Page 10 of 10 FirstFirst ... 6 7 8 9 10
Results 316 to 336 of 336
Thread: How to: DIY rear axle bushing replacement, MKIV
  1. 04-11-2012 11:09 AM #316
    Started this task this weekend. I had to remove the axle beam by removing the two brackets because one side was so siezed up. I'll have to take it in for alignment anyhow, so not too worried that I unmoutned those brackets.
    Long story short, I had to cut through one of the bolts.
    Anyone know where I can get a replacement pivot bolt that go through the bushing? The local parts shops can't figure it out or don't have a listing for it . Before I call the dealership, has anyone used and have specs for a different sized bolt that is close enough? The stock one has a thicker diameter near the flange? Is it that critical that I use a replacement identical to the factory one?
  2. Semi-n00b
    Jun 9th, 2011
    Toronto
    2001 Jetta TDI
    04-11-2012 08:12 PM #317
    Get the right bolt. The dealer cant be that expensive.
  3. Member zak's Avatar
    Aug 26th, 2004
    02 99 1.8T Passat Variant, Audi B5 A4 Avant tqm
    04-25-2012 12:10 AM #318
    Quote Originally Posted by wakarimasen View Post
    They are one-time use bolts anyway. Dealer. Cheap enough.
    I had to cut one to get the beam out. If you remove the bracket, you can disturb the rear wheel alignment.
  4. Junior Member
    Mar 16th, 2012
    Seacoast, NH
    1999 Golf 2.0 MKIV
    05-21-2012 10:25 AM #319
    Thanks for the write up! I did it with the axle on the car, just removed axle bolts and raised the car on jacks. Drilled a couple of holes in rubber - put screw driver in center of bushing and hammered out. Sawzall a couple of slits, but did not cut all the way to axle - hammered and chisled out the metal. My golf has 106k and the bushings were beat! I went with energy polys (yes I read all the negative responses, but i don't plan on keeping this car forever). They slide right in! Worse-case I will put OEM's on if I don't like the poly's. Car handels fine, but most importantly.... No more clunk noises in the rear end!!!!!!!!!!!!!!!!
    Nov 7th, 2008
    Stamford, CT
    2001 (AWD engine) GTI :: 2011 Shadow Blue GTI
    06-09-2012 08:30 PM #320
    I'm about to tackle this project and went ahead and returned the cheap bushings made in china from and bought the oem ones from the dealer for 32 a piece at 1stvwparts or w/e, monday I find out shipping, also got swaybar bushings while I was at it, ~160k bushings are starting to go so might as well do em all.
    Anyways....the dealer happened to have 2 of these laying around and 2 bolts nuts also. The BOLTS/NUTS were 6.50 a piece or some crap.....but w/e. I've had experience breaking off bolts when working on my car from all the rust so I ALWAYS buy the bolts for the job now, better to be safe than sorry, esp over a weekend when they are closed.
    I think I'm going to make that 2x4 tool and hope it fits under there. If I do drop the axle I want to sandblast it and use that (primer/paint 2-in-one stuff from rustoleum to save some time). If I dont have to drop it would spraying that paint on it with it still on be a bad idea? I dont care about overspray really.....black looks better than rust. Dust shield should protect the new brakes I just put on.
  6. Member
    Nov 7th, 2008
    Stamford, CT
    06-09-2012 09:26 PM #321
    does someone want to take a picture or explain to me how to use the "washer system" please. It seems it would take up a LOT less room to use while the axle is still on the car than the 2x4 method.
    v/r
    Nov 7th, 2008
    Stamford, CT
    06-09-2012 09:28 PM #322
    Quote Originally Posted by 10sec-rabbit View Post
    i did this job today took me about 2.5 hours
    on jack stands i took out the axle took a 1/2 hours
    cut the rear bushing out with a sawzall, was very easy 15 min
    I designing a tool based on that wheeling bearing installer i have.
    i went to home depot got a 12inch 3/8 piece of all thread 4 nuts a 2inch end cap for threaded pipe and a flange for something not sure what it was
    i drilled a hole in the end of the pipe cap for the all thread and used it for a receiver and used the flange on the flange side of the bushing. i had the plastic casing bushing too...i also used a hose clamp to keep the thing nice and round. once i had it all set up it took me about 10 min a side to actually get the new bushing in, ill try and get a pic of this rig i used soon . but it worked great!!
    no more clunking or banging made a big diffrence
    with the right tools this an easy job bledding the brakes took longer
    this is what im looking to understand please v/r
    Nov 7th, 2008
    Stamford, CT
    06-17-2012 05:38 PM #323
    or can someone pm me please or post the specs for both of these, tools.
