Page 671 of 721 FirstFirst ... 171 571 621 661 667 668 669 670 671 672 673 674 675 681 ... LastLast
Results 23,451 to 23,485 of 25222
Thread: What did you do to your Mk2 do today?
  1. Member MK2Lalo's Avatar
    May 7th, 2011
    Kent, Washington
    '91 Jetta 4 door
    08-02-2012 05:33 PM #23451
    Quote Originally Posted by Sycoticmynd29 View Post
    Any more pictures?
    Wheel specs?
    haha, you guys probably wont like this but they're
    XXR 002 15x8 0 Offset
    165 45 15 Federal Formoza FD1.
  2. Member VW_MK_III's Avatar
    Mar 12th, 2010
    New York
    1990 Golf "Wolfsburg"
    08-02-2012 06:11 PM #23452
    Picked up a set of 15x7 Borbet Type E's, Test fit and ordered proper hubcentric rings/lug nuts. Undecided on spacer sizes... advice?? Excuse terrible phone picture.
    [My MKII thread] [2012 H20i MK2 GTG Photo Album] [Music, Cars & DSLR's... The life indeed] _m/
  3. Junior Member
    Jul 21st, 2012
    Nashua, NH
    92 VW GTI, 98 VW Jetta
    08-02-2012 06:48 PM #23453
  4. Member ShotgunFacelift's Avatar
    Feb 23rd, 2007
    Houston, TX 77019
    92 GTI ABA (sold), 09 Passat 2.0T, 91 535i/5
    08-03-2012 12:04 AM #23454
    Mk3 subframe, steering rack, tie rods, control arms, ball joints, axles, and 10.1" brakes...
  5. Member m_kufner's Avatar
    May 28th, 2010
    eau claire, wi
    ratted to the 9's
    08-03-2012 01:39 PM #23455
    sticker bomb
    ClearWaterDubs
  6. Member
    Apr 20th, 2012
    Portland
    1991 Jetta GLI 16v
    08-03-2012 03:57 PM #23456
    Going to pick up my beloved Fred soon after having some oil seals and timing belt and tensioner done! Can't wait. Was less $$ than I thought, bonus.
  7. Member Ice.dk's Avatar
    May 27th, 2007
    Karup J Denmark
    1986 Golf GTI 16v project car 1996 Audi A4 B5 1,9 TDI Quattro Daily driver
    08-03-2012 04:13 PM #23457
    i did cleaned it up and polished it and got it rady for a carshow tomorrow
  8. Member ekua516's Avatar
    Feb 28th, 2008
    GREENWICH CT
    1mk2/1mk3/1mkiv all jettas.....
    08-03-2012 09:06 PM #23458
    Head back on.finally got this cam to cam timing right. started it up and nothing but joy i missed driving her,its been a month..will finish up tomorrow and hope everything else is good..
  9. Member Fizzo20's Avatar
    Mar 28th, 2010
    Calgary, AB, Canada
    1990 Jetta Coupe .....................1998 Golf GTI VR6
    08-03-2012 09:48 PM #23460
    cleaned 22 years of dirt, grime, grease and other unknown sh!t off every nook and cranny of half the engine bay. Time for primer/paint after I finish the second half!
    ///MK2s are a helluva drug.
    1990 Jetta Coupe - VR Swap Project
    1998 GTI VR6 cam'd/chipped - Daily
  10. Member Fizzo20's Avatar
    Mar 28th, 2010
    Calgary, AB, Canada
    08-03-2012 09:54 PM #23461
    Quote Originally Posted by MK2Lalo View Post
    [IMG]sexy MK2[/IMG]
    That looks boss man! Do you have a closeup of the fender/tire? I'm still debating 165/45/15 and 165/50/15 on a 15x8. For now I'm gonna run them on a small bumper/no flares Jetta for a bit then when my swap is done they'll go on my big bumper/8v flares Jetta. The 175/55s that came with my wheels are getting destroyed by the fender
  11. Member PigPen14's Avatar
    Feb 27th, 2011
    San Antonio, TX
    98 Gti Vr6, 88 8v
    08-03-2012 11:48 PM #23462
    replaced the fuel line that goes from the pump to the filter cause it manged to spring a leak, also went a head and changed the filter to because i had a new one sitting around.
