nice write up!
#1
I did some searching and couldn't find what I was looking for, so here is a how-to on replacing the hydraulic-bonded rear axle bushings in a MKIV.Why do this at all: Some MKIVs came with an oil-filled bushing which can crack and leak over time, causing clunks and poor handling. Mine weren't leaking, but they were cracked and the car is pushing 100K miles. I was adding bigger rear brakes and a sway bar at the same time, so I decided to just remove the axle from the car. I can't see how this could be done with the axle still in the car, but some people claim to have done it.
Why do this yourself: I already had the axle out of the car, so I figured it would be no sweat to have the machine shop press out the bushings. I was wrong. They took one look at it and said they'd never be able to maneuver it the right way in the press. I called the VW dealership and they said they farm the work out to another local machine shop. I called them and they claimed they'd never done one. I figured I better do it myself since I don't have all month to get this done. If you have access to a place that is willing and able to press them out / in for you, I would recommend it.
Replacement Part: Originally this was a non-replaceable item, just get a new beam if you need new bushings
. Now the replacement part is: 1J0501541C. I ordered mine from http://www.worldimpex.com, I think they came to around $60 for the pair. I asked about different versions of the bushing, i.e. an Audi TT bushing or a 337 bushing. The part number listed above is the same for all MKIVs, including the TT. It is a "bonded rubber mount", has no oil inside, and looks like this:
Tools you will need for this job:
1) A decent-sized cold chisel, and a Big Hammer, like this:
2) A garden-variety hacksaw with a removeable blade, like this:
3) A drill with about a 1/4" bit
4) basic hand tools, air is nice, but not necessary
5) I didn't think I would need this, but it turned out to be the case -- a Big Honking C-Clamp, this one has at least an 8.5" throat. Oh, and a couple of scraps of wood:
Remove Axle:
1) Jack up car and remove wheels, obviously. Don't forget jack stands.2) Disconnect brake lines, e-brake cables, and shocks (I left them dangling from the top mounts). Rotate the axle down and rest the rotors on the ground. Coil springs should almost fall out at this point.
I removed my calipers, rotors, and stub axles also, because they are getting replaced. This made handling the axle beam easier, but not necessary if you are just doing the bushings3) Remove pivot bolt and nut, which goes through each bushing. The inner fender liner is in the way, but you can bend it back rather than removing it. You might want to support the axle in the center with a jack so it doesn't come dropping down as you take out the second bolt.
Remove Old Bushings:1) With the axle on the ground, drill a couple of holes in the bushing to drain out the oil. Let it all drain out, you don't want it splattering around when you're using your Big Hammer.
2) With the chisel and Big Hammer, go to work on the lip of the bushing, driving it in the direction of the bushing on the other side, like this:
After a couple of hits it will start to look like this:
Keep driving it until you have it out. No need to burn it out with a torch, making a huge mess in the process.
3) Now you have to remove the metal sleeve that was around the bushing. It looks like this:
Take apart the hacksaw, put the blade through the hole, and cut one slot in the sleeve carefully. With the axle standing up, the bushing housing is angled perfectly for this type of easy cutting. You want to cut through the sleeve, but not into the housing:
4) One slot is all that is needed to relieve pressure on the sleeve, allowing you to pound it out with the chisel:
Here is what the old bushing and sleeve look like:
And the empty housing:
5) Repeat on the other side, stand back and admire your work. My axle looked like a mess, so I borrowed a friends sand blaster and went to work. After blasting and priming, it looked like this:
Just a little inspiration for you in case you're wondering why you tackled this job :biggrin: .6) Go put your new bushings in the freezer.
Install New Bushings:
This part turned out to be a lot more difficult than I anticipated. I'm not sure if freezing the bushings did any good at all. Maybe the freezer wasn't cold enough or they weren't in there long enough.
1) Take new bushings out of the freezer. Try to fit them into the housing to see if they are even close. Mine were tantalizingly close, and I thought I could just tap them in with a hammer. Ha.2) Check their orientation according to the diagram from the Bentley:
3) The problem is, the new bushings are rubber with a plastic sleeve, so the whole thing wants to give and rebound while you're hammering on it. There was just no way to get it started where it didn't pop back out of the hole when I hit the opposite side. There is a lead-in chamfer on both the bushing and the steel housing. My assessment: these chamfers need to be worked so that the bushing can get started in the hole. Break out a half-round metal file for the housing and some rough grit sandpaper for the bushing, and sand a nice gentle lead in on those puppies. I had hoped to get it done without filing metal, but in my case it was necessary. You might have better luck cajoling the bushing than I did.
