VWVortex.com - please post pics of mk2 jettas with 9" wide rims.
    Results 1 to 23 of 23
    Thread: please post pics of mk2 jettas with 9" wide rims.
    1. 06-14-2005 09:28 PM #1
      i was interested in seeing some crazy rims on some mk2 jettas, anyone have a jetta with brock b1 also?
    2. 06-15-2005 05:55 AM #2
      I used to have a Coupe VR on B2s 16x9"
    3. Member GLI_DRIVER's Avatar
      Mar 26th, 2002
      WA.
      04 R
      06-15-2005 10:20 AM #3
      9and 3/8ths to be exact
      .:R
      Build your car for yourself, not what an internet forum tells you.
    4. 06-15-2005 10:22 AM #4
      Quote, originally posted by GLI_driver_found »
      you must be measuring from outer lip to outer lip..
      your supposed to measure a rim width on the inside of the lip..
      otherwise my 8.5" wheels would be more like 9" wheels.. and they aren't..
      In fact.. after closer inspection.. I'd say your wheels appear to only be 8" RM's.. maybe 8.5 at the most..
      also.. what size are your tires?.. they would have to be 225's or more to not be stretched on a 9" wheel.. because the tires in that picture are just barely stretched... And if you had 225's on them.. they sure as hell wouldn't fit under mkII flares..
      so I'm going to say they are 8" RM's with a 205 tire on them.
      here's are some closeup pics of my 8.5" RMs..
      see how the first step of the lip is wider that the outer part..
      Modified by thelumpya2 at 2:28 PM 6-15-2005
    5. 06-15-2005 10:38 AM #5
      Quote, originally posted by thelumpya2 »
      Thanks for sharing... i used to do it the wrong way too... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. 06-15-2005 10:53 AM #6
      Apr 9th, 2003
      Kirkland, WA
      20th AE
      06-15-2005 12:03 PM #7
      THANK YOU. definately not 9.5's.
      and here is mine with my friends wheels on it
    8. 06-15-2005 01:06 PM #8
      mmm 9" wide
      May 3rd, 2004
      Toluca, MX / Detroit, MI
      1998 Toyota Camry / 2009 Toyota Corolla base
      06-15-2005 01:53 PM #9
      oooooh.... if i can scrounge hard enough i might have some type A 16x9s [IMG]http://*****************.com/smile/emthup.gif[/IMG] hot hot hot.
    10. Member EvoVEnto's Avatar
      Sep 29th, 2000
      Issqauah
      too many to list
      06-15-2005 02:52 PM #10
      Yummy , WORKS 14x9 with 25mm of set
      CEO - Happenstance Events - PNW Springmeet | The Old School Reunion | Stancewars | OktoBugFest | E36 Treffen | SNKR Head Seattle
      Events I help with - Waterwerks Seattle-Portland-SanFran-Vegas
      Current Cars - 14 Passat | 75 Rabbit |76 Rabbit |06 Audi A8 |13 Tig |66 Beattle | and the Oddy Past cars - 32+ and counting VW's
    11. Member
      Dec 22nd, 2002
      CT
      06-15-2005 02:54 PM #11
      only 16x7.5 n 16x9 but they work for me [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      [IMG]http://www.msnusers.com/_Secure/0ZAAAAHQgQoUeSiLYNeVj888daBwvth4Se1OsGk5tl2El8VQcG QHMob2OonEBSe6LJcN3NFHiqVqFvng9R!UPAy9JtHa0b4xCfnU aPEm5rhR3f1D6HA9HIkngVnfLjr5kwdidL4vK**dw14LeNp22D w/jetta%20pics%20at%20garage.jpg?dc=4675521466237136 065[/IMG]
      1988 Jetta Carat Vr6 powered by www.LugTronic.com (99.9% done!!! )
    12. 06-15-2005 03:07 PM #12
    13. 06-15-2005 03:07 PM #13
      Quote, originally posted by PjS860ct »
      with the Type A's.. I actually think it looks better with 7.5's out front..
      the 9's out front just seem to poke too much..
      but that looks just right.
    14. Member
      Dec 25th, 2003
      N. Phx, Az
      91 20vG60 GTi, 91 VR6T GTi, 12 Golf R
      06-15-2005 03:09 PM #14
      Quote, originally posted by MrPoonerson »
      Dem dirteens mang???
    15. Member GLI_DRIVER's Avatar
      Mar 26th, 2002
      WA.
      04 R
      06-15-2005 08:59 PM #15
      In fact i didnt measure from inside lip to inside lip. I am running 215/45's. So i guess they are 8.5 wide..I see the difference with your lips to mine... Thanks for clarifying.
      .:R
    16. 06-15-2005 09:20 PM #16
      Quote, originally posted by EvoVEnto »
      mmm nice work wheels
    17. 06-15-2005 10:52 PM #17
      Quote, originally posted by snoopydub »
      hey did you have to pull your front fenders to make them flush?
    18. 06-15-2005 10:54 PM #18
      yes, but.. My lips are the 2.5 inch lips, which would make my wheels 8.5.
      your lips appear to be even all the way around, which would indicate that they are in fact 8" wide.
      but I could be wrong, as I've never seen them in person.
    19. Member
      Apr 9th, 2003
      Kirkland, WA
      20th AE
      06-15-2005 10:58 PM #19
      Finally you believe us. I've only been telling you this since you first posted the wheels
    20. Member dubious311's Avatar
      May 1st, 2003
      Lower Dutchess, NY
      90 VRT Jetta Coupe
      06-15-2005 11:05 PM #20
      Quote, originally posted by CatEyeGLi »
      Here you go ask and you shall receive
      I need to lower it a little bit all around and take better pics, Car is in the shop getting a rebuilt VR put into it should have it back before July.
    21. Member GLI_DRIVER's Avatar
      Mar 26th, 2002
      WA.
      04 R
      06-15-2005 11:14 PM #21
      Quote, originally posted by dmoney »
      .:R
    22. 06-15-2005 11:16 PM #22
      soooo many oppurtunitys to whore mine out!!
      "drop it like its hot"
      Main man at Punch Drunk Customs
    23. 06-16-2005 12:14 AM #23
      Quote, originally posted by digifart »
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] Perfect Rims
