    Feb 15th, 2009
    salinas,CA
    07-31-2012 01:31 PM #38
    Quote Originally Posted by J. Daniel View Post
    rip jetta vr6
  4. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    1988 16v Scirocco 2012 GTI 2003 allroad 1990 Jetta GLI
    07-31-2012 07:22 PM #39
    Thread inspired me and since I needed to replace my rear calipers anyway I'm going to give the mk4 upgrade a try. I picked up some good used calipers from Lakeview in Charlotte today and planning on ordering the braided hoses tomorrow. Wish me luck
  5. Junior Member killervr6's Avatar
    Feb 15th, 2009
    salinas,CA
    08-02-2012 03:59 PM #40
    Quote Originally Posted by Sanityana View Post
    what hoses are you going to use to use for that? the stock scirocco hoses dont work.
    and good luck on that let me know how it all goes.
    rip jetta vr6
  6. Member Angrygilmore's Avatar
    Sep 28th, 2008
    ny
    87 scirocco 1.8 16vt with gotech mfi, 2001 gti 1.8t
    08-02-2012 07:14 PM #41
    Thedubnutz.com call keith and he sells the whole shabang
  7. Junior Member killervr6's Avatar
    Feb 15th, 2009
    salinas,CA
    08-03-2012 05:49 PM #42
    just a quick question. kind of a noobie question lol
    does anybody know if the a4 jetta vr6 calipers will bolt on to the corrado g60 carrier/bracket?
    i have a set of front calipers from the jetta but not sure if should just buy the carriers and bolt the calipers on or would i still need to get the complete g60 caliper. im kind of on a budget so if its a direct bolt on to the g60 carrier then i will go for that. if not oh well i guess ill save up for a bit.
    rip jetta vr6
  8. Member Angrygilmore's Avatar
    Sep 28th, 2008
    ny
    08-03-2012 06:11 PM #43
    ask keith at the dubnutz he is also a rado freak..... http://www.facebook.com/TheDubNutz
  9. Junior Member killervr6's Avatar
    Feb 15th, 2009
    salinas,CA
    08-03-2012 06:16 PM #44
    Quote Originally Posted by Angrygilmore View Post
    lol thanks i will send him a message right now.
    rip jetta vr6
  10. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    08-03-2012 09:46 PM #45
    Ordered mine from http://www.germanautoparts.com/ came in today
    Dumb question...my newest VW is a MK3..anything special about how you compress mk4 calipers. Tried my trusty C clamp and got exceptional resistance decided to stop until I asked. Thanks!
  11. 08-03-2012 10:04 PM #46
    Dumb question...my newest VW is a MK3..anything special about how you compress mk4 callipers. Tried my trusty C clamp and got exceptional resistance decided to stop until I asked. Thanks!
    Fronts or Rears? (I get to ask dumb and/or even Rhetorical Questions. It's in the Rules...)
    Investigate "How to Do a Brake Job" on the donor car they go w/, esp the part about twisting them (the pistons) back in during the procedure.
    Please excuse me, but I'm feeling rather 'Hal-ish' lately.
  12. Member Blaines_Rocco's Avatar
    Nov 8th, 2011
    Texas
    1986 Scirocco 16v
    08-03-2012 10:12 PM #47
    Quote Originally Posted by TBerk View Post
    Well you and he and a few others are the guys whose opinions I trust the most.
    also Sanityana did you open up you brake reservoir cap?
    I'm a mechanical engineer, not a mechanic. I know why it works, not how.
  13. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    08-04-2012 12:51 PM #48
    Rear Brake calipers (what entire thread is about.....) came from salvage yard and are sitting on bench so not really sure of the cosmic connection between them and the brake reservoir cap but willing to give it a shot
  14. Member
    Dec 15th, 2010
    south jersey
    87 16v rocco
    08-04-2012 03:35 PM #49
    less resistance will result by opening the reservoir cap while retracting the rear caliper pistons, not drastically less, but it helps. do this all the time with hondas. noticeable difference, just use some type of fine mesh filter on top of the reservoir so that foreign materials won't go in. any kitchen strainer big enough to fit the opening will do.
  15. Junior Member killervr6's Avatar
    Feb 15th, 2009
    salinas,CA
    08-08-2012 03:51 AM #50
    make sure that you dont have to turn the piston while compressing it. on the mk4's you have to turn the piston clockwise while compressing it.
    rip jetta vr6
  16. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    08-08-2012 07:39 AM #51
    Thank you!
  17. Junior Member killervr6's Avatar
    Feb 15th, 2009
    salinas,CA
    08-11-2012 02:28 AM #52
    your welcome.
    i just put some mk4 calipers on my scorocco and even with the caliper empty of brake fluid it was still hard to compress and turn at the same time. i used some needle nose pliers to turn the piston with the groves it has on there. a caliper piston tool kit would be great for these style calipers.
    http://www.ecstuning.com/Volkswagen-...ols/ES2153340/
    rip jetta vr6
  18. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    08-11-2012 03:03 AM #53
    Found a similar kit for 39.95 at harbor freight
  19. 08-11-2012 03:27 AM #54
  20. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    08-11-2012 06:39 AM #55
    your welcome.
    Trust me, I do quite a lot of brakes, and for any car with rear discs a kit like this (or similar) is indispensable, forget any of the small cube tools or horsing around with pliers etc. I use this exact kit on many makes and models, works very well.
    Old sciroccos never die....they just go faster....sometimes.......
    www.ziggituning.com
    My Project...
