Page 1 of 2 1 2 LastLast
Results 1 to 35 of 69
Thread: DIY tail light removal
  1. Member Z000M's Avatar
    Jun 13th, 2004
    College Station, TX
    02 Jetta Hatchback
    06-07-2005 11:45 PM #1
    I recently changed my tails. Although I found the DIY in the DIY section of this forum helpful, I think it could be better. It was lacking one thing. Pictures. I am a very visual learner. I am willing to bet other people out there are that way too. So here it is, my new and improved DIY to tail light removal.
    The Original:
    I got tired of the amber turn signals. I thought the tails with smoked turns would better suit the overall theme of my car. So i changed them. Here is how I did it.
    The tools you will need (or atleast i used):
    1. 3/8 inch drive extender
    2. 3/8 inch ratchet
    3. 10mm screwdriver bit
    4. 10mm 12 pt socket
    5. 8mm 12pt socket
    6. 10mm wrench
    7. 1/4 inch ratchet
    8. 1/4 inch drive extender
    9. screwdriver thing
    10. toothpaste
    I am going to assume that everyone knows how to undo the carpet in order to expose the backs of the tail lights. If you don’t, it is really easy. Looks in the hatch, and you will figure it out. Once you have removed the carpet flaps, you can start to work.
    The passenger side:
    There are 3 bolts holding the tail light to the car. Two of the bolts are visible (circled in green) and the third bolt is hidden behind the flap of carpet. All the bolts are 8mm. I had to use an extender to get to the bolts. Once the bolts are loosened, I recommend removing them by hand. This way you don’t run the risk of dropping them down into the body of the car. If you do drop a nut, it is ok, just reach down and grab it.
    Once all the nuts are removed, you pull the tail light off the car. When facing the hatch, you are going to pull the tail to the right (away from the wheel) straight out. This is to avoid breaking the rivet at the end of the tail. You may have to pull rather hard.
    The tail light removed:
    Peel off the black foam-rubber thing. Don’t discard it. You will need it for your new taillights.
    The driver’s side:
    The driver’s side is a little more complicated. Make sure to remove the tail light bulbs. Unbolt the two bolts (in pink) that connect the taillight to the car. These are two of the three bolts that hold the tail light in place. These two bolts are 8mm. Be careful not to drop them down inside of the car. Once this is done, you will have to do a little work to remove the third bolt.
    The first thing that you need to do is to remove the CD changer holder. Remove the 5 bolts (circled in yellow). They are all 10mm. I used a wrench to remove bolt number 5 because it was a tight fit with the ratchet and extender. Once you have removed the CD holder, peel back the carpet. Be careful to not rip the carpet. It is help into place by a plastic rivet. Remove that and peel the carpet to expose the body of the car. Once this is done, you will see some wires and a square cut out in the body of the car.
    This is where the third bolt is located. Everyone stresses that you do not want to drop the bolt down inside of the car. This is true, you don’t. If you do, it is OK just reach down in there and get it. It does make things a little harder if you do drop it though. To prevent from dropping it, many people suggest the “sticky nut” idea. This involves using some gum to stick the nut to the end of your socket. I didn’t have any gum, so I used some toothpaste. It worked very well. Use tools number 9 and 3, along with some toothpaste, and fish around inside of that hole until you can loosen the bolt. Remove the taillight just as you did on the passenger side. To avoid dropping the nut, I just left my screwdriver in the hole. I didn’t want to risk pulling it out and dropping the nut. Once the new taillight was in place I just fished around until I lined the two up once more. It was easy. Once you have the new taillight bolted in, just put everything back together the same way you took it apart. There should be nothing left over. Don’t forget to put the black foam-rubber thing on your new tails if you need it. It is a pain to remove it all again. If you have any questions or problems with this DIY, feel free to pm me. Total work time is about an hour, assuming nothing goes wrong.
