Page 643 of 721 FirstFirst ... 143 543 593 633 639 640 641 642 643 644 645 646 647 653 693 ... LastLast
Results 22,471 to 22,505 of 25225
Thread: What did you do to your Mk2 do today?
  1. Member lnoriel's Avatar
    Jul 31st, 2000
    Pasadena, CA
    1985 Golf GL with a 2.0l 16v, 1990 Corrado G60
    05-07-2012 01:14 AM #22471
    Finally found some rain gutters for the Golf. Surprisingly good shape too.
    85 Golf GL with 2.0l 16v
    90 Corrado G60 TEC 2RS
    corradog60project.blogspot.com
    mkiigolfproject.blogspot.com
  2. Member lnoriel's Avatar
    Jul 31st, 2000
    Pasadena, CA
    05-07-2012 01:16 AM #22472
    Had a set of these lying around and test fitted them. Gonna take some fender rolling and spacers to make these fit.
    Might be worth it as they weigh only 14lbs each. 15x6.5 up front 15x7 in rear. Zero offset! but with a 4x100 bolt pattern.
  3. Junior Member 86 Coupe's Avatar
    May 7th, 2012
    Pierce county, WA
    1986 volkswagen Jetta Coupe
    05-07-2012 02:16 AM #22473
    cruise for the cure.. 150+ miles in about a 1/4 tank!!
  4. Member Ice.dk's Avatar
    May 27th, 2007
    Karup J Denmark
    1986 Golf GTI 16v project car 1996 Audi A4 B5 1,9 TDI Quattro Daily driver
    05-07-2012 10:32 AM #22474
    this is actually from the weekend when i did go to a carshow with some of my mk2 body freaks
    We did not get a trophy home but we had a fun weekend
    here is som pics of our place and som pics of my mk 2 when they did want it on the stage
  5. 05-07-2012 11:58 AM #22475
    • Assembled the control arms.
      Finished the hard lines and installed 2 MC mounted pressure limiters rather than the prop valve under the car.
      Changed transmission fluid to Redline.
    Next is to put the control arms, axles, bearing housings and brakes on and it's should be good to go.
    Question: do people install the axles first then the control arms or the other way around?
    VW Engineers design things so that no one else can work on them. GM engineers design things so that everyone has to work on them.
  6. Member Sickvwguy's Avatar
    Apr 12th, 2011
    High Desert
    03' GTI BMP, 97 TDI Passat, 85 Mk2 Jetta diesel, 69 vw bug, 58 dbl. cab
    05-07-2012 02:08 PM #22476
    I did control arms first..
    Sent from my throne using Crapatalk
  7. 05-07-2012 03:51 PM #22477
    That's what I opted for as well, decided it would probably be bad to have the axles hanging there while I curse and pry at the control arms.
    I think I just hit a new personal record; 2.75 hours to install one control arm. An hour and a half of that was just trying to get the front bolt in. Turns out somewhere in the car's past it was dropped on the subframe and the box that the front bushing mounts in was crushed out of shape.
    Oh well, it's in now and I'm sitting back with a well earned beer. After supper I'll get back to everything else and with luck it will all be HorsePowerTV easy.
  8. Junior Member Oxbudd100's Avatar
    May 5th, 2012
    Orange county,ny
    91 mk2 gti
    05-07-2012 07:51 PM #22478
    I just purchased a pair of kicker 3 1/2 inch speakers ds series time to get the inside rocking
    Living the GTI life
  9. Member the sneakiest panda evar's Avatar
    Nov 19th, 2011
    Maine
    91 Jetta Wolfsburg TD, 07 Snow Camo Ruckus, 91 EA Cabby, 81 Diesel Caddy (SOLD), 02 1.8T (SOLD)
    05-07-2012 08:06 PM #22479
    drove 35 minutes to drop it off at the shop with no radio wanted to do the front bearings, but i couldnt get the calipers off. bently says they are supposed to be floating calipers but they deff are not and have those stupid allen bolts
    >>>PM ME FOR CUSTOM STICKERS AND TSHIRTS<<<<
    CUSTOM BATTERY RELOCATIONS!! ANY CAR ANY MOTOR!!!
    >>>POWDER COATING AND CERAMIC COATING NEEDS<<<<
    formally "a sneaky panda" 7,022 posts...now starting over
  10. Member Vee-DubbVR6's Avatar
    Jul 31st, 2007
    .:Kirkland, WA
    04 DBP R32, 96 GTi VR6, 92 GTi VR6, 99 HPS Stg 2 SC C43 AMG, 66 Ford F100, 85 Ford F250, 04 GSXR 600
    05-07-2012 08:10 PM #22480
    Quote Originally Posted by the sneakiest panda evar View Post
    Did the allen heads strip out on them? Or were you just not able to break them free?
