Page 641 of 726 FirstFirst ... 141 541 591 631 637 638 639 640 641 642 643 644 645 651 691 ... LastLast
Results 22,401 to 22,435 of 25387
Thread: What did you do to your Mk2 do today?
  1. Member Sickvwguy's Avatar
    Apr 12th, 2011
    High Desert
    03' GTI BMP, 97 TDI Passat, 85 Mk2 Jetta diesel, 69 vw bug, 58 dbl. cab
    05-03-2012 10:04 AM #22401
    Quote Originally Posted by 92_MK_2 View Post
    what u mean?
    I mean they ride ok for the price lmao.. Change the rubber isolators on the top and bottom sides of where the coil mounts to the body..if yours are original they are probably toast..and don't use air tools to install..it will spin the shaft and destroy the seal in the shock.
    Sent from my throne using Crapatalk
    Apr 21st, 2008
    sand and palm trees
    Mk2 Diesel for sale
    05-03-2012 10:12 AM #22402
    ^Good advice. The upper rears should be easy - just need 17mm stuff. For the recessed nut I have a socket grooved (via Dremel) and clamp it w/ vice-grips. Might need some fine-nose vice-grips for the top tab in the rears to get the nut loose.
    PB blaster is your friend. Don't settle for WD40 (useless stuff..).
    In the front, do the upper nut first (set it in place, and thread down to the lock portion) this should leave the assembly hanging. Attach the knuckles, wheels, lower the car. The top piston is now as high as it's gonna be through the upper strut mount, so stick the plate on, and carefully tighten the nut (22mm) - the central allen key should be 5mm or 6mm (to prevent the strut piston from spinning; spinning it will destroy the valving inside).
    USMC
    29 Palms, CA
  3. Member Urwrstntmare's Avatar
    Feb 21st, 2011
    The Rockies
    1996 WolfyJetta....soon to be for sale! 1992K1500 Blazer-Ole faithful
    05-03-2012 10:23 AM #22403
    Try checking to make sure your not sucking air anywhere in your intake boot, sounds like your taking in air near your TB, I had that same problem, the plastic elbow on the boot was cracked and taking in air and giving that cammed rumble sound, it was an OBD-1 ABA as well.
  4. Member R-Dubya's Avatar
    Jun 23rd, 2011
    '86 Mustang GT
    05-03-2012 10:31 AM #22404
    Quote Originally Posted by Sycoticmynd29 View Post
    What was your car doing when you had a bad ISV?
    Just curious because the PO of my car told me the ISV is bad on my car, and it idles like it has a big cam in it, so I'm curious to if replacing it will actually solve the problem or if I'm going to have to figure it out from there.
    Its an ABA obd1 swap if that changes anything.
    Well a faulty but still functioning ISV can cause a whole bunch of idle problems; loping idle, sporadic revving at idle, really high idle, etc. Mine just didn't work at all, and my car would basically start up like it was carbureted and had no choke. I'd have to hold the rpms up around 1k-1200 on cold starts until it warmed up enough to idle properly. After that, it would idle perfectly fine albeit a little low at times. If you can find a cheap ISV in a junk yard or on here, it's definitely worth checking out.
    Mine's a digi II 1.8, but the ISV still does pretty much the same thing.
  5. Member 92_MK_2's Avatar
    Oct 11th, 2010
    Texas
    92 MK_2(SOLD) -- 2011 Ducati 848EVO (SOLD) -- 2011 Mitsubishi Outlander Sport -- 89 Honda Accord
    05-03-2012 10:33 AM #22405
    Quote Originally Posted by Sickvwguy View Post
    Quote Originally Posted by Project_2501 View Post
    got it.
    Roses are red Violets are blue, BLA BLA BLA BLA MK_2
  6. Junior Member
    Apr 9th, 2012
    Denmark
    Golf mk2 84" Audi 100 2,3 Avant 94" Suzuki Swift 1,5 07" Porsche 924S 84"
    05-03-2012 10:37 AM #22406
    Was at the junkyard and tjek'd som of the new cars that have come in.... scored me this for 25$
    Image Hosted by ImageShack.us
    By nimbustd at 2012-05-03
  7. Junior Member
    Mar 5th, 2011
    '89 Carat the "project"
    05-03-2012 11:21 AM #22407
    Chickened out and didn't drive it to school today, and now I'm sitting in class wondering why the front left side seems to undulate up and down. Scary.
    Don't hate on my hooptie and I won't on yours. Savvy?
  8. Member Deezy's Avatar
    Jan 3rd, 2009
    Waco, TX
    1988 GTI VR6 - 1990 Jetta Wolfsburg 8v Daily
    05-03-2012 11:24 AM #22408
    Use air tools for removal!
    And yes replace the front strut mounts for sure.
    Bags are for groceries.... I My Dub, So does your girl.
