VWVortex.com - Low pressure AC port location?
    Results 1 to 5 of 5
    Thread: Low pressure AC port location?
    1. 07-13-2005 01:37 PM #1
      Im charging my AC but having trouble locating the low pressure AC port, does anyone know where this is located on a 95 golf?
    2. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      Previous: 1997 8v Golf. Current: 2000 1.8t Passat
      07-13-2005 01:46 PM #2
      There are two steel lines coming off the passenger side of the fire wall. A fat one and a skinny one. The FAT one is your LOW pressure line. This is the line you use to check/refill your refrigerant. Both nipples are of different size ....the fat, lower pressure line has the small connection.
    3. Member J-J-Jetta's Avatar
      Oct 29th, 2003
      NH
      2012 Tiguan SEL
      07-13-2005 01:47 PM #3
      look on the firewall behind where the belts are located... it'll be coming out of the firewall, 2 stainless pipes, you want the one on the LEFT
      c.b.s.
      Contact me if you have VCDS requests in New England (2006+ only)
    4. Member 9seven6's Avatar
      Jun 8th, 2004
      NY
      14GLI
      07-13-2005 02:13 PM #4
      Quote, originally posted by J-J-Jetta »
      Yes the one closest to the wheel. The fitment on the hose should only fit the low pressure side opening also.
    5. 07-13-2005 05:24 PM #5
      Thanks alot guys, my air is ice cold now, worked out well for $24.