    **FS** 16x7 16x8 VOLK GR-C's - 3 piece 5x100 http://forums.vwvortex.com/showthrea...2#post78639522
    **FS - MK2 stockpile - good quality, hard to find pieces!!** http://forums.vwvortex.com/showthrea...CH-KAMEI-etc..
  11. Member FaithInMkIII2.0's Avatar
    Jul 10th, 2008
    Cape Cod
    '91 GTI TDI powered, '97 B4GLXTDI, Vitus 979, Schwinn Traveler Fixie
    05-07-2012 08:12 PM #22481
    Quote Originally Posted by Deezy View Post
    I would like to weld the nuts on the inside of the frame that the rebar connects to so I can bolt it from the outside. the bolts being inside are a pain in the rear end. The car has small bumpers now but I have a set of big bumpers I might fit on at a later date. Would hate to drill holes in them
    [IMG] IMG_0087 by dr.vdub, on Flickr[/IMG]
    [IMG] IMG_0165 by dr.vdub, on Flickr[/IMG]
  12. Member the sneakiest panda evar's Avatar
    Nov 19th, 2011
    Maine
    05-07-2012 08:19 PM #22482
    Quote Originally Posted by Vee-DubbVR6 View Post
    the allen was rusted out on 2, the others i couldnt break free
  13. Member Fizzo20's Avatar
    Mar 28th, 2010
    Calgary, AB, Canada
    1990 Jetta Coupe .....................1998 Golf GTI VR6
    05-07-2012 08:31 PM #22483
    Quote Originally Posted by Ice.dk View Post
    What wheels are these?
    ///MK2s are a helluva drug.
    1990 Jetta Coupe - VR Swap Project
    1998 GTI VR6 cam'd/chipped - Daily
  14. Member Sickvwguy's Avatar
    Apr 12th, 2011
    High Desert
    05-07-2012 10:22 PM #22484
    Got my wheels back !
    *Extra points if you can name the vehicle carrying such wheels*
  15. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
    05-07-2012 10:24 PM #22485
    Quote Originally Posted by Sickvwguy View Post
    Ooooh nice
    And looks like a B4 Passat interior...?
    /// VRSociety Member #298 /// Mk2 Milita-VR6 Battalion-2dr Regiment /// Instagram @scottyvr6 ///
    My 2.9L BVH build and the machine shop #%@- up that almost ruined it all.
  16. Junior Member Pauly76's Avatar
    Apr 18th, 2012
    Stone Mountain, GA
    1989 VW Jetta 1984 GTI
    05-07-2012 10:38 PM #22486
    That looks GREAT!
    I like chicken!
  17. Member Sickvwguy's Avatar
    Apr 12th, 2011
    High Desert
    05-08-2012 12:29 AM #22487
    Quote Originally Posted by Scotty_2.0 View Post
    Ooooh nice
    Thanks! And yup! I guess it was pretty easy cuz my cars are listed lmao..
  18. Member Sickvwguy's Avatar
    Apr 12th, 2011
    High Desert
    05-08-2012 12:32 AM #22488
    Quote Originally Posted by Pauly76 View Post
    That looks GREAT!
    Thanks!
  19. Member 92_MK_2's Avatar
    Oct 11th, 2010
    Texas
    92 MK_2(SOLD) -- 2011 Ducati 848EVO (SOLD) -- 2011 Mitsubishi Outlander Sport -- 89 Honda Accord
    05-08-2012 08:00 AM #22489
    Is it DIY or someone did them for you and how?
    Roses are red Violets are blue, BLA BLA BLA BLA MK_2
  20. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    King of Prussia area
    92 GTI, 2000 GTI
    05-08-2012 09:20 AM #22490
    The pictures from that show made me hate my car a little, I have SO FAR to go
    Yesterday, I found the weak point in my headlight wiring that was causing my passenger side head light to not work every so often as well as making the high beam not work.
    Didn't get to test fit / put my wheels on, it rained until it got dark
    Plans for today;
    Try to make it to the stereo install shop before they close and get a quote on installing my head unit.
    Eurofine
    '95 Jetta 2.0: R.I.P. || '92 GTI ABA: Current Project || 2000 GTI 1.8T: Current Daily
    FS: OBD1 ABA + parts
  21. Member 92_MK_2's Avatar
    Oct 11th, 2010
    Texas
    05-08-2012 09:30 AM #22491
    Painted front bumper at last.
    While at it, I sanded rear drums and painted them...
  22. Member Sickvwguy's Avatar
    Apr 12th, 2011
    High Desert
    05-08-2012 09:58 AM #22492
    Quote Originally Posted by 92_MK_2 View Post
    It's just powdercoat gloss black..I took them to a local wheel guy and he straightened 3 that were bent then sanded the nicks out of them..then took them to a local powder coat guy
  23. Member noddaz's Avatar
    Aug 4th, 2004
    maryland
    1986 GTi 1997 Jetta GT
    05-08-2012 10:09 AM #22493
    But Sunday (5/6/12) I drove her hard in Auto Cross at Fed Ex Field in DC...
