Results 1 to 9 of 9
Thread: Guide: How to fix the side vents cold air only problem
  1. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    Q7 4.2 V8 , Smart 451 Turbo
    06-18-2005 06:57 AM #1
    A BIG THANKS TO MAHONY for creating this.
    I come up with this save doc in my pc and thought of putting it online for you guys. I don't know who this page belong too. I saved it a couple years ago.
    http://gkoutsis.2mydns.com/Pho...s.htm
    Fix the side air vents cold air only problem
    A1 Volkswagens with AC had a design flaw in their heating system. the outer dash vents do not blow heated air. only center vents are heated. Outer vents blow ambient (or cold air when AC is on). when you factor in poor insulation and any drafts or leaks associated w/ the door and glass, the part of your body towards the outside of the car can get cold whilst you crank up the heat and cook the half of your body towards the car's centerline.
    There are two ducts that carry air from the heater box to the outer dash vents. While I had my dash out recently, i noticed the proximity of these two outlets to the front area of the heater box, which carries warm air. i figured i'd set out to seal up the ducts from the cold air that was their current source and create a new source of heated air.
    There is nothing between the two oval-shaped outlets on the heater box, so i went to Home Depot's HVAC duct area and picked up a 3" diameter aluminum heater duct for $2 or 3. This is a rolled sheet that is not joined to form a tube, but rather has a seam that can be snapped closed.
    I removed the two ducts and rolled the tube up and jammed it inside the two oval outlets (See the Green Outline in the Figure Above), so that if i reattached the ducts the two outer vents would be connected to each other but sealed up from entrance of any air at the heater box. after expanding the rolled aluminum, i screwed a couple of self-drilling, self-tapping #10 screws (maybe 1/2" long?) (See the Blue Dots in the Figure Above) thru the two oval outlets into the two overlapping portions of the rolled aluminum to hold it expanded against the inside of the outlets, sealing the ducts from the airbox.
    The oval aluminum tube that now runs thru the htr box runs close to the heated portion of the heater box near the center vents. I used a dremel to cut a big "port" from the heated side into the oval aluminum tube. this allows heated air to enter the aluminum tube and thus the outer vents are supplied with heated air
    Before
    After
    Modified by Black_cabbie at 1:04 PM 6-18-2005
    Modified by Black_cabbie at 9:48 AM 6-21-2005
    Chip Tuning for a living @ www.microchips-tuning.com
  2. Member Adam from Oz's Avatar
    Apr 8th, 2003
    Ex 2002 VW Golf Cabriolet - NOW 2007 Audi TT Roadster
    06-18-2005 03:35 PM #2
    This is totally bizarre! My car retailed at $35,000 AUD in 1990 yet came with no air-con nor centre vents. Its only "luxury" feature is the electric top.
    The side vents only blow cold air (Winter here).
    Would be great to get them to warm my frozen fingers as I go about topless. Now I know why they didn't sell many! A tiny convertible with nothing vs a HUGE Aussie made car with a V8 and the lot!
    Explains VW's absence of 12 years from our shores.....
    Would love to get some warm air through the side vents! My fingers are going numb on the steering wheel......
    Cheers,
    Adam
    Modified by Adam from Oz at 5:37 AM 6-19-2005
    Melbourne, Australia.
  3. 06-20-2005 11:47 PM #3
    All the substantive content is present ... Here's the original:
    http://members.toast.net/mahoney/heaterbox.html
  4. 06-21-2005 09:09 AM #4
    this is great! now how can we do to blow a/c from the center vents?
  5. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    06-21-2005 09:18 AM #5
    thats another problem.....
    Vacuum servo or vacuum reaching the distribution block inside the heater controls.
  6. 06-22-2005 02:24 PM #6
    any "how to..." gides on that George?
  7. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    90 Jetta GLI 16v, 99.5 Cabrio Highline
    02-23-2012 12:44 PM #7
    I know this is randomly old, but this is an awesome Mk1 improvement. Not sure if anyone else has seen this, but thought it deserved a bump.
    A2Resource
  8. Banned They_Call_Me_Bob's Avatar
    Mar 20th, 2006
    Washington DC
    02-23-2012 01:03 PM #8
    Quote Originally Posted by vdub2625 View Post
    i know this is randomly old, but this is an awesome mk1 improvement. Not sure if anyone else has seen this, but thought it deserved a bump.
    thank you for the bump sir! I never knew of a potential fix.
  9. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    1986 Cabriolet Best Seller, 2000 Jetta VR6, 1990 Vanagon Westfalia
    02-23-2012 01:52 PM #9
    Quote Originally Posted by VDub2625 View Post
    Quote Originally Posted by They_Call_Me_Bob View Post
    http://www.cabby-info.com/hvac.htm#Only_Cold
    Cabby-Info.com -- Your online guide to the VW Cabriolets
    Old Blue's Blog -- The adventures of a 1990 Westfalia
    "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