    3301
    3416
    once i have the specs i can make it on CAD for fun
  9. Junior Member
    Mar 11th, 2004
    NJ
    2000 GTI 1.8t
    08-09-2012 05:38 PM #324
    Dude.. if I ever see you in person i'd give you a kiss on the lips. Thank you for confirming this. i too have the hydrolic bonded and i was about to put a nail in the wall.. paint a red circle and run into it when i found out I'm supposed to replace the entire beam. If i come up with alternative steps, I'll post pictures and write up.
    I'm in the middle of doing this too.
  10. Junior Member
    Mar 25th, 2012
    Palisades Park, NJ
    2001 VR6 GLX, 91 Jetta GL, 01 Jetta Wolfs 1.8t, 05 Audi A4
    08-19-2012 03:01 PM #325
    I just replaced the rear bonded rubber axle bushings, MK4. Definitely not recommended for the weak and/or feeble minded DIY'er. It's a simple process, take the old out an put in the new ones, but a few steps require some elbow grease. Some tips to help you along:
    1) Freezing the new bushing the night before will not make installation a whole lot easier. Liquid nitrogen not recommended either.
    2) Taking out the axle will make life easier for you, and it's not that much more additional work.
    3) Don't even bother pressing the old, rusted, and grimy bushings out. After years of weathering and pressure these bushings are basically rusted to the trailing arm. Cut out the sleeve with a saw and/or chisel. Careful not to cut into axle.
    It took me a solid five hours from start to finish. In addition to installing the bushings, I also replaced the brake lines, and the caliper seals.
  11. Junior Member
    Jan 2nd, 2011
    South Texas
    '88 951, '02 Town&Country minivan, '95 pickup, '00 1.8 New Beetle, Son's '02 Jetta VR6
    09-23-2012 10:00 AM #326
    I'm installing the bushing today. Is anybody intimately familiar with the various rear suspension bushing configurations and how they are supposed to be oriented in the axle. I have the latest VW bushings for the sport suspension ('02 Jetta VR6). Does the thick part of the outer lip go down, along with the alignment tabs, both sides?
    The Bentley illustration leave a little too much to the imagination.
    Thanks.
  12. Junior Member
    Jan 2nd, 2011
    South Texas
    09-23-2012 10:23 AM #327
    Adding to the confusion factor was that the original bushings (02 VR6 Jetta) were installed with the tab down on one side and the tab up on the other side, still resulting in symmettrical installation right and left side (gap in original bushing facing same direction both sides).
  13. Junior Member
    Jan 2nd, 2011
    South Texas
    09-23-2012 10:14 PM #328
    Installed bushings with tab down - in line with location shown in Bentley illustrations, both sides. Thick portion if rubber lip is mostly down, oriented same on both sides.
    Used pusher based on 3" muffler pipe. Pipe slipped perfectly over the rubber lip to contact the narrow plastic hat/ridge. Also used hose clamp to help keep pipe on the hat/ridge. On the receiving end used two wood blocks, one with 3/4 hole to clear bushing. Passed allthread through middle of pusher. First bushing went ok. 2nd one did not want to stay lined up Guess I got overconfident after first one went easy. Slowed down and took my time and second then went ok.
  14. Junior Member
    Jan 2nd, 2011
    South Texas
    09-24-2012 07:09 PM #329
    Car is rolling again. No alignment yet but it's clear the axle beam was the major alignment problem cause. Now I know it was bent. Steering wheel is almost straight again while rolling straight. The visual rear toe out on the left and and unequal neg camber is corrected. And the car drives right - squirreliness is gone. Front wheel is still a little off, probably due to front end alignment. Will have alignment checked soon.
  15. Junior Member
    May 15th, 2012
    NY
    2003 GTI VR6 stock
    01-10-2013 12:30 AM #330
    2 questions:
    1) What is a tell tale sign that you need new rear axle bushings? Noise or movement? My car makes a hollow clunk over bumps most noticeable at slower speeds. I've inspected the bushing with a pry bar and there is some movement, maybe 3/8-1/2 inch. Can't remember if it was up and down or lateral.
