Page 10 of 10 FirstFirst ... 6 7 8 9 10
Results 316 to 349 of 349
Thread: Official 337/20AE/GLI Dyno Sheet Thread
  1. Member johnandbek's Avatar
    Jan 9th, 2006
    Beautiful Bummerton
    04.5 GLI, 01.5 S4
    12-06-2008 10:53 PM #316
    Quote, originally posted by IFiONLY »
    @22psi on 93. and it was about 93 degrees today
    Holy Turbolag Batman,
    Nice overall nubmers but wow does it look like a lightswitch went off at about 4200rpm.
    Modified by johnandbek at 7:54 PM 12-6-2008
    //NS Performance
    Auburn, WA
    253.333.8856
  2. 12-07-2008 03:14 PM #317
    Is there really that big of a difference between dynos? I ran at swift on there dyno dynamics with only a chip and put down 186hp 255tq.
    Ive seen some other dyno sheets on here with guys listing alot more mods and running around the same hp and like 40 ftlbs less....
    Quote, originally posted by kimlin85 »
    Dyno Type: Dyno Dynamics at Swift Motorsports
    BEFORE: 42dd 3" downpipe, magnaflow catback, forge 007 dv.
    AFTER: added adjustable fpr, Revo stage 2 software, custom dyno tune.
    BEFORE: 150 hp, 165 tq
    AFTER: 183 hp, 215 tq
    and ill get my dyno sheet up as soon as i can
    Modified by twistedlive at 3:22 PM 12-7-2008
    Modified by twistedlive at 10:16 PM 12-7-2008
  3. 12-09-2008 04:42 PM #318
    Quote, originally posted by johnandbek »
    there really isn't any lag on my setup. that run started off in 4th gear, so it took a little while to spool up.
  4. 12-26-2008 07:48 PM #319
    Revo Stg. 2 @18psi
    Boost hiccup AHHHHH! This sucked. Ended up buying new plugs and coils re-gapping the plugs and replacing the N75 with a "J" valve. Runs smooth now, time for a new dyno!
  5. 01-03-2009 05:06 PM #320
    my mods are as follows:
    Unitronic Stage 2 chip, 4 bar FPR, forge 007 DV, samco TIP, smoothed/drilled airbox w/ K&N, eurojet FMIC, progressive WM injection 100% meth. nozzle right after the TB into the intake mani, advanced timing by 1.5 degrees, 2.5 inch downpipe. 2.5 inch straight pipe exhaust
  6. Member deki337's Avatar
    Feb 15th, 2004
    Burnaby,Canada
    05 BL BT GLI,coming soon 2011 S4
    01-24-2009 12:46 AM #321
    Quote, originally posted by deki337 »
    2.0l stroker kit
    gt3076r
    unitronic software
    ghl 3" TB
    custom FMIC
    =305whp/344lbft tq @16 PSI cant wait to crank up the boost to 25 PSI
    now 366whp/319lbft tq @ 20 PSI
    05 Jetta 2.0T GLI - GT3076 + UNITRONIC = 366whp/319lbft tq @ 20 PSI
  7. Member anndreuw's Avatar
    Jan 9th, 2008
    South Fl
    03 BMP20AE
    01-28-2009 02:12 PM #322
    go damn, i cant even fathom how much wheel spin you must have ^^^, you must only be able to do 4th or 5th gear pulls lol, awesome dub, i'm glad your on our team lol
  8. Member PetrBrno's Avatar
    Apr 1st, 2003
    Milford, MA
    3BG Variant 1.8T
    02-11-2009 09:28 PM #323
    337
    Unitronic 1+ (93oct)
    Samco DV
    Autotech CAI
    Stock Exhaust
    188.7whp / 235ftlbs tq
    Modified by PetrBrno at 9:31 PM 2-11-2009
    Loud Noises.
  9. Member vabeach337's Avatar
    Jul 31st, 2004
    Norfolk, VA
    MKVI Golf R 4door
    02-23-2009 05:44 PM #324
    This dyno was done a few years ago before my recent mods.
    Installed at the time:
    APR 93
    APR 2.5" Turboback
    Carbonio CAI
    Forge 007 DV
    Once I find a dyno dynamics dyno in the area I'll get my new numbers and post them up
    MKV R32 HPA FT425(sold)
    337 APR 3+(sold)
    MKIV GLI (ex took it)
    2012 R Black APR Stage 1, GOLF Monster Mats, New South Boost Gauge in Vent Pod
  10. 03-25-2009 12:56 AM #325
    How do you have less tq with 4 more psi? Nice numbers regardless.
  11. Member TheGreasyJap's Avatar
    Jan 12th, 2003
    San Diego, CA
    337 & MkII Coupe
    04-25-2009 03:27 AM #326
    Both runs on the same dyno.
