VWVortex.com - Hella Twin Supertone Horns Installed
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 47
    Thread: Hella Twin Supertone Horns Installed
    1. Member Phrost's Avatar
      Mar 8th, 2004
      Green Bay, WI
      '11 Audi S4, '77 VW Westfalia
      06-15-2005 10:02 PM #1
      Just got my Hella Twin Supertone Horns from Safe Drives today and installed them (118 dB) They were $60.99 and only took 2 days to ship to my house.
      Here is a better view of what they look like right out of the box
      You can find these horns, as well as others from Safe Drives in this link below:
      http://www.safedrives.com/products.asp?cat=60
      Installation requires removal of the front bumper. Once everything was off, I removed the negative terminal to my battery. The two oem horns are located down in the driver side corner. This is what your oem horns look like
      You only have to remove 2 nuts to get them out, and this is what it looks like after they're off
      Next you'll have to chop off the harnesses and crimp on some female connectors. Other horns may be different!
      The yellow/black wire is positive, and the brown wire is negative. I guess you could mount these however you want... I wasn't sure how they were supposed to sit, so I pointed them down. Here is the bottom one mounted and wired
      Then both mounted and wired
      Then a few more beautiful shots to get a better idea
      Installation was very simple, but I needed to buy the female connectors along with nuts/bolts to mount the horns since Hella doesn't include any hardware. These are 300Hz and 500Hz. They sound pretty euro to me but are a little higher pitched than I thought. I still like em though They are fairly loud, but I really haven't gotten the chance to just lay on the horn and compare to the oem ones. There are 2 sound clips floating around the vortex somewhere, but I don't know where they are and haven't made my own yet.
      Comments/Questions?
    2. Member proshot's Avatar
      Apr 22nd, 2004
      Texas
      MK4 R and MK6 TDI
      06-15-2005 10:07 PM #2
      i've never even thought about getting different horns. are they louder than oem, different tone, etc?
      PSN: CoachBombay_
    3. Member Phrost's Avatar
      Mar 8th, 2004
      Green Bay, WI
      06-15-2005 10:12 PM #3
      They are higher pitched, and louder. My oem horns are all plastic, but everything on these ones I bought is solid metal, and they weigh maybe 2-3 pounds each. Hella quality for sure [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. 06-15-2005 10:48 PM #4
      Bump, because I'm going to install my Hella horns sometime soon !!
      thanks for the writeup.
      -Matt
    5. Banned
      May 6th, 2004
      06-15-2005 10:51 PM #5
      interesting...i've always wanted euro sounding horns. how do these compare to the hella dual trumpet airhorns?
    6. Member Frosty_spl's Avatar
      Aug 4th, 2003
      Laguna Beach CA
      2012 Ducati Streetfighter 848, 2006 Ducati 999s
      06-15-2005 11:10 PM #6
      Awesome.
      They sound like ferrari horns. High pitched and italian sounding.
    7. 06-15-2005 11:13 PM #7
      Yeah, I actually have the hella trumpet horns.
      I don't know how well they're going to mount behind the bumper, but I've heard that they sound very similar to the ones shown in this post.
      I think (not positive) that the trumpets are just a little louder.
    8. 06-15-2005 11:16 PM #8
      One question though, for the original poster:
      In the first Big picture, do you use that cube shaped plug (amp/transistor?)
      and where does it actually go?
      thanks,
      -Matt
    9. Member Phrost's Avatar
      Mar 8th, 2004
      Green Bay, WI
      06-16-2005 03:25 AM #9
      That plug thing is a relay. You don't need to use it if you install the horns the way I did, since your horn already has one. I found that out in a DIY so I just never used the thing and it's working fine so far [IMG]http://*****************.com/smile/emthup.gif[/IMG] I guess the only way you'd use it is if you kept your oem horns but also wanted these horns too... I have no idea actually lol
    10. Member Phrost's Avatar
      Mar 8th, 2004
      Green Bay, WI
      06-16-2005 03:26 AM #10
      Quote, originally posted by VDub GTI »
      I think both the airhorns and these are rated at 118 dB, but I've heard that the airhorns are louder. I've never heard a set of airhorns though... The only reason I didn't buy those was I thought they might be tricky to mount.
    11. 06-16-2005 03:31 AM #11
      Installing my Hella Triple Horns were a pita. However, the three frequencies produced sounds pretty cool.
