Page 504 of 721 FirstFirst ... 4 404 454 494 500 501 502 503 504 505 506 507 508 514 554 604 ... LastLast
Results 17,606 to 17,640 of 25225
Thread: What did you do to your Mk2 do today?
  1. Member URIN 2ND's Avatar
    Oct 29th, 2001
    SoCal
    '89 GTI 16V
    10-01-2010 01:57 AM #17606
    Before:
    After:
    -Big Bumpers installed
    -Oil change
    -Compression check (190, 180, 175, 180)
    -New tires on the BBS' (BFG G-force Sport, 205/40/16 on BBS RK 16x7, 32.5 lbs wheel + tire)
    -New O2 sensor
    -Installed Zender deck spoiler
    Quote Originally Posted by SGLoki View Post
    I believe rupaul is the tallest trans.
    Considering the following sticker for the rear window:
    "Fv@k tire stretch, fv@k air suspension. See you in the canyons..."
  2. Junior Member
    Aug 24th, 2010
    Southside, Va
    87' Jetta mor-door
    10-01-2010 08:38 AM #17607
    Completed bottom end of the 9A and sent the head of to be resurfaced and checked. Only thing I'm waiting for now is the head. I need cams!
  3. Member renngolf's Avatar
    Aug 24th, 2005
    Burlington, ON
    99 Acura 1.6El, 98 Jetta GT(gone), 91 Golf CL
    10-01-2010 06:35 PM #17608
    Got some more stuff for it
    Threw in the pedal cluster along with the column. regreased + new ignition switch
  4. Member URIN 2ND's Avatar
    Oct 29th, 2001
    SoCal
    '89 GTI 16V
    10-02-2010 12:19 AM #17609
    Went from this:
    To this:
    Also...
    - Removed A/C condenser, compressor, lines, and chopped a few lbs. worth of bracket off. For those wondering, (1) you don't need any extra or special parts to delete the A/C in a PL or 9A, and (2) all parts together were 35.3 lbs.
  5. 10-02-2010 02:07 AM #17610
    I helped the nephew get some more of his stuff out of it so i could get it running again.
  6. Member farvy87's Avatar
    Oct 13th, 2009
    Richmond, Indiana
    1998 jetta glx
    10-02-2010 05:02 AM #17611
    put the dash back in, swapped wheels, lowered it more, put the small bumpers back on, and a few other small things..
    its almost ready for dubdash tomorrow !
    May 5th, 2006
    757 to the 843
    All except mk1 and mk4
    10-02-2010 06:00 PM #17612
    Coils, new rotors, pads and brake lines... overall a good day
    Yes needs moar low however i have gigantic speed bumps i have to drive over inorder to park at work everyday
  8. Junior Member dieselanything's Avatar
    Dec 3rd, 2008
    boulder creek
    1987 vw golf gl
    10-02-2010 06:14 PM #17613
    put a new oil pressure sensor, and linkage bushings for the shifter. shifts alot better and i can tell r and 1st apart now
  9. Member ImSpecialerThanU's Avatar
    Sep 25th, 2007
    Marysville, Wa
    92 Jetta GL (sold), 92 Jetta GLI (sold), 90 Jetta GL, 02 Jetta GLS, 92 Cherokee
    10-02-2010 06:29 PM #17614
    cap,rotor,plugs,plug wires, oil filter,oil and a damn starter. got every thing elese done first no problems. go to get in and start her up nothing. . . . starter failed at some point to no supprise an oddly long thin crack exposing the guts of the starter. Adjusted front coils up axle had rubbed a little on the frame due to no notch yet so had to go up.
  10. Member
    Aug 3rd, 2010
    socal
    88 GLI
    10-02-2010 07:33 PM #17615
    Quote Originally Posted by Fizzo20 View Post
    Pchopped my plans onto it
    Before:
    After:
    nice photoshop lol
    almost looks real
  11. Member rconn14's Avatar
    Sep 6th, 2006
    Connecticut
    2004 BMP R32
    10-02-2010 09:27 PM #17616
    Spent the first significant time with it in years. It's been dead in the garage since last year. Had a fellow texer come help out and we determined fuel pump was bad. Ordered a new one tonight.
    Also put in new spark plugs and fuel pump relay, and have a new fuel filter, injector seals, and some injector cleaner waiting for the pump to show up. Also picked up a cleaner-than-mine fuel dizzy at H20 last weekend, and if I can get the rusty ass bolts off the current one it'll go in as well.
