Changed the oil, 20w50 dyno juice, and tightened the clamps on the PS tank hoses.
I really need an OEM MK2 PS fluid tank...
#22576
Got my grille visor and installed it. Then took my son to a cruise in.
I like chicken!
#22577
#22578
/// VRSociety Member #298 /// Mk2 Milita-VR6 Battalion-2dr Regiment /// Instagram @scottyvr6 ///
My 2.9L BVH build and the machine shop #%@- up that almost ruined it all.
#22579
#22580
#22584
#22585
Spent the day at pick-n-pull. Didn't find anything that cool, but the weather was great and my lady wanted to come with, so it made for a nice saturday.
P O W W W W D E R R R E D T O A S S T M A N N N N N N N N N
BRIANEDWARDTUCKER.com <--- check out my website!
#22586
22mm master cylinder
passat booster
non-abs bracket to firewall
bled the brakes and clutch by myself and did a messy job
brake lights were then stuck on, but I fixed the brake pedal switch with a piece of wood and a zip tie (it had 1/4" less travel)
and 28.40 usd worth of 91 octane at 4.599 / gallon
also bought wheels this morning![]()
#22588
finished my 9A swap
#22589
#22590
drove it to pick up some stuff for the caddy when i heard a loud noise from the engine bay, then the battery light kicked on. drove 45 minutes home (thank god for diesel) opened the hood and found out the alternator bolt rattled out and the alternator fell off, belt was perfectly intact not a mark on it. put it all back together and put the battery on the charger
>>>PM ME FOR CUSTOM STICKERS AND TSHIRTS
CUSTOM BATTERY RELOCATIONS!! ANY CAR ANY MOTOR!!!
>>>POWDER COATING AND CERAMIC COATING NEEDS<<<<
formally "a sneaky panda" 7,022 posts...now starting over
#22591
#22592
#22593
#22595
pulled the trans out to do the clutch only to find a brand new clutch installed absolutely soaked in gear oil. Its sunday so no one is available to deliver the input shaft seal ofcourse (since the only place that carries it is VW). now i wait for parts, the only major down side to german cars.![]()
"any society that would sacrafice a little freedom for a little security will deserve neither and lose both" -Benjamin Franklin-
"In three words I can sum up everything I've learned about life: it goes on" -Robert Frost-
#22596
Moving out, and loaded it with luggage:
#22597
#22598
Car stopped going into gear when I was driving, was worried that my trans went until I looked under the hood and found the shifter relay shaft bushing completely torn off. Managed to get it back in for now but obviously it's going to need a new bushing. Apparently the bushing is supposed to look like a ball, mine just looked like a ring
Anyone know where I can get just the bushing? Don't feel like paying 30 bucks for the whole shaft with a new bushing attached.
#22601
I bought this one on eBay. It is Custom made using delrin I think. Comes with the ball only for $15.
http://www.ebay.com/itm/VW-Golf-Jett...-/160788253033
Also here on Vortex
http://forums.vwvortex.com/showthread.php?t=5681422
Sent from my iPad using Tapatalk HD
#22603
Found 2 TDI swaps, just gotta try and get the owner to part ways with one of them![]()
Mk4 shift knob, boot and trim ring into your mk3/mk2 DIY:
http://forums.vwvortex.com/showthrea...ng-to-your-mk3
#22604
New inner/outer tie rods and discovered my passenger wheel bearing that was fine 2 weeks ago is now shot. :facepalm;
2012 Scooter's GTG - The biggest ever
www.scootersgtg.webs.com
poop
ihasabucket
#22606
Just dropped her off for an oil and filter change at a local Vdub shop.
#22607
#22608
Took my car to safelite to get a new windshield, about 45 minutes after my appointment started I got a phone call.
They can't install a new windshield or put the old one back in because of this:
Any of you guys ever need to get that replaced / repaired?
Eurofine
'95 Jetta 2.0: R.I.P. || '92 GTI ABA: Current Project || 2000 GTI 1.8T: Current Daily
FS: OBD1 ABA + parts
#22609
#22610
Eurofine
