VWVortex.com - Automatic Jetta's Stuck in Park...Please Help!
    Results 1 to 13 of 13
    Thread: Automatic Jetta's Stuck in Park...Please Help!
    1. 05-31-2005 10:37 AM #1
      My girlfriend's 2001 Automatic Jetta GLS got stuck in park this morning at the gas station and wont shift into gear. This has happened before but always cured itself with a little time and patience, but today she was stranded indefinetely. Does anyone know what a possible cause and fix could be? It will be taken to a mechanic shortly, but I would like to have a little knowledge under my belt before I talk to the mechanic.
      Also, the EPC light on the dash just came on the night before this all happened...related in any way? I read some other posts somewhere about a faulty brake switch, coudl this be the problem? Where is this located and is it an easy fix? Thanks.
    2. 05-31-2005 10:41 AM #2
      did you push the brake in?
    3. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      VWs & Audis
      05-31-2005 10:43 AM #3
      check and make sure the brake lights work, if not, the switch is bad and will prevent the tranny from shifting into gear.
      Dave
    4. 05-31-2005 10:43 AM #4
      Pushed everything in your could possibly push in.
      Pumped brakes, start/restart car, etc.
      She is having trouble with it as we speak, but now finally got it into Nuetral, but still cannot shift into drive.
      Tow truck is on the way.
      Any help is appreciated. Thanks.
    5. 05-31-2005 10:51 AM #5
      Brake lights dont work...
      Is replacing a brake light switch expensive, anyone know? Thanks.
    6. 05-31-2005 10:54 AM #6
      Quote, originally posted by NeedsHelp »
      Costs less than a tow truck
    7. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      VWs & Audis
      05-31-2005 10:57 AM #7
      No, but considering there is a recall it can be free if you do it right.
      Dave
    8. 05-31-2005 11:01 AM #8
      my Wifes jetta does the same thing, the switch has been replaced 3 times. and it is still an intermittent problem
    9. 05-31-2005 11:03 AM #9
      Can any dealership/mechanic do the repairs under recall, or only Jetta dealers/certified or whatever do the recall.
      Thanks.
    10. 05-31-2005 11:06 AM #10
      any VW dealership can do the recall repair
    11. 05-31-2005 11:27 AM #11
      After finding the recall online (http://www.internetautoguide.com/auto-recalls/67-int/2001/volkswagen/jetta/gls/index.html) and calling the number listed, the lady from Volkswagen tells us that there is no recall out for that part. (brake light switch)
      Bull****!
    12. 05-31-2005 11:49 AM #12
      Bull****!
      my wife took her car in had the switch replaced under warranty then a few days later recieved the recall notice
      her car is also a 2001 GLS 2.0L automatic
    13. 05-31-2005 11:53 AM #13
      Part is $10 and 20mins to change yourself... good DIY on here by VgRt6.... search is your friend... learn it, live it, love it