    ---iPhone repair in Waco---
  9. Member Ice.dk's Avatar
    May 27th, 2007
    Karup J Denmark
    1986 Golf GTI 16v project car 1996 Audi A4 B5 1,9 TDI Quattro Daily driver
    05-03-2012 04:43 PM #22409
    Got my door cards putted back after after some leather work and then i drove it to a car show there is in this weekend
  10. Member
    Apr 21st, 2008
    sand and palm trees
    Mk2 Diesel for sale
    05-03-2012 05:48 PM #22410
    Picked up 10.1/11" spindles for 11" / Girling 60 upgrade, also got a Mk3 subframe and control arms, and a rear beam w/ torsion bar (base model).
    11" slotted rotors, dual piston calipers, w/ 8.9" slotted rears w/ mk4 Al calipers should haul a 2200lb car down pretty nicely.
    Oh and received the 215/35r17's for my RPF-1's. Damn these have hardly any sidewall... But if I can fit them.. then methinks it's time for some 17x8+ wheels.
    USMC
    29 Palms, CA
  11. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    King of Prussia area
    92 GTI, 2000 GTI
    05-03-2012 06:03 PM #22411
    Did you buy the parts online?
    If you did, would you mind PMing me the links to where? I've got the same set up and when it comes time for brakes I want to be absolutely sure I'm buying the correct parts instead of just guessing based on something I read.
    Sorry I keep posting off topic, you guys just keep posting things related to questions I have haha.
    Eurofine
    '95 Jetta 2.0: R.I.P. || '92 GTI ABA: Current Project || 2000 GTI 1.8T: Current Daily
    FS: OBD1 ABA + parts
  12. Member the sneakiest panda evar's Avatar
    Nov 19th, 2011
    Maine
    91 Jetta Wolfsburg TD, 07 Snow Camo Ruckus, 91 EA Cabby, 81 Diesel Caddy (SOLD), 02 1.8T (SOLD)
    05-03-2012 06:07 PM #22412
    went to get inspected, failed lucky that its just a tierod end, a ball joint and a wheel bearing. im just going to do both ball joints, drop the knuckles off at the shop to have the bearings pressed in, and do the one tie rod end for now.
    really not that bad though considering it hasnt been on the road for over a year and half
    >>>PM ME FOR CUSTOM STICKERS AND TSHIRTS<<<<
    CUSTOM BATTERY RELOCATIONS!! ANY CAR ANY MOTOR!!!
    >>>POWDER COATING AND CERAMIC COATING NEEDS<<<<
    formally "a sneaky panda" 7,022 posts...now starting over
  13. Member ncbrock's Avatar
    Sep 28th, 2010
    Raleigh, NC
    e36 M3 Sedan, M Coupe, FFR Cobra
    05-03-2012 08:17 PM #22413
    just driving through the neighborhood at about 25mph without my core support on, just to test some things and my hood flew up and screwed it badly and some body damage as well
  14. Member DasMk2's Avatar
    Jan 18th, 2010
    Calgary AB
    1990 Jetta
    05-03-2012 08:22 PM #22414
    finally got my wheels on (check my build)
    Instagram: 403LowLife
    :.German.:
    Ridin low'n'slow since '92
    1990 L97A Jetta
  15. Member the sneakiest panda evar's Avatar
    Nov 19th, 2011
    Maine
    05-03-2012 08:27 PM #22415
    Quote Originally Posted by ncbrock View Post
    did you expect anything less to happen when you have a unsecured panel with massive surface area sitting on the front of the car with a huge air tunnel running under it?
  16. Member Sickvwguy's Avatar
    Apr 12th, 2011
    High Desert
    05-03-2012 09:33 PM #22416
    Lmao right.. think about things before you do them it's good for your car and your pocket..
  17. Member Deezy's Avatar
    Jan 3rd, 2009
    Waco, TX
    05-03-2012 10:45 PM #22417
    I would have lied and said the latch broke.
  18. Member speedkillz's Avatar
    Jan 26th, 2005
    Statham
    '05 GLI, '99 Herbie
    05-03-2012 11:06 PM #22418
    Quote Originally Posted by Deezy View Post
  19. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    :faceplam: :beer: :thumbup:
    buncha junk
    05-03-2012 11:07 PM #22419
    Crooked Euros | Low is NOT a lifestyle | Slow & Quiet
    WTB - 04.5 GLI REAR VALANCE
    Pennsylvania Volkswagen Owners & Enthusiasts Page
    O/R/T
    We Do It Big In PA
  20. Member The Janitor's Avatar
    Jan 24th, 2011
    Vancouver BC
    1987 Jetta
    05-04-2012 02:10 AM #22420
  21. Member 92_MK_2's Avatar
    Oct 11th, 2010
    Texas
    05-04-2012 08:01 AM #22421
    Quote Originally Posted by The Janitor View Post
    good job... now the rest...
