DIYINTERIOR
Changing the Shift Knob (MT only) by jokr02
DIY - Aluminum Pedals by Pretarion
Replacing the card holder with a cup holder by RyanA3
How to Remove Door Panels by xt0rted
Ultimate Pedals Install by OOOO-A3
steering wheel removal by terje_77
INTERIOR ELECTRONICS
DIY: iPhone-tastic - Dock w/ Light & better iPhone/iPod NAV connection option
Satellite Tuner install w/ BOSE non-navigation system
Nice Aftermarket Stereo install by RyanA3
Hardwire a radar detector by RyanA3
Installing AWE Boost Gauge by WhyteIncognito
Replacing the yellow 'PASS AIRBAG OFF' LEDs with red ones by MisterJJ
Setting up SD cards for optimized use in the RNS-E NAV+ by Grisnjam, OOOO-A3 and others
iPod Integration with the Dension ice>Link
lus by OOOO-A3 and an alternate install by Akrion
Stealth Valentine One (V1) Concealed Display Hardwire Install (BWW) by yam
Bluetooth Phone Integration with Concert Head Unit (Mute & Audio) by OOOO-A3
Adding Power to Center Armrest by yam
Alternate Power to Center Armrest install by OOOO-A3
Disconnecting subwoofer by MisterJJ
Nav+ (RNS-E) and Bluetooth Retrofit: single-DIN to double-DIN conversion by WhyteA3
Turning the ashtray into an iPod cradle by A32Have
Auto dimming interior mirror w/compass by ZFXR
DIY '07 Homelink install write up complete
Custom Trailer Hitch by OOOO-A3
Trailer Lighting Wiring Instructions by OOOO-A3
iPod Integration with the DICE interface by OOOO-A3
Aftermarket sub in the OE spot by mack73
Homemade home-link by terje_77
EXTERIORDIY - Installing Jack Pads by SwiftA4
Trim License Plate Backing Mount by MisterJJ
DIY Black Rings (rear) by Ultimatetaba
Grill Removal w/out Removing Bumper by irishpride
Front Bumper Removal by kwanja_a3
wiper arm/ ecu removal by OOOO-A3
brushed aluminum grill by mack73
S3 front end swap br kwanja a3
rear bumper removal by 0000-A3
EXTERIOR LIGHTING
A3 LED DRL's...to keep them from turning off when turning signal is on
Euro amber tail lights and Blind spot mirrors; DIY heated mirrors by RyanA3 & additional euro tail DIY by 27spots
Wiring the City Lights in the Bi-Xenon Headlamps by OOOO-A3
European Taillights with Amber Turn Signals by OOOO-A3
Clear Sidemarkers Install by OOOO-A3
Rs6/TTs style LEDs by tiptronic
25 second bumper lenses removal by krazy boi
Bumper grill LEDs by tiptronic
Bixenon Wiring and Coding by melstrom
UNDER THE HOOD
Crankcase Breather Supplemental Checkvalve by OOOO-A3
Suspension
Rear Sway Bar Install by BalloFruit
VAG-COM required:Replace lighting switch to enable rear fogs by Dan@HillsideImports
Updated Rear Fog Switch install and enable by OOOO-A3
Adding Trip Computer Functions to the instrument cluster in Non-Convenience Sport A3s by AHA3
Adjusting the HID Xenon lights when installing lowering springs
A3 CAN System Long Coding Worksheet & Instructions by OOOO-A3
Additional VAG-COM coding reference by OOOO-A3
Footwell lights installation by A4MouseJunior
Tire Pressure Monitoring System (TPMS) install by OOOO-A3
Modified by irishpride at 2:55 PM 11-24-2008
Modified by irishpride at 2:56 PM 11-24-2008
Modified by irishpride at 12:35 AM 12-16-2008
Modified by irishpride at 6:21 PM 1-14-2009
Modified by irishpride at 6:25 PM 1-14-2009
Modified by irishpride at 7:10 PM 2-27-2009
Modified by StormChaser at 9:21 PM 12/13/2009
Modified by StormChaser at 9:23 PM 12/13/2009
lus by OOOO-A3
