VWVortex.com - Wheel Stud Torque Spec??
    Results 1 to 14 of 14
    Thread: Wheel Stud Torque Spec??
    1. 04-16-2005 05:39 PM #1
      Just wondering what the torque spec. if for the wheel studs that hold on the wheel. I just took my wheels off to clean them and dont want to over tighten them or anything. I was figuring on it being around 125-130ft/lbs??
      Thanks in advance
    2. 04-16-2005 05:44 PM #2
      90 ft/lbs is fine
      Jul 13th, 2001
      Oakland, CA
      04-16-2005 06:25 PM #3
      I think the actual specification is 85 ft/lb.
      Kenji
    4. 04-16-2005 07:19 PM #4
      I believe the owner's manual says 120Nm, which is 87-88ft/lbs.
    5. 04-16-2005 08:20 PM #5
      yep, 88 lb-ft
    6. Member
      May 17th, 2000
      Los Angeles
      2002 GT2871 TT Q coupe, 1969 RS Camaro
      04-16-2005 08:44 PM #6
      that's why 90ft/lbs is o.k.
      easier to dial into as well.
    7. 04-16-2005 08:48 PM #7
      true, it's doesn't have to be exact... i'm sure there's a reasonable range in the spec
    8. 04-16-2005 09:01 PM #8
      thanks!
      I guess I will have to back them off tomorrow, Im at like 125ft/lbs right now.
      May 17th, 2000
      Los Angeles
      04-17-2005 03:56 AM #9
      DAMN that's high! one thing you'll notice, after coming from that torque number, you're going to think 90 feels WAY too low.
    10. Administrator Emeritus adg44's Avatar
      Aug 2nd, 2000
      VA
      04-17-2005 11:47 AM #10
      Yeah, the manual says 88, but I always use 92.
      It's more important that they are all torqued evenly rather than what torque they are at (as long as you are pretty close to 88).
      - Anthony
    11. 04-17-2005 12:18 PM #11
      Before I got my VW I came from a truck background where torque specs were in the 160-180ft/lbs range. I guess this is a bit high for such a small car.
    12. Member osbornsm's Avatar
      May 7th, 2004
      Elgin, IL
      2004 VW .:R32
      04-17-2005 02:27 PM #12
      Quote, originally posted by GTINC »
      Some reason the spec in the owner's manual was not OK for your?
      Yea, just wanted a lil piece of mind. 88 ft/lb plus a lil extra
      Or you could just go the Porsche GT route and do 600 ft/lbs With only ONE center lug nut... you better have that mother tiiiiite.
    13. Member DiscoStu's Avatar
      May 8th, 2001
      MA
      2010/VW/Passat - 2014/VW/Touareg
      04-17-2005 04:55 PM #13
      I just put my Aristos back on today and I torqued the lugs down to 95 ft/lbs. It felt like they were barely on.
      The "click" came much sooner than expected.
