Page 2 of 10 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 36 to 70 of 349
Thread: Official 337/20AE/GLI Dyno Sheet Thread
  1. Moderator Flyin18T's Avatar
    Jan 10th, 2001
    Long Island
    05-06-2005 12:54 PM #36
    Quote, originally posted by Frank aka Rick »
    ok fine I'll contribute instead of naysaying
    You're a good man Charlie Brown. That's some nice torque you got there. Sweet setup.
    2012 MKVI Jetta GLI / 2008 Civic Si Sedan / 2007 Mazdaspeed 6 / 2004 MKIV Jetta GLI (1.8T) / 1996 MKIII Jetta GLX VR6
    https://twitter.com/Flyin18T
  2. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    05-06-2005 02:13 PM #37
    Quote, originally posted by 2004GLI »
    for those who cant see it says 197.7whp and unfortunately they couldnt find a solid place to tap the torque sensor so no accurate torque measure
    Huh?
    All dyno's only measure Torque. Horespower is a mathmatical conversion from torque.
    Oh and my runs;
    Modified by grizzlyone at 2:15 PM 5-6-2005
  3. Moderator Flyin18T's Avatar
    Jan 10th, 2001
    Long Island
    05-07-2005 07:53 PM #38
    Thread is too young to die......BUMP. I'm enjoying all the info from this thread anyway.
  4. Member gtivrsix's Avatar
    Aug 10th, 2000
    Sanford NC
    03 20th AE #775, 04 Saab 9-3 Convertable, 10 Mini Cooper
    05-07-2005 08:38 PM #39
    Heres the latest dyno I had. I was running half a tank of 116 octane mixed with half of 93, but instead of running the 100 octane program, i accidentally switched to 91 octane. Then numbers were still pretty good.
    Stock K03s
    EVOMS FMIC
    EVO DV
    N75J
    APR-91
    Samco Inlet
    Carbino CAI
    GHL 2.5" turbo back
    This was run #3 and the engine only got stronger with each pull. Intake air temps stayed around 30 degrees above outside air temps. Pull was made in 4th gear on the same dyno as the charts I posted earlier in the thread. Also, i was tweaking boost and timing with Vtune and the engine seemed to respond very well to it.
    K04-020 going on as soon as i get the rest of the parts, ill post charts whenever i finally get it done.
    Modified by gtivrsix at 2:00 PM 5-28-2005
  5. 05-08-2005 08:32 AM #40
    my runs were done in 4th gear for reference.....
    Am I OG status yet? Close to 40 years old and still driving a slammed and Boosted 'Dub...cool or sad?
  6. 05-08-2005 09:12 AM #41
    id like to see what a samco TIH and intake spacer would do.
  7. 05-08-2005 01:38 PM #42
    MAke this a sticky!
  8. 05-08-2005 02:21 PM #43
    Quote, originally posted by Jesse’Z JeT »
    Jesse what is the intake spacer? I can't recall what part you mean by this?
  9. Member gtivrsix's Avatar
    Aug 10th, 2000
    Sanford NC
    05-08-2005 03:09 PM #44
    I think hes talking about the evo-heatshield or the newsouth powergasket.
    I Just installed the rest of the samco boost hoses and i have the evo-heatshield out in the garage, i will hopefully be able to post some numbers when i get around to installing it.
  10. 05-08-2005 03:20 PM #45
    Quote, originally posted by gtivrsix »
    yes i guess i am a old school muscle car guy....we call em heat spacers but i guess for the vw it is pretty thin so it would be just a shield......i run a 1" on my mustang......
  11. Member Dr. Hank McCoy's Avatar
    Jun 10th, 2003
    21227 via Chicago
    '11 VW GTI (Miss Chelsea Dagger)
    05-09-2005 12:15 PM #46
    how old school???? what are you "used to" working on?? small-block V8's??
    is this your 1st dub??
    what do you think??
    **The Pelvic Exam Ninja**
  12. Moderator Flyin18T's Avatar
    Jan 10th, 2001
    Long Island
    05-09-2005 04:07 PM #47
    Request: Dyno of downpipe w/ dump tube. (full open) Hopefully with a before/after comparison.
  13. 05-09-2005 05:17 PM #48
    This was an awesome thread Idea.
  14. 05-10-2005 04:00 AM #49
    this is by far, the most interesting thread ive seen in a while
  15. 05-10-2005 01:38 PM #50
    Here is my latest run compared to my best run on GIAC v12.
    mods were:
    GHL CAI (may soon be replaced my modded airbox)
    4BAR FPR
    EIP Dogbone
    2.5" Techtonics TB
    Samco TIH
    N75J
    Forge 007p
    GIAC X+
    Here is a cross comparison of a stock run that I did on my previous 02 Jetta. The stock run on the GLI was practically the same thing, I just can't seem to find the sheet to scan
    Mods were:
    GHL CAI4BAR FPR
    EIP Dogbone
    2.5" APR DP with custom catback
    N75J
    Forge 007p
    GIAC v12
    Modified by Curl at 1:41 PM 5-10-2005
    Modified by Curl at 1:45 PM 5-10-2005
  16. Member gtivrsix's Avatar
    Aug 10th, 2000
    Sanford NC
    05-10-2005 02:34 PM #51
    looking good. You can already start comparing the differences between chips and other mods.
    keep em coming guys
  17. 05-10-2005 04:41 PM #52
    Comparission is between a stock exhaust w/ K&N CAI Intake and 2.5" MagnaFlow Exhaust and K&N Intake.