  12. Member audi80Quattro's Avatar
    Apr 7th, 2004
    Woonsocket, RI
    1990 Jetta Diesel, 1987 Jetta, 1986 Jetta, 1986 GLI, 63 356
    08-04-2012 12:14 AM #23463
    drove it a bunch.
    forgive the hipstergram shots
  13. Member littlebill86's Avatar
    Apr 13th, 2008
    lancaster, ca
    85 GTI
    08-04-2012 01:54 AM #23464
    Quote Originally Posted by ShotgunFacelift View Post
    just tore my front end off tonight to do the same, im using vr6 control arms axles and 11.3 brakes, i made my own heim joint tie rod ends as well.
  14. Member joseph052188's Avatar
    Nov 10th, 2007
    TX
    04 VW R32, 86 GTI
    08-04-2012 12:24 PM #23465
    Finally back in the mk2 game :-)
    Also picked up these wheels yesterday from polishing for the mk2
  15. Member
    Apr 20th, 2012
    Portland
    1991 Jetta GLI 16v
    08-04-2012 02:40 PM #23466
    Well, yesterday, picked it up from the shop and drove the hell out of it. Finally took my mom for a ride in it through the twisties and blew her mind
  16. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
    08-04-2012 05:25 PM #23467
    Centred my steering rack, replaced both tie rods and did a quick eyeball alignment. Also installed my Neuspeed 28mm rear sway bar
    /// VRSociety Member #298 /// Mk2 Milita-VR6 Battalion-2dr Regiment /// Instagram @scottyvr6 ///
    My 2.9L BVH build and the machine shop #%@- up that almost ruined it all.
  17. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    08-04-2012 05:43 PM #23468
    Front passenger side brakes started grinding yesterday, today I put new rotors and pads.
    Passenger side inner brake pad had no brake compound on it at all,
    driver side pads had the brake compound crumbled to pieces when I took the pads off.
  18. Member
    Sep 10th, 2011
    Colorado
    1986 Jetta
    08-04-2012 06:12 PM #23469
    I have a question and it would be stupid to make a thread about it and i tried searching.
    I have an 86 jetta GL. Came with 13"s with 175/70s. I am going to get BBS RAs, 195, 50 r15s. I figure this will change my speedo a bit, how can i get it back to being accurate? or is it not going to make a difference?
  19. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    08-04-2012 06:20 PM #23470
    Quote Originally Posted by cody227 View Post
    See how much of a difference there will be: Wheel/tire size comparing calculator (in the middle of the page)
  20. Member R-Dubya's Avatar
    Jun 23rd, 2011
    '86 Mustang GT
    08-04-2012 06:21 PM #23471
    Decided that mother nature is probably trying her hardest to force me away from using CIS in my 16v swap since I can't find the harness that I need after searching since Wednesday with no luck. Now I have to buy a fuel rail and a chip, with barely any money.
    Blah blah, long story short I really need a 16v fuel rail with fpr holder, and I need it now. If anyone has one, please message me immediately. I will take it right now.
  21. Member oldskoolracer's Avatar
    Mar 6th, 2009
    Clearlake, California
    1989 Volkswagen Golf GTi, 79 Plymouth Volare 225 supersix
    08-04-2012 06:50 PM #23472
    Got all my front end parts from ECS last night! Gonna be getting a k-frame and control arms from a local yard on thursday for $200 But at least Ill be able to start getting things back together.
  22. Member BeetleGpx's Avatar
    Oct 19th, 2004
    Anniston, AL
    Hilde: 85 Golf 8v
    08-04-2012 07:23 PM #23473
    Sent it to the Dr. this morning for a new clutch, I went down to Auburn and picked up a new toy:
    Yeah, it's an 8v. If I wanted a sporty car, I'd buy an R.
  23. Member
    Sep 10th, 2011
    Colorado
    1986 Jetta
    08-04-2012 07:52 PM #23474
    Quote Originally Posted by izzo View Post
    alright thanks for the help.
    also, original vw lugs should be good for bbs right?