    2) Were there two different bushing styles for MKIV's. I'm not sure..... From what I gathered here below is the newer style. Correct me if I'm wrong. The older style is the pic below that? My '03 has the ones in the top pic. Would those be original?
    Thanks, hoping to figure out IF I need to replace my bushings.
    If so, I'll definitely be using my ball joint press. Used that tool to install my LCA bushings and axle bushing on my F350. I rented it from Advanced Auto for $100 and haven't returned it and prob won't. Very handy tool!
  16. Junior Member
    Jul 17th, 2012
    Sudbury, Ontario
    MK4 Jetta GLI VR6
    01-14-2013 09:44 PM #331
    I'll be starting this job on my 2003 GLI VR6 tomorrow..
    Hope everything goes smooth..
  17. Member KG18t's Avatar
    Aug 9th, 2006
    Teh RVA
    1986 Mercedes 300E (grey market with a clutch) // 02 VW GTI Matchstick // 12 Golf TDI - DD
    01-14-2013 10:13 PM #332
    Quote Originally Posted by '03VR6 View Post
    Real nice.
    VW Vortex, the perfect place to get your daily dose of
  18. Junior Member
    May 15th, 2012
    NY
    2003 GTI VR6 stock
    01-21-2013 08:58 PM #333
    Quote Originally Posted by KG18t View Post
    Real nice.
    The way their tool rental works is you buy the tool, use it, and get your money back when you return it. You don't have to return the tool if you want to keep it. That's why the rental price is the FULL price of the tool. And since it's such a handy tool I'm keeping it.
    Back to the topic.
    ....Peterbuilt, How did you determine your car needs new bushings? Did you get in there with a pry bar or something? I'm still wondering if mine are bad. It drives pretty well but the hollow clunk drive me nuts sometimes.
    24V VR6, 88,000 miles, 2nd owner, BFI stage 1, K&N, Continental DW, Bilstein TC, Audi TT LCA bushings, Long beach
    Futures Upgrade: Exhaust, tune,???
  19. Semi-n00b
    Dec 10th, 2012
    03 GLI
    04-05-2013 01:44 AM #334
    Sorry to bump this thread, but I thought I'd share my method of changing the axle bushings.
    Here's how I did it:
    I used a strut spring compressor set(rented from Autozone). Lay down the axle on its side, positioned the spring compressors on both sides, stood the axle back up, and tightened each side a little bit at a time with a long-handled 1/2" ratchet - not with the impact gun in the picture. Once the spring compressors started rubbing on the inner diameter of the bushing, I took them out and used the orange dead blow hammer you see in the picture to drive the bushing all the way in. Was easy as cake. I didn't even need to freeze the bushings.
    Hope this can help someone struggling with getting these buggers in.
  20. Member volks25's Avatar
    Dec 14th, 2001
    Ottawa, Ontario
    04-05-2013 06:08 PM #335
    Brilliant !
  21. Member
    Jul 28th, 2002
    2002 Jetta GLS 1.8T, 2001 Porsche Boxster S, 2011 Audi Q7TDI, 2000 Honda VFR,
    05-07-2013 01:28 PM #336
    My car has 245,000km on it, and a Neuspeed RSB.
    Been working on this since Saturday on and off for the past few days. Finally got over the hump.
    The passenger side one is installed. I was able to do this side without removing the brake line, just undo the clips, and straighten out the solid brake line that goes down the trailing arm to give a little more wiggle room, and you can hopefully wedge the axle down enough to get at it. I initially was going to take the brake hose off, but when I was turning the flare nut, the solid line was turning with it, causing a kink. I have a new RR brakehose to put on when I get the bushings installed.
    I am going to attempt the driverside tonight, hopefully there is enough room to do it with the axle in.
    Be careful when cutting the relief slit in the bushing sleeve. I was a little overzealous with the sawsall, and cut into the axle a wee bit.
    I'm working on a midrise lift, (Maxjax) which definitely helps. If this is your only mode of transportation to work/school etc. definitely think about paying someone to do this. I make a puller from some all thread rod, coupler, washers and plywood. I'll post a pic of it. I've put about 4-5hrs into it over the past 3 days, trying to figure stuff out. I like working on cars, so that's why I do it. If it was something that I had a deadline to get done, than it would be a nightmare on your own.
    Peter