    January 2008:
    Mods: APR 91, AEM CAI, APR TIP, APR TBH, Tyrol UGSMIC, Milltek 3-2.5 TB
    April 2009:
    (134,250 miles)added Kinetic Hi-flow exhaust mani, K04-001 and APR K04 91 octane program with MBC holding spike to 22/23psi
    The numbers look low, but the curves look good, and the car feels really good on the road.
  12. 04-30-2009 09:57 PM #327
    201whp and 238 ftlbs
    dynojet
    2005 gli
    giac software
    crappy p-flo
    3 inch dp
    2.5 cat back
    apr TIP
    evoms DV
    now have evoms cold air took care of some of the surging
  13. Member 20thAEGti1009's Avatar
    Jan 27th, 2005
    Martinsburg, WV
    2003 VW GTi (Daily) 2003 VW 20th Anniverary GTi (Drag Car) 2004 Chevy 3500 Crew Cab Dually (Tow Rig)
    05-02-2009 11:42 AM #328
    2L 20v
    Supertech 83mm Pistions
    Eurospec Rods and Crank
    AEB Head
    Ferrera Valves
    Techtonics Tuning Springs and Retainers
    Cat Cams 3652's
    Force Fed Engineering Tubular Header
    Force Fed Engineering Custom Intake Mani
    T3/60-1 .63 a/r
    Force Fed Engineering 3 inch DP
    Bosch 044 Fuel Pump
    1000cc Delphi Low IMP Injectors
    Autronic SM4
    Kevin Black Tuned
    Pump Gas @ 17psi
    C16 @ ~29 or 30psi
    Pic of the Bay
    Best Turbo Kits around.
    565whp 60-1'ed 2.0 20v
    Billet 67mm True Street Build in Progress
  14. Member integragsr423's Avatar
    Sep 11th, 2008
    2007 GTI 6 speed
    07-14-2009 10:35 PM #329
    STOCK!!!! GIAC PUMP MODE and ebay CAI [IMG]
  15. Member kevinadamsvw's Avatar
    Oct 15th, 2007
    Lexington,KY
    2010 CW 4-Door GTI,2003 BMP 20th AE RIP, 2003 Wolfie
    08-25-2009 09:18 AM #330
    dyno dynamics dyno-
    178.8 whp
    uni stage 2, 3" TBE, intake, forge 007, evoms fmic.
    seems really low, it was a real cool day almost no humidy.
    there on underdrive pulleys on the car... problem?
    a/f hit 10.1-1 under boost. that too seems excessivly rich.
    2010 CSG 4-door GTI- 8380 labs coilovers
    #3324 20th AE -Frankenturbo- Uni Tuned- RIP 1/28/12
  16. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    09-02-2009 04:48 PM #331
    my motor came from a JB 20th and is now in my OG 84 GLi..does that count????
    388whp333ft.lbs 1.8T 3071.
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  17. 10-21-2009 10:11 PM #332
    DynoDynamics 194HP, 225TQ red, pink = 4th gear, green = 3rd gear
    GIAC X+, 3" Turboback (ebay downpipe mated to GHL catback), Forge TIP, modded stock airbox (smoothed inners, lateral cutout, K&N), stock DV
    Just ordered N75J and forge 007 to hopefully smooth out my curve around 3k-5k... lots of fluctuation from 15psi to 20psi in that area....
    Modified by DrTacoElf2 at 7:12 PM 10-21-2009
    Modified by DrTacoElf2 at 7:13 PM 10-21-2009
  18. 12-05-2009 04:46 PM #333
    Just got my car dynoed wish i can post the chart but I have no way of scanning it. Anway its bone stock just unitronic stage 2 chip, boost controller, and 2 1/4 inch exhaust cat back with stock cat. 220hp 267tq
  19. Member johnandbek's Avatar
    Jan 9th, 2006
    Beautiful Bummerton
    04.5 GLI, 01.5 S4
    12-08-2009 11:15 AM #334
    My dyno sheets looks just like this (but not as high) with spikes and dropouts evenly spaced accross the RPM band as well. Is this a problem with chip tuning, mabey a boost leak, FPR playing catchup to increased boost, dirty or failing MAF?
    Quote, originally posted by DFTsGLI »
    Modified by johnandbek at 8:18 AM 12-8-2009
    //NS Performance
    Auburn, WA
    253.333.8856
  20. Member GrkA4's Avatar
    Apr 28th, 2005
    South Philly
    2008 MkV R32
    01-31-2010 11:36 PM #335
    Spotted a black 20th parked outside of my house around 22nd and South in Philadelphia. Car had smoked tails, tint, a-pillar gauge cluster and some other minor work.
