got my alignment done and correcfted and got my ball joints replaced. handles and drives much better![]()
#142
It's a car, it's meant to be ****in driven. ~ elijah-
My stuff: zidesign.com(site) @imdoingstuff(twitter) ZidesignFanPage
#143
She got naked in front of my v70.. lost a fender here a bumper there.. all for good reason.. My little girl is going through some changes.
#145
took out the intake and exahaust manifolds, the pulleys, alternator, ps pump, brackets, ac compressor, radiator. basicly it's ready for an engine swap.![]()
all that's remaining is to take off the tranny bolts and 3 more engine mount bolts and it will just slide right out.
#147
i went in my garage and looked at the rust in the floor and turned around and went back inside![]()
#148
Quote, originally posted by 88mkIIGOLF » i went in my garage and looked at the rust in the floor and turned around and went back inside ![]()
a man who thinks like me.
#150
Gave mine a hug and then gutted the coolant system. Pulled the radiator out, hoses, and airconditioning condensor. Replacing everything.Factory VW Spring/Hose Clamps suck
#151
I call Roxy - GONE!! I love money.
#152
Well i didnt do this today but yesterday my friend and I replaced my stock intake with an after market one, ITG but with a matrix airfilter
#153
I miracled the transmission back on the engine.
#154
I installed some chrome stripping on my bumpers...
#155
installedBrake pads
o2 sensor
air filter
crank to alt beltremoved
A/C
windsheild washer tank
TOMORROW!
Oil change
fuel filter
checking master cylinder for brakage
maybe ripping the exhaust off and mesuring for a new onedads car
weld on new cat.moms car.
finish axels
and figuring out the bastid vaccume lines![]()
The more i learn, the more worrying noises i hear
"Play a Windows CD backwards and hear scary messages. Thats nothing, play it forwards and it installs Windows"
#156
Well I installed a new radiator hose cause one of them sprung a leak and my motor got way! hot.
#159
i had my windows tinted. it looks really good but now i can't roll them down for three days. it's going to be about 108 this afternoon.
#160
Quote, originally posted by b00st1n » i had my windows tinted. it looks really good but now i can't roll them down for three days. it's going to be about 108 this afternoon. who told you that you can't roll them down for 3 days ? the tint shop ? that's BS. with that amount if heat , leave the car under the sun for 2-3 hours and you'll be fine. trust me
i've tinted 2 of my cars myself and they looked great.![]()
btw the tint shop (or maybe you) should use a heatgun on the tint to make it sit flat (without wrinkles) on the window, and that heat gun will actually make the tint stick to your window pretty hard. so don't worry about pulling them down. BUT i would recommend that if you pull your windows down don't pull them ALL the way, leave about 1/2 inch of the window out (if you pull all the way the edge, or molding that's touching the window could pull your tint off for now)
#161
I went out to do the headgasket , got everything prepped then realized I don't have the correct bit !!!![]()
#162
Well I finally pulled the motor for the VR swap....yeah I know...another mk2 vr....yawn...lol
#163
finally converted and recharged my AC......new injectors tomorrow
#164
Put the O2A back in my car today... in the process broke the little nipple on the coupler on the upper radiator hose... won't happen again i already found a nice piece of aluminum tubing and a 45 degree barbed fitting that will be replacing that plastic ****Took the VR out for a quick spin around the block... clutch grabs like it should and doesn't chatter all to hell... woohooo!!!!!!!!!! Time to have some fun once i'm not spewing coolant everywhere...
#165
last month i got arrested in my dub.this week in my jettas front doors. I custom installed in new pionner 4"'s, washed, waxed, put a 1/2qt in, vacumed, madeout in the back seat with a hotti, then went to her house and did the deed.
A friend whos a girl, i installed some pionner 6x9's in her back dash, then ended up chilling with her for the nite.
Pimpin ain't easy..........
o yea, my getta now has 2 subs, and 8 speakers.
#167
Installed a shifter rebuild kit. Much smoother now!Never thought my engine bay had so much grease and oil covering stuff up. Nice rust proofing tho... I really should clean it up.
#168
timing belt, water pump, thermostat, tensioner, rear cross drilled rotors, new calipers, wheel bearing kits. Took me all day and I can't get it to run now. Damn car. I have to keep it now.![]()
#169
#170
Washed my car for about 2 hours getting it ready for a show tomorrow.![]()
#171
i licked my cars tail pipe because thats how i get down![]()
#172
went to bow wow for parts and saw a gorgeous rabbit gti. i definetly need to get one of those someday.replaced the rear brake pads. the old ones were missing the anti rattle clips ( ? ).
took it out for a rip anound ubc area and enjoyed the rattle free sounds of the 16V.
(pic not from today)
#174
Quote, originally posted by twodubs » i need to stop....
those schmidt wheels look soo nice!
PAGE 6 OWNAGE!
#175
Replaced the latch mechanism on my hatch, it now locks!
Bought a used EuroSport exhaust that I will be installing tomorrow.
Bought and installed an ashtray, though I don't smoke, damn aesthetics!
Bought a door panel (card), but the damn thing is too small, who knew??
Going to try to get a glovebox tomorrow. Good times![]()
