VWVortex.com - how to test coil pack ohm's meter HELP!!!! PLEASE """
    Results 1 to 3 of 3
    Thread: how to test coil pack ohm's meter HELP!!!! PLEASE """
    1. 06-30-2005 04:18 AM #1
      WILL A OHM METER TEST THE 1.8T COILS ??
      TO SEE IF THERE ANY GOOD OR GOING BAD ??
      DOES ANY ONE KNOW THE TEST PROCESS INSTRUCTIONS TO DO A TEST ???
      THAT IS IF THERE IS ONE ??
      GOT THE RANDOM MISFIRE IN CYLINDERS ALSO TENDS TO STALL WHEN COLD
      (DID CHANGE THE PLUGS TO THE NEXT COLDER ONES NGK)
      2001 JETTA 1.8T 80,000 MILES
    2. Member MINT 1.8T's Avatar
      May 27th, 2004
      1994 Golf CL 1.8T, 2004 Audi A4 Q Ultra Sport, 2000 Golf 1.8T Alpine White, 2003 Audi A4 , T2 Touarg
      12-03-2005 11:00 PM #2
      Does anyone of you crazy dubbbbers... know how to figure this out..
    3. 12-06-2005 08:39 PM #3
      yes very easy man , with your meter put it to ohms and put one lead to the metal case of the coil pack and with the other lead touch each of the connectors there is four in that socket where you plug your harness into, the read out should be very low between 1 to 2 ohms if it is a high number then your pack is gone .
