VWVortex.com - jetta 1.8t engine cuts out. suggestions?
    Results 1 to 5 of 5
    Thread: jetta 1.8t engine cuts out. suggestions?
    1. 07-02-2005 02:05 PM #1
      Hi all. I have a 2001 Jetta 1.8T. I have upgraded the exhaust, chipped the ECU thru APR, added a blowoff valve, and cold air intake. My MAF sensor was going out so I had the dealership replace it. (defective part) Problem is, my engine is cutting out. It cuts out when I'm out of gear and coming to a stop. The idle will go down slowly then completely cut out. The ONLY LIGHT that is on after the engine dies is the battery light. No Check Engine light comes on so I can't pull any codes. I just replaced the MAF sensor. Seems it has something to do with the idle. I'm pulling my hair out trying to figure out what it could be. Has anyone had any problems like this? ANY help/tips/suggestions would be GREATLY appreciated! Thanks in advance.
    2. Member 2kjetta18's Avatar
      Mar 12th, 2005
      Richland WA
      09 Jetta TDI, 00 Jetta 1.8T, 89 GTI VR6
      07-02-2005 02:13 PM #2
      it could have faults in the ecm even if the mil light is not on
    3. Member VR-Slow's Avatar
      Nov 21st, 2002
      Rhode Island
      1999 1/2 Golf 8v, 2000 Audi A4 1.8tq, 2002 Triumph Daytona 955i Centennial Edition
      07-02-2005 03:23 PM #3
      Your problem is your blow-off valve most likely. put a DV in and it should fix it..... Or it could be the plug you have in place of the DV in your TIH, if its letting in air, it has a tendance to stall.
    4. 07-02-2005 05:53 PM #4
      I heard it could be the blowoff. I'm gonna try the DV. Thanks for the tip!
    5. Member VR-Slow's Avatar
      Nov 21st, 2002
      Rhode Island
      07-03-2005 02:00 AM #5
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] Good luck