4) Spray a little WD40 on the outside of the bushing and set it up as shown with the Big Honking C-Clamp. Once you get it started it will look like this:
I was able to get it a little over half-way in using this method, but then it didn't want to go any farther. I hammered it the rest of the way using the Big Hammer.4) And viola! You're done. Now you get to do the other side!
Final Analysis: With a little perseverance you can do this. I would have much preferred to pay someone with a press to do this for me, especially after the difficulty putting in the new bushings. I had read where the frozen bushing just slipped right in, almost by hand. That was definitely not the case for me. I'll post up pics of the finished and painted axle once it is all assembled. On to other projects . . .
Modified by RabbitsKin at 8:16 AM 12-4-2008
Modified by RabbitsKin at 8:19 AM 12-4-2008
#2
nice write up!
#3
Great job!
#4
looks pretty easy too. i have to replace my rear axle b/c its bent, wanted to know if you knew if the axle can be shifted similar to the subframe or is it bolted in one place (the hangers?) also are new bolts always used? torque spec super high or what. thanks.
#5
Quote, originally posted by Banditt007 » looks pretty easy too. i have to replace my rear axle b/c its bent, wanted to know if you knew if the axle can be shifted similar to the subframe or is it bolted in one place (the hangers?) also are new bolts always used? torque spec super high or what. thanks. I didn't remove the body brackets that the axle mounts to, so I don't know if the holes are slotted to allow adjustment or not. There is definitely no adjustment in the pivot bolt. I plan on re-using the bolts, as they didn't seem to be a critical one-use part like the axle nuts. Torque specs aren't super high, I got mine loose without an impact gun.
#6
Next time try hitting the beam with a heat gun and putting the bushings in the freezer. This is how I did bushings before I got a press. From tantalizing close, to dropping right in.![]()
Btw the factory brackets that bolt to the car are slotted so that you can adjust even toe on each side.
#7
Quote, originally posted by enginerd » Next time try hitting the beam with a heat gun and putting the bushings in the freezer. This is how I did bushings before I got a press. From tantalizing close, to dropping right in. ![]()
By the time I thought of the heat gun, I already had it painted. Well glad to know there is another method for people to try.
#8
Exceptional! Thanks for your work on a topic sorely needing doccumentation. I just ordered a 6-ton shop press for the rear LCA bushing (mines cracked). Thanks,
#9
thx for the write up , im gona do mine next week ,
#10
Instead of the freezer, get some dry ice. Works great and cools/shrinks quickly. Preferred method to replace bushings in the aviation industry.Many welding supply houses stock dry ice. It's cheap. Take a cooler with you to pick it up.
Modified by paramedick at 2:04 AM 6-15-2005
#11
Perfect. Someone aked the same question I was gunna ask, and then answered too! I love the search option, I would of never found this.I took my car in for an alignment and they told me my right rear left wheel as excessive toe-in, and the right one toe-out
This is causing the whole car to sway back and forth at high speeds(autobahn mind you). He told me he had never seen this and that I needed a new rear axle... I priced one for $600+.
But know if you say that there is an adjusment, then I will damn look and see what I can do before spending all that money...
Thanks
Adrian
#12
Sweet!![]()
#13
UPDATE: Here are some pics I snapped of the finished and installed rear suspension. Too bad it won't stay this clean:
Modified by RabbitsKin at 8:22 AM 12-4-2008
Modified by RabbitsKin at 11:37 PM 4-14-2009
#14
Just wanted to say thanks for the writeup. I just did this tonight and even with a press, it was still a pain in the ass. It took me six hours to complete but I was taking my time. Anyways, a word to the wise, if you are going to use a press, make sure you have a buddy with you. I left my rotors, calipers, and sway bar on and the whole unit probably weighed in at around 80-90 lbs. This is a difficult thing to hold up by yourself. The whole process was not difficult but god do I hate doing brake flushes.