    I have a N75 and soon REVO Software, but not on this dyno.
    The only mods to the car are:
    K&N Cold Air Intake
    2.5" MagnaFlow Prototype Exhaust (No Resonator, Single Muffler)
    Heres the Dyno Chart:
  18. 05-10-2005 04:46 PM #53
    Quote, originally posted by wig-out-at-denkos »
    K&N Cold Air Intake
    full 2.5 turboback or just cat-back?
  19. 05-10-2005 04:50 PM #54
    sorry, just cat-back. stock downpipe, TIP, IC and everything else.
    The only mods that this car are CAI and the Exhaust.
  20. 05-10-2005 04:53 PM #55
    Quote, originally posted by Curl »
    Mods were:
    GHL CAI4BAR FPR
    EIP Dogbone
    N75J
    Forge 007p
    GIAC v12
    That stock run is quite impressive.
  21. 05-10-2005 05:01 PM #56
    I meant to say stock as in no software. It did have a K&N drop-in and a Forge 007p, but thats it
  22. 05-11-2005 11:38 AM #57
    That's even more interesting. I say that because of the running debate on whether a K&N filter adds HP and/or torque. Did you do both mods at the same time? I'm curious to know which one gives the most addition....
    Either way, it is still very impressive to have those numbers with the mods you did have.
    -C
  23. Member
    May 16th, 2004
    North of you
    05 GLI Rswap
    05-11-2005 11:13 PM #58
    here is mine, with revo and Carbonio CIA and forge 007!!
  24. 05-11-2005 11:46 PM #59
    Quote, originally posted by wolfs1eightns »
    Im curious with yours is there any SAE corrections, because that seems way to high for a car with stock exhaust and DP.
    It doesnt seem at all in-line with any other 18t dyno ive ever seen
  25. Member
    May 16th, 2004
    North of you
    05 GLI Rswap
    05-12-2005 10:29 AM #60
    I ran it stock at 160whp and last year my 03 W/E ran 180hp 230ft/lbs with the same mods, my buddy ran 300whp with his stage 3++ and that was the same dyno and right after mine and he was running 3gallons of 116 with half a tank of 91. and this was all done on the same dyno.
  26. 05-12-2005 11:37 AM #61
    im just asking wether or not the dyno operator was using SAE smoothing as there is no indication from your posted sheet.
    Seeing how your numbers are higher than nearly every chipped, intake exhaust and DP car is seen.
  27. Member
    May 16th, 2004
    North of you
    05 GLI Rswap
    05-12-2005 11:45 AM #62
    im not too sure if he was using that or not ill give him a ring and find out.
  28. 05-15-2005 03:40 PM #63
    All I know is that I dynoed my 05 GLI a few weeks ago. Bone stock it ran 135whp. Stupid printer was not working so I didn't get a print out. Anyways, is this on par with what it should run stock.
  29. 05-15-2005 06:02 PM #64
    thats seems about 20-30 HP short of most bone stock gli's
  30. Member gtivrsix's Avatar
    Aug 10th, 2000
    Sanford NC
    05-16-2005 01:40 AM #65
    yea, that seems really really low. Check my earlier posts in this thread for my stock and chipped dyno. It is about the average of what your car should be pushing to the wheels when bone stock.
  31. Banned Hetzen's Avatar
    Dec 9th, 2003
    05-19-2005 09:49 PM #66
    5 runs in a row. First two wouldn't read.
    2.5in GHL TB, APR 93, GHL CAI, Hyperboost DV.
  32. 05-23-2005 12:54 AM #67
    apr seems to be weak in torque
    thus far from comparison it's giac X or REVO
    post more dyno's so that the the best chip can be found, GIAC or REVO
  33. Member gtivrsix's Avatar
    Aug 10th, 2000
    Sanford NC
    05-23-2005 01:12 AM #68
    your missing the point of the thread. Its not a "whats the best chip" or "who has the most power" thread. The purpose is to research before and after effects of certain mods. Since each dyno and weather condition will be slightly different, there will be variations in peak power. What we are trying to see is torque curves, A/F rates and horsepower curves and the changes certain mods make.
    If you want a "best chip" thread, use the search, there are a million different polls and threads discussing it.
    Thanks
  34. 05-25-2005 02:40 PM #69
    You, you, and you . . . Panic. The rest of you, come with me." -U.S. Marine Corp Gunnery Sgt
    haha, sadly i've heard that more than a couple of times.
  35. 05-26-2005 08:01 PM #70
    Run 01 was stock with and autotech intake.
    Run 04 was Revo (boost - 9; timing - 3) and autotech intake.
    Difference in hp - 22
    Difference in tq - 50
    Dyno was done at tuning technologies