    Hopefully it'll run for the first time in 2010 in the next week or two.
    Also grabbed the spare teardrop from the trunk, gonna take the tire off and have my first go at refinishing a wheel.
    Piece o' junk:
    http://r32registry.org/802 ||| Large Garage Banners FOR SALE
    Quote Originally Posted by B3VW Hasan View Post
    I have to stop this idiot from deminishing my credibility every time he posts because my usernsme is in his sig. Who do I talk to?
  12. Member BlkMaGiC 3526's Avatar
    Sep 10th, 2005
    NorCal / El Sobrante
    10-02-2010 11:06 PM #17617
    My Mk2 has been dead and has been sitting for a couple of months so I removed the battery to get it recharged. I thought it would crank right up after the recharge, but no dice. Need to do further diagnosis.
    Also, I had to kill and remove the wasps and wasp nest that was being built in between my door jam.
    Past: Too many to list
    Current: MK5 .:R32 UG #4735
  13. Member BUC43's Avatar
    Jan 29th, 2001
    Southern California
    91 GTI 16v, 92 Corrado VR6, 09 Tacoma Sport, 10 Jetta SW TDI, 85 Toyoya 4x4, 89 Helios GLI
    10-02-2010 11:25 PM #17618
    The Helios got new:
    Rotors
    Pads
    SS brake lines
    ball joints
    tie rods and ends
    cap
    rotor
    plugs
    plug wires
    Hope to have some more time tomorrow for a few other things.
  14. Member F3t1sh's Avatar
    Oct 17th, 2008
    Gatineau, Quebec
    01 A4 1.8T, 88 jetta ABA ITB
    10-02-2010 11:28 PM #17619
    Modernized my old girl
    joke, not my car
  15. Member URIN 2ND's Avatar
    Oct 29th, 2001
    SoCal
    '89 GTI 16V
    10-02-2010 11:37 PM #17620
    Quote Originally Posted by 85vwgolfer View Post
    No, it does not need moar low. Any moar low and you'll be thuggin' it like the icy hot stuntaz. Don't be a sheeple...it looks great as-is!
  16. Member
    May 5th, 2006
    757 to the 843
    10-03-2010 11:08 AM #17621
    Quote Originally Posted by URIN 2ND View Post
    Haha thanks... ya the moar low was a preemptive strike against the tex's moar low crowd
  17. Member Fizzo20's Avatar
    Mar 28th, 2010
    Calgary, AB, Canada
    1990 Jetta Coupe .....................1998 Golf GTI VR6
    10-03-2010 12:11 PM #17622
    Looks great as is, but I still say moar lower and bring long sheets of plywood to those speed bumps
    ///MK2s are a helluva drug.
    1990 Jetta Coupe - VR Swap Project
    1998 GTI VR6 cam'd/chipped - Daily
  18. Member rconn14's Avatar
    Sep 6th, 2006
    Connecticut
    2004 BMP R32
    10-03-2010 02:31 PM #17623
    NO MOAR LOW! That's perfect like that. Some people are insane scraping their car around town
  19. Member Cherry_Bomber_SA's Avatar
    May 21st, 2009
    Romania/South Africa
    92' A2 Gti 16vT, 85' A2 8v Gti, 93' A3 VR6
    10-03-2010 03:23 PM #17624
    Fitted my 16v's wheels on my daily..gave her a wash and took a few pics..need better tires..
    '92 Mk2 Gti 2l 16vT - 305hp & 362nm atv @ 0.8bar The Cherry Bomber [Oo=w=oO]
    '85 Mk2 Gti 16v - The Dub [O==w==O]
    '93 Mk3 Vr6 - The B11TCH
  20. Member yeayeayea's Avatar
    May 29th, 2005
    md
    89 GTI 16v with carbs, 99 528i, 95 gsx600
    10-04-2010 12:20 AM #17625
    Feel free to follow me on instagram @wesmurphy for pictures of bikes, bimmers, vws, etc
    my "build" thread: 16v+carbs FOR SALE!!!