  22. Junior Member Elementti's Avatar
    Dec 17th, 2010
    Euro / Finland
    Vento Vr6 -92
    05-04-2012 08:16 AM #22422
    Bought Golf Mk2 again.. Because my Mk3 AAA tranny broke
    Here is how she came:
    Here is what she looked after 4hrs:
    And same night on meeting:
    It has 173,000km on cluster and mint original condition. Engine is strong 1.3 =DD
    I payed 150€ of it. She will drive me to work and back awhile.
  23. Member 92_MK_2's Avatar
    Oct 11th, 2010
    Texas
    05-04-2012 09:31 AM #22423
    Quote Originally Posted by Elementti View Post
    pink glasses are kool
  24. Member perdaniel's Avatar
    May 6th, 2007
    Askøy, Norway
    '92 Golf 1,8 8v "Pasadena"
    05-04-2012 03:19 PM #22425
    Quote Originally Posted by crap_carat View Post
    Have you tried to drive it with some other wheels?
    Quote Originally Posted by PDXGTI8V 2.0 View Post
    ugh, sorry, i like drivable cars
  25. Member Vee-DubbVR6's Avatar
    Jul 31st, 2007
    .:Kirkland, WA
    04 DBP R32, 96 GTi VR6, 92 GTi VR6, 99 HPS Stg 2 SC C43 AMG, 66 Ford F100, 85 Ford F250, 04 GSXR 600
    05-04-2012 04:34 PM #22426
    Quote Originally Posted by by crap_carat
    Quote Originally Posted by perdaniel View Post
    I was thinking the same thing...or take the wheel off and take it to a tire shop and have them throw it on the balancer to see if it might be the wheel or tire.
    Hit any massive potholes lately?
    **FS** 16x7 16x8 VOLK GR-C's - 3 piece 5x100 http://forums.vwvortex.com/showthrea...2#post78639522
    **FS - MK2 stockpile - good quality, hard to find pieces!!** http://forums.vwvortex.com/showthrea...CH-KAMEI-etc..
  26. Member choochoo's Avatar
    Nov 12th, 2008
    OC, CA
    05-04-2012 04:40 PM #22427
    Quote Originally Posted by morimori View Post
    morimori, do you know this Tokyo A2 shop?
    http://forums.vwvortex.com/showthrea...okyo-Pictures!
  27. 05-04-2012 04:55 PM #22428
    Quote Originally Posted by Vee-DubbVR6 View Post
    Or even rotate to a different corner and see if the issue goes with it
  28. Member Vee-DubbVR6's Avatar
    Jul 31st, 2007
    .:Kirkland, WA
    05-04-2012 05:07 PM #22429
    Quote Originally Posted by blubayou View Post
    YES, very true...should've suggested that as well. Good call
  29. Member jettaracer1989's Avatar
    Jan 8th, 2009
    CT
    Now a proud Subaru owner, I will be back with an aircooled vw!
    05-04-2012 06:07 PM #22430
    Put in new ball joints and tie rods, now just to paint my wheels, order tires, and get an alignment then ill be good to start driving it FINALLY (its been registered 4 months and left the driveway once)
    Mk4 shift knob, boot and trim ring into your mk3/mk2 DIY:
    http://forums.vwvortex.com/showthrea...ng-to-your-mk3
  30. Member Sickvwguy's Avatar
    Apr 12th, 2011
    High Desert
    05-04-2012 06:52 PM #22431
    Got this beauty
  31. Junior Member
    Apr 8th, 2012
    1992 Volkwagon jetta
    05-04-2012 10:32 PM #22432
    well my car sat outside in the rain while i sat in school then on my way home she decided to play hard to start but she she started up then i drove home no problem yay!!!!
    just gota figure out the fuel problem this weekend
    yet another weekend working on my car and thats how i like it!!!!
  32. Member Muzzicman75's Avatar
    Apr 3rd, 2005
    Forest, Va
    MANY!!
    05-04-2012 10:45 PM #22433
    found out my new wheels won't arrive until the end of may. Boooo I need them before a show this month. Ordered them in the middle of april from tuner shop
  33. 05-05-2012 12:00 AM #22434
    Been contemplating this for a couple of years, finally spent a couple hours in the garage trying it out. Happy cinco de mayo:
    1 down, 3 to go! That first one still needs some touch up here and there, but the hard part is done
  34. 05-05-2012 12:07 AM #22435
    FYI, they were originally all black. I stripped the powder coat off the now exposed outer ring, if you want to call it that, primarily with a die grinder. I took a spare knuckle with bearing and hub installed, and clamped it in my bench-mounted vise. This let me position the wheel horizontally or vertically, depending on the surface I was working on, and it let me spin the wheel so I could work more quickly on it.
    Kind of a pain in the ass, but I like the outcome.