#15
does that website still have this product? because I can't find a site that does.
#16
Just call them, they can look it up. Ask for Justin.
#17
I don't have a heating gun, and the only thing i have is an acetlyne torch or propane. Would this get it to hot causing the plastic on the bushing to melt?
#18
Quote, originally posted by El Romano Loco » my right rear left wheel as excessive toe-in, and the right one toe-out This is causing the whole car to sway back and forth at high speeds
i have the same problem, but my car pulls to the left and my sterring wheel is about 35 40 degrees to the right so i could keep the car straight. also my tires have major cuppage.
im glad that someone had pointed this out so ill go under my car tommorow to see if there is any adjustment.
Clutch, Cams, Engine Tuning, Coilovers etc. Call (714)997-5842
www.FourSeasonTuning.com
#19
These bushings are the last thing to install. I've replaced all other suspension bushings so far... but need to drop the rear beam - and I've never done this before.Thanks for the write up.
m.
#20
awesome write up!![]()
#21
Nice write up. I just completed mine with no issues, except i found it very hard to use a c clamp and wood to push the bushing home. The bushing kept tilting over and it wouldn't go in straight. easy way around this, i had got a 7" long bolt, and a nut to fit, along with a few huge washers. i was able to put the washers on both end and i used the bolt and nut to pull it togeather. no more bumps and bangs under my car its perfect.Cheers
John
#22
To anyone who has done this, did the new bushings make much of a difference?
#23
so can you drop the axle enough to press the bushings out without removing the hard brake lines?
#24
Just have to disconnect those short pesky flexible lines from the chassis to the axle.
#25
by disconnect you mean unclip? or disconnect and ill have to rebleed the system?
#26
you have to disconnect them......or you risk damaging them if something slips and weight comes down on the lines.here's a trick i alway use.....when you disconnect the lines, twist one of the rubber bleeder caps into the female opening.....it's a tight fit, but can be screwed in with a little force. this keeps all the brake fluid from gravity bleeding while you have the axle off....and makes less of a mess. This usually only requires a quick bleed of the front and then the rear. just my experiences and i have not had any problems with doing it this way. Ymmv.
#27
Any other feedback on how hard this job is to drop the axle?
#28
Quote, originally posted by XM_Rocks » Any other feedback on how hard this job is to drop the axle? I would like to know as well. It seems pretty straightforward to me though.
Unbolt brake line
Unblot shock
Unbolt axle beam from body (where the bushing is)
lower axle beamAm I missing anything?
#29
Quote, originally posted by VgRt6 » To anyone who has done this, did the new bushings make much of a difference? X2
#30
are there any aftermarket bushings instead of using OEM ones? Some that will hold a little better?![]()
#31
Quote, originally posted by mescaline » are there any aftermarket bushings instead of using OEM ones? Some that will hold a little better? Aftermarket bearings...from Shine Racing or Bildon I think.
PS shoudln't you be using some sort of grease instead of WD40? WD is penatrating fluid, NOT lubricant. I used WD to slide poly bushings onto a swaybar and it was a ngihtmare. Realized my mistake, switched to white grease and it slid on like a charm.
#32
Nice write up. It's a lot more different from the mk2/3 than I thought!
#33
As far as how to do this without dropping the axle.....guys, I just don't see any way around it. The bolt that goes through the bushings is what is holding the axle to the chassis. I suppose you could take out the bolts and drop it down a few inches, but then you'd be working upside down and have no leverage for, say, swinging the hammer.By the way, whoever suggested using a big bolt and some washers to draw the bushing into the housing -- that's a great idea! Wish I would have thought of it, but the C-clamp method still works.
#34
Awesome write up, wish i'd have seen it before taking this t**t of a job on. I did everything same as but used a set of spring compressors to pull the little bleeders in. I have to admit i didn't line up the bushes as per your diagram, does anyone know why the bushes have to be orientated like this apart from the obvious, 'cos it says so in the book'. Thanks
#35
May be doing this soon, any update on sources of new bushings?
"Turning right in fifth gear from the left hand lane into the wrong end of a one-way street while indicating left, if at all."
All the custom, none of the cool.
"Trying to be the cool kid is so cool." - MkIV Scene