    The finished product:
    ~z000m
    Modified by Z000M at 11:49 PM 6-7-2005
    Modified by Z000M at 12:08 AM 5-22-2006
    Aggies for 40k ||| Flickr ||| VWs of Tennessee
  2. Member VDUBRACER187's Avatar
    Jun 16th, 2004
    New York
    11' WRX
    06-07-2005 11:49 PM #2
    nice DIY
  3. Senior Member abydielsgli's Avatar
    May 7th, 2003
    san diego
    06-07-2005 11:51 PM #3
    i love DIY's
  4. 06-07-2005 11:52 PM #4
    Actually the easier method is not to remove the cd changer or anythiogn like that. Just take off the bracket that is meant to hold the fire extiinguisher in eyro cars and then use a socket set that has aflexible wire like shaft found in hardware stores, easy as pie , you just bend the tube like socket around the cd changer wire and set in your socket with gum on it and bam your hardest socket is done. leave it there and remove your taillight. PLace in new one and reattach the hard to reach nut and then the corner nuts and you can do them all in less then half an hour including cleaning.
  5. Member Z000M's Avatar
    Jun 13th, 2004
    College Station, TX
    02 Jetta Hatchback
    06-07-2005 11:54 PM #5
    i didn't know they had bendy sockets... i will have to check that out...
  6. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    06-08-2005 08:25 AM #6
    Images mirrored. (CLick on links)
    Quote, originally posted by Z000M »
    The Original:
    http://is.rely.net/2-1060-8513...g.jpg
    2. 3/8 inch ratchet
    5. 8mm 12pt socket
    6. 10mm wrench
    7. 1/4 inch ratchet
    10. toothpaste
    The passenger side:
    http://is.rely.net/2-1060-8510...g.jpg
    http://is.rely.net/2-1060-8511...A.jpg
    The driver’s side:
    http://is.rely.net/2-1060-8507...A.jpg
    http://is.rely.net/2-1060-8508...w.jpg
    http://is.rely.net/2-1060-8512...g.jpg
    ~z000m
    Dave
  7. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    Formerly London Dub B5.5 Passat V6 4mo Wagon, MK6 GTI 6MT
    06-08-2005 08:36 AM #7
    Nice work - would have been great when I did my tails. One thing about that pesky hidden nut for the drivers side - what I did, was simply have my friend undo it for me, but once it was off the bolt, he just held the socket there - pushed against the hole. I took off the old light, then put on the new one and he tightened the nut again - no need to even worry about threading the nut over again.
    Buy my clear GTI sidemarkers cheap!
    Will VagCom Mk5 and 6 in the GTA for donuts!
  8. 06-08-2005 09:12 AM #8
  9. Member Mad Chef's Avatar
    Oct 30th, 2004
    orlando, fl
    2001 gti vr6
    06-08-2005 09:30 AM #9
    man i desperately needed this like 2 weeks ago when it took me 2 days to figure out how to install my Hella R/S/S/R tails
  10. 06-08-2005 09:39 AM #10
    nice DIY
  11. Member
    Feb 19th, 2005
    Norco
    2011 CC, 2007 XB12, 2004 R32 (Gone), 2000 BT TT(Gone), 2002 GTI (Gone)
    06-08-2005 09:55 AM #11
    nice DIY zooooooooom, i fel that the tails were really holding you back when i saw your car at eurofest
  12. 07-22-2005 01:31 PM #12
    Thank you Z000M, i will be putting this tutorial of yours into practise.
    Cheers
    Zeno
  13. 07-22-2005 02:23 PM #13
    I changed my tails on my CL and I've never removed the CD changer....?
  14. 11-28-2005 04:24 PM #14
    Hey i need help 02 mk4 gti 1.8t
    Passager side tail got 3 bolts off 8mm their is a forth that is black and i dont know how to remove it or what it is someone help me.[URL=http://is.rely.net/2-1953-12512-l-jXX8k7QNl4GrWuSCcmS4A.jpg][IMG][URL=http://is.rely.net/2-1953-12513-l-DrAmRy9equ4UXZqNZNaLIg.jpg][IMG]
  15. Member
    Mar 21st, 2005
    PoMo
    '12 Golf TDI
    12-02-2005 08:29 PM #15
    is there a way to pop out the amber and/or smoke the amber part???
    or change the amber and paint it somehow?
    Sunshine and farts.
  16. Member SanDiegoR1Rider's Avatar
    Apr 5th, 2005
    San Diego
    12-02-2005 09:03 PM #16
    Wow, this is much harder than what I had to do on my Jetta.
