VWVortex.com - how to locate ECU unit in 97 vw jetta?
    Results 1 to 3 of 3
    Thread: how to locate ECU unit in 97 vw jetta?
    1. 06-08-2005 07:52 AM #1
      can anyone please just drop a few lines telling me where to find the ecu and what tools are likely to be needed. much appreciated 97 jetta gl 2.0
    2. 06-08-2005 07:59 AM #2
      The ECM is mounted in the right-hand side of the air plenum - you'll have to remove the plastic cover directly in front of the windscreen.
      Wait at least one minute after turning the ignition off to disconnect the battery and unplug the wiring harness. It's held in with a simple bracket, a wrench should be all you need to get it out.
    3. Member Shawn M.'s Avatar
      Oct 15th, 2002
      Brentwood, MO
      1998 GTi VR6 Ginster, 2004 Forester
      06-08-2005 09:17 AM #3
      umm if your pulling your ecu, disconnect the battery
    « Back
