VWVortex.com - my oil smells like gas
    Results 1 to 17 of 17
    Thread: my oil smells like gas
    1. Member twisted turbo's Avatar
      Mar 12th, 2005
      maine
      2010 Gti
      06-03-2005 06:59 PM #1
      my oil smells like gas what does this mea should i be worried?
      06 gli apr stage 2, billy boat custom turboback, neuspeed intake.
    2. 06-03-2005 07:15 PM #2
      My cat's breath smells like catfood.
      Oh yeah...bump [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 06-03-2005 07:21 PM #3
      Quote, originally posted by twisted turbo »
      this is typical...it will be worse however if you skimp out on changes
      nothin to worry about tho
      2002 337 1.8VBT
      2000 Jetta 1.8T stockish
      2011 Jetta TDI 55MPG
    4. 06-03-2005 07:30 PM #4
      I guess is normal too, how black is it?
    5. Member twisted turbo's Avatar
      Mar 12th, 2005
      maine
      2010 Gti
      06-03-2005 08:15 PM #5
      its ne woil about 1000 miles on it
      i just wasnt sure it it was normal or not
      thanx for the info
    6. Member
      Oct 15th, 2004
      Western N.C.
      03 Jetta 1.8t, 86 Ranger, 02 Rodeo
      06-03-2005 08:29 PM #6
      Lots of variables there. Like when you checked it. How long are your drives. If and how you are modded. You'll almost always smell a little fuel on the oil dipstick. Just as long as it doesn't wreak of fuel.
      Check this out. Run your finger along the rear bumper or hatch and see if it is sooty. Or pull a plug. Or go to someone with scan tools and check adaptation trends.
    7. 06-03-2005 08:31 PM #7
      This is not normal, if it is enough that it is a strong smell, i would start with a compression/leakdown test...
    8. 06-03-2005 08:33 PM #8
      Mine has smelled like gas since day one.
      Jun 3rd, 2003
      SF Bay Area
      2015 Subaru WRX
      06-03-2005 09:49 PM #9
      just get it analysed by Blackstone laboratories and be done with it.
      2015 Subaru Fortester XT
      2015 Subaru WRX Limited
      190+ Video GTI Modding/DIY Library /
    10. Member twisted turbo's Avatar
      Mar 12th, 2005
      maine
      2010 Gti
      06-03-2005 10:17 PM #10
      i didnt check the dip stick i took the oil cap off (where ya fill the oil) and it was strong enough to say holy **** it smells like gas
      i just changed my plugs and they were white
    11. 06-03-2005 10:29 PM #11
      white? I'd say you've got some problems....leeeaaaaan problems!
      Oct 15th, 2004
      Western N.C.
      06-03-2005 10:30 PM #12
      Well,
      It's important not to smell of the oil right after start-up, like after changing your plugs. The oil will have all kinds of volatiles in it that may smell of fuel. Drive the car for say a half hour or so then stop and smell. See if it is as strong.
      Like I said before, if it is really a strong fuel smell- like smelling your gas tank filler, then Benard is right something is wrong.
      You say you changed your plugs. Why? Were they fouled or worn out? Were you getting a lot of mis-fires? This would cause oil dilution and a fuel smell would be expected at the oil filler.
    13. Member twisted turbo's Avatar
      Mar 12th, 2005
      maine
      2010 Gti
      06-04-2005 09:05 AM #13
      i changed the plugs cuz i ws gettign a mis fire on cyl 1 -2 and it was the first thing i could think of to fix the mis fire
    14. Member
      Oct 15th, 2004
      Western N.C.
      06-04-2005 09:54 AM #14
      ah ha,
      Two cylinders with lots of mis-fires. That means two cylinders filling with fuel on some cycles, not firing and washing down the rings and filling the sump with fuel.
      First make sure you've fixed the mis-fire problem with just the plugs. We all know the coil problems we have. If they are fixed, then immediately change your oil. Do not drive you car if you are still having mis-fires. Because heavy oil dilution will FUBAR your engine.
      If still mis-firing of course the coils and possibly the wiring (didn't look to see how old your 1.8T was) would be a good place to start.
      Good luck.
    15. Member forcefedjetta's Avatar
      Aug 14th, 2003
      metrowest
      02 jetta 1.8t
      06-04-2005 12:44 PM #15
      Quote, originally posted by RIVWMKIV »
      my dogs breath smells like cat
      i wish my grass was emo so it would cut it's self
    16. Banned
      Jun 24th, 2004
      06-04-2005 03:30 PM #16
      get rid of the misfire and change the oil.
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] to slickfisha
      yes, gasoline is not a good lubricant...
    17. 06-04-2005 09:05 PM #17
      at least is doesnt smell like coolant...
