Bump for a "Thanks for this thread!"![]()
Mine has been rattling for the last 30K mi (has 80K on it now).
I bought a set of Paul's bushings 2 years ago & finally put 'em in last night. They rock!. No more rattle & throttle response *seems* better, but that could just be me enjoying the result of my labor.![]()
It took all of ~ 30 mins.
Some notes:
- Getting the old rod out required some tugging. I was afraid I'd snap something, but it finally came out intact.
- Getting the newly rebushed rod in was even harder. The new bushings hung up on the lip of the manifold hole. I put a little graphite on the bushings and it went in with moderate force. It will snap into place when properly positioned.
- Once in place, tightening the actuator housing screws all the way caused the rod to bind. I ended up shaving about .5mm off the orange bushing. After that it rotated freely. (in pic below)
Quote, originally posted by norcalmanvr6 » ..... The only thing that scares me is putting on Paul's bushings and having to use super glue to keep them from coming apart. I didn't use super (or any) glue. The new bushings snap together tight enough for re-assembly. And, once in, they're not going anywhere. Hopefully I'll never be in there again so I wasn't worried about them separating slightly and preventing future rod removals!
But when you think about it, this proceedure, along with the improved bearings will keep you from having to 1. Buy a new rod that will just fail again or 2. wear the plastic manifold beyond repair.
