VWVortex.com - Golf/GTI Rear Sunroof Drain Fix DIY
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 81
    Thread: Golf/GTI Rear Sunroof Drain Fix DIY
    1. Member -Kage-'s Avatar
      Aug 4th, 2004
      Appleton, WI
      '72 Karmann Ghia, '92 Calypso Golf, '05 TDI Golf
      07-31-2005 04:43 PM #1
      For everyone that has a leak in the rear of their Golf/GTI, this is for you.
      Materials required:
      [2] Thin Hose clamps that fit 3/4" OD tubing(should be 5/8" to 1/2" rated)
      [10-15 FT] 3/4" OD 1/2" ID Clear Vinyl Tubing for 90 cents a foot. More flexible tubing would be better, however this does the job just fine and is available at almost every hardware store. Each stock tube measures 53" so you really only need 9 FT but having a little extra provides a cushion for any mistakes.*Note about the tubing* The 1/2" ID allows the tubing to fit over the ball very snugly and the 3/4" ID allows the tubing to create a very good seal in the drain. No need to consider other sizes of tubing. Luckily this is the tubing size I used for my watercooling system in my computer so that is how this specific size came to me. I knew watercooling my computer would be helpful in more ways than one!
      Tools required:
      17MM Socket for the seat belts
      10mm Deep Socket for the little screws holding the C pillar panel on the bottom of it.
      10mm regular Socket for the hunk o junk removal
      Small extensions for the sockets, makes it easier to get the bolts on.
      Standard large/medium Philips screwdriver for the handles and hose clamp.
      Pointy angled pick(as seen in the headliner removal guide) for the handles.
      Torx20 Screwdriver(mini hunk o junk and the two plastic pieces as shown in the headliner guide.
      Time Estimate: 1-4 hours depending on your skill level. If you don't know how to take your interior apart and have the right tools ready, it will obviously take longer than someone who knows what they're doing with all the tools at their finger tips.
      Bentley diagrams of the Golf/GTI temporarily removed until I research the freedom of information act, I/M me if you 'are wondering what happened to them'
      When I washed my car the other week, I found a *minor* water leak.
      This guide did help a little but didn't provide enough info for what I needed. So I posted a thread and that's where the searching for the Golf/GTI sunroof drain spots began.
      Headed over to the MKIV FAQ for the headliner removal found here: http://forums.vwvortex.com/zerothread?id=1312975
      In order to get to the rear drains, the back seat handles on the headliner need to be removed along with the rest of the standard stuff in that guide, minus everything in the front. Dropping the whole headliner is completely unnecessary for the sunroof drains. The rear lights by the handle can stay in place. I removed one of them and it was very difficult since it has a funky clip on it only to find out it can just stay there.
      !!!EDIT ALARM!!! Turns out that these PITA clips are properely removed using a hook screwdriver. Follow the 42DD guide here for proper instructions: http://www.42draftdesigns.com/tech/restraintclip.html <---That's for the A-pillar, but the same method can be used for the back clips too.
      ATTENTION, the following information for the clip is obsolete, use the guide above^.
      One tricky part to removing the C pillar is the metal clip that holds it on. For this, you have to use both hands as to not break the plastic and just pull/wiggle it very hard until it pops out. I cracked the plastic just a little bit from bending it too much since my hands weren't close to it, no biggie my interior is trashed anyway(black 20th interior someday after the car is paid off).
      Woooooops
      Everything ripped apart
      Driver Side
      Passenger Side
      Door Molding taken off, allows the panel and headliner more room to be removed.
      EDIT: Be careful to keep the white cloth rubber part attached to the black molding, these things are a single piece item. DO NOT seperate them, or you will have to carefully slide it back in!!!
      Don't we all love taking apart the interior of our car?
      Now you need to take care of some hunk o junks in order to get to the driver side drain.
      This allows you to fold that carpet on back very far for a huge workspace.
      Reinstalling these things involves one special note, make sure that the prongs are tucked in.
      NO!!! [IMG]http://*****************.com/smile/emthdown.gif[/IMG]
      YESSSSS!!! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Fold down your seats so the headliner has some more room to hang down. Here's what I found when pulling down the headliner:
      How did that ish get in there?!? WAIT...VW used OPEN DRAINS instead of sealed so junk can make its way out of that and onto the headliner. <IMG NAME="icon" SRC="http://vwvortex.rely.net/zeroforum_graphics/mad.gif" BORDER="0"> Pure. Genius. Just. Kidding.
      Pull that crap stock tube out!
      Look at this, some ingenuity must have been involved in using TOTALLY SWEET FALL APART CONNECTOR TUBES:
      These connectors end up losing their bond with the tubing and then the water leaks through. [IMG]http://*****************.com/smile/emthdown.gif[/IMG] to VWOA for cutting costs yet again.