    12. 06-16-2005 04:23 AM #12
      I must be sleepy. As I scrolled down I froze at this pic cuz for a second I thought you had a dead baby moose tucked away in your engine compartment.
      nice write-up, sounds like a good idea [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      _/_/_/__/___/____/_____/______/_______/________/_________/__________/
      Dub Cult | Simply Clean | MK3 Squad
    13. 06-16-2005 01:12 PM #13
      [QUOTE=Mr Euro]I must be sleepy. As I scrolled down I froze at this pic cuz for a second I thought you had a dead baby moose tucked away in your engine compartment.
      That's awesome...I can see the moose, too.
    14. Member focalBlur's Avatar
      Dec 5th, 2003
      Baltimore, MD
      2016 VW GTI/PP, 2005.5 VW Jetta(RIP)
      06-16-2005 01:31 PM #14
      I could be wrong but as I understand it with these horns they should be pointed toward the front of the car, such as behind the grill so that you can see them from the outside of the car.
      their sound pattern in narrow and projected forward so that they can be better heard on the highway. you have them pointed down so you are losing alot of their usefulness.
      the relay is not needed but can sometimes actually make the horns louder(these horns pull alot of power)
      have fun with your new horns, now people might actually be able to hear you on the highway
      Modified by focalBlur at 1:36 PM 6-16-2005
    15. 06-16-2005 01:41 PM #15
      looks great although we now need sound bites
    16. 06-16-2005 02:07 PM #16
      my supertones just died (mine are mounting using the stock brackets)...one of them is barely working...time to get new ones...
    17. Member Phrost's Avatar
      Mar 8th, 2004
      Green Bay, WI
      06-16-2005 04:48 PM #17
      I thought about aiming them forward but that would involve me making a bracket and doing a lot more work I figured aiming them down would be alright, because that's what you're supposed to do with alarm sirens... Next time I have my bumper off I'll probably relocate them [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    18. 07-05-2005 03:22 PM #18
      Here's how I mounted my Supertones this morning.
      I used an 8" straight steel bracket from Canadian tire and two little L brackets. Got a few Stainless Steel Bolts with Nylock Nuts to attach everything together, used Locktite on them as well to be safe. I had to play around with the positioning in order to clear the bottom of the bumper, and to have them far enough apart to keep them from touching each other or the back of the Micro DE's.
      I don't have an intake to worry about, my concern was moving the horns further back to clear the Micro DE. I used the relay and didn't cut the stock horn wiring up, I used a male connector to plug into the stock positive female connector and just taped up the second connector. Your car is way cleaner than mine. hehe
      Modified by mtltdi at 8:26 PM 7-5-2005
    19. Member andi_kg's Avatar
      Nov 2nd, 2004
      757 VA / 410 MD
      LB9A : 97, 2010 GTIs
      07-05-2005 04:13 PM #19
      i want a new horn. i was thinking more like an air horn
      MKIII | MKVI
      IDM | BHC | MK3FAM
      BURNALLTHEMK3S
      Instagram : andi_kg
    20. Member dj_dub's Avatar
      Jan 1st, 2002
      Bay Area, CA
      2010 BMW E90 M3, 2006 BMW E46 M3 Vert, 2010 VW Tiguan SEL, 2001 MBZ ML430
      07-05-2005 04:17 PM #20
      tight!! i cant wait to install mine now! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      - Wendell - OG noFÜKNjoke -
      2010 BMW E90 M3 & 2006 BMW E46 M3 Vert current obsessions
      2008 Audi B7 A4 2.0T Quattro - sold
      2000 VW MkIV Golf 1.8T - totalled
    21. Former Advertiser
      Jan 17th, 2005
      07-05-2005 04:24 PM #21
      Nice write up(s) guys!
      Get all your auto safety stuff at http://www.safedrives.com! [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. 07-05-2005 04:32 PM #22
      I have a small mpeg with the beep, can anyone host it? It's 155kb
    23. Member Phrost's Avatar
      Mar 8th, 2004
      Green Bay, WI
      07-05-2005 04:51 PM #23
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] There are multiple ways to wire these up, so you don't have to chop everything up like I did
      I still haven't gotten around to making different brackets for my horns yet, so mine are still pointed down. Once I finally mount them how they should be, I'll let you all know exactly how different they sound... if any
      Now go to http://www.safedrives.com and buy some new horns! You know you want to
    24. Member Chacolla's Avatar
      Jun 19th, 2004
      RI
      2006 GTI
      07-05-2005 05:01 PM #24
      speaking of horns, does anybody know where I can find some novelty horns...like the cucaracha
      no but seriously, does anybody know
    25. 07-05-2005 05:26 PM #25
      Quote, originally posted by Chacolla »
      ask Balsac he has one
