Results 1 to 4 of 4
Thread: VW Bolt Patterns
  1. 01-09-2002 10:27 AM #1
    The bolt pattern or bolt circle is the diameter of an imaginary
    circle formed by the centers of the wheel lugs. Bolt patterns
    can be 4, 5, 6, or 8 lug holes. A bolt circle of 4x100 would
    indicate a 4 lug pattern on a circle with a diameter of 100mm.
    The diagram indicates the proper measuring methods.
    6 lug wheels are measured like the 4 lug wheels.
    Conversion Table - Inches to Millimeters
    .....................................Vehicle.............................Bolt Pattern
    ......................All Mk V, Passat-B5, B5.5 & B6
    ......................All Audi (95+) Except TT.......................5X112
    ......................All Mk4 (99.5+), All VR6 (Pre Mk V)
    ......................Audi TT, Audi A3..................................5X100
    ......................All 4-cyl (pre Mk IV).............................4X100
    ......................Most late '80/early '90's Audi................4X108
    ......................Air Coolers..........................................4X130
    Tools
    Centerbore
    Torque Specs
    Lug Hardware
    Cleaning Products
    ..........................Alex @
    .................Performance Products Specialist
    ........................877-522-8473 ext 294
    Modified by Eric @ TIRE RACK at 12:34 PM 9-19-2005
  2. 10-15-2008 12:06 AM #2
    Hello, would you happen to know what I need to do in order to change my bolt patter from 4 to 5? I want to use a 5 bolt pattern porsche mag oin my MK1.
  3. 06-13-2011 08:30 PM #3
    The table should read:
    (modified for the Audi A3 wheel bolt pattern which is 5x112 for 2nd Gen,
    and 5x100 for first Gen...)
    ......................Vehicle..................... ....................................Bolt Pattern
    ......................& A3 8P 2nd Generation (2003 - present)
    ......................Except Audi TT..............................................5X 112
    ......................& A3 8L 1st Generation (1996 - 2003)..............5X100
    ......................All 4-cyl (pre Mk IV)........................................4X100
    ......................Most late '80/early '90's Audi..........................4X108
    ......................Air Coolers........................................... ........4X130
  4. Member
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    06-14-2011 08:38 AM #4
    We (TireRack's main market) never got the 1st gen Audi A3 (based on the PQ34 chassis)
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