      Here's the drain connector on top:
      Time to replace that tube with something quality, how about some tubing that goes over that ball and a hose clamp? What a brilliant idea!
      Now for the driver side. The driver side hose must be routed between the metal panel that the stock hose goes through. This can be a pain with tubing that is curved. Just keep trying and you'll get it, poke your fingers through the other slots in the panel to push it down, and then once you can feel it on the bottom just wiggle it around and push from the top and pull from the bottom.
      Be sure to route the tubing through everything BEFORE cutting it. Repeat this 'trick' on the passenger side as well. This is the most time consuming part of the whole project since it involves luck/skill.
      Break off those clips that held the stock tube in, I left the stubs to use as a guide for the new tubing.
      Route the new tubing in place of the stock:
      [DO NOT] zip tie the new tubing to the tube wrapped in the blanket. Come to find out it is supposedly the curtain air bag
      Instead, just let it hang there and push it up with the headliner:
      Put that hose clamp on the tubing positioned right before hooking it up. When it gets on there, it's hard to take off because of the sweet seal the 1/2" ID hose makes.
      The driver side drain is right below the tail light:
      Looky here, a nice swimming pool; IN MY CAR! ---> ***Side Note: Soak up any leaks before continuing and let it air out before putting everything back together. ***
      For the drain tube connectors that go in the hole you should take it out, wiggle/slide/push it onto the tubing so it points down, and then slowly but surely secure it back in from within the car. They are made to be inserted from the back of the car when the back bumper is off although with a little bit of magic they can be pushed back in. Slide as much as you can onto the metal, and then use the good ole roundabout to get the rest to slide under to create the seal. It's self explanatory once you have in your hands [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      With the tubing coming out from the metal panel, it doesn't give much room for positioning the end at a good angle. Do the best you can, it should still drain a sufficient amount of water.
      On to the passenger side. Much easier than the driver side since the tubing has a straight shot down to the drain.
      Hose clamp connected on top, the rear seat being folded down helped a great deal for the passenger side since you have a tight space to work with the screw driver.
      Originally I had fastened this tube in place with a zip tie. This ended up preventing the C pillar panel from snapping up since it was too close to the connectors. Let it all hang loose, the panel will keep it in place.
      Here's the drain location on the passenger side:
      Connected together, the passenger side allows for more of an angle so the water can drain out quicker in case you didn't notice.
      Put everything back together in reverse order and confidently drive in that rain knowing you have upgraded sunroof drains in the back of your car.
      Revisions are complete, specific information will be added on request.
      Modified by -Kage- at 8:47 PM 7-4-2007
      Oct 6th, 2003
      PHX
      72 Westy, 06 MKv Gti, 66 C10, 62 Monterey,
      07-31-2005 04:47 PM #2
      Great Diy
    3. Member SlavaKM's Avatar
      Feb 1st, 2004
      DC
      2012 VW CC
      07-31-2005 04:48 PM #3
      wow man...talk about overkill
    4. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      01 Golf GLS 1.8T, 11 Jetta SE, 11JSW 2.5SE (Wifes)
      07-31-2005 05:46 PM #4
      This is awesome!
      ET Feature Car 1/08|Forgeline Wheels|WRDusa.com|
    5. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      2008 Cayman S, 2006 GLI, 2008 Rabbit
      07-31-2005 05:47 PM #5
      Yeah, uhh... you're a champ. This has been added to the MkIV forum DIY thread. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Ride In: 2008 Signal Green Cayman S Sport 378/700 .:. 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
      Ride On: 2010 Trek 2.1 .:. 2011 Fisher Cobia
    6. Member theAntiRiced's Avatar
      May 6th, 2005
      Baltimore
      07-31-2005 06:45 PM #6
      Nice DIY.
      Just a thought: Inserting diagrams taken from the Bentley Manual probably violates copyright law. I don't want to see this DIY taken off because of anything like that.
      I sold my bagged VW and bought a 5.0?
    7. Member -Kage-'s Avatar
      Aug 4th, 2004
      Appleton, WI
      07-31-2005 11:37 PM #7
      Bentley pictures removed, I'm going to look into what a man can do with pictures these days.
      BRM-Thanks man
      If you have any questions just I/M me and I will (most likely) be happy to answer them.
    8. Member VacantSkies88's Avatar
      Nov 15th, 2004
      USA
      07-31-2005 11:47 PM #8
      Thanks for the DIY, now Ill have something to do next weeked
    9. Banned LETTERMAN52's Avatar
      Jul 28th, 2003
      07-31-2005 11:47 PM #9
      Awesome write-up....Thanks for taking the time to write it up. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. 07-31-2005 11:59 PM #10
      I noticed one problem, unless I'm just looking at it the wrong way (which is totally possible). I think you ziptied the new tubes to the curtain airbag. Don't think that's too good.