    My gti is for sale, check it out! http://forums.vwvortex.com/showthrea...7#post79821897
  21. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    :faceplam: :beer: :thumbup:
    buncha junk
    10-04-2010 12:27 AM #17626
    bout damned time wes! ive been interested into see what all went into the ITBs
    i didnt do a damned thing, H2O is over, i wont touch the car for the next 5 months
    Crooked Euros | Low is NOT a lifestyle | Slow & Quiet
    WTB - 04.5 GLI REAR VALANCE
    Pennsylvania Volkswagen Owners & Enthusiasts Page
    O/R/T
    We Do It Big In PA
  22. Member yeayeayea's Avatar
    May 29th, 2005
    md
    10-04-2010 12:36 AM #17627
    I recently got this ac/dc tig welder, so the real building is yet to come
  23. Member iskr33m's Avatar
    Jun 29th, 2010
    Auckland
    Volkswagen golf 1989 MK2
    10-04-2010 03:47 AM #17628
    Resprayed my front VW badge silver, as the chrome was faded 3/4 of the way. Will post pics tomorow as it's dark now.
  24. Member vwjn311's Avatar
    Aug 26th, 2005
    ar
    99 gti
    10-04-2010 01:47 PM #17629
    bought it a new exhaust hanger so it doesn't have to scrape as much ha
  25. Member choochoo's Avatar
    Nov 12th, 2008
    OC, CA
    10-04-2010 06:00 PM #17630
    unintentionally drove it in the rain today. no pools of water yet.
  26. Member BlaktOut02's Avatar
    Sep 3rd, 2009
    Cleveland
    69 Squareback, 90 Cabriolet
    10-04-2010 07:26 PM #17631
    got stranded on the way to school at 6:30am. bought a new battery, alternator and all new cables for her, getting installed tomorrow. maybe now i can go a week without an issue
  27. Member iskr33m's Avatar
    Jun 29th, 2010
    Auckland
    10-04-2010 11:46 PM #17632
    Quote Originally Posted by iskr33m View Post
    Took photos today:
    Before badge respray:
    After:
  28. Member Slowroller's Avatar
    Jun 5th, 2010
    Central CT
    88 GLI, 91 GLI, 03 B5.5 wagon
    10-05-2010 12:19 AM #17633
    [IMG]Cleaning the trunk[/IMG]
    I did some cleaning yesterday. today, I researched parts. I need fuel pump banjo bolts, and fuel lines on both sides of the filter. Will trade for beer!
    I'm lurking, and yeah, I'm looking at you
    ...the saga continues!
    88 GLI- dead/91 gli- gone/02passat gls wagon- cel/03 passat glx wagon-4mo
  29. Member farvy87's Avatar
    Oct 13th, 2009
    Richmond, Indiana
    1998 jetta glx
    10-05-2010 01:06 AM #17634
    gotta love mk2's
  30. Member choochoo's Avatar
    Nov 12th, 2008
    OC, CA
    10-05-2010 06:21 PM #17635
    Quote Originally Posted by choochoo View Post
    spoke too soon. rained hard today. water gushing in behind the heater box and air blower water coming in through the doors too damn this weather. Last week it was 110..... this week, it's pouring rain
  31. Member NummerEins's Avatar
    Feb 15th, 2010
    Louisville, KY
    2001 A4 Avant
    10-05-2010 08:19 PM #17636
    Found a tranny for $400. Hope to have it completed in a week. Replacing tie rods, clutch kit, rotors/pads. Excuse my junky ass garage.
    Before:
    After:
  32. Member BimmerTim's Avatar
    May 3rd, 2009
    MPLS
    08 Rabbot and 89 Audi 90q
    10-05-2010 11:41 PM #17637
    Buffed the **** out of it.
  33. Member popejames's Avatar
    May 23rd, 2010
    Fayetteville, NC
    85 cabriolet manual
    10-06-2010 07:20 PM #17638
    bought a mk2 jetta coupe for $350, took 2 hours to remove a oil filter. Runs great!, no reverse
  34. Member thepurpledinosaur's Avatar
    Mar 6th, 2009
    Minot, ND
    85 4000q vr6, 94 SAS'd 4runner, 86 ZUK
    10-06-2010 08:02 PM #17639
    nothing with a complete build and 1.5 mos before i move from fla to ND...
    The never ending http://forums.vwvortex.com/showthrea...7186-4000q-vr6 project...
    I NEED AN 01E TRANS! PM ME!
  35. Junior Member
    Aug 24th, 2010
    Southside, Va
    87' Jetta mor-door
    10-07-2010 10:33 AM #17640
    de-oxidized all of my trim, painted all of my accesories brackets, and started installing valves!