  24. Junior Member
    Mar 3rd, 2012
    ne pennsylvania
    91 gti montana green 06shmazda3 96vrjetta walmart shopping cart daily
    08-04-2012 09:03 PM #23475
    today i took the tranny out and ended up pulling the motor and started shaving the bay.... amazing how it always ends up being way more work than i wanted to do and 95 % of the time its personal preferance not mechanical...
  25. Member BlkMaGiC 3526's Avatar
    Sep 10th, 2005
    NorCal / El Sobrante
    08-04-2012 09:56 PM #23476
    Had my GTI for a month. It had some glazed hard water spot windows. I could barely see thru it. Spent 5 hours cleaning them but well worth it b/c now I can see thru them and cleaned my black mk2 floor mats I found at the yard
    Past: Too many to list
    Current: MK5 .:R32 UG #4735
  26. Semi-n00b
    May 14th, 2011
    Morin-Heights, Qc, Canada
    90' Golf 1.9TD T3 FMIC 17 psi daily :)
    08-04-2012 11:54 PM #23477
    Finally test fitted my RG's on 165/45's and I am abundantly satisfied
    Next is swapping in my 1.9TD with mk3 subframe
  27. Member The Janitor's Avatar
    Jan 24th, 2011
    Vancouver BC
    1987 Jetta
    08-05-2012 12:23 AM #23478
    Bought, cleaned up, and installed a bunch of misc parts that I needed to finish my Jetta off.
  28. Junior Member BGosnell's Avatar
    Jul 23rd, 2012
    Hillsboro, OR
    87 Jetta GL with GX CIS-Lambda
    08-05-2012 01:33 AM #23479
    Gave the 87 jetta a wash and removed some wax stains.
    I know it's an 87, but it's MY 87.
  29. Member Fizzo20's Avatar
    Mar 28th, 2010
    Calgary, AB, Canada
    08-05-2012 05:21 AM #23480
    Vacuumed the interior, cleaned the door jambs and windexed all the windows. Gonna wash/wax tomorrow before the IllMotion show in Calgary!
  30. 08-05-2012 03:48 PM #23481
    Painted the old girl today
    Before
    after
    Switch to the all carb diet
  31. 08-05-2012 05:15 PM #23482
    Paint came out pretty good man. I dig the color.
    Disregard my new username and low post count, I've been here for a long time I just can't get onto my old account...
    -Adam
  32. Member respect_my_fast's Avatar
    Nov 18th, 2007
    Lynn MA
    95 rodeo: 86 golf: 01 kidcarrier van
    08-05-2012 05:52 PM #23483
    thanks man, the black isnt finished, but i ran out of paint
    "Why did you do that?"
    " I dunno, because is cool?"
    "Your an idiot"
    -FossZ
  33. Member the sneakiest panda evar's Avatar
    Nov 19th, 2011
    Maine
    91 Jetta Wolfsburg TD, 07 Snow Camo Ruckus, 91 EA Cabby, 81 Diesel Caddy (SOLD), 02 1.8T (SOLD)
    08-05-2012 07:53 PM #23484
    pulled the following items from a parts car to swap into the diesel:
    sub frame
    lower rad support
    front tie bar
    motor mounts
    complete steering rack
    front brake lines
    water pump
    rad hoses
    >>>PM ME FOR CUSTOM STICKERS AND TSHIRTS<<<<
    CUSTOM BATTERY RELOCATIONS!! ANY CAR ANY MOTOR!!!
    >>>POWDER COATING AND CERAMIC COATING NEEDS<<<<
    formally "a sneaky panda" 7,022 posts...now starting over
  34. Member joseph052188's Avatar
    Nov 10th, 2007
    TX
    04 VW R32, 86 GTI
    08-06-2012 07:57 AM #23485
    Tested out the gottireps on the mk2.
    Looks like I will need more than 20mm to make it poke a bit more. Also the front won't go lower since the wheel will hit the coilovers spring. The rear is all the way down :-/, I actually like how the fk's ride.
    Rears
    Fronts