    11. Member -Kage-'s Avatar
      Aug 4th, 2004
      Appleton, WI
      08-01-2005 12:11 AM #11
      Is that the curtain air bag? It's a metal tube with some blanket attached to it so I didn't think it was anything important and had no clue what it was. Now if that's the case, just don't use zip ties anywhere and let the panel secure the tube like on the passenger side.
      [Added the hunk o junk removal and a pic of the accumulated water from the leak.]
    12. Geriatric Member firefighterjunkie's Avatar
      Mar 26th, 2004
      PNW, Washington State
      '04 GTI and '03 Passat Wagon
      08-01-2005 12:17 AM #12
      Nice write up!!
    13. 08-01-2005 02:25 PM #13
      I have to do this with my driver's side A-pillar tube soon.
      Hopefully many of the same points apply. Thanks for the write up. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    14. Member -Kage-'s Avatar
      Aug 4th, 2004
      Appleton, WI
      08-03-2005 03:36 PM #14
      boi- Sending you an I/M, let me know how removing the air bag pillars goes...looks like there's a bracket you have to push up to remove them.
      Everything looks to be near the final product now, adding a tools required section since they are not the same as what Jkrew has listed.
    15. 11-08-2005 09:53 AM #15
      how do you fix the front tubes?
    16. Member evil-e's Avatar
      Aug 15th, 2005
      PNW
      2007 X3 3.0si
      11-08-2005 10:13 AM #16
      Nice writeup [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. 11-10-2005 06:42 PM #17
      Kage,
      Excellent job posting DYI for rear sunroof drain. Reading through the posts it seems like you are working on the same instructions for the front sunroof drain.
      I would really appreciate if you could let me know what are all the items I have to remove to access the drain outlet that is behind the dashboard on passenger side.
      I have removed the glove compartment, and I cant figure out what to remove next to get access to drain.
      I'm in little bit of panic, as I had this leakage problem before, and the moisture eventually killed the car computer, I have spent $3K getting the computer replaced. I'm determined to get it fixed once and for all.
      Thank you,
      Dominik
    18. Member -Kage-'s Avatar
      Aug 4th, 2004
      Appleton, WI
      11-10-2005 11:56 PM #18
      Dominik- Reply sent.
      Sean- I just sent an I/M to boi retro asking if he got around to the front drains. If he did, he'll be the man who can help.
      On a side note, the new tubing did not help me on the driver side. Water still forms the same pattern, I believe it's because of the actual plastic connection to the metal drain. Water will still drain out of the hole(verified by some sick colored puddles on the garage floor after some rain) so I know the part I fixed is at least working and not dumping back into the car like it was before. Chances are I will end up completely replacing the whole system with tubing to get rid of this junk, but that is going to involve completely dropping the headliner and that's something I don't have time for now.
      I'll keep you all updated, -Travis
    19. Banned Elvir's Avatar
      Oct 18th, 2004
      11-11-2005 12:01 AM #19
      wow, that is a very good write up..
      Elvir
    20. 11-12-2005 05:17 PM #20
      where was this post months ago when i was swimming in the abck seat of my gti. good write up. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    21. 01-10-2006 01:45 PM #21
      nice write up kage::::It rained a bit last night and there was no water inside the car....
      now to redo the headliner and pillars in black.......
    22. 01-10-2006 01:50 PM #22
      Sorry I'm late to the thread guys. I forgot completely about it and then couldn't find the IM from Kage.
      The headliner dropping was a long, drawn out, disastrous process for me. All I wound up doing was dirtying it up and creasing it in a few places.
      In order to fix the front tubes the entire headliner needs to be dropped. I removed everything and couldn't for the life of me figure out how to get the clip that holds the visor in place off (not the swivel, the other one). Anyhow I poked around and finally decided to run a thin gauge pipe cleaner through the driver's side tube. I don't think it really did anything, but it hasn't flooded since then, so I guess I fixed it.
      It's still a mystery to me. Twice it flooded ONLY on the driver's side with about 2" standing water to greet me when I opened the door. Hasn't done it before, hasn't done it since. Hopefully it's fixed once and for all.
    23. Senior Member idwurks's Avatar
      Oct 25th, 2003
      Hill Valley, California
      Time Machine
      01-10-2006 01:53 PM #23
      NICE diy for people out of warranty. [IMG]http://*****************.com/smile/emthup.gif[/IMG] I recently had this issue, and the dealer flushed the system for me under warranty.
    24. Member Fugee's Avatar
      Aug 22nd, 2003
      Las Vegas, NV
      06 VW 95 GMC
      01-10-2006 01:56 PM #24
      good DIY man..Im glad i checked mine when i tore my headliner down [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    25. Member -Kage-'s Avatar
      Aug 4th, 2004
      Appleton, WI
      01-11-2006 07:05 PM #25
      Glad to see people having good luck with this, it sure feels good to help out
      When summer comes I hope to drop the headliner and totally revamp the whole sunroof drain system if all goes well between now and then.