    Finished third in my class. And beat my son...
  24. Member 92_MK_2's Avatar
    Oct 11th, 2010
    Texas
    05-08-2012 10:10 AM #22494
    sweet. you got it done the right way. they wanted to charge me like 300 to straightened them... FAK that... they weren't even that bad but stright wheels are straight wheels...
    what tire size you going to use?
  25. Member Deezy's Avatar
    Jan 3rd, 2009
    Waco, TX
    1988 GTI VR6 - 1990 Jetta Wolfsburg 8v Daily
    05-08-2012 10:36 AM #22495
    Yesterday I bolted the axles to the transmission. Was able to tighten one tie rod end back and the other is stuck. Today I will cut it off and replace.
    Put the pass side wheel well cover back Will most likely be taking it off to remove ac and ps today.
    Pics on my other phone.
    Bags are for groceries.... I My Dub, So does your girl.
    ---iPhone repair in Waco---
  26. Member naterkane's Avatar
    Feb 8th, 2001
    Baltimore, MD
    Nothing street-able
    05-08-2012 10:48 AM #22496
    Quote Originally Posted by noddaz View Post
    Hows the surface down there? I was thinking about brinking my mk2 down to visit family and run an event or two there this year.
    Best,
    Nater Kane
  27. Member Sickvwguy's Avatar
    Apr 12th, 2011
    High Desert
    05-08-2012 11:51 AM #22497
    Yea 150 to straighten all 3 then 2 bills to coat...umm I'm not sure..I have a set of brand new 185/50/14's that will probably go on for now until I cut the frame for axel clearance..then I will run a shorter tire..
  28. Member 92_MK_2's Avatar
    Oct 11th, 2010
    Texas
    05-08-2012 01:17 PM #22498
    I got these. They sit just right but very low profile and being 14" if the car isnt really low it doesnt look that good. i tried them on before removing my suspension i sold. my racelands are on the way thou...
  29. Member Sickvwguy's Avatar
    Apr 12th, 2011
    High Desert
    05-08-2012 01:34 PM #22499
    Those are nice..that's probably the size I will go with when these are worn.. Here's how I'm sitting right now so those should be perfect
  30. Member 92_MK_2's Avatar
    Oct 11th, 2010
    Texas
    05-08-2012 02:08 PM #22500
    tat'l work for now. its hard to find 14" tires that can fit as good as 15" tires would. Theres more verity on 15" tires... i think.
  31. Member torque89's Avatar
    Feb 13th, 2011
    York, PA
    1989 jetta gli helios 1997 jetta trek 1998 de wannabe gti
    05-08-2012 03:20 PM #22501
    Trying to figure out what I need in a vr k frame to make it fit in my mk2
  32. Member Urwrstntmare's Avatar
    Feb 21st, 2011
    The Rockies
    1996 WolfyJetta....soon to be for sale! 1992K1500 Blazer-Ole faithful
    05-08-2012 03:30 PM #22502
    Onlinetire.com has Toyo Proxes T1R's on sale now for like $80 a pop 195 45 14 and like $69 for 195 45 15 now.
  33. Member Aggro Crag's Avatar
    Apr 23rd, 2005
    Boyertown, PA
    87 gti, 96 jetta
    05-08-2012 06:43 PM #22503
    Pulled the bottom rad hose off of the waterpump to drain coolant. Need to wait til there's not someone parked next to it so I can do the t-stat another day
    -Zac
    @feces
  34. Member perdaniel's Avatar
    May 6th, 2007
    Askøy, Norway
    '92 Golf 1,8 8v "Pasadena"
    05-08-2012 06:49 PM #22504
    Quote Originally Posted by Urwrstntmare View Post
    Do you mean http://www.onlinetires.com/?
    Quote Originally Posted by PDXGTI8V 2.0 View Post
    ugh, sorry, i like drivable cars
  35. Member
    Apr 20th, 2012
    Portland
    1991 Jetta GLI 16v
    05-08-2012 08:09 PM #22505
    Cleaned a bunch of dried oil and dirt gunk from around my cold start valve and fuel distributor, some old rotted rubber insulation came right off with the gunk on one of the wires bundles I was cleaning . There is this little rubber grommet underneath the CSV that ends in a wire that is kind of spongey, need to figure out what it is because it looks really old and oil is leaking around the edges which I'm pretty sure is where all the gunk came from. Also cleaned oil from around my oil filler cap, it looks like some might be leaking out of the edges. Oh yeah and I drove around a bunch with a smile on my face pumping chemical bros on the stereo.
