Hello Everyone:I had some very productive discussions with the German Phaeton owners this past weekend. Many of them are just as keen on making small tweaks and modifications as we are. What is funny is that in some cases, they want to do the opposite to what we want to do. For example, Phaetons sold within Germany do not make any kind of beep when the doors are locked with the remote control, or in the case of keyless access, by pressing the button on the door handle. Some German owners wanted to turn the beep on, whereas most North American owners want to turn the (enabled by default) beep OFF.
Now, here is the really, really funny part - which makes me appreciate how unique human beings are, how different we all are: Phaetons sold in Germany are delivered with the capability to raise and lower the windows (and open and close the sunroof) via the remote key fob turned ON. Phaetons sold in North America are delivered with this capability turned OFF. After I showed one owner how to enable the beep when the car is locked, he told me he would show me an equally good trick - how to turn OFF that 'undesirable' window up and down control via the remote control. He considered it undesirable because if the key fob button was held down too long while it was raining out, all the windows (and sunroof) would open, and the car would get wet.
Well - I don't have to tell you that we have been searching for the answer to this question like it was the Holy Grail - and our fellow German owners know the answer. Here is how to do it.
1) Determine the part number and suffix of the J393 Central Control for Comfort System controller installed in your Phaeton. This is the controller at address 46. In order to do this, you need a diagnostic scan tool such as a VAG-COM or a VAS 5051 or 5052. There is some discussion of these diagnostic scan tools at these threads, if you are not already familiar with them:
VAS 5051 Diagnostic and Programming Tool
VAG-COM Diagnostic Scan Tool and the Phaeton - reference information
Additional Information about the VAG-COM diagnostic scan tool
The controller in your Phaeton will most likely be one of three different versions:
- If you have a W12 Phaeton
Address 46: Central Conv.
Controller: 3D0 959 933 E
Component: 6P HSG 3212
By example, the W12 controller shown above is from my Phaeton.
- If you have an early production V8 Phaeton
Component: 4D HSG 3212
By example, the V8 controller with part number suffix E and software 3212 shown above is from my dealer's demonstrator.
- If you have an later production V8 Phaeton
Controller: 3D0 959 933 F
Component: HSG 0101
Forum members Fly4Food (Philippe) and Uberanalyst (Dave) have the later production controllers in their Phaetons, as you can see by looking at the VAG-COM Controller Lists from Phaetons - for comparing coding, controller part numbers, software revisions, etc. post, where Philippe and Dave contributed their scans to our growing body of reference material. By the way, if you are not sure what the different suffixes of part numbers mean, or the differences in software codes shown above, have a look at this post, it will explain the nuances of understanding controller versions: How to determine controller software version levels using a diagnostic scan tool.
2) If your controller is the later production version - meaning, it has the part number suffix F and software version 0100 (very rare) or 0101 (more common, this is what is currently being used in Phaetons built today) - well, jump for joy, because enabling remote control of your windows and sunroof with your key fob is easier than turning off a seatbelt chime. If you have a W12, or a V8 with the earlier version part suffix E and software version 3212 - hang in there, we haven't quite figured that one out yet, but we think we are close.
3) If you have the later version controller (PN with the F suffix), simply open up controller 46 with your diagnostic scan tool, go to adaptation channel 25 - no security code is required - and change the value from 0 (meaning, remote control of windows from key fob NOT enabled) to 1 (meaning, remote control IS enabled. If you are using a VAG-COM, press the test button, then the save button, then close the controller, disconnect the VAG-COM, close the car doors, and try out your new trick.
4) To unlock the car, and make all the windows open, and the sunroof open, just press the unlock button on the key fob and hold it pressed in for longer than about 3 seconds. To lock the car and make all the windows and the sunroof close, press the lock button on the key fob, and hold it pressed for longer than about 3 seconds.
I can't recall if the windows "express up" - meaning, once they start to move, you can let go of the button - or if you have to hold the button on the key fob depressed until the glass has reached the fully open or fully closed position. I am pretty sure that the windows "express down", which is why the German owners wanted to turn this feature off - the car will get flooded if you hold the unlock button too long when it is raining out.
If you discover that your windows will "express up", and you have small children, then you will need to have a talk to them about not playing with the key fob, otherwise, the results will be like this rather funny Ford commercial: click here.
Regards,
Michael
PS: I note that there are some slight differences in the prefix of the component number - some controllers are just 'HSG 0101', others have a number in front of HSG, such as '1A HSG...' or '12 HSG...' I don't think this prefix number will make a difference, but the only (German) cars I saw that had the feature enabled had these prefixes: three cars - no prefix at all, another car, the prefix was 29.
Philippe, Dave - give it a try, let me know if it works. Michael
Modified by PanEuropean at 10:02 PM 6-18-2005