    Here it is:
    8 mm socket, 8 mm ratchetting wrench.
    Open trunk
    Open velco flap over lights
    Remove the 3 8mm nuts
    Unplug lights
    Pull lights out.
    That is it.
  17. Banned paranoia's Avatar
    Apr 1st, 2004
    12-02-2005 09:14 PM #17
    finally, a DIY! i was about to tape up my back end with newspaper.
  18. Member dragon813gt's Avatar
    Feb 18th, 2003
    Ruining VWs one car at a time
    '04 GTI that has rolled maybe 60' since September of '06
    12-02-2005 09:14 PM #18
    Quote, originally posted by oldschool86045 »
    You can't pop it out as it's all one piece. GTIs come stock w/ it smoked lightly. Then you have the OEM Euro Tails(light smoke) and Hella Tails(heavy smoke) that have the 2 center sections blacked out. There's also the OEM '03 Euro special edition tails that have the amber section as a white/clear color.
  19. Member antarchitect's Avatar
    Jan 17th, 2005
    '08 Rabbit / '03 Passat Wagon
    12-02-2005 09:30 PM #19
    toothpaste? who would've thought
  20. Senior Member abydielsgli's Avatar
    May 7th, 2003
    san diego
    12-02-2005 09:30 PM #20
  21. Member sleepbelowstars's Avatar
    Sep 16th, 2004
    Chicagoland, IL
    2010 Mini Cooper, 1967 Beetle
    12-02-2005 09:36 PM #21
    Quote, originally posted by antarchitect »
    Yeah, I wish I knew that. On one of my many tail changes (3) I managed to drop a bolt from each side and never find them. ooops.
  22. 12-09-2005 12:50 AM #22
    great guide thanks
    FOR SALE
    BBS RK 18" wheels 5x114 bolt pattern 600$ + shipping obo
  23. 12-09-2005 12:56 AM #23
    nice write up..I remember doing this taillight removal is such a pain in the arse...
  24. Member
    May 3rd, 2005
    801 UT
    1960 FL
    12-09-2005 12:57 AM #24
  25. Member
    Apr 4th, 2005
    NYC
    M-Coupe
    12-09-2005 01:04 AM #25
    Quote, originally posted by abydielsgli »
    i love DIY's
    unaffiliated
  26. Banned LETTERMAN52's Avatar
    Jul 28th, 2003
    12-09-2005 01:05 AM #26
    Finally.... A decent write-up on this...
  27. Member lagunaroone's Avatar
    Jun 15th, 2003
    Vienna, Austria
    VW, Skoda, Derbi
    12-10-2005 05:46 PM #27
    Great DIY, helped me a lot, thx.
  28. Member Z000M's Avatar
    Jun 13th, 2004
    College Station, TX
    02 Jetta Hatchback
    12-10-2005 06:19 PM #28
    thanks guys...
  29. Banned LETTERMAN52's Avatar
    Jul 28th, 2003
    12-15-2005 03:03 AM #29
  30. 03-12-2006 09:19 PM #30
    I'd like to add 1 thing to this DIY....disconnect the battery. I didn't do this and blew a fuse. As well as the screws, there is a butt plug at the bottom corner of the light you might have forgot to mention (I skimmed over the article and posts). Over all the process is easy, but I seemed to mess mine up when I couldn't get the backing off easily with the lights in so I removed the bulbs. If you remove your bulbs, make sure you place them back in the correct place or you will melt the new lights like I did
  31. 04-25-2006 07:25 PM #31
    Can we get the pictures reposted?
  32. 04-25-2006 07:26 PM #32
    yes please.. id love some photos and less x.
  33. 04-25-2006 08:04 PM #33
    Quote, originally posted by divided »
    x2 i been wanting to get my tails changed but then never got the time to do it but if u post the pics up then i could do it tonight if it looks easy
  34. 04-25-2006 08:07 PM #34
    Awesome DIY, I was looking for a tail lamp removal guide yesterday. Thank ya
  35. 04-28-2006 09:45 AM #35
    Desperately seeking pictures on this install as I'm getting my new tail lights next week...unless someone in the Toronto area wants to give me a hand doing this install?
    PJStyles
