VWVortex.com - High beam+Low beam light relay/wiring question...
    Results 1 to 9 of 9
    Thread: High beam+Low beam light relay/wiring question...
    1. Banned
      Jan 7th, 2003
      05-16-2005 07:44 PM #1
      I searched,maybe i couldnt find the correct terms....
      How do i wire up my high beams and low beams to come on together...
      I am running a regular na light switch,and im using the plug and play wiring kit for the hella duals...
      Modified by HK1980 at 4:51 PM 5-16-2005
    2. Banned
      Jan 7th, 2003
      05-17-2005 12:15 AM #2
    3. 05-17-2005 12:17 AM #3
      this help out? you can make some lumpers from some heavy wire and plug them in the spots shown if you have no "jumpers"
    4. Banned
      Jan 7th, 2003
      05-17-2005 01:53 AM #4
      Quote, originally posted by LostSheepSquadron »
      so...after i put the "lumpers" in ...when i hit the high beams,all the lights will stay on...?thats all there is to it? no other relays or anything?
      thanks a bunch
    5. 05-17-2005 02:03 AM #5
      stinkin' noob
    6. Banned
      Jan 7th, 2003
      05-17-2005 02:05 AM #6
      rofllll
    7. Member LG6R's Avatar
      Oct 20th, 2003
      A working MB and a broken VW
      05-17-2005 03:35 AM #7
      Quote, originally posted by HK1980 »
      thanks a bunch
      Pretty much [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Dec 29th, 2001
      Northern California
      1998 Jetta VR6, 2010 Audi S-line Avant
      05-17-2005 03:37 AM #8
      Quote, originally posted by EUEL »
      stinkin' noob
      i can vouch for that
    9. 05-17-2005 05:15 AM #9
      You only need the C shaped jumper shown in that pic, the 7 shaped jumper is to run your fogs with highs, or fogs with parking lights if you have a euro switch. It goes in relay slot number 10.