    2008 .:R32 #3859
  21. 02-06-2010 01:14 AM #336
    johnandbek- I think it's just the fuel trying to play catch up. I tweaked the timing on the tune but didn't match the fuel to it due to street tuning and limited time. When I get back i should be dialing in the fuel a little more and it should smooth out the graphs. But I work on my STI rally car more so finding the time for the GLI is hardpressed
  22. Member acetate909's Avatar
    Jul 2nd, 2006
    Border Town Tucson
    337, '67 Square
    03-24-2010 03:51 PM #337
    Quote, originally posted by GrkA4 »
    I think you're looking for the spotted thread, which the 3/2/G doesn't have...more of a regional thing
    Quote Originally Posted by Chris Palko
    This bitch is Waste Management cuz I piss in her mouth
  23. Member acetate909's Avatar
    Jul 2nd, 2006
    Border Town Tucson
    337, '67 Square
    03-24-2010 03:53 PM #338
    Quote, originally posted by Vegeta Gti »
    yes! and can I have it?!??!
    any videos of that monster?
  24. n00b
    Sep 8th, 2010
    Grants Pass
    01 VW GTI+ 07 Honda Element
    09-08-2010 02:27 AM #339
    Yo, well im not sure if in in the right spot, and I didnt see a new to the fourm area and i didnt want to start another thread just to introduce my self..
    and I dont know if im in the right spot, there isnt any spot for a MK4 GTI,
    i dont have a 337 or a 20th edition....
    But i do have a 01 GTI MK4
  25. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    05-19-2011 03:11 PM #341
    figured i'd bust in here again with my OG 84 GLi that has a 20th motor...last dyno was 406whp@25 on 92..got higher but was spinning so doesn't count.
    some changes:
    built and worked AEB
    SEM
    port matched intak eand exhaust mani's
    cat 3651 cams
    fresh tune for above along with some other little things
    hope to dyno soon.
  26. Junior Member inVENTOr's Avatar
    Jun 23rd, 2009
    Russia Moscow CVAO
    GTI 2002 337 edition
    05-24-2011 02:57 PM #342
    Hi here is dyno my 337 from Russia Moscow
    1. Neuspeed catback 2.5 custom 3' downpipe Apr stg1 stock and 93
    all other mods are stock K03S turbo
    2. Neuspeed 2.5 catback custom 3' downpipe,Forge Front Mounting Intercooler , APR R1, 4bar reg, Neuspeed Turbo Air Intake Pipe, K04-001 turbo, Denso IK22, new fuel pump(VDO)
    APR soft for K04-001kit (Stock 91-93-104)
    here is 93 oct
    here is stock
  27. Junior Member
    Jul 22nd, 2010
    10-03-2011 08:21 PM #343
    675
  28. Member JWoody's Avatar
    May 16th, 2006
    Planet Earth
    2005 Jetta GLI 1.8T 6SPD/2008 BMW X5 3.0si/2009 BUELL 1125CR
    11-20-2011 01:29 AM #344
    With 100 Octane in the tank and adjusted Timing Advance from +.75 to +1.5. BKR8EIX gapped at .25-.26. W/M was disabled, Snow controller failed the previous day.
    -J
  29. Member
    Feb 14th, 2006
    Western Mass
    04.5 vw jetta GLi 1.8t
    02-18-2012 04:22 PM #345
    223.5whp and 254wtq
    (giac x+,3" turbo back,fmic,tip,intake,dv,Catch can,powergasket. Boost was 22psi)
    04.5 TR GLi 224WHP 254WTQ giac x+ tuned
  30. 02-20-2012 07:25 PM #346
    Mods on sig...
    Pag Parts kit, PTE 5130, Brute rods, Eurodyne 630cc, Stg 2 water/meth, Pag Parts FMIC Kit with TT225 intake mani, Stage 3 Clutchnet n 17lb FW, 398whp @ 24psi
  31. Member desertdubs_C's Avatar
    Sep 20th, 2009
    Phoenix
    2005 VW Jetta GLI Blue Lagoon --all stock--
    05-13-2012 01:15 PM #347
    Uploaded with ImageShack.us
    Build thread in sig
    100*F day of run. 91oct pump gas at 27psi
    My never ending project RootsNeverDie
  32. Junior Member
    Apr 2nd, 2012
    FortCollins
    SOLD 04.5 BL GLI
    10-17-2012 06:28 PM #348
    ok as promised gonzo stage 2+ mods in sig 213whp 284wtqPhotobucket
  33. Member SB_GLI's Avatar
    Oct 17th, 2005
    Stevens Point, WI
    10 Wolfsburg Tiguan, 04.5 TR GLI, 90 Cabriolet
    02-03-2013 02:47 PM #349
    Frankenturbo k04 - F21
    GIAC K04-02x file - 225tt injectors & MAF
    snow performance wmi
    3" TBE
    UG SMIC
